My cell phone won't turn on
Replace Battery
Most of the time, the phone will not turn on because the battery is either missing or dead. It is an easy step to replace the battery. Once the battery is replaced turn on the cell phone and it showed start up.
This guide can be helpful in the process:
Repair Guide for Battery
Replace LCD Screen
Sometimes the cell phone turns on and functions properly but the screen will not correctly display the functions of the phone. You will need to replace the LCD screen if this is the case.
Replace Logic Board
There maybe a small chance that the problem lies with the logic board of the cell phone. If the other parts of the phone are fine, but the logic board is broken, the phone may have had water damage. If the other solutions on this page don't help, you may need to replace the logic board.
Repair Guide for Logic Board
Keypad Problems
For General Problems
Move Around the Keypad
Sometimes the keys get stuck. Try moving the keypad around to see if this is the case. If the problem still persists then the best thing to do is replace the keypad.
Replace Keypad
If the problem is not solved so easily, then the next step is to replace the keypad for an entirely new one. This will solve any functionality errors with the keypad.
This guide may be of some help in the process:
Repair Guide for Keypad
Replace Logic Board
If the problem persists even after completing the steps above then the complication is most likely with the logic board and a replacement logic board is necessary.
A Section of the Keypad Broke Off
Keypads for cell phones either broke off or malfunction due to various factors. This is definitely a problem if one text messages others as well as makes constant phone calls. The best thing to do is to replace the keypad with a new one to help with the functionality of the cell phone.
LCD Screen Problems
There is a crack in my LCD screen
The only option is to replace the LCD screen in the cell phone.
Screen will not display anything
Try turning the cell phone off and on again. If the problem is not logic board-related then this should work.
If the above does not work then replacing the logic board is the only choice.
There is a crack in my cell phone case. Is there anyway to replace it?
Remove and Replace the Casing of the Phone
Having a crack in the cell phone case can be disturbing to the user. To fix that noticeable distraction, simply replace the case of the cell phone with a new one.
These guides can be helpful in the process:
Repair Guide for Replacing Outer Casing
Repair Guide for Replacing Phone Casing
Elizabeth Chandy
crwdns2935283:004/15/10crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
Cal Poly, Team 26-26, Regan Spring 2010 crwdns2935289:0Cal Poly, Team 26-26, Regan Spring 2010crwdne2935289:0
CPSU-REGAN-S10S26G26
crwdns2936753:030crwdne2936753:0 42
crwdns2959996:0crwdne2959996:0 3,248
