crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
The Hoverboard Won’t Move
The wheels will not spin.
The Power Has Not Been Turned On
Double check that the power button is on. Then see if the hoverboard will move once the power button is turned on.
The Battery Is Not Functioning
Consider replacing the battery if the hoverboard stops working unexpectedly.
The Motor Is Defective
Ensure the wires are receiving power. If not, consider replacing the hoverboard’s motor.
The Hoverboard Will Not Balance
The hoverboard is unstable when trying to ride it.
The Hoverboard Needs to Recalibrate
Sometimes if the system is not calibrated properly, the hoverboard will remain unstable. In order to recalibrate, put the hoverboard on a flat surface, then press and hold the power button down until the LED lights begin to flash. After 30 seconds, shut the hoverboard off.
The Foot Mats Are Broken
If the hoverboard also will not steer properly and is not responding to changes in pressure on the foot mats, the foot mats may be broken and need replacement.
The Central Bearing Is Stuck
The hoverboard has a central bearing which allows the two sides of the hoverboard to turn as needed. If this bearing is broken, the hoverboard will not be able to reset itself to a flat position. If recalibration does not work and the hoverboard seems to be stuck and unable to tilt each side separately, consider replacing the bearing.
The Motherboard Is Faulty
If the foot mats can still sense pressure changes and recalibration does not work, the motherboard may need to be replaced.
The Hoverboard Will Not Hold a Charge
The hoverboard dies faster than it is supposed to.
The Battery Needs Replacement
If you notice your hoverboard still does not drive after being charged, the battery may be defective and need to be replaced.
The Charger is Defective
If the light on the charger does not light up, then the charger is faulty and needs to be replaced.
The Motherboard is Faulty
If you plug in the hoverboard and the charger light is green, then the battery is 100% full. If the issue is not the battery, then it is the motherboard that needs replacement.
The Hoverboard Has Flashing Lights
The LED light is flashing red.
A Loose Connection
Disconnect all connections, then reconnect all wires. Check to make sure none of the wires are loose. The main connections to focus on are that of the motherboard.
A Motherboard Is Faulty
Recommend purchasing a replacement motherboard and replacing the circuit boards.
The Internal Motor Is Malfunctioning
The internal motor is impossible to fix. Consider purchasing a new internal motor.
The Hoverboard Needs to Charge
Typically, the hoverboard’s LED lights will flash red when it’s charge is low. You may just need to recharge your hoverboard.
The Hoverboard Has Trouble Powering On
The hoverboard fails to turn on and drive.
The Internal Circuits Are Bad
Plug the charger into the wall and make sure the light is red. If the red light disappears, then the internal circuits are bad and need to be replaced.
The Battery Needs to Be Replaced
Plug the charger into the wall and make sure the light is red. If the red light stays on, turn the hoverboard on. If you see a flashing orange light appear, the battery needs replacement.
The Charging Port Is Damaged
Plug the charger into the wall and make sure the light is red. If the red light stays on, turn the hoverboard on. If the hoverboard fails to turn on, the charging port is damaged. Unscrew and remove the bottom of the hoverboard to see if the charging port wires have faults or are plugged in properly.
Cassandra Aarrestad
crwdns2935283:001/23/20crwdne2935283:0
627 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S7-G2, Paton Spring 2020 crwdns2935289:0Cal Poly, Team S7-G2, Paton Spring 2020crwdne2935289:0
CPSU-PATON-S20S7G2
crwdns2944067:017crwdne2944067:0
My son got a maverick for a gift he charged it and now it won’t stop beeping what can I do
Mary - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
One side of the Hoverboard will not move forward or backwards? Suspect a bad motor or motherboard connection. any ideas?
Jeremy - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
My hoverboard 1 seems broken and very unbalanced by alot.the feet steps go in different directions by alot.cannot even balance myself on it.I tried to recalibrate it several times.did not work.what can I do?
Lisa Clark - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
The lights on one end of wheel stay on and it will now recalibrate.seems
Red light on right side continuous flashing and beeping. Tried recalibrating and seemed to turn off for a few seconds and then beeps again continuously. Please help.
John Castro - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 55
crwdns2959996:0crwdne2959996:0 18,327
