crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Device will not turn on
The device does not power on, regardless of how many times I press the power button.
Broken power button
First check to make sure that the power button is functioning properly. Refer to the Buttons will not respond section in this troubleshooting guide.
Battery is not charged
Your battery might be out of life. Try charging the device, using several different power outlets.
Broken charger
If the device doesn't charge, then the charger itself might be broken. In this case, the charger will have to be replaced.
Faulty battery
If your device still does not charge, then the battery is defective and will have to be replaced.
Screen will not register a touch input
The screen appears frozen, or the start screen will appear when I press the power button but the screen itself will not move no matter how much I touch it.
Too many applications are running
If your screen appears frozen, there might be too many open apps causing the device to run slow. Try restarting the device.
Broken glass
The glass might be broken to the point that the touch screen below no longer registers your finger. The glass will have to replaced.
Faulty touch screen
Your touch screen might be broken and will have to be replaced.
Faulty logic board
If the screen does not respond after restarting the device and replacing the touch screen, then you have a bad logic board and you will have to replace it.
Nothing happens when I press certain buttons.
Clogged with debris or dirt
The buttons may be clogged with dirt and/or debris. Check surrounding areas of buttons and clean out any dirt, dust or debris.
Buttons may be jostled out of place
The buttons may have been displaced through continuous or vigorous use. Open device and check the buttons to make sure they are in proper slots, and place back in proper slots if necessary.
Faulty logic board
The logic board of the device may simply have gone bad. If this is the case, simply replace.
Speakers are not functioning properly
The speakers are not emitting any sound or the speakers' sound is distorted.
The volume is muted
Try Adjusting the volume with the two volume buttons on the side of the device. If these buttons are stuck, you can adjust the volume on the touch screen.
The sound is lagging behind the video or is choppy
This could be due to poor system performance, which can be solved by clearing memory space, updating the tablet's software, reducing the number of applications running simultaneously, or ensuring you have a strong internet connection if the media you are accessing is online.
The headphone jack is activated
If the headphone jack is activated, it disables the sound coming from the internal speakers. Blow any dust that accumulated in the jack out with a can of compressed air, or use a toothpick to get it out. You may need to do a more thorough cleaning by shutting the device down and gently cleaning out the jack with an cotton swab dipped in rubbing alcohol or by spraying the jack with a cleaning spray that is safe to use on electronics. Make sure you let the jack dry out before reactivating the device.
The speakers are faulty
If none of the fixes above solved the problem, then there may be an issue with the physical speakers. In this case, the speakers need to be replaced.
Katherine
crwdns2935283:001/22/15crwdne2935283:0
439 crwdns2915208:0crwdne2915208:0
UWT Liner: Group 2 crwdns2935289:0UWT Liner: Group 2crwdne2935289:0
Community
crwdns2935297:036crwdne2935297:0
crwdns2942667:0crwdne2942667:0 553
