Drill Master Heat Gun Power Cord Replacement
  1. Drill Master Heat Gun Power Cord Replacement, Power Cord: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Be sure the heat gun is unplugged before starting this process.
    • Remove the seven 14mm screws from the side of the drill using the PH#0 screwdriver.
    • You will need a screwdriver extension.
  2. Drill Master Heat Gun Power Cord Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 8mm screw from underside of barrel using the PH#0 screwdriver.
    • Don't try to open the casing just yet.
  3. Drill Master Heat Gun Power Cord Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Drill Master Heat Gun Power Cord Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Drill Master Heat Gun Power Cord Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the barrel casing on either end by twisting and pulling each side off.
  4. Drill Master Heat Gun Power Cord Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the top casing to reveal inside of drill. You might have to tug a little harder for this one.
  5. Drill Master Heat Gun Power Cord Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Loosen four screws on the wire connector using the flathead 2.5 screwdriver.
    • Screws do not come out of connector.
  6. Drill Master Heat Gun Power Cord Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the power cord wiring from the wire connector.
  7. Drill Master Heat Gun Power Cord Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 12mm screws from the base of power cord using the PH#0 screwdriver.
  8. Drill Master Heat Gun Power Cord Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the power cord from the heat gun.
Mikayla Kim
crwdns2935283:001/31/17crwdne2935283:0
529 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 1-2, Campbell Spring 2017 crwdns2935289:0University of North Texas, Team 1-2, Campbell Spring 2017crwdne2935289:0
UNT-CAMPBELL-S17S1G2
crwdns2942667:0crwdne2942667:0 953
