The internal fan keeps your machine from overheating. A faulty fan can also cause smoking. To remedy these problems, use this guide to replace your fan.
Remove the seven 14mm screws from the side of the drill using the PH#0 screwdriver.
Remove the 8mm screw from underside of barrel using the PH#0 screwdriver.
Remove the barrel casing on either end by twisting and pulling each side off.
Remove the top casing to reveal inside of drill. You might have to tug a little harder for this one.
Remove the metal casing and fan cover from the fan unit.
Bend the metal prongs backward that connect the fan motor to the plastic cap.
Remove the plastic cap from the motor,
Remove the fan by pulling it from the motor rod and replace.
