crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Laptop Does Not Power On
The laptop does not respond to being powered on, no lights on the laptop.
Faulty Power Adapter
Check to see if the charge light is currently on with the power adapter plugged in. If the light is not on, your power adapter may be faulty, in which case you may want to buy a replacement adapter.
Faulty Motherboard
If your charge light is on and you still cannot power the system on, your motherboard may be faulty. If this is the case, you will want to replace your motherboard using this guide.
Screen Is Blank
Laptop powers on, but the screen is completely blank and unresponsive.
Faulty Display
Using an HDMI cord, plug your laptop into an external display to ensure that the issue is your laptop screen. If the external display works fine, make sure that the display connector on your motherboard is plugged all the way in. For steps on accessing the display connector, use this guide until step 10.
Memory Failure
If there is no output to an external display, try re-seating the memory using this guide. If that does not work, you may want to replace your memory module.
Laptop Does Not Hold A Charge
Laptop turns on when plugged in but does not hold a charge.
Faulty Battery
If your laptop does not charge completely, or only powers when plugged in, you most likely have a faulty battery. To solve this issue, use this guide to replace your lithium ion battery.
Laptop Overheats and Shuts Down
While operating laptop, the device gets warm/hot and shuts down without warning.
Dusty Components
A build up of dust in any computer system can cause a lack of airflow, and thus overheat the system. Try opening up the back of your laptop as shown in this guide and use a can of compressed air to blow the dust out of your machine.
Faulty Cooling System
Your cooling system may not be functioning properly. Check to see that your cooling fan is actually moving. If it is not, replace it using this guide. If it is, try reapplying the thermal paste to your CPU as shown in the same guide.
Very Loud “Hum” Coming From the Laptop
While operating your laptop under normal conditions, there is a loud humming noise being emitted from the device.
Faulty Cooling Fan
Remove the hard drive using this guide. If you can power up your laptop and it is still making noise, you may have a faulty cooling fan. Check to see that there isn’t a build up of dust in your cooling fan.
Faulty Hard Drive
If your cooling fan is spinning properly, the noise is likely coming from your hard drive. Backup your data on another drive if possible, and replace the one in your laptop using this guide.
Laptop Loops through Startup Cycle
When powering on the laptop it turns off, then on again, and continues in this loop.
External Device Interference
If you have any attached USB or DVD devices, please disconnect them from the laptop and attempt a manual reset by powering down your laptop and then powering the system on again. It is possible that these devices are interfering with the startup process for the laptop.
Contracted Virus
If removing the devices and performing the manual reset does not resolve the issue, then the startup cycle is most likely a result of a virus corrupting your laptop’s BIOS (Basic Input Output System). You can recover your laptops BIOS by recovering the system’s last working BIOS version. Follow this guide to reset your laptops BIOS.
Laptop Restarts Unexpectedly
While operating your laptop, it spontaneously restarts during usage or shut down process.
Disable the Automatic Restart Feature
Most likely if your device is restarting unexpectedly then it is possible that the Automatic Restart feature is turned on. This feature causes the laptop to restart when an issue within the device is found. Turn off this feature by following these steps provided by HP.
Battery Malfunction
If turning of the automatic restart function does not work, it is possible that there could be dust building up between the battery and device connectors. This dust build can cause the system to restart by preventing contact between the battery and laptop. You can fix this by removing the battery as shown and using a compressed air can to blow dust off the connectors.
Joshua Brockman
crwdns2935283:003/25/19crwdne2935283:0
368 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S2-G4, Bailey Spring 2019 crwdns2935289:0UMass Dartmouth, Team S2-G4, Bailey Spring 2019crwdne2935289:0
UMASSD-BAILEY-S19S2G4
Please tell about how to repair usb port
Abdullah 12345 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2942667:0crwdne2942667:0 721
