crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Troubleshooting
Phone won't turn on
Phone won't power on
Faulty Battery
If phone won't power on battery may be faulty. Remove back cover exposing battery.
Remove and replace battery. LG Optimus F60 Battery Replacement
Faulty Charger
If phone charger is plugged in and light is not on or screen not displaying charging symbol then the charger is faulty. Consider purchasing new charger.
Faulty Power Button
If phone won't turn on when battery has been replaced and charger is working then power button may be faulty. Try turning it on again and check to make sure battery and charger are inserted correctly. If the phone still won't turn on consider fixing the power button with this guide. LG Optimus F60 Power Button Replacement.
Screen picture is distorted
Damaged or cracked screen
Screen is cracked
If cracks or damage to the screen exist then consider replacing the screen with this guide. LG Optimus F60 Screen Replacement.
Loose display connector
If screen won't turn on or remains black, distorted, or faded while the phone is otherwise operational consider replacing the phones digitizer with this guide. How to repair LG Optimus F60 Screen Digitizer
Phone won't charge
Phone fails to hold a charge, dies often
Faulty Charger
Faulty USB port
If phone charger is plugged in and light is not on or screen not displaying charging symbol first try the charger on other devices to ensure it is working. If the charger works then the usb port is faulty. Consider fixing the usb port with this guide. How to repair LG Optimus F60 USB port
Faulty Battery
Phone battery old or outdated
Phone loses power often or won't remain charged
Power settings are too high
You can improve battery life by adjusting the power settings on your phone.
Too many background applications open
Some apps continue to run in the background after you exit them. It is recommended that you close background applications when you're not using them.
Device is running outdated software
There may be a software update that improves battery life on your phone. Check for software updates.
Too long since last update
If the device is running the most recent software, all apps are closed and the power settings are normal consider performing a soft reset. A soft reset restarts your phone and does not erase any of your content or data. Begin by turning the phone off. Next remove the battery and wait for 30 seconds. Replace battery and restore power to the device.
Front Camera Not Working
When camera app is open screen remains black or app won't open
Front camera connector loose
Sometimes the front camera can freeze due to the device running to many applications at the same time. If the front camera is frozen or not operating properly, turn the phone off wait ten seconds and power the device back on.
Too long since last reset or update
If the device is running the most recent software, all apps are closed and the camera is still not working consider performing a soft reset. A soft reset restarts your phone and does not erase any of your content or data. Begin by turning the phone off. Next remove the battery and wait for 30 seconds. Replace battery and restore power to the device.
Front camera cracked
If the above steps have not resolved the issue consider replacing the front camera with LG Optimus F60 Front Camera Replacement
Austin Johnson
crwdns2935283:004/09/18crwdne2935283:0
171 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team S3-G3, Rowley Spring 2018 crwdns2935289:0Eastern Washington University, Team S3-G3, Rowley Spring 2018crwdne2935289:0
EWU-ROWLEY-S18S3G3
crwdns2931471:06crwdne2931471:0
crwdns2959996:0crwdne2959996:0 1,001
