Drill Master Heat Gun Power Switch Replacement
    1. Drill Master Heat Gun Power Switch Replacement, Power Switch: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Be sure the heat gun is unplugged before starting this process.
      • Remove the seven 14mm screws from the side of the drill using the PH#0 screwdriver.
      • You will need a screwdriver extension.
    2. Drill Master Heat Gun Power Switch Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the 8mm screw from underside of barrel using the PH#0 screwdriver.
      • Don't try to open the casing just yet.
    3. Drill Master Heat Gun Power Switch Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Drill Master Heat Gun Power Switch Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Drill Master Heat Gun Power Switch Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the barrel casing on either end by twisting and pulling each side off.
    4. Drill Master Heat Gun Power Switch Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the top casing to reveal inside of drill. You might have to tug a little harder for this one.
    5. Drill Master Heat Gun Power Switch Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Loosen four screws on the wire connector using the flathead 2.5 screwdriver.
      • Screws do not come out of connector.
    6. Drill Master Heat Gun Power Switch Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Squeeze the tabs on either side of the power switch to remove from the casing.
    7. Drill Master Heat Gun Power Switch Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Drill Master Heat Gun Power Switch Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the black, plastic wire protectors from the end of the power switch.
    8. Drill Master Heat Gun Power Switch Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use soldering iron to remove the electrical wiring from the power switch. To replace the power switch, solder the new switch onto the wires.
      • Heating the soldering metal will allow you to pull off the electrical wiring.
      • For a brush-up on proper soldering, check out How to Solder and Desolder Connections.
Mikayla Kim
crwdns2935283:001/31/17crwdne2935283:0
532 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 1-2, Campbell Spring 2017 crwdns2935289:0University of North Texas, Team 1-2, Campbell Spring 2017crwdne2935289:0
UNT-CAMPBELL-S17S1G2
crwdns2935297:059crwdne2935297:0
crwdns2936753:07crwdne2936753:0 36
crwdns2936753:030crwdne2936753:0 88
crwdns2942667:0crwdne2942667:0 4,083
