Dell Inspiron Won’t Turn On
No matter what I do, I can't get my Dell Laptop to turn on...
Bad Power Adapter
If your laptop will not turn on once it has been unplugged from the power adapter. You may have a bad power adapter. Purchase or borrow the correct power adapter for the laptop to test your laptop.
RAM Issues
If your laptop suffers to frequent reboots, crashes or the “Blue Screen of Death”, a bad RAM chip could be the cause. The RAM chip may need to be replaced. Please refer to the guide on How to Replace the RAM.
Bad Motherboard
If replacing all of the above, and the problem still persists. You more than likely have a bad motherboard. The motherboard will need to be replaced.
Laptop Shuts Off When I Unplug It
The laptop shuts off when I unplug it from the power adapter...
Dead Battery
If your laptop is shutting off once the power adapter is unplugged you may likely have a dead battery. This dead battery may no longer be holding a charge. The only solution is to purchase a new battery and replace the old one with the new one. Please refer to the guide on How to Replace the Battery.
Bad/Slow Fan
If changing the battery doesn’t work, you may have a bad fan. The fan keeps the laptop from overheating. The laptop will automatically shut off if the laptop is on and the fan is not running. In order to fix this issue, please refer to the guide on how to disassemble the Laptop and Replace the Fan.
Screen Backlight Lights Up but Nothing Else Happens
I’m getting the Blue Screen of Death.
Bad Hard Drive
If the screen lights up but does not produce a laptop image you may have a bad hard drive. In this instance the hard drive will need to be replaced. Please refer to the guide on how to Replace the Laptop Hard Drive.
Laptop is On but Screen is Black
My laptop is running but there is no image on the screen.
The Screen Needs to be Replaced
If the laptop is running but there is no image on the screen, you may need to replace the screen. Please refer to the guide on how to Replace the Laptop Screen.
Cannot Play CD/DVDs
I put the CD in my CD drive but nothing happens.
The CD/DVD Drive Needs to be Replaced
When the CD/DVD isn’t responding when you put a disc in the drive, you may have a broken CD/DVD drive. In this instance, the drive needs to be replaced. Please refer to the guide on how to Replace the CD/DVD Drive.
Clean your CD/DVDs
Inspect the back of your CD/DVD for scratches and dirt. Apply water or a cleaning solution to a soft cloth and very gently rub any dirt off the CD/DVD. If you can, test your CD/DVD in a separate computer to ensure that it is working.
Keys Do Not Function Properly
I press my keys while typing but nothing types on the screen...
Replace the Laptop Keyboard
When the laptop keys are pressed and nothing is typing on the screen, you may have a broken keyboard. The keyboard will have to be replaced to fix this issue. Please refer to the guide on how to Replace the Laptop Keyboard.
Kenneth Odum
crwdns2935283:009/23/14crwdne2935283:0
569 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 11-1, Blackwell Fall 2014 crwdns2935289:0USF Tampa, Team 11-1, Blackwell Fall 2014crwdne2935289:0
USFT-BLACKWELL-F14S11G1
crwdns2935297:084crwdne2935297:0
Can't remember my password, Mine just has Windows XP, how do I do a factory reset?
Melissa McIntosh - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
A bit late in the game for me to reply considering your response was 2 years ago but here is how I just did it today.
Right after you turn it on keep hitting F8
Go to reboot in safe mode.
Wait for the main screen then go to control panel.
Once you're in the control panel, find user accounts then look for the one that you want to erase.
Click okay then shut off the machine. Reboot as normal
Red Foreman - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 35
crwdns2959996:0crwdne2959996:0 3,094
