The VX4500 was released in 2004. It is a flip phone with an internal and external LCD display.
Phone won't turn on
Your phone will not start up
Battery is Dead
Battery needs to be charged or battery is not able to be charged. If the battery runs down within minutes of a full charge it is time to replace the battery pack.
Visit the Battery Repair Guide for help replacing the battery.
Bad Logic Board
If the phone doesn't function even while plugged in, you probably have a bad logic board.
Visit the Logic Board Repair Guide for help replacing the logic board.
Damaged screen
First check the screen for any cracks. Next try resetting the phone by turning it off then back on again. If your screen is cracked or doesn't work after a reset the screen may be bad.
Visit the LCD Display Repair Guide for help replacing the screen.
Disconnected/damaged ribbon cable
Another possibility is the cable connecting the body of the phone to screen is damaged or disconnected. This is mostly like to occur with age or after dropping the phone.
Visit the Ribbon Cable Repair Guide for help repairing or replacing the ribbon cable.
No Sound or Bad Audio Quality
When placing a call, you cannot here anything coming from the speaker.
Broken Speaker
Continual abuse and a constant level of high volume can cause a speaker to "blow" causing fuzzy, unclear sound.
If the speaker is not making any sound at all then the speaker is either bad or has been disconnected from the logic board. If after reconnecting the speaker to the logic board, you still cannot hear anything, the speaker is bad and will need to be replaced.
Visit the Speaker Repair Guide for help replacing the logic board.
Cannot be heard
When placing a call, the person on the other end cannot hear you.
Broken Microphone
If they cannot hear you at all then either the microphone itself is bad or the connection to the logic board is bad. If the connection is good or still doesn't function after reconnecting the microphone will need to be replaced.
Keypad doesn't work
Pressing buttons on the keypad does not produce any letters or numbers on the display.
Keypad is misaligned
Ensure that the keypad is properly aligned. The keypad works by pressing a switch on the logic board every time a button is depressed. If the keypad isn't lined up correctly when you depress the key the switch isn't pressed.
Debris under keypad
Check to see if there is any material between the keypad and logic board. If there is any foreign objects, free floating in this area remove it immediately.
Visit the Keypad Repair Guide for help replacing the keypad.
Screen has a Crack/Won't Light Up
Broken Screen
If there is a visible crack in the screen, it will need to be replaced to function properly. If it won't light up, try restarting the phone first. If it still does not light up, the screen may need to be replaced.
Phone has been Dropped in Water
Water Inside the Phone
If the phone has been dropped in water, or water is visible underneath the screen, you should take apart the phone and let it sit and dry. If the phone does not work after this, the water may have caused permanent damage.
David Foster
crwdns2935283:004/11/10crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 25-88, Amido Spring 2010 crwdns2935289:0Cal Poly, Team 25-88, Amido Spring 2010crwdne2935289:0
CPSU-AMIDO-S10S25G88
crwdns2935297:0108crwdne2935297:0
where can I buy a battery for lg vx4500 phone.
thanks
jrosenblatt18@gmail.com
joan rosenblatt - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2942667:0crwdne2942667:0 2,837
