crwdns2862678:0crwdne2862678:0
crwdns2895503:0crwdne2895503:0
Device Will Not Power On
The device will not power on when connected to the USB charging cable.
Damaged USB Port
Dropping the device can cause the USB port to disconnect from the motherboard. The USB port may need to be replaced or be re-soldered to the motherboard. Use this guide to replace the port.
Defective USB Charging Cable
The USB charging cable may not be functioning properly and will not charge the Mixamp device. The cable will need to be replaced with a new charging cable.
Audio Distortion
The audio is not audible or is distorted.
Poor Cable Connection
There may be a loose cable connection with the Mixamp or other device. Try disconnecting and reconnecting all cables.
Defective Cable
Though unlikely, the headphones in use may not be operating correctly. Try connecting a different pair to the Mixamp device.
Faulty Motherboard
If the audio is still distorted there may be a broken connection in the amplifier motherboard. This guide will replace the motherboard completely.
Adjusting Dial Fails to Work
Settings cannot be adjusted effectively using the panel dials.
Residue Build Up in Dial
The panel dial may be sticking or not rotating properly. A buildup of dust or other material can be affecting the dial performance. Use the Panel Dial Replacement Guide to disassemble the dial, then clean and reassemble the device.
Panel Dial is Missing
If a panel dial is missing, replace it using the Panel Dial Replacement Guide.
Motherboard Issues
If the dial fails to respond the connections to the motherboard may be damaged, replace the amplifier motherboard.
Control Buttons Fail to Respond
Device doesn’t respond when control buttons are pressed .
Control Buttons are Stuck
The control buttons of the device may be affected by a buildup of residue. If the buttons are toggled but don't return to their original positions, the problem can be fixed with the control button replacement guide.
Motherboard Issues
If the buttons are not stucking, there may be a broken connection to the motherboard. Replacing the motherboard will be necessary in this case.
Bo Sun
crwdns2935283:010/08/16crwdne2935283:0
183 crwdns2915208:0crwdne2915208:0
IUPUI, Team S4-G4, Wilson Fall 2019 crwdns2935289:0IUPUI, Team S4-G4, Wilson Fall 2019crwdne2935289:0
IUPUI-WILSON-F19S4G4
crwdns2944067:04crwdne2944067:0
My usb port was damaged. I have refixed it. But now theres no audio. What can i do
Bilal Khan - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I’ve had a constant problem with what I believe is my mixamp. It constantly acts as if I am disconnecting and reconnecting my headset over and over again. I’ve read things that say I need a new mixamp but before I go out and buy one I would like to confirm it with multiple sources.
Derrick Halvorson - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I have volume but cant control it. Muted it seems with all red lights lit. No mic and no volume control
Any ideas?
Eric Garcia - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
my brandnew mix amp will not power on what do i do
Micah B Millraney - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 55
crwdns2959996:0crwdne2959996:0 12,699
