crwdns2959928:0crwdne2959928:0 ↓Accessing the RAM in this laptop is fairly simple and requires little disassembly.
Flip the laptop over, bottom-side up.
Push the switch next to the battery.
At the same time, lift the battery away from the laptop.
Unscrew two 4 mm Philips #00 screws.
Remove the RAM door panel.
Pull the tabs located at red circles apart in order to separate the ram from its housing.
