This guide for the Hover-1 Maverick guides users in replacing the battery in their device. The battery is crucial in powering the hoverboard. Symptoms of having a faulty battery include the device not being able to move, hold a charge, or power on.
Before you begin, make sure your Hover-1 Maverick is off and not charging.
Remove the twenty 15mm Phillips #1 screws from the shell of the hoverboard.
Remove the shell.
Remove the four 8mm Phillips #1 screws holding down the black plastic casing.
Lift off the black plastic retaining bracket.
Pull the battery upward lightly to remove from the device.
What voltage should the battery put out? Mines is 30v, charger is green at the wall but still the board won’t turn on
Barry Rogers - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Where can I find that same battery i cant find one
Toad Blue - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
