HP 15-R011DX Motherboard Replacement
    1. HP 15-R011DX Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-R011DX Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Slide the lock mechanism on the left side of the laptop to the right.
    2. HP 15-R011DX Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • While holding the right slide mechanism, remove the battery from the laptop.
      • The battery is not pictured here because it is missing from this particular device.
    1. HP 15-R011DX Motherboard Replacement, How to Access the Internal Components of an HP 15-R011DX: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-R011DX Motherboard Replacement, How to Access the Internal Components of an HP 15-R011DX: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Flip the laptop over to reveal screw locations.
      • Use a metal spudger to remove the two rear rubber feet. There are screws hidden underneath them.
    2. HP 15-R011DX Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-R011DX Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the twelve 5mm Phillips #1 screws on the back of the laptop.
    3. HP 15-R011DX Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-R011DX Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the DVD drive from the laptop.
      • Remove the two 3 mm Phillips #1 screws underneath the DVD drive.
    4. HP 15-R011DX Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 15-R011DX Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 15-R011DX Motherboard Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Flip the laptop and open.
      • Detach the keyboard by prying it free from the laptop using a spudger.
      • Do not completely remove the keyboard yet. It is still attached by a ribbon cable.
      • Disconnect the keyboard ribbon cable.
    5. HP 15-R011DX Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-R011DX Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Disconnect the two narrow ribbon cables to the left of the keyboard connection.
      • Remove five 4 mm Phillips #1 screws from the metal tray for the keyboard.
      • Pry open the plastic casing using a spudger.
      • If struggling to remove the plastic case, check that all screws have been removed.
    1. HP 15-R011DX Motherboard Replacement, Hard Drive: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove two 5 mm Phillips #1 screws located at the base of the hard drive.
    2. HP 15-R011DX Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-R011DX Motherboard Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pull the hard drive upwards and away from the laptop.
      • The hard drive should disconnect from its port on the motherboard as shown in the second image.
    3. HP 15-R011DX Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Flip the hard drive over.
      • Remove the two 4 mm Phillips #1 screws from the base of the hard drive.
      • Remove the mounting brace (silver bracket) from the hard drive.
    1. HP 15-R011DX Motherboard Replacement, Motherboard: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-R011DX Motherboard Replacement, Motherboard: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the remaining two 5 mm Philips #1 screws from the motherboard.
    2. HP 15-R011DX Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the tape from the display connector attached to the motherboard.
      • Disconnect the display connector from the motherboard.
    3. HP 15-R011DX Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove one 4 mm Phillips #1 screw from the wireless chip.
      • Remove the wireless chip from the motherboard.
    4. HP 15-R011DX Motherboard Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove two 5 mm Phillips #1 screws from the USB component connected to the motherboard.
      • Lift the USB component until the band connecting it to the motherboard lifts off of the laptop.
    5. HP 15-R011DX Motherboard Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Slowly lift the motherboard out of the computer.
      • Be sure that the I/O ports on the left side of the motherboard are not stuck on the laptop frame.
      • Disconnect the power connector from the motherboard as shown in the image.
Ethan Guillotte
crwdns2935283:003/20/19crwdne2935283:0
517 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S2-G4, Bailey Spring 2019 crwdns2935289:0UMass Dartmouth, Team S2-G4, Bailey Spring 2019crwdne2935289:0
UMASSD-BAILEY-S19S2G4
crwdns2936753:030crwdne2936753:0 36
crwdns2942667:0crwdne2942667:0 981
