Astro Mixamp USB Port Replacement
crwdns2869540:0crwdne2869540:0: 9.1K
4
26
118
9,054
crwdns2955950:0crwdne2955950:0: 5
crwdns2960002:01crwdne2960002:0, crwdns2960008:04crwdne2960008:0
crwdns2959984:0crwdne2959984:0: 2
crwdns2959974:02crwdne2959974:0
crwdns2959986:0crwdne2959986:0: 2
crwdns2959982:02crwdne2959982:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:015crwdne2931287:0
crwdns2955970:0crwdne2955970:0: crwdns2937803:0crwdne2937803:0
Use when the USB port needs to be removed. (Soldering Required)
    1. Astro Mixamp USB Port Replacement, Panel Dial: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Astro Mixamp USB Port Replacement, Panel Dial: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Grip the dial tightly and pull straight off the device.
      • Repeat for the second dial
    2. Astro Mixamp USB Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Astro Mixamp USB Port Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using tweezers, remove the spacer nuts and washers from each dial post.
    1. Astro Mixamp USB Port Replacement, Outer Casing: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Astro Mixamp USB Port Replacement, Outer Casing: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Before opening your device, ensure the device is not on or connected to the charging cable.
      • Insert a plastic opening tool into the seam between the rubber foot and plastic casing.
      • Pull the rubber foot free of the plastic casing.
    2. Astro Mixamp USB Port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a screwdriver to remove the screw from the rear casing.
    3. Astro Mixamp USB Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Gently lift the rear casing from the device.
    1. Astro Mixamp USB Port Replacement, Motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Astro Mixamp USB Port Replacement, Motherboard: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Astro Mixamp USB Port Replacement, Motherboard: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the four screws that hold the motherboard in place.
      • Only touch the edges of the motherboard. Touching the surface can damage the motherboard.
    2. Astro Mixamp USB Port Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Gently pull the motherboard from the front cover.
    1. Astro Mixamp USB Port Replacement, USB Port: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Astro Mixamp USB Port Replacement, USB Port: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Astro Mixamp USB Port Replacement, USB Port: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Press the tip of a hot soldering iron to the USB connection to melt the solder.
      • Use a nylon spudger to lift the USB from the solder.
      • Repeat for each of the four USB connections.
      • For more help on soldering, refer to this guide: How To Solder and Desolder Connections
Hope Burns
crwdns2935283:010/29/16crwdne2935283:0
769 crwdns2915208:0crwdne2915208:0
What port is used as a replacement?
jonescoleman1738 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Did you ever identify an appropriate replacement port?
Lepec - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
something was broken out of the port of the USB connection
MoreZemtor - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Will this method work with the 2015 tr mixamp?
jeffreyalvarez9 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 118
crwdns2959996:0crwdne2959996:0 9,054
