iRobot Roomba 650 Bumper Sensor IR Transmitter Replacement
crwdns2942287:0crwdne2942287:0This will involve getting deep into Roomba's inner core and removing the motherboard. The IR transmitter is a small blue device housed in a black plastic casing towards the front of the Roomba. This infrared sensor helps the Roomba to locate itself and detect its surroundings.
crwdns2944105:0crwdne2944105:0
With the Roomba upside down and turned off, use the Phillip's 02 screwdriver to remove the one 3.5 mm screw from the center of the side-brush.
Set the screw aside and pull the brush out.
Unscrew the four screws that hold the bottom panel using the Phillips 02 screwdriver.
Once you are sure that all the screws have been loosened as much as possible, then lift the bottom panel up off the Roomba.
Once the side brush and bottom panel are out of the way, simply grasp the battery by the two green flaps and pull it out.
Remove the front bumper. You may remove it with your hands or a tool. It should snap off with some effort. It will still be attached to the Roomba by a couple of wires.
Pull out the bin while pressing down on the release button. Set aside.
Remove the top plastic cover by first using a plastic opening tool or metal spudger around the edges. Then, carefully lift up from the back.
Use the Phillip's Head #1 Screwdriver to take out the 10 5 mm screws.
Continue to take out the two 5.5 mm screws with the Phillip's Head #2 Screwdriver.
Finally, remove the last 7.5 mm screw with the Phillip's Head #1 Screwdriver.
Lift the panel off and set aside.
Remove the yellow ring and the two plastic control panel covers.
Use the Phillip's #1 Screwdriver to remove the four 7.5 mm screws that hold the control panel to the motherboard.
Lift the control panel off, then lift the clear plastic motherboard protecting sheet and set both aside.
Use the Phillip's Head #1 Screwdriver to remove the five 5.5 mm motherboard screws.
Gently lift the motherboard up off the Roomba about half an inch.
Remove the round cliff sensor belt by pulling it up off of the front edge of the Roomba.
Disconnect the three cables that attach the motherboard to the front of the Roomba.
Lift up the motherboard, cliff sensor belt, and front bumper up and out of the way.
Remove the rubber cover on the bumper sensor.
Use the Phillip's #1 screwdriver to remove the two 7.5 mm screws from the bumper sensor module.
Pry the module clips open with a spudger or your finger.
Open the sensor module.
Once the bumper sensor module is open, remove the small IR chip.
Pull off the black protector surrounding the chip.
Use a soldering iron to desolder pins on the blue IR receiver. Try repeatedly warming each pin up and giving a tug on the receiver. It should eventually slide out.
You will need to then solder in a new receiver in the exact same place you took the old one out.
I've done this fix based on directions I found elsewhere. You've left out one vital detail, which is what kind of IR emitter to get
Amen. And is it a 5mm or 3mm?
Is the IR emitter 940nm or 890nm or does it matter?
Hi, I am curious about this given what my 650 is doing... It turns on and runs for 2 minutes before I get the error about cleaning the wheels. Basically, the Roomba goes in a circle to the left and that's it. Occasionally, it will back up to the right, and then go in a faster circle to the left. If I hit the bumper it will go back to the right and then forward again to the left. I replaced the left wheel and it had no impact. Do you think it's the sensor? Thanks
