crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Device not turning on
Phone is not turning on no matter what I do
Bad battery
If the phone is not turning on, it might be because the battery is damaged. Try turning your phone on while charging the battery. If this does not work, the battery will have to be replaced.
Power button is damaged
If the phone is not turning on, try rebooting your phone by pressing the power button and the volume at the same time. If the phone is not responding to this, it might be that the power button is damaged and has to be replaced.
Bad display
If the phone is not responding to any of the solutions above, it might also be the case that the display is not working. In this case, the display/screen on the phone will have to be replaced.
Bad motherboard
Ultimately, if the phone is still not turning on, it is most likely that the motherboard is damaged/not responding, in which case it will have to be replaced.
Phone turns off when reaching 25% battery life
Even though I have plenty of battery left, the phone turns off
Bad/drained battery
If the phone turns off when reaching 25% of its battery life, it is most likely that the battery is drained/damaged. In this case, the battery will have to be replaced for a new one.
Phone not detecting SIM card
I'm not able to place calls and phone says not detecting any SIM card
Bad SIM card
This might be a problem with the SIM card itself. In order to fix this problem, the SIM card will have to be replaced.
Bad Motherboard
If replacing the SIM card is still not working, then it is most likely the problem is within the motherboard. In this case, the motherboard will have to be replaced.
Screen freezes when adjusting volume
Whenever I change the volume, my screen freezes
Bad display/screen
If the screen keeps freezing when adjusting the volume, it might be because the display is damaged. In this case, replacing the display might fix the issue.
Bad motherboard
If the screen still freezes after replacing it, the problem might be fixed by replacing the motherboard.
Phone not receiving picture messages
I'm not able to receive and/or download any pictures in my messages
Not enough storage available
If picture messages are not downloading, it might be that there is not available storage in the device in order to download the picture. In order to fix this problem, clear some storage space or expand the memory.
Bad SIM card
If the storage is not the problem, then the SIM card might be damaged and will have to be replaced by a new one.
crwdns2944067:04crwdne2944067:0
Display messed up on mine two weeks after getting it nothing happened to it but they won't help me!
joni352001 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
This phone is garbage so is customer service
Agreed. This phone is so worthless
Stephani Marlin - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
When sim card is inserted, it reads no sim, meanwhile that same sim is working in another phone
mavis.commey - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
