Removing the DVD/CD drive will help to replace a broken or damaged drive.
Flip the laptop over, bottom-side up.
Push the switch next to the battery.
At the same time, lift the battery away from the laptop.
Remove one 4mm Philips #00 screw.
Open the paperclip as seen here.
Insert the paper clip into small hole next to the eject button on the disk drive.
With slight pressure, push the paperclip into the laptop.
The disk drive will slowly "pop out" of the side of the laptop.
Using your hand, pull the disk drive out of the laptop.
