A hard drive can be the source of many issues in a laptop computer. This means that it is important to know how to replace a hard drive. Before you decide to replace a hard drive, you should always attempt to back up your data to a secondary source so that nothing is lost in the process.
Slide the lock mechanism on the left side of the laptop to the right.
While holding the right slide mechanism, remove the battery from the laptop.
Flip the laptop over to reveal screw locations.
Use a metal spudger to remove the two rear rubber feet. There are screws hidden underneath them.
Remove the twelve 5mm Phillips #1 screws on the back of the laptop.
Remove the DVD drive from the laptop.
Remove the two 3 mm Phillips #1 screws underneath the DVD drive.
Flip the laptop and open.
Detach the keyboard by prying it free from the laptop using a spudger.
Disconnect the keyboard ribbon cable.
Disconnect the two narrow ribbon cables to the left of the keyboard connection.
Remove five 4 mm Phillips #1 screws from the metal tray for the keyboard.
Pry open the plastic casing using a spudger.
Remove two 5 mm Phillips #1 screws located at the base of the hard drive.
Pull the hard drive upwards and away from the laptop.
The hard drive should disconnect from its port on the motherboard as shown in the second image.
Flip the hard drive over.
Remove the two 4 mm Phillips #1 screws from the base of the hard drive.
Remove the mounting brace (silver bracket) from the hard drive.
