crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Smoke Coming Out of the Barrel
Smoke comes out of the end when you turn the gun off after use.
Overworked Heating Element
The problem could be caused by rapid changes between the high and low settings. When the coil does not cool quickly enough, the heating coil in the barrel smokes.
Instead of switching rapidly between settings, turn off the gun completely for a few seconds before switching to a different setting.
Faulty Motor
First, check the connections on the motor to make sure they are secure. If they are secure, open the gun casing to ensure the motor casing is free of debris. If the motor is smoking, it is likely because an electrical problem. To fix it, replace the motor using the Drill Master Heat Gun Motor Replacement Guide.
Sparks Emit from the Butt of the Barrel
When powered on, the butt of the barrel produces sparks.
Cable to Motor Connections
Ensure all of the connections on the motor are secure. If the motor sparks when switched on, replace the motor immediately. Avoid switching the device on again until the motor has been replaced.
Both Settings Produce High Heat
Both heat settings produce the same heat temperature.
Broken Diode
The diode inside the power switch that allows the the device to switch between low and high heat may be broken. When the diode is broken, the heat gun can work on only one setting. In order to fix this problem, follow the steps in the Drill Master Heat Gun Power Switch Replacement Guide.
Device Will Not Turn On
The heat gun is unresponsive when switched on.
Faulty Power Switch
If the power switch appears loose and the device is unresponsive when plugged into a power supply, the power switch may be faulty. Replace the power switch using the Drill Master Heat Gun Power Switch Replacement Guide.
Faulty Power Outlet
Ensure the device is plugged into an electrical outlet. This device is not battery-operated and must be plugged during use. If the device continues to be unresponsive, consider trying a different outlet and check for a tripped breaker. This might be an issue with the power supply to the outlet.
Faulty Power Cord
Ensure the device’s power cord is completely flush with the outlet. If the device remains unresponsive, unplug the cord. Check for any exposed or frayed wires near the plug or base of the device where the cord it attached. If frayed wiring is exposed, the power cord is damaged and must be replaced. To replace it, follow the steps in the Drill Master Heat Gun Power Cord Replacement Guide.
Device Remains Cool When Powered On
The heat gun is on, but is not heating up.
Faulty Heating Coil
If the device blows cool air and does not produce heat when powered on, it is because of a faulty or broken heating coil. The best fix for this problem is to open up the casing and replace the heating coil. For a step by step guide to replace the heating coil, see theDrill Master Heat Gun Heating Coil Replacement Guide.
Device Smells Like Burning Plastic
Heat Gun smells like burning plastic when powered on.
Initial Use Smell
It is normal for the device to smell like burning plastic when powered on for the first time. Between device production and consumer use, dust collects on the heating elements. During the device’s first use, the dust burns off.
Internal Wires Touch the Heating Coils
If the device smells like burning plastic shut it off immediately. Continued use of the device while wires touch the heating coils may result in damage to the wire insulation. Follow the first few steps in the [http://Drill Master Heat Gun Heating Coil Replacement|Drill Master Heat Gun Heating Coil Replacement Guide] to open the device and check that no wires are touching the heating coils.
Faulty Fan
If the device produces heat, but does not blow air, replace the fan. This is an especially important problem to fix quickly because a faulty fan can cause the heating coil to overheat and burn internal wiring and plastic. To replace it, follow the steps in the Drill Master Heat Gun Fan Replacement.
Daniel Blackburn
crwdns2935283:005/25/16crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2935297:00crwdne2935297:0
IUPUI, Team 1-3, Wilson SU 2016 crwdns2935289:0IUPUI, Team 1-3, Wilson SU 2016crwdne2935289:0
IUPUI-WILSON-SU16S1G3
crwdns2944067:04crwdne2944067:0
I’ve use my Drill Master heat gun a bunch of times over several years and all of the sudden the black plastic handle is sticky all over. I’ve tried to get rid of the “sticky” with many full strength cleaners including goo remover. Black comes off on rags but nothing works to make the plastic un-sticky. The handle must be made out of a bad plastic mixture. This makes it annoying to use - I pray it’s safe.
Finch - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
That's the plasticiser leaching out of the plastic. It happens over time to most plastic finishes that have that “soft-touch" (rubbery) feel.
To fix it, take a clean rag soaked in rubbing alcohol and vigorously wipe down the handle. You want to rub off all the rubber coating and just leave the hard plastic underneath exposed. The rubber coating is only a fraction of a millimeter thick but it'll take a lot of rubbing and a lot of alcohol, and you'll probably use several rags as the sticky stuff tends to coat the rag while you're working. Once done the handle will be rescued for good. The sticky stuff only comes out of the rubberised coating (which you’ve just scrubbed off) and not the hard plastic underneath.
Luke Formosa - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
First time I used it it shut off in the middle of what I was doing and has not come back on yet. What can I do to fix it?
Kibbie Cockrum - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
what if the heating elements are working correctly and the fan motor is good but the fan motor is not receiving the 17vdc it is supposed to receive? this started after I dropped it
jpeezy - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 35
crwdns2942667:0crwdne2942667:0 9,658
