Replace a jacket zipper (without unraveling)
crwdns2935443:0crwdne2935443:0
= crwdns2915112:0crwdne2915112:0 = crwdns2861241:0crwdne2861241:0
crwdns2936319:0crwdne2936319:0
      crwdns2931349:0crwdne2931349:0
      crwdns2936071:01crwdne2936071:0 — Cut off old zipper
      Open the zipper.
      crwdns2936071:02crwdne2936071:0 — Cut out the box part
      I separate out the reinforced piece with the box piece so I can sew the new zipper in there neatly, too.
      crwdns2936071:03crwdne2936071:0 — Prepare the 1st fabric strip
      The fabric strips will be on the inside as a backing. This way the zipper tape is also covered with fabric from the inside, which is more comfortable to wear. In addition, especially the lower end of the zipper can be nicely bordered and additionally stabilized.
      crwdns2936071:04crwdne2936071:0 — Sew zipper to 1st strip of fabric.
      If you have a zipper foot for your sewing machine, insert it. Keep the needle in the middle position, the seam does not have to go right next to the zipper teeth.
      crwdns2936071:05crwdne2936071:0 — Prepare the 2nd fabric strip
      Place the second strip of fabric in front of you with the right (pretty) side facing up.
      crwdns2936071:06crwdne2936071:0 — Sew the 2nd strip of fabric to the zipper.
      Sew the second strip of fabric to the zipper. Also start at the bottom; the zipper foot must be adjusted so that the needle runs along its other side.
      crwdns2936071:07crwdne2936071:0 — Pin the facing and zipper to the jacket.
      Lay the jacket in front of you with the inside facing up. Mark the place where the zipper should start with a pin. I want mine to go all the way down, if possible, so I put the pin in just 2 mm from the bottom of the cuff.
      crwdns2936071:08crwdne2936071:0 — Sew the facing to the lower waistband
      It's best to start on the side that doesn't have the zipper - the fabric is thinner there and will feed better.
      crwdns2936071:09crwdne2936071:0 — Pin facing/zipper to jacket
      Now flap the facing and zipper over the seam you just sewed so that the zipper is between the jacket and the facing. The zipper tape should now no longer be visible.
      crwdns2936071:010crwdne2936071:0 — Sewing the slip/zipper to the jacket
      Be sure to use a very strong needle for this seam, preferably a 100 or 110 gauge jeans needle, or alternatively a 100 gauge universal needle. A regular 80 gauge needle would not get through the layers of fabric and would bend or break.
      crwdns2936071:011crwdne2936071:0 — Sewing the facing/zipper to the jacket (2)
      Lower the presser foot and topstitch the zipper and facing to the jacket opening. Make sure the facing is smooth under the zipper and keep it taut as you sew, so there are no overhangs that the zipper could snag on later.
      crwdns2936071:012crwdne2936071:0 — 2. pin the cover
      Close the zipper.
      crwdns2936071:013crwdne2936071:0 — 2. pin the cover (2)
      Open the zipper.
      crwdns2936071:014crwdne2936071:0 — Sew 2nd piece to bottom waistband
      Sew the 2nd facing to the bottom of the waistband in the same way as the 1st (step 8).
      crwdns2936071:015crwdne2936071:0 — 2. pin and sew the cover/zipper to the jacket.
      Now fold the facing onto the jacket. The edge of the jacket fabric should lie on the seam with which you sewed the zipper to the facing.
      crwdns2936071:016crwdne2936071:0 — Sewing the facings to the upper edge
      Now you only have to sew the facing to the upper edge. Pin them in place with pins. The top edge of the facings should run parallel to the top edge of the jacket.
      crwdns2936071:017crwdne2936071:0 — Finished sewing in!
      This is how the zipper now looks on the top and bottom.
