iPhone 4S Home Button Gasket Replacement
crwdns2942287:0crwdne2942287:0Use this guide to replace the home button gasket.
crwdns2944105:0crwdne2944105:0
Power off your iPhone before beginning disassembly.
Remove the two 3.6 mm Pentalobe P2 screws next to the dock connector.
Push the rear panel toward the top edge of the iPhone.
how can i take out the screw if it is stripped
with a small driller, but I guess it is very difficult. Never attempted that myself on an iPhone.
lantzero -
There is no screw in Step 2?
Is the screw stripped or the head stripped?
I have used superglue on the screwdriver to remove a stripped screw, it would turn but not come out, with superglue I could turn and pull the screw out. May also work on a stripped head.
Trevor -
If you are careful, use a Dremel tool and a micro drill bit (sold where Dremel tools are purchased) to drill it out. Last resort kind of thing, good luck.
Why isn't it moving? I removed my screws.
I didn't see any extra screws holding the back in place. I had to use the included pry tool to get the back off. Just start at the bottom and pry gently...if you just "pull" like the guide says it won't work.
Don't use too much force to slide the back -- the back on my phone was hard to slide, and I bent and broke a silver metal contact tab at the top of the back (on the inside).
Super easy fix. Thanks for the tutorial!
Those little screwdrivers are easy to mix up, for those of us without ultra-perfect vision! Once I used the correct screwdriver, and my 13yo son's little fingers and perfect eyes, it went smoothly! Also my son noticed that the rubber piece around the camera len was covering the camera; it likely slid out of place when sliding off the back cover. A little playing around (with plastic tools only!) and it looks perfect now!
sorry but the rear panel is not pushed up. I pulled out the screws in the step 1 but still the rear panel does not move with even when I push it strongly.
I too tried to push and slide the rear cover without success. I then tried just pushing the bottom edge up with my thumbnails. It moved very easily forward. Just a few mm movement is needed and then the cover can be removed.
The finger friction approach did not work for me, even when using a sticky pad.
Here is what worked for me: Grab the iPhone in your right hand with the screen facing your hand and the top facing your body. Find a sharp edge of a desk or counter and place the bottom of the phone's back cover on is so that when you push it, the back cover remans against the desk with the body of the phone sliding free. BE GENTLE as this approach takes far less force than the finger friction approach.
Pull the rear panel away from the back of the iPhone, being careful not to damage the plastic clips attached to the rear panel.
Remove the rear panel from the iPhone.
On reassembly, be sure to clean the metal plate at the place of contact with the tiny pressure contact mentioned in step 4.
I pried one end of the back off only to find 2 funny little screws holding the other end on so I took my Dremel, like Jack said, and ground those suckers out. Once I had the back off I loosened all the screws then turned it upside down and shook the crap out of it. The screws went flying everywhere and fell on the floor. Its my moms house so of course she's got gross brown carpet. How am I supposed to find my screws in that? I get the vacuum out and go over every inch of the floor to suck up all them screws. Then I dump the bag on the table and all I find is a bunch of hair and gods knows what else, but no screws. When I look for my phone I see its covered in all that stuff that came out of the vacuum. I mean, what's up with that? How can I work on my phone if its covered in dirt? Nobody said anything about that, did they? The average guy's gonna screw up his phone big time if he follows these instructions and nobody warns him about all the dirt that's gonna end up in his phone. Are you kidding me!! Now what?
The replacement panel I got had two sheets of protective plastic on the inside and one on the outside. I used a toothpick to carefully lift and peel the two inside sheets off. One small one was over the lens on the inside. The other was over some large brown sheet of unknown function (though I think it goes over the battery). When I peel that away, some of the brown material tried to lift of with it, so be very careful.
From this point go to step ?? Just peel off the tape from the chip. Take some aluminium foil and cut a hole the size of the chip (Use a second layer of foil if you don't thrust it). Heat the chip as described at temperature 300 deg C for 5 minutes. Let it cool down. Reassemble and ..... hura WIFI is on again.
I spent longer reassembling the back than the complete battery replacement! And this while it seems so simple. I kept trying to slide the backside into the original position, but this proved impossible in my case.
What I ended up doing was fitting the 2 screws at the bottom while the back was still not 100% in the correct position. By tightening these 2 screws, they “pulled” the backside into the correct position!
Remove the following screws securing the battery connector to the logic board:
One 1.7 mm Phillips screw (PH00)
One 1.5 mm Phillips screw (PH00)
This step needs a few more caveats.
The bottom screw on my phone was locked with some thread adhesive, and required more force to loosen it than I expected.
Even after removing the screws, the battery connector was rather firmly seated, and required a fair bit of persistent gentle prying with the opening tool before it came loose.
The ground clip came loose and nearly flew off while loosening the connector, so it would really help people if there were a warning on this step to watch out for the ground clip and make sure it doesn't bounce away.
I had the same problem with the ground clip! I’m glad that I didn't for it.
iScott -
The battery connector is attached to the battery. You're not going to completely lift it out and remove it. It pulls out from the socket you can see in step 5 picture 3. The pressure contact (little black and gold thing) will probably just slide out from under the connector. Not a problem.
I completed this successfully, but this step gave me the most trouble. The pressure contact is really difficult to reseat. So much so that it should probably be called out more clearly in it's own step.
If your pressure contact pops out you might find the video at http://www.hightechdad.com/2013/05/07/ho... helpful
I found this link to be incredibly helpful in identifying how/ where to put the pressure contact back in place
In french: attention avant de retirer le contacteur de la batterie. La vis du haut tient "en sandwich" une petite pièce métallique noire et dorée. Cette pièce a pour but de faire contact de masse avec le dos de l'iphone quand il est refermé. Donc il ne faut pas la tordre. Quand les deux vis du contacteur sont retirée, attention au moment de débrancher le contacteur: cela va faire bouger cette pièce qui ne doit pas être abîmée ni tordue. Au remontage, il faut bien la remettre en place sous le contacteur de batterie: il est tout à fait possible de mettre d'abord le contacteur, puis de glisser la petite pièce au dessous pour qu'elle soit bien à sa place, le trou en face du trou de vis et du trou du contacteur. En remettant la vis, la pièce tient bien en place. Elle doit bien continuer à dépasser de manière a faire contact avec le dos de l'iphone.
Top screw didn’t move with iFixit Philips #000 driver. The metal is too soft and in the result the screw was damaged while still in place. Having nothing to lose I also tried #00 and #0. Any way to remove the stuck screw? I would gladly saw it off if I could.
Ok, I had to drill the screw to break it. It was very delicate and time consuming operation. But in the end the screw cap finally broke off and I was able to remove the battery!
The Liberation Kit Philips head screwdriver strips the battery connector screws! It stripped the ne 1.7 mm Phillips screw circled in red in the photo above. I was able to remove the other screw, then I lifted the battery connector off while the red screw was still in position and wound the connector around in circles while lifting upwards and managed to unscrew the stripped screw. Advice, find a decent philips heard screwdriver for the internal screws like the two found on the battery connector.
Bottom screw was totally stuck, nothing could budge it. I removed top screw, heated up battery with hair dryer to release the glue, pulled it out using the spudger. Lifted up the metal plate thing (after taking out the ground piece and putting it aside). Cut off the flexible bit between the plate and the battery and twisted the plate around the screw as you did.
Well, the screw eventually came out—but only the top half! Yes, it split in two. Then the bottom half came out, still attached to the thing it was screwed in to (a sort of barrel).
I put the new battery in, put the bottom half (with the barrel) of lower screw back in its original position, replaced the ground piece and positioned the new plate over it, and screwed the top screw back in. Then put the top half of the lower screw in and tightened it.
Et voila!
Extra: It was helpful to discover that the 1.5 and 1.7 mm measurements refer to length of screw, not size of Phillips head.
When reassembling, use EST tweezers to get align the pressure contact over the top screw hole. using the pointy end of a spudger to assist: put the point through top screw-hole on the battery connector, then through the pressure contact and into the screw-hole. this will help to keep the small piece in place while re-seating the battery connector. Leave the top hole spiked as such until the screw in the bottom hole is gently fastened. Remove the spudger and replace the top screw.
Pressure contact needs to be remain EXACTLY in the same position if you remove/replace battery. I had to re-open my iPhone 4S after a battery replacement (the mobile connectivity was lost) and tweak the position of the Pressure to restore functionality.
I used my 16x magnifier loupe to be certain I had the pressure sensor aligned with the screw hole - no problem, no stripping. I consider it indispensable for tricky steps like this, and IFixit sells a similar tool for just $14.
The pressure connector is the battery connector under the silver plate. BE CAREFUL. It seems like it'd be really easy to tear that pressure connector out without meaning to. The bronze and black thing is the ground, *not* the pressure connector. If you remove it just keep track of it and re-install it.
The phillips head screwdriver provided in the ifixit repair kit does not work well this these two screws after my first attempt at unscrewing the screws became stripped. The 1.7 mm phillips screw gave me the most trouble. It took an hour to unscrew after the screwdriver from the kit stripped the screw. I used a piece of masking tape over the screw for grip to loosen it, then used finger nail clippers as pliers to unscrew. I would recommend investing in a better screwdriver for this one step. Assembly is otherwise simple and easy.
Here's a tip if you're having trouble removing the 1.7 mm screw. I had real problems removing it – the 1.5 mm screw came out easily using a Phillips #000 screwdriver but I almost stripped the 1.7 mm screw using the same screwdriver. What I did instead was use a flathead screwdriver from the iFixit pro tech toolkit I got, the one with a "–" sign and 1.0 size. That worked perfectly!
When disconnecting the battery make sure to use a plastic tool not a metal tool that could short out the battery
I would agree that a decent magnifier would help as the screws and components are small.
Also take necessary precautions to ensure the screws are not lost or mixed up.
Other than being a bit fiddly (particularly the earth connector), the only challenge I had not covered was that the battery was fixed with glue close to where the connector is and despite releasing the battery along the side, I couldn't get the battery to lift out using the tab. In the end I had to use the plastic tools to gently lever the battery away, working from the outside edge and ensuring I wasn't levering against the volume control buttons.
The new battery is in and following the advise given, I hard reset the phone and all my usual functions are now running... and if this £18:00 fix gives the phone another year or two of use, it will be well worth the effort.
Vous dites "Le connecteur de batterie s'enlève verticalement de la carte mère. Ne forcez pas latéralement"
Ou placez vous la verticalité ? pour moi c'est connecteur d'alimentation en bas, bouton d'alimentation en haut ?
Parce ce que sur la photo suivante, vous enlevez le connecteur de la gauche vers la droite ... c'est à dire latéralement ...
Soit nous n'avons pas le même sens vertical / horizontal, soit il y a un GROS problème dans l'explication, ou dans la traduction.
En tout cas, à la lecture de votre explication, j'ai essayé d'enlever le connecteur vers le haut !!
Donc il m'est maintenant impossible de remettre la batterie neuve, le connecteur est cassé !!!
Bravo pour l'expertise ifixit :(
I've gone through this process twice now. I found this video also very helpful: https://www.youtube.com/watch?v=nYYdbk3U...
The little contact thing that sits under top screw is always the biggest hassle to fit back into place (I do it after attaching the battery cable) with tweezers from ifixit.
My personal tips:
- plan that the incredibly tiny screws or the top-screw contact thing, might get away from you. so work in a space where you can find them easily. Not over carpet, etc.
- I use strips of tape on a piece of paper to secure the screws while they are out, and position them so I know which one goes on top of battery connector, and the one on bottom.
- If you have access to a spouse's/mate's iphone, in Accessibility settings there's a Magnifier option (triple-click home button) which does an amazing job at magnifying stuff at a circa 4-6" distance. Lacking any good magnifying glasses, this feature helped a lot. https://www.imore.com/how-use-magnifier-...
Why the guide don't mention PH000 or PH00 instead of Phillip 1.7 mm / 1.5 mm? I didn't know it is PH000 until some comments here save my time. Thanks guys
I wonder if the two screws shown on the picture are not inverted. It would seem logical to me that the longest (1.7mm) screw be placed on the upper hole, (where there is the yellow circle) ie on the hole where there is extra thickness (of the gold plated grounding contact sheet metal) in the sandwich. I have not checked, however, I just put the screws in the same location as found.
I was able to remove the screws without problem, but almost stripped one of the screws when reinstalling the battery connector. Be careful how much force you use!
It does not work
When removing the 1.7 mm Philips screw, on rare occasion, the socket it is threaded into, might come out with it. (It depends on how little of that blue glue was used underneath on the assembly line.) Grab the socket under the removed plate between your fingers and use your Phillips screwdriver to back out the 1.7 mm screw from the old shield. Then once separated, thread back in the socket, into the case where it came from. You will want to do that before installing the new battery. You will need a small flat blade to span the socket hole in order to thread it back in snug. When the 1.7 mm screw is threaded back in with the new shield (with the Phillips screwdriver), it should tighten the rest of the way. Don’t over tighten. Great little kit!
Carefully push the pressure contact away from the battery connector until it slides free from its position.
Remove the pressure contact.
Use a plastic opening tool to gently pry up the battery connector from its socket on the logic board.
Place the tip of the tool between the loudspeaker enclosure and the metal cover of the connector, and lift the bottom edge of the connector first.
No idea what exactly this step means. I just pulled the battery connector without trying to move the pressure contact. Installed new battery, plugged in connector and aligned the pressure contact slightly for the screw to fit.
Got a big scare as the phone would not connect to the cell network at first boot, only WiFi. Shut it off and when it rebooted it seemed to work. WIll probably know in a day or so if everything works fine or if there are interference issues, etc.
This is normal ... removing the battery resets internal clock to start value and your provider doesn't accept that, hence no network.
Going online through wifi or manually setting date right corrects this after a reboot.
Dreetn -
The black & copper contact piece is missing from my iPhone. Does that explain why my phone won't restore and keeps re-booting? I have tried every kind of restore with no luck. Any ideas?
After reassembling the iPhone I the GSM connection wasn't working. After cleaning all parts with isopropyl alcohol it still didn't work. What solved my problem was to turn on WiFi and then synchronizing the date and time which was set to 1970-01-01. After a reboot everything worked just fine. :)
I had the same problem. Thanks for the solution!!
thanks for this!
The black ground contact needs still more "flagging." This is a simple metal strip that is attached ONLY by the 1.5mm (upper) screw. It will help if you look at it before you remove the upper screw. Notice the gold contact arm and point. That contact point must be in a plane above every other surface inside the device when you replace the battery connector, because it makes a ground contact with the metallic inner surface of the device back plate.
When I replaced it, I used the Pentalobe driver to line up battery connector and ground contact with the screw socket post. I then attached the 1.7mm (lower) screw loosely, removed the Pentalobe driver gently, and inserted the 1.5mm (upper) screw into the assembly. There is a tab on the ground contact that helps it align properly once pressure begins to applied. I completed driving the upper screw, pressing lightly with the spudger on the battery connector plate to make sure it was seated on the pressure contacts. Finally, I completed driving the lower screw.
I didn't find any need to remove the pressure contact. I just pried the battery connector up (gently) with a spudger and left the pressure contact in place. Connected the new battery and aligned the pressure contact screw hole. Replaced the screws, finished reassembly and all was good.
After reassembly, the CELL CONNECTION WASN'T WORKING. You might need to slightly bend the contact in step 5 up just a little, so it will make contact with the metal back plate. Did that and it worked perfectly.
Great kit, great instructions, thanks!
all those teeny screws...and the world is so...well...BIG!
go slow and put those parts INTO something...
putting them "on" something will just cause heartache and and an infected bladder...
after a lot of froofroo and very errant iphone behaviour problems, i concluded that that tiny grounding piece must be being lazy as hello. i spread it out a bit to ensure a better contact with the back plate and everything appears to be working smoothly.
did this repair, as well as the battery replacement...GTG!!!
spoke too soon, i 'spect...random reboots persist.
Just went through the replacement and the battery "plug" (step 5) on my replacement battery was slightly misaligned relative to the metal plate used to screw it onto the board. The plastic and "gold" "plug" was slightly askew on the metal plate, which meant that when the plug was inserted, the screw holes (step 4) were poorly aligned.
I managed to pull everything back into line using the screws, but the QC on these replacement batteries is a bit suspect.
Guess what happens when you rotate that ground connector 180 degrees...it grounds what I deduced to be the heat sink of the power amplifier for the speaker! So it is silent. It took me a couple of attempts to discover this as I was distracted by the new speaker not sitting down properly and a little dot of stuff under the main connector stuck to the pins. The latter was cleaned-off with a pin under 5x magnification followed by some isopropyl alcohol.
I suggest that Step 5 is more explicit about the orientation of this ground connector. It's only obvious after a really close look and if one has a lot to do like I did, it's a long time before one comes back to this step so the correct orientation is not obvious.
I accidentally removed the pressure contact and I was not able to put it back in place and so far haven't ran into any problems. Is this safe??
I did it als well. All Funktionen well.but i am Not sure if that reduce battery power? Thanks very much for information
The hole in the pressure contact aligns with the top screw. The IFIXIT tool kit I bought contained a black sharp “thing” that I used to align the pressure contact with the top screw hole. I used this tool to align the bottom screw hole also. I put the bottom screw in first but did not tighten it all the way. A good magnifying glass with a light helped a lot. Tim
Aligning with the black pointy “thing” definitely helps. Also, the small copper end of the contact piece is supposed to stick up once attached, to make contact with the back plate of the phone after re-assembly. The piece slides under the silver metal plate, and the the pointer can be used to align the silver plate hole and the black/copper plate hole in place for the screw.
How to fix back the battery connector after prying off?
Without that contact. Will the iPhone still use wifi? I need an answer ASAP!
Nope, Just tried it and without it it won’t connect to cellular or WiFi
What if i lose that little metal ? Huhu
Reattached it before removing the battery in next step? Or you mean upon reinstalling after all following steps ? Little confused why I would disconnect then reconnect then take battery out ? Or that is just for reinstalling?
Hi Nikko,
You’re right—reattach it when you reassemble the phone. I’ll re-word it to hopefully clarify that.
Arthur, you still need to re-word steps 7 & 8 ;-)
Excellent job highly appreciate by the way!
Regards,
Antoine L
Thanks Antoine!
I’m not sure what needs to be re-worded in step 8?
What if you lose it?
Can I use 72% ethanol instead of isopropyl alcohol?
As I understand it 72% is good for disinfecting, but at that concentration there's a lot of water and therefore residue once it evaporates. I think that you'll need a higher concentration to get the best results.
Insert the edge of a plastic opening tool between the battery and the outer case near the bottom of the iPhone.
Run the plastic opening tool along the right edge of the battery and pry up at several points to completely separate it from the adhesive securing it to the outer case.
Wait about one minute for the alcohol solution to weaken the adhesive.
Use the flat end of a plastic opening tool to gently lift the battery.
This can be very tricky because sometimes theres just too many glue on the back of the battery, and eventually the battery will be deformed.
Yes, there did seem to be a lot of glue holding my battery in. At first I was afraid of breaking it, but after reading up on the subject I've learned that it is okay if the battery gets a little deformed. Due to the nature of the battery it will still work if slightly deformed.
I found the plastic pull tab to be useless. Peeled pretty much the whole battery out from the left side. Used a probe to "break" a few strands of glue to help. Just watch the connector and ribbon cable in the lower left corner as you pry up so you don't crimp them or damage them.
Try a used plastic credit/gift card to apply gentle pressure to lift the battery out of the phone, the short edge of the card fits within the gap on the logic board side between the battery and video cables. You can also use it on the opposite side if there is room between the battery and iPhone frame. This has worked on all of the 4 and 4s models I've replaced screens on.
I offer an alternative image if interested.
Removing the battery wasn't necessary. I attempted the removal but decided not to in the end. It didn't get in the way at all.
i also skipped the battery removal step. the battery didn't get in the way, but it did make it difficult to see if the wifi grounding fingers (step 14) were underneath the case lip. everything worked in the end though so i don't think removing the battery is a strict requirement.
How can you not remove the battery in a battery replacement fix? Step 14, there are only 7 steps. Me thinks these comments are getting mixed up between different fixes!
bluezzer -
I did not remove the battery to do a Speaker replacement and had no issues with getting the Speaker out/in. So, steps 4 and 5 are required but not step 6.
The plastic tab is not attached to the battery. I just pried from the right and slid tools under until I broke all the adhesive.
I found it easier to start by pulling the plastic lip to loosen the battery, then, if needed, use the plastic tool to pry from the side.
I tried to get the battery out as depicted in the first picture. It deformed and is now broken. Not happy. It seems better to leave it or get it out by gently pulling the tab.
Please, Please, PLEASE avoid using probing elements to try remove batteries. I have had dozens handed in to me with punctures and two that actually started smoking due to people trying to prise the battery out. DO NOT DO IT.
The best way I have found to remove the battery is this process;
1) Try remove it with the pull tab directly, some will come out, some will not. Do NOT use excessive pull force else it'll deform the battery and reduce the capacity.
2) If the pull test didn't work, then get a hot air gun on medium and warm up the area around the battery for about 30 seconds, focusing on the perimeter of the battery. If you see ANY popcorn'ing then you're too hot, you don't want to cook the battery.
2.1) Wait about 30 seconds for the heat to now wick underneath the battery to soften the adhesive.
2.2) Now try pull the battery up, the extra heat should have softened the glue that you can remove the battery without excessive force and without sticking objects under the battery.
Use the exposed clear plastic pull tab to peel the battery off the adhesive securing it to the iPhone.
Remove the battery.
Be VERY careful NOT to pull off the part of the connector that is on the logic board! Mine now has only contact but no solder until I can get a small enough soldering iron and a less shaky pair of hands!
I lost the 1.5mm and 1.7mm screws when replacing my 4s battery. Is there a place that sells just these two screws? I bought a 4s screw kit from Zeeton.com but figuring out which screw out the of 39 screws were the the 1.5mm and 1.7mm was impossible.
Buy a cheap pair of digital callipers ($20 -$30) and it will be clear. You can then use them to measure all kinds of things instead of squinting with a ruler.
bluezzer -
I bent the wire of the silent button on right top of the battery. Now the silent botton don't work. The wire on the bent is half-cut. BE CAREFUL when you put the new battery inside!
Was having a hard time getting the screws back into the battery connector. Read another tip online that helped - pushed the end of my phillips screwdriver into some soft candle wax which gave it just enough stickyness to have the screw stay attached to the screwdriver while I was moving it toward the hole. Thought I'd pass that along.
I did as wazzamagu did (and stated above), "My Pentalobe tool was slightly magnetized so I used that to bring the screws in for tightening with the Philips screwdriver." That made replacing the screws fairly easy. Thanks for all the advice on this page. It was not hard at all. Go slow and carefully, everything is smaller in there than I expected. The "searching" thing came up as it seems for most people, but just took a reboot and all is fine.
TO ALL WITH NETWORK PROBLEMS!
I had the same issue with "searching network". After resetting the network settings in settings it did work perfectly!
Took about 15 minutes. The only thing that was confusing was the reference to parts, using the partname, and I didn't know what they were referring to. So I had to figure it out by the photos. Slightly frustrating. Got it in and it worked. My problem then, was it kept SEARCHING and couldn't find my carrier. I followed everyones advice on here, plugged phone into my computer to itunes. then turned off network settings in settings, then turned them back on, and I got 3 bars. good to go.
sally -
Instructions were good and everything works fine after replacement. Needed to use a tweezer on the pressure contact on the top screw of the battery. Thanks
I swapped out the battery today. No real issues. Pretty easy task.
For the past couple of months, my phone had been dying very fast. I knew that my phone's battery capacity was getting quite low as this phone is older now, and is out of warranty. So I ordered a replacement battery about a week ago, and just installed it yesterday. The install was pretty easy, if you pay attention to where everything belongs. But my draining issue has not gone away. It stays charged a bit longer, my capacity is at almost 100%, yet it can't even hold a charge over night. I'm not sure what is causing this and would love any tips or stories from someone else!! Please help!!
Beim Einbauen des neuen Akkus ist es sinnvoll diesen zuerst anzuschließen und dann erst wieder in die richtige Position zu bringen da man so dass Anschlusskabel besser verlegen kann
OMG thank you iFIXIT, the apple store wanted 3 times the cost of this repair kit. It took less than 5 minutes with most of the time spent trying to prise out the battery as it was glued in nice and tight but steady pressure from the spudger did the trick.
I think the best advice would be to touch nothing with your fingers as with careful use of the spudger I was able to position the tensioner point no problem. Everything else was nice 'n' easy.
Finally there was no cell connection only Wifi when I powered up so I simply powered down and up again and all is well in the world!
Thanks again.
The battery was incredibly hard to remove. I slid the spudger underneath the battery from the right side as far as it would go. Then, I worked it from the bottom to the top. The battery still was adhered and wouldn't budge using the pull tab. I wound up leaving the spudger underneath the battery at the top and then pressing down on the bottom of the battery to get leverage. After a few strong pushes, and then swapping the top and bottom in the last sentence, the old battery came loose.
I used tweezers to hold the tiny screws and align them with the screwdriver head before taking the screw to the destination hole.
One more tip.. if you don't have any other cartons or containers convenient, use the box that the product comes in as a workspace for holding the tiny screws while you work.
good tips, i took a couple of photos so i knew what it should look like and removed the screws and placed them in the order i removed them pretty easy if you take your time and be gentle
Sam B -
Be VERY careful not to pull on the plastic tab before you fully detach the adhesive or else you will rip the tab clean off. If you did this it is still possible to remove the battery. I just used the guitar pick tool things to slowly work it through the adhesive and under the battery
It is possible to remove and replace the upper antenna WITHOUT removing the logic board!! So skip from step 7 to step 21 to 26 and 27.
Stuck on searching after unplugging and plugging in the battery?
This is due to the date and time being set back to default. To fix this you will need to synchronize the date and time back to what it is currently.
You can do this by either:
- Connecting the phone to either a Wi-Fi network, Cellular Network (Mobile Data).
- Connecting the phone to iTunes (It will synchronize the time automatically once iTunes is opened and can detect and access the iPhone).
Once the date and time is synced you will need to turn airplane mode off and one as it may display 'Searching... 3G' or if it still says searching (which most of the time happens if the sim card has a sim pin lock enabled on it) you will then need to turn the phone off and on.
Watched the video and ordered the kit, followed all the steps and it all went brilliantly - thank you all so much.
Is it suggested that I add more adhesive with the replacement battery?
One thing I noted with the replacement battery - from AussieBattery here in Australia; not from iFixit - but the same problem might occur; is that the cable on the new battery had to be 'tamed' (bent here & there like on the old battery, before I could reseat the screws and even the battery itself. One again the black - pointy & flat ended - spudgers, that we use in desktop iMacs, were helpful in getting under that battery and releasing it from sticky-!&&*! I used a pair of '2.5' reading glasses for this job, but '3.0' might have been better, as those screws are INFINITESIMALLY small!!!!! :(
Thank you IFIXIT! The battery replacement went very well for me. I was exceedingly careful with the minuscule fasteners. Reading through the instructions, watching the video and reading these comments before jumping in helped. I found the parts and tools to be of good quality. I feel like I beat the system! I used a pair of diopter 3 reading glasses which was a real aid. I hope my comment encourages others...
My rare earth magnets came in handy when I managed to lose the little grounding connecter screws. Those little guys will go flying if, while trying to align them for reassembly, pressure gets applied in just the wrong way. I say one fly out and bounce off my shirt, then it was gone, on the floor I presume. I grabbed my stack of 8 little magnets, waved it around on the floor under where I was sitting and what do you know? A little screw was stuck to it! I never would've found it just by looking...
You really need to include information about the pressure sensor. It WILL inevitably pop out, leaving us wondering how and in what order it should be replaced. I had to look elsewhere for videos outside of iFixit to figure this out. Also, tell us which screwdriver to use using the label on the bit (PH000, P2, Y000, etc.). Providing only the sizes of the screws does nothing to help determine the appropriate bit to use when they aren’t labeled as such. Otherwise thank you!
I replaced the battery and the phone started right up. But I cannot get it to charge It was half charged when it went in new and I plugged it into a charger Checked it later - not charged. So tried another charger and the green charging light still will not come on . Any suggestions? Thanks Don
My iPhone 4s somehow has another connector on the battery. I cant connect the new battery to the phone. Its a complete different looking connector. And yes its never been replaced before or opened. The iPhone is one of the first versions for the german market after the fall of the simlock. Pls help
If it doesn’t look like what you’re seeing here, it’s probably not an iPhone 4S. Check the model number carefully. People mix up the regular and “S” models all the time. ;)
I succeeded to replace the screen, but I made a mistake with the batterie cable, and it finally broke, seems that the cable was too long and I was forced to make too tight loop.
Maybe a series of photo to explain how to make this the right way.
yoooo that was so easy and fun man!!!!!! love y’all
January 21st, 2020. My original iPhone 4s battery finally kicked the bucket. I just finished installing the new battery with ifixit.com and their parts kit. $16.99 and 30 mins of my time and the phone lit back up and is currently doing the charge for calibration. Thanks so much ifixit!
I succeed without any trouble. Tools and guide are excellent! Thank you
Great instructions. Couple of things. If new battery comes with a removal tag make sure you remove the old tag, Step 7 could be clearer, the pressure connector just falls loose when you first remove the battery connector and its hard to work out how correctly realign.
Excellent product - and now for a glass of Australian Shiraz to celebrate
Mon iPhone 4S se trouve ressuscité et je peux l’utiliser comme second téléphone en activant les réglages de transfert d’appels et des SMS vers d’autres appareils sous iOS (via le Wi-Fi et iCloud). Merci iFixit pour vos précieux tutoriels ;
Why would you disconnect the battery on the last step?!
Remove the following screws securing the dock connector cable cover to the logic board:
One 1.2 mm Phillips screw
Remove the metal dock connector cable cover.
Are the screw sizes switche up by any chance? A 4S i have here has the left hole bigger and one of the screws didn't want to go into the right hole when it went nicely into the left one.
Fabulous tutorial! Many thanks! i have now a working iPhone back after display crash and glass brake!
In Step 8 I think the colors of the screws are inverted. The larger screw is at the left (near the sideboard) and the smaller is in the middle, near the battery (iPhone 4S).
Was trying to fix guide but accidently messed some things up in formatting and I too also believe the picture is incorrectly displaying the 1.5mm(which is the left screw) and the 1.2mm(which is the right screw.
I believe the guide is correct, but be careful as the screws are not the same as the other 1.2mm screws from later on. Length is the same, but the diameter is not... just keep them all separate.
Organizer: tape cheap duct tape tacky side up to a tray. Get a ball point or roller ball pen. For every screw, write step number and a letter for color (R, O, Y, etc.) then stick the screw there. I bumped the table and nothing moved. Also use a big white towel as a work surface: nothing bounces away if you drop it. This helped re-assembly
Also remove 4 screws holding metal cover plate adjacent to camera lens, remove plate to expose camera plug. when removing the rear facing camera, be careful not to loose the small grounding finger mentioned in step 21
Same for me as for various other posters here: the bigger screw goes on the left, the smaller on the right. Doesn’t fit the other way.
Switch the position of the screws, it’s incorrect in the pic.
Use the edge of a plastic opening tool to pry the dock cable up from its socket on the logic board.
Peel the dock connector cable off the adhesive securing it to the logic board and the side of the speaker enclosure.
My gold adhesive has torn, exposing a sliver of the flat wire beneath it. I have put a bit of insulation tape to prevent any contact between the wire and the top of the vibrator and metal piece on the logic board. I don't know if this is sensible or not. Depends whether the gold adhesive is intended to be an electrical contact with these bits, or an insulator from these bits! I will post to update once the phone is powered up / blown up!
I just broke the cable with frame. Careful…
Use the edge of a plastic opening tool to pry the cellular antenna cable up from its socket on the logic board.
De-route the cellular antenna cable out from under the metal fingers attached to the logic board.
Ok, I did all the steps and phone seems to be OK, wifi is actually working again, yaaay.
But cellular connection is messed up. It will have full reception (5 pins) for about 10 seconds, then drop to 1 pin for a couple seconds, then go into "searching" mode. After a few seconds in "searching" mode it will go back to full reception and the process repeats itself in a timely fashion, over and over again. Obviously I messed up somewhere but where? Which connections are faulty/beyond repair?
I dismantled the phone again and concluded that the digitizer cable was kind of loose (don't know if that affected anything, but i put it down firmly this time). I had 2 problems, the cellular connection I mentioned plus the phone would charge to 3 percent, die, and then repeat the procedure. What I did was I took out the battery, the tin plate above the cables, and lifted the dock connector. So I did not redo that much. I cleaned all contact surfaces as I had been told but chose to not do before.... I also took out the grounding clip by the battery connectors and bent it upwards quite a bit while also peeling away 2 mm of the black insulation material on the back of the phone to make sure the grounding clip connects well to the back of the phone. I also cleaned that surface with window cleaner, which is basically isoprypol alcohol as has been recommended. The cellular antenna connector I pushed down firmly to make sure it was connected, I was gentler the first time, now everything works.
Note that the antenna cable goes around the the right side of that little guiding hook/finger. On the photo it shows the cable on the left of it. The hook is almost right below the socket.
Thanks Jasperm, that info was a big help!
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Sometimes found stuck to the inside of the back cover.
Don't do it!!! you can skip that, it will stay and its more of a pain to remove it.
This is unnecessary step!! Don't do that!!
Agreed, mine was stuck inside of the back cover
So was mine - thanks for telling! Rests of soft glue could be scratched off the place - so the ring was already off and I looked for it everywhere.
Mine was stuck to the cover too, thanks for posting.
Mine too, thx :)
Remove the following four screws securing the cable cover to the logic board:
One 2.7 mm Phillips screw
One 2.6 mm Phillips screw
One 1.3 mm Phillips screw
On reassembly, note that the metal lip below the (red) 2.7mm screw and to the right of the (green) 1.2mm screw goes between the ribbon cable and the main logic board, as can be seen in the picture for Step 12. If you don't get this right, the 2.7mm screw is difficult and, worse, there's a risk the edge of the lip will tear the ribbon cable.
I had challenges here. As noted, the metal lip below the (red) 2.7mm screw and to the right of the (green) 1.2mm screw goes between the ribbon cable and the main logic board. That lip points away from you, towards the screen, THEN BENDS UP towards the power button. You need to pull the metal shield down a little (which stresses the ribbon cable) to get the hook-shaped feature free.
griffn -
The fastening on the board came loose when trying to remove screw the 1.2 mm Phillips screw. So the screw hole for that screw is still attached to the cover that I removed.
Got to step 13 and could not remove the 1.3mm screw (yellow circle), even using a different Phillips head screwdriver than the one that came with the kit. So frustrating. Was able to remove the other screws leading up to this point without difficulty (used the saran wrap trick on the other screws to prevent stripping, but this 1.3mm screw just would not budge).
Ended up abandoning the screen replacement--luckily the phone works after putting it back together.
In my case, the 1.3 screw (yellow) wouldn't tighten on reassembly. I might have tightened too much so that it stripped the screw hole. Anyone know whether this has damaged the board in some way. The phone works fine, but concerned about the long run.
Use the edge of a plastic opening tool to pry the cable cover tabs out of their slots cut into the EMI shield on the logic board.
Lift the cable cover from its edge nearest the top and remove it from the iPhone.
If you just very slightly twist this plate clockwise as you are lifting it out, it will help as there is a little hooked piece at the lower edge on the very far right. You have to be careful not to turn it too much though because this hooked piece is right beside a ribbon that could be damaged.
To add to Trisch's comment:
If turn the plate clockwise doesn't do the trick, the hooked piece on the lower right comes off when you pull the plate towards you a tiny bit. Still, watch out not breaking that ribbon the hooked piece is behind of.
If you're having trouble removing the EMF shield, try using a plastic prying tool to lift the top right part while pushing it ever so slightly downwards with a finger. Consult this video for details: https://youtu.be/8fujLMaxJsw?t=6m42s
Use the edge of a plastic opening tool to pry the rear camera connector up from its socket on the logic board.
Remove the rear camera from the iPhone.
Im pretty sure that when you reinsert the cam the grounding clip has go to between metal sticker and the cam body, or the camra wont be grounded
I've got a trouble at this step. Is there anybody who could help me out with my problem? When I was removing the camera module, accidently removed small element, which is marked with the red line http://i63.fastpic.ru/big/2014/1022/4e/9...
As I figured out - that is the SMD capacitor. After that Iphone was switched on, and it seems to be working fine at the moment, but I am very scared, if it will continue to work well without that small piece. Anybody to help?
In my case, the grounding clip was taped to the camera! In addition, my repair process stopped at this step as the left screw on the power button had come out and was floating around next to the camera slightly stuck to the tape. This was lucky since a loose screw in an iPhone under the logic board would be a bad omen.
Use a SIM eject tool or a paperclip to eject the SIM and its tray.
Remove the SIM and its tray.
I have an Iphone 4 but the inerds look more like this 4S than the 4, except I do not have a SIM card port. What's up?
Probably a CDMA (Verizon) iPhone 4.
Pepper -
Is there a reason for waiting until step 18 to remove the sim card and its holder? I can do it right before I start without much force, is this not better?
I don't see any reason. So it was my step 1 to remove the SIM card.
Ida -
I agree that the SIM card should be removed before you even start. After I completed this repair (waiting until this step to remove the SIM), the SIM card and holders won't go flush with the side of the phone anymore. The phone still works and everything else is fine, it's just annoying that I have a SIM holder sticking out about 1mm. I'm not certain this step caused this, but I'm just letting folks know that I agree with jmaelzer.
for the life of me I can NOT get this sim card and holder out!
While "This may require a significant amount of force." may vary by individual device, I found it to be true. I used a straightened paper clip held with a (really good) pair of needle nose pliers and pushed straight in until it fully popped out.
Orac -
To be honest, it's really hard to remove SIM card without a correct tool.
You have to PUSH the paperclip IN, then the tray pops OUT.
I agree. Push in.
ivesrubl -
ifixit needs to edit this: "significant force" is NOT needed! I started to bend out the hole until I read the last post- just push the tool straight in, the SIM card will eject easily.
That may depend on the specific device; significant force *was* needed to eject it in the case of the phone I'm working on. Putting it back in, however, was very easy and didn't require any significant effort.
Orac -
Is there any reason why you still have the ribbon cable under the little metalic plate (right under the sticker that says "Authorized Service Provider Only") plugged in in STEP 10. And it is without any instruction step removed in STEP 12? I mean it's not like it is complicated, but when I got to that part I was confused there for a minute that I forgot some step, and then reassured myself that I did everything as it said in the manual.
I have done everything correctly but when i turn the phone on all i get is a blank screen. The phone operates as normal i.e. it rings, vibrates etc but the screen is just blank so you can't actually do anything with it :(
anyone had the same issue?
FWIW, I found it easier to replace during re-assembly by turning the phone front-side up, as on the Sprint-locked one I was working on, the SIM card faces that way. Otherwise, it tends to fall out (down) while trying to re-insert it if the phone is face down.
Popped the SIM card holder out no prob - but there’s no SIM card. This is a Virgin Mobile phone, does that matter?
There is a rubber spring that fits on the power button hinged wire bar that slipped out of place here (button was stuck, no click), take a look at it here: http://geulah.net/test/
Remove the five cables near the top of the logic board in the following order:
Headphone jack/volume button cable
Front facing camera cable
Digitizer cable
Display data cable
Power button cable (located underneath the headphone jack/volume button cable as shown in the second picture.)
There is an additional cable that you have to disconnect that's under the headphone jack cable. You have to do this before you try to remove the logic board. Otherwise, you'll rip that cable.. and I just freaking did.
The digitizer cable won't reach! I've already ripped it off once. which disconnect are you talking about?
kct16k -
I just ripped off the power cable ... i can live without the power button though!
is that sarcasm or is there really a way to turn on the phone without the power button?
The only way to turn on an iPhone without a power button is to plug it in to power. If it was shut down while connected to a sync cable then disconnect and reconnect for it to turn on.
Ben -
I just broke off the power button as well because I forgot to disconnect the cable. Thank goodness for chargers and assistive touch!
Need to remove the shield over the connectors first. Look at the other guides for the 4S they show the 4 screws and how to lift the shield out, take out the camera etc.
True, these steps are missing from the instructions. See for example 15-17 steps here: iPhone 4S Screen Replacement
zzkovacs -
During reassembly, I noticed that the data display cable is rather stiff. It may be a bit tricky to get it reconnected, but you'll know once it's in.
That power cable connector is very delicate. I managed to tear it just a tiny bit in the curve of the cable too. So I’ve got another part on order now. Apart from that the screen replacement went great ;) I’m not sure at which step the tear actually happened, it might have been during re-assembly when I was trying to get all these cables to stay on top of rather than go behind the motherboard. Realizing how easy that is to tear and keeping that in mind as you do this is important.
I ripped the power button cable(didn't see it), any chance it could be outlined with a dotted color in the future? (I'm bad at reading the warnings)
It was a lot easier for me to use a fingernail to remove these cables. It provides a lot less force, and is more likely to remove the cables without damaging them as they are very easy to break.
Whoops… there are 5 cables to disconnect, not just the four shown in the first picture but one sneaky one hidden underneath these. It apparently rips off when forcefully removing the logic board. Guess ill have to wait for the replacement cable to arrive now.
一定要小心第二张图片的蓝色电源排线啊,我不小心没拆就撕断了
Remove the 1.5 mm Phillips screw securing the grounding clip to the logic board near the headphone jack.
During reassembly, note that this small 1.5 mm screw goes into a thread in the head of the larger 4.8 mm standoff screw near the headphone jack.
Use the tip of a spudger to pry the small grounding clip up off the logic board.
Carefully grasp the grounding clip and remove it from the iPhone.
(be careful but gently forceful; the part doesn't come out without effort)
Prying this off took the most effort as it's a squarish 'C' clip with two small 'teeth' like points that grip the bottom.
You can use the edge of a plastic opening tool to easily lift the other side of the grounding clip.
Top for taking the grounding clip off: use the spudger on that end, and use a prying tool ever so slightly on the opposite end to get it out of that little part catching it, then it will come out easily.
crwdns2935267:0crwdne2935267:0Standoff Screwdriver for iPhones$5.49
Remove the 4.8 mm standoff screw near the headphone jack.
I used a metal spudger from the Pro Tech Toolkit to remove the standoff, seemed to work better for me than a flathead screwdriver.
The flathead screwdriver provided is much too small to remove this piece!
I recommend that steps 20 and 21 are swapped. It's much easier to remove the wifi antenna flex from the board using the blue spudger if the board/PCB is still secured with the 4.8mm screw.
Removing the screw first makes the PCB move up too much when you're trying to detach the wifi flex and can lead to mishaps.
Not all screwdrivers are equal. I took mine in the shop and ground the blade thinner then made sure the end was square and flat. You can do this with an emery board or sand paper. You want a good fit in the stand-offs.
The iFixIt standoff screwdriver is a great help.
Use the edge of a plastic opening tool to disconnect the Wi-Fi antenna from the logic board.
Great Guide and thanks. Now...what if i snapped the wifi antenna cable together with its male connector from the board? Like tearing it apart ? Can this be replaced by any chance? Thanks!
I also had a problem with the connector breaking off, but after putting everything together, the WiFi seems to work like before, so I guess there is no problem there...
Ok so no fret here if you accidentally pull off the metal insert placed on top of the actual antenna. This step needs to be rewritten imo, the deal here is that there is an actual 'socket' looking deal underneath here that you need to lift up. There is a metal tab semi'glued' to that part of the antenna and it does come off easily, however all you need to do is press them back together to get them back, I believe it to be a range 'extender' of sorts.
So your looking to actually lift up what looks a lot like a ribbon cable as well in this step. YOU SHOULD NOT HAVE A PIECE REMOVED IN THIS STEP, it's still in the case at this point.
I have connected my wifi antenna to the phone but when my phone switches on the wifi button is a grey colour and won't let me turn it on, help?
When reassembly - take care with flat cable, which might be pushing connector to side. If so - I found easy to put connector in place before tightening screws on step 23 and 22. Because then logic board can move a bit when repositioning connector and to slide right place before connecting it properly.
If present, peel the piece of black tape covering the hidden screw near the power button.
Remove the 2.6 mm Phillips screw securing the logic board near the power button.
Dimension given are Length of screw. I think it meant to say 2.6mm screw.
Note that there is a rubber insulator that is loosely attached to the PBC that can be seen in the upper right corner of the red outline near the tag with Q5M on it. It falls off after the logic board is removed and should be replaced before reassembly.
where the heck does it go back on the logic board?! It fell off during removal and I cant seem to locate it in the pictures. :(
As noted: Put the bumper back right above the white bar code label. The label says Q5M on the far right side. The bumper goes on the edge of the board to protect the ribbon cables that bend over the board.
griffn -
So, my 2.6 Philips screw near the power cable just spins and spins. It happened the first time, so I know I didn't strip it. Any ideas?
So, I couldn't gind the tape and instead of digging around. I did what no one should do. I twisted and pulled. So now the screw that holds the upper left corner on broke that part of the logic board off. Everything else went back great....Phone won't turn on. Am I screwed here?
step 13 - “One 1.3 mm Phillips screw”
step -22 “Notice the small rubber bumper under the screen & digitizer cables (which are detached at top above the Q-code)”
“Note that there is a rubber insulator that is loosely attached to the PBC that can be seen in the upper right corner of the red outline near the tag with Q5M on it”
now, the problem :-)
while assembly the iPhone I screw by mistake the 2.6 mm instead of the 1.3, and without noticing I break the 1.3 base screw from the motherboard :-/
Now, the rear camera is not working.
I couldn't figure in the picture above, if the rubber bumper you mean, is under that screw or above the Q5M tag ?
Can it be that the dewar camera don’t work because of that broken screw?
Any idea how to fix it?
Is there any option to buy the rubber bumper, if I lost it ?
Appreciate any help,
thanks!!
Under the screw is a ground clip from step 25. I tweezed it out here since it might bounce free while pulling logic board out. Use a big white towel as a work surface to prevent wayward bouncing bits from flying off the table.
Caution: the image with the QR code is "mirrored" --> look at it "reversed" !
If your driver is just spinning in this step, you may be trying to turn the offset screw instead of the phillips screw beneath the tape. The tape is not obvious, and I found tweezers helpful when removing it.
Remove the following screws securing the logic board to the case:
One 2.5 mm Phillips screw near the vibrator motor
One 2.4 mm Phillips screw
One 3.6 mm standoff along the side of the logic board nearest the battery opening.
The Kit Provided flat head screw driver didn't fit in the stand off screw heads on my IPhone 4s. I had to use it in only one side of the screw notch to slowly twist them out. Its doable but could use a larger flat head, but the blade needs to be micro thin.
I wound up stripping one of the screws on this step. Was frustrating but I found if I too a sharp knife and gently went back n forth I was able to make a little notch to use a flat head and got it off. Other than that all went well.
Carefully lift the logic board from the end closest to the speaker enclosure and slide it away from the top edge of the iPhone.
Remove the logic board.
After I had lifted the logic board and moved around a little a small rubber piece fell off. Approx. 1 cm long and 2 mm wide. I'm guessing it's for some sort of isolation between the board and the chassis. Where should it go when I reassemble the phone?
The piece I'm referring to can be seen on the table in the upper right corner in this video: http://www.youtube.com/watch?v=IVQtgD89e...
It sits between the logic board top-edge and the two ribbon leads from the screen. Its purpose is to stop the PCB cutting in to the FPC leads over time due to vibrations. If you require I can send a photo.
hey, i removed the logic board and gave it a bit isopropanol spray. is this ok? how can i found out if it is working? is it possible to remove something from the logic board? thank you :)
On reassembly, make sure you lift up the power button cable before installing circuit board. I thought I had all of the cables lifted until after getting to step 17 (in reverse) only to find out power cable was under the circuit board. Added 15 minutes to my process.
I had a similar problem as I was back tracking steps to perform something I missed and actually broken the power and sensor cable (the one that is connected to the digital board first during re-installation. A secondary order and another 20 minutes took care of it. Glad you were able to not hit that barrier.
Check this... Rubber Bumper Location =)
On reassembly, you are putting the plate under the spaghetti. I went back a few times to get all the cables out. Here is a check list before you tighten any logic board screws or try to jam the top edge of the board in place:
Counter clockwise from upper right near power button:
- Wi-Fi Cable from step 21
- 5 cables near the camera from step 17.The ‘blue’ power cable underneath loves to hide. The ‘orange’ front facing camera cable can get kinked under the board during re-install (no more selfies on this phone).
- Dock cable from step 9
- Cell Antenna from step 11
Go slow. Look twice.
Before logic board re assembly it is nice to use scotch tape ( temporarily) to bend all the connections above the battery compartment . Doing as such avoid to have the power button connection remaining below the logic board .
if I LOSE it, what will happen?
Actually, i DID lose it.
Hi. This little clip is responsible for the image stabilization on the 4S. When the iPhone 4S was launched, one of the things that were different from iPhone 4 was Image Stabilization, specially when the user was filming. This clip holds the camera module in place while the phone is shaking in the hands of the user. Pretty high tech :D
Apparently it had uncovered my iPhone before, because when I did not find this piece uncapped here. I need to know which function is on the iPhone and if it is very important. How could I get?
Hi, I had the phone apart to replace the wifi chip.
Has anyone found a source for the two nano sized SMD resistors, because this also causes "no wifi" syndrome due to them being important for the I2C lines.
thanks!!! -A email testing_h "at " yahoo.com
I think this is one of the parts I didn't put back in... Does it affect anything?
Also, Took apart my iPhone 4S to fix the screen and battery... Now the camera light doesn't turn on and I'm left with two pieces. Help!
Here are the parts: http://imgur.com/DsYtdlR
Left part: See step 5 - "Take notice of the small black ground clip on the upper screw of the battery connector".
Right part: See step 25 - "Be sure not to lose the small grounding finger for the rear facing camera near the power button".
I removed this in step 22 even though it only slightly alluded to it. If you did, too, don't panic. Go find your step 22 parts and verify it is there. :)
What are the consequences of losing the 'small grounding finger for the rear view camera'?
I did it. No problems!!!
I used a Tupperware orange peeler as a plastic opening tool and didn't touched any screws oder other inner parts.
I had to do it two times, because my old 4S 64GB has a broken WLAN Chip on the logic board, and my wifes 4S has broken her display glass. So I took her logic board into my 4S body. Now we have one running iPhone 4S 64GB instead of two broken phones.
HELP! Miy clip does look different, and i have no idea how to fit it in
This little piece was missing when I opened my phone, seems it was lost last time I sent it to the repair shop for screen replacement.. :-( but it does take pictures
My iPhone 4s Logic board is water Burned when i was 3 years old I took my dads phone and threw it to washing machine that was set on 50 c and it won’t turn on I need help it was brand new it was four or three days old I need everything that was on that phone pls respond
Wedge the plastic opening tool between the vibrator and the side of the iPhone.
Pry the vibrator up to release it from the adhesive securing it to the iPhone.
Remove the vibrator.
How do you reinstall the vibrator? Can the adhesive be used again for the reinstallation or do you need some new adhesive pad for installation?
Very tacky adhesive. It is reusable. It also took the kind of slow, hard leverage the battery requires to remove.
griffn -
Remove the two 2.4 mm Phillips screws from the sides of the speaker enclosure assembly.
Remove the small plastic bracket that was installed under the screw closest to the dock connector cable.
Rounded screw on the black metal piece.... fml what should i do
What to do if I lost the bracket? Without it, the screw really has no purpose, as the left side of the speaker enclosure assembly just slides up past it and the wifi grounding fingers slide up from under the lip.
I could not see it and flipping over the phone, or what’s left of it, it dropped. Where to put it back though ?
Remove the speaker enclosure assembly from the iPhone.
Careful not to lose the tiny rubber spacer that sits below the mic enclosure - I nearly did as it is not mentioned here, probably because it rarely comes out. See mention and photo of this in this guide, step 20: Dock Connector Replacement
I had some problems with the cellular cable during re-installation. It actually had gotten scratched to where the wire was actually worn and the silver cable was visible. I discovered this once it was all closed and the phone's cellular status was always "Searching...". A little bit of electrical tape over the exposed area seemed to take care of this.
Successfully reinstalled the display, but now the lower speaker doesn't work. I'll have to reopen it to find out what's up. So many possibilities for error.
I "lost" one of the screws securing the speaker, but re-assembled it anyway without the RH screw. Everything worked; then I realised where it might have gone. The speaker has a magnet which will attract any loose screws nearby. Sure enough, that's where I found it when I opened it up again.
I was trying to get the little triangle spacer in place to get the speakers installed. I had it in some tweezers trying to see what I was doing wearing some magnifying goggles, when the spacer shot out like a watermelon seed from between your fingers....Never got a clear view of where i went but it looked like it went sailing over into a part of the room where there is loads of little small bits+pieces in loads of other bigger boxes and containers...it sailed off into the land of the lost. I'd be lucky to happen to see the little booger during spring cleaning...I won't hold my breath. Anybody know where i can buy such a thing?
edit- I made a replacement out of some scrap plastic . Doesn't look too bad. Not sure about thickness. So I'm just gonna put everything back together and hope for the best.
buy a equal phone that is perhaps destroyed AND locked . that is how I have replaced many parts I have done what you have done . I now have parts I may never use but ... who knows I just aim for the phones I have extra parts for
As ++hutchwilco++ mentioned don’t forget to put back the rubber spacer on the bottom right side of the speaker (as seen on picture from step 29). Comes on the bottom of it, between metal bezel and speaker.It is a marking on the speaker.
I’ve seen mine and I have struggled to find it’s place.
Remove the small pieces of black tape covering the display mounting tabs.
Remove the 1.5 mm Phillips screw securing the display assembly near the power button.
Remove the 1.5 mm Phillips screw near the headphone jack.
Be very careful when removing this screw, as the angle of your screwdriver may risk stripping it. In order to be 100% safe, it may be worthwhile to remove the headphone jack connector. (There is a guide to do this as well.)
I've never taken this phone apart before and this screw is missing entirely.
sarawr -
This screw, as well as being difficult to get to in order to remove it, is very difficult to replace. Much patience is required as you can't get the right angle on the screwdriver to start with.
I suspect, given there are 10 screws holding the screen in !!!, that this one could be left out during a rebuild... especially as 'sarawr' mentioned her phone didn't even have one in in the first place.
I also had problems getting at this screw, you really need to move to Step 27-31 of removing the headphone jack.
iPhone 4S Headphone Jack Cable Replacement
Don't recommend going any further and messing with the antenna. Then resume to step 34. Likewise ensure you back track when reassembling.
I too had difficulty removing this screw, mainly because the ifixit bit driver is somewhat fat and gets in the way. Luckily, I had bought the replacement screen from iCracked and their provided screwdriver was somewhat thinner.
Be careful with this and have patience!
This screw was very difficult to reinstall. I spent 50 minutes and much patience to get it back in without stripping it. I thought about not reinstalling it but pressed through making the job "complete" with no left over parts. The great thing is the phone works well saving a ton of money not having to replace it.
Yes, this screw it's hard to reinstall. Here is what worked for me. I put the screw carefully on the side of the magnetic bit driver. Then I carefully aligned the screw perpendicular to its hole. Then I applied just a little bit of force to seat the screw in the hole. I carefully slid the screwdriver away and the screw stayed there in the right alignment. Then I went back in with the screwdriver and very carefully tightened it, making sure that it was threaded properly. It worked.
Brilliant tip.
chris -
Be careful "pushing aside" the headphone jack! I wanted good access to the upper-right display screw so I attempted to move the jack. It is not easy to tell that the jack is tethered to the secondary mic which is visible just to the left of the jack in the photo. The secondary mic needs to be removed at the same time as the jack. I broke the secondary mic off, and then needed to replace the headphone jack/secondary mic/volume button/mute button flex, which is an even harder repair!
I had exactly the same thing happen, cpwittenberg! Be careful, everyone who decides to take off the headphone jack! That secondary mike attachment is VERY easy to tear off.
suzanneb -
This screw stripped for me, I tried a few different 'tricks' to get it out. (Rubber band, super glue, even solder) Nothing worked. I ended up just snapping the display off of it, then snapping the corresponding piece on the new display.
Remove the 1.5 mm Phillips screw near the lower microphone.
For the re assembly of those ones , first locate the two slightly larger screws which goes on top of the iPhone and use a long philips magnetic screwdriver which use the edge of the iPhone as a guide to re assemble those screws . otherwise it will get on your nerves . When doing that , be sure the screen is properly flush with the frame .
Remove the 1.5 mm Phillips screw near the dock connector cable.
Loosen the three large-headed Phillips screws along the volume button side of the iPhone about one half turn.
Two of these screws refused to budge so I had to use a pair of pliers to carefully loosen them.
I almost finished, but 2 screws won't come off! Now I'm stuck.... the screen broke off, but I can't put the new screen in because the prongs from the old screen are still stuck. Any advice on loosening the last 2 screws?
I can not get two of the washers out they wont even losen just a little :/ my hands are hurting and i just dont know what else to do i have searched and searched in hope to fine an answer and can not PLEASE HELP!
Cling wrap, 1-3 layers between the screwdriver and the screw, helped me get the grip i needed.
Also, I found if I put the phone on it's side for this step, I could screw straight down against the table and put more force into it.
My iPhone was missing one of these screws, but the two left they came out easily. I also tried the half-turn technique but gave up after washers were jammed or on the wrong side. I had no difficulty removing these completely and refitting them properly.
Other than raiding a dead iPhone, does anyone know where I could buy two additional screws with washers?
I also had problems here. I needed to use quite pressure, and find best bit. For me it was PH000 from Ifixit's kit.
Loosen the three large-headed Phillips screws along the other side of the iPhone about one half turn.
I found that I had to remove the 6 side screws and washers completely, because the new front tabs were bent inwards. To reinstall them all, I supported each screw on the up-facing tip of a magnetic screwdriver, then I placed the washer onto the screw with a tweezers, and then I inserted the screw upwards into its hole, never changing the orientation of the screwdriver.
Magnetic screwdriver, washers on the end. Brilliant tip, thanks.
chris -
It is very easy and helpful at the end of this step, to gently push down the screen holders in the 6 spots with screws and washers, that way the screen gently comes out and you don't have to poke with anything.
I had to cut out some of the flaps of the new screen in order to fit (also one of the corners like on step 31)... I have no idea if the replacement part was bought wrong or if it was a compatibility issue (my iPhone 4S was bought in London and the replacement from iFixit).
help me, i have one sweep screw on this point
Use the edge of a plastic opening tool to gently pry up the display assembly around its perimeter.
While removing the Front, a black rubber piece fall off and I have no idea where it came from.
Has anyone a suggestion?
Same here. Anyone any idea where it belongs?
Found it - it can be seen on the photo of step 22 right above the QR code.
If you cannot easily get the plastic opening tool in, you can gently push from the back in the corner near the head phone jack, where you can see a bit of black at the bottom. The black part is part of the display assembly.
Thanks for tip. I couldn't get anything started with the pry tool. Pushing a glass panel from the back seemed rough, but it worked.
griffn -
CAUTION with inserting plastic tools to make a lever and pull up the LCD. I've inserted a guitar pick too deep in the corner and I've broken the LCD. It's very very sensible component; now I'm a believer! :) It's much better to suck it with a suction cup or to push the LCD out by the back side (use the tiny metal part where the screw goes).
great tip! THANKS
Found using the small suction cup to help pull the screen up and then used the opening tool to pry apart.
I’ve struggled a lot with this step.
My solution was to use a suction cup placed on the middle or middle/left or right of the phone.
The sides of the display come off easier in the middle area (display is bending easier) therefore you can place a guitar pick tool
in between and make your way up to the upper part of display then on the bottom side of display.
Remove the display assembly from the iPhone.
When you reassemble the device, be absolutely sure that the digitizer cable is pulled all the way through the slot ...it tends to get stuck since it has a sharp edge for whatever reason. Failing to notice that, the digitizer cable wont reach its socket. But not only that! Pressing the display against the case will introduce a more or less sharp bend to the cable which likely results in a broken digitizer cable, hence a broken digitizer!
Tobias is absolutely correct. It is imperative that you carefully straighten and feed the digitizer cable through so it has enough strain relief to make the connection. The key is to fold it up and once fed through, make sure it is as tall as it companion. Fail to do this and you have to take everything apart as it won't mate to the logic board ... yeah ... I had to do this.
Rayeng -
Also, depending on the condition of the old (broken?) display, watch for any debris/glass fragments that may obstruct re-assembly. I found that the replacement I was installing wouldn't sit flat, until I checked closely and found a *tiny* sand grain sized bit of glass off to one side of the home button. Once that was removed, the new display fit just fine. It probably can't be emphasized enough not to force anything; if it doesn't fit right, check it - and keep checking until you find the obstruction.
Orac -
Snapped my digitizer cable by trying to pull it. apparently it just wouldnt fit on the logic board!!!
When putting everything back together, if you encounter "searching" for long time for your wireless signal, just manually set time/date and restart phone. It worked for me!
KF
Use step 39-40 of Home button replacement. Be careful not to tear gasket and don't go further and remove gasket.
Once my screen was removed, a piece of rubber fell out of the phone onto my work surface. I sweated and looked for half an hour, at the frame in my hand and at all the photos in the guide, for a place that it might fit. I eventually gave up, and my phone has been working fine without it, but where is this piece supposed to go?
I had the same exact thing happen to me. I couldn't see where this piece came from either. Just like you, I gave up and reassembled my phone. It works just fine. I still held on to the part just in case, but I don't expect any problems.
It's been a month now, and I've been using my phone with no problems at all. Battery life is great, it has all sorts of reception, and there are no unusual sounds as the phone is shaken or put under pressure. Whatever that piece is, I feel like it's not important enough to put back in.
I didn't remember to look inside the iPhone 4S for this piece of rubber but I believe they are present in both AT&T and Verizon iPhone 4's. The rubber wraps around the edge of the main logic board where the display and digitizer cables wrap around. It's not needed for proper operation but may protect the cables from long term flex and wear against the edge of the board.
It attaches to the logic board by where the cables for the display assembly sit next to it. I guess it protects the cables from the hard edge of the logic board.
When you are putting the new screen on make sure the little wires are pulled all the way through! or else you will be very frustrated 15 steps later and have to go back again.
To add to the last comment, one of the of the digitizer cables was was too short. I disassembled it twice to figure out it was folded. When I straightened it out it snapped. A 12.0 repair turned into over a 100.00 when I had to replace the screen assy. But, still cheaper than a new phone.
If you use an aftermarket replacement, the backlight might flicker until you temporarily disable autobrightness or let it sit for up to 6 hours. There's quite a few comments about this on other forums but figured one here would be relevant. Otherwise, this was great.
Broke my digitizer cable. %#*!^@. This is by far the hardest part. Failure is here. :(
When removing the screen from the casing, a screw fell out from somewhere - I have no idea where from or what it does - anyone have any ideas?
Oh, and all screws I removed are accounted for
Tim -
I'm having an issue with the front camera's clear plastic ring.
When I try and put the replacement front display on the front the ring does not seem to line up with the camera.
Any tips?
Try putting the ring around the camera itself rather than adhesing it to the new screen and trying to line it up. Its a simple solution but I admit I certainly didnt think of it right away and had the same trouble as you
Nick has the right answer- the grooves on the ring will slide into the gap around the camera. I realized this the hard way by glueing the the ring to the display side. Luckily I was able to get it off without totally destroying it.
+1 for the tip of Nick Hughes.I spent 10 minutes trying to figure out why the front screen was not aligning, thinking it was one of the six washers that were misaligned. Then I noticed that there was pressure around the front-facing camera when I tried to push together the parts near the top edge. As my front-facing camera wasn't exactly aligned the way the glued-on plastic ring was aligned, all the jiggling I tried did not fix the problem. I took the ring off the front panel and dropped it in around the camera and after a few tries, I got the alignment.
henning -
Fellas, is it possible to detach digitizer from the front cover? I got this pink front cover I want to install in my GF's iphone, but it came without a digitizer? So can I just remove the old digitizer and install it into the new front cover?
Did everything to Step 37.. then Step 38 (yep the step of replacing the screen) almost discouraged me due to the presence of the rubber-like ring on the replacement screen (around the back camera). Since this ring was also present on the phone body, both prevented the new screen from fitting nicely. It wasn't obvious for me at first until I forcibly removed the ring from the replacement screen. Re-screwed every piece and it works like charm!!!
A serious recommendation for anyone attempting repairs: get the toolkit from iFixit!!! Don't also forget the magnetic mat - it is a MUST!!!
Look closely at the digitizer cable before you reinstall the screen. The cable is wider at its base and that part sits flush against the panel when you receive it. It doesn't look like it goes quite alongside the display data cable, but it does; do a quick check to make sure that both are the same length, and if they're not, look to see if the wider part of the cable is not pressed flat. You'll need every millimetre of length to connect it properly.
Also, you might be tempted to believe that the digitizer cable goes through the small hole above where the display data cable goes (it's pretty hard to see where things came from when you first remove the display). It doesn't; it nestles right against the display data cable. If you try to put it through the small hole, you're apt to rip the top off it by accident. There's really nothing more frustrating than painstakingly taking apart an iPhone only to break your replacement part.
Getting the digitizer cable threaded without having it fold or kink is, without question, the single hardest part of this whole repair. Everything else requires just being meticulous, measuring twice and cutting once, and making sure you use a reasonably light touch when detaching contacts, etc.
And after 37 steps (o hai Hitchcock!) you feel like you're home free.
But the digitizer cable is the last henchman between you and the Bond villain, the last lock protecting the treasure.
After you've threaded it through, pull GENTLY to make sure it extends fully (both cables should be about the same length), and check on the underside to make sure there's no fold. This is where a mm or two makes ALL THE DIFFERENCE. Keep checking it occasionally as you screw down the screen, because you don't want to have to go back after you've installed the logic board.
And I've replaced with both iFixit kits and 3rd party screens. The cable is always an issue-- but with patience they DO extend far enough.
Agreed. Had to troubleshoot by tearing the iPhone again only to notice this stupid mistake, digitizer cable was ripped.
It is very sensitive, be very careful.
Ditto on not pulling too hard on the digitizer cable. Mine tore trying to reassemble. There went $20. Reassembled with my cracked screen until I can get another replacement. Now I know and knowing is half the battle....
Hi guys , i’m having problems when mounting the new lcd. In particular, It is very difficult to make it “completely” fit inside the metal “frame”. As long as I apply force, it stays in, but as soon as I stop manually keeping the frame and the new screen together, it just disassemble. When I try to fasten the 6 lateral screws (see steps 35-36) it barely holds together, with the “corners” moving out of the frame and making it impossible to fast the 4 corner screws (steps 31-34).
Any suggestions ??
Remember to switch the home button from your old display to the new display (in most cases, this is not provided). The home button gasket is thin rubber, so care must be taken not to tear it. Also, check that the mesh for the speaker hole is present in the replacement; if not, move it over from the old display.
Be sure to peel off the protective backing (usually blue or pink) from the new panel before installing it.
If your replacement display does not come with a 7 mm clear plastic ring surrounding the front-facing camera, be sure to transfer it between the old and new display.
can some one tell me how to test the new display before reinstalling it?
How do I stick the speaker mesh and plastic ring back on?
Careful, when I removed the blue plastic coating on my replacement display, it peeled up the silver sheet component too. make sure the sheet separates properly
The 7mm plastic ring can be a pain when refitting the display.
But it's your lucky day because It only takes 2 extra steps to remove the front camera and make it a lot easier. ;-)
My replacement display from the ifixit kit is slightly thicker than the original. It is hard to spot, but you will feel it when using the home button.
My old front was sufficiently cracked that the camera ring is long gone. Hope it work anyway!
I found that the corner holes for my new display would not line up with the old frame & I wasn’t able to get one of the small screws in. My suggestion is to check this to make sure there is adequate exposure of the threaded hole. If there isn’t use a Dremel grinder to raise the level of the corner holes in the new display, being careful to not get grinding dust over everything. This should be done before the protective pink film is removed from the new display.
Carefully straighten the digitizer and LCD data cables, and feed them through the slot cut in the outer case.
This photo shows the display assembly being installed incorrectly, with too much slack in the digitizer cable, which then forms a bend/loop that gets caught in the slot. The third photo also shows this loop.
the picture on the right is the wright one
I made a very dumb mistake and ripped the cable.
It is very sensitive, I cannot address how important patience is with this step :D
Be VERY careful to ensure that what you see when you're doing the repair matches the picture showing the 2 cables approximately the same length. It's really easy to trap the rear cable
I’ve accidentally bended the digitizer cable, not too much, but after reassembly the iPhone the whole screen went white with flickering vertical lines. I messed up the LCD. Be very carefully! this is a very sensitive cable.
During reassembly, do not touch the metallic area at the base of the LCD data cable, as this can cause problems with the LCD. If you do touch it accidentally, clean it gently with an alcohol wipe before continuing.
After reassembly, protect your new display from any scratches by installing a new screen protector.
I did everything as in the guide (or at least I hope), I reassembled the phone and everything but when I connect it to the charger continues to make a sound and will not turn on.
What does it mean?
have you found any solution ?? Because i have the same problem and i have no idea about what to do
MWino -
Try re-seating the dock connector cable. The charger connection goes through this connection to the iPhone.
So my screen works, ive connected to my network, and i can even make phone calls. but im getting terrible quality of sound from the top speaker. anyone know which part i may want to clean/check the connection on?
I have the same issue, did you find a solution?
After reassembling with new screen, plugged into charger/computer the phone just repeatedly says "blunk". Once I re-plugged in the old screen, it worked fine. No bunks. I assume this means the phone boots up (~1m), then blunks if it can't get the screen. Amazing tutorial, but a tricky and time consuming venture. I'm about 8 hours in, with a half-dead phone.
After following the guide to the exact, front-facing camera does not work properly.
Anyone know how to fix this? You go into camera app, click to turn it to front-facing, it trys to come on put gets stuck and goes to what looks like it is trying to focus? Sorry it is hard to explain.
Before screen replacement, I believe it was working, not 100% for sure though.
did you forget to reconnect the front facing camera cable?
When I finished the repair, the touchscreen was no longer working and it said it was disabled for over 3000 minutes. Was there something I did wrong in the repair or was this out of my control?
Why should i connect the iPhone to the AC first?
+1 on this one
Cracked the screen yesterday, thought it was the little clear ring that went around the front facing camera but it was a little rectangular piece that may have been for the proximity sensor. Bought a new screen which had no such plastic piece and all went back together smoothly with the front facing camera ring in place.
The clear ring for my replacement screen was installed about 90 degrees out of alignment. New screen failed to come together with the case frame. I carefully removed and replaced it in the correct orientation. Not sure what adhesive to use…used very small amounts of clear Gorilla glue…awaiting drying results.
I'm no stranger to replacing screens, but having read through this I decided to buy a secondhand replacement 4s phone instead.
Use the edge of a plastic opening tool to gently peel the bottom right corner of the home button assembly from the display assembly.
Just push the home button from above through the glass until the gasket is separated from the glass
Use a pair of tweezers to peel the home button assembly off the adhesive securing it to the display assembly.
Remove the home button assembly from the display assembly.
Remove the home button from the home button gasket.
do i need to put that adhesive on the gasket or do i need to by another .
Home button gasket remains.
crwdns2935229:068crwdne2935229:0
I followed this guide to replace my home button ribbon and home button because it was slightly chipped. I left the original gasket. After going through 2 hours of work and assembling it back together i found that my button is not able to be pressed. it does not "spring" up when pressed. could i have placed the gasket wrong or something? what is your take? I have to take it apart again!!! :'(
Hello i had the same issue , did you find out what was wrong??? Please if you see please answer
Vasilis -
Can the rubber gasket be reused?
I am also trying to figure out why my home button is now not able to be pressed after I place the screen back in. Does anyone have any ideas?
The Liberation Kit just stripped the screw. Now what.
nimpsy - crwdns2934203:0crwdne2934203:0
Had local iPhone repair shop remove the screw. Repair complete!
nimpsy -
I left the battery in and everything above the middle, using a pen knife to flex the logic board, I had plenty of room to else the old out and the new in.
Worked well and saved a lot of time.
Keith M - crwdns2934203:0crwdne2934203:0
After reviewing the steps I decided to follow this guy's advice and left the battery in.....one less item to possibly foul up. I don't know if it made it any faster (first time to open my phone, so nothing to compare it to) but I can say that my phone is charging for the first time in 6 months :D
Jennifer -
BEFORE YOU START:
1) This is doable but not easy, quick or without risk.
2) If this is your 1st time, the whole process can take >2 hours (half of it reading this fixit manual and notes, which I highly recommend!)
3) I highly recommend placing a large, thin clean white cloth on the table. This prevents screws from rolling around and you will clearly see anything falling out.
4) If you have them, use tight surgical (latex) gloves. This prevents you from greasing up contacts.
5) Have e.g. a big old egg box ready, so you can place the screws in order (and maybe write step/screw size on the side).
6) I bought my display from "Generic" on Amazon ($20.36). Screen works fine and tools were ok but not great (screw drivers do not withstand force needed to unscrew some).
7) I had my own 2mm Phillips screw driver and a 2.4mm flat (for the big screws).
8) Have a nice cold beer by your side! Good luck!
superedu111 - crwdns2934203:0crwdne2934203:0
Sounds like this comment relates to a screen replacement, not a rear panel replacement. No way a rear panel replacement would take 2 hours - can be done in 2 minutes!
Jonathan Deamer -
I was paranoid about stripping the pentalobes - I used the ifixit pentalobe screwdriver TOGETHER with a layer of Glad Wrap (cling film or saran wrap for the non-Aussies) over the pentalobe holes - absolutely no problems. Guess it helps the driver head gain purchase?
Anyway hat tip to this guy:
http://modmyi.com/forums/hardware/806092...
jimforbes - crwdns2934203:0crwdne2934203:0
It's also called glad wrap in the US as well. :)
Scorppio500 Webmaster -
After seeing the comments about trouble finding the carrier, I shut down the phone, did a soft reset (by holding the power and home buttons until it started and then shut down and stayed off), and removed the SIM. After the repair, I replaced the SIM and plugged it in to the charger. It started up and found the carrier (Verizon, as it happens) immediately. I would guess that only the soft reset made a difference, but I did both.
DavidLewis - crwdns2934203:0crwdne2934203:0
Thank you David, will I need to reload operating system if I replace thr logic board? I'm hoping to use a 32gb boards from a locked but working phone to place in my 8gb device. Thanks for your advice,
Sharif
Sharif Bagnulo -
I pried one end of the back off only to find 2 funny little screws holding the other end on so I took my Dremel, like Jack said, and ground those suckers out. Once I had the back off I loosened all the screws then turned it upside down and shook the crap out of it. The screws went flying everywhere and fell on the floor. Its my moms house so of course she's got gross brown carpet. How am I supposed to find my screws in that? I get the vacuum out and go over every inch of the floor to suck up all them screws. Then I dump the bag on the table and all I find is a bunch of hair and gods knows what else, but no screws. When I look for my phone I see its covered in all that stuff that came out of the vacuum. I mean, what's up with that? How can I work on my phone if its covered in dirt? Nobody said anything about that, did they? The average guy's gonna screw up his phone big time if he follows these instructions and nobody warns him about all the dirt that's gonna end up in his phone. Are you kidding me!! Now what?
Marv - crwdns2934203:0crwdne2934203:0
Here's a little vacuum trick for anything small: put nylons/panty hose over the end of the hose and then you don't have to dig thru the bag contents.
paul -
Marv you a first class pleb! Please don't try and fix anything again. Tool
ticklejahfancy -
It's clear who's at fault here, Marv.
It's as clear as the day has long legs. It's your Mom's fault.
Milfs who make earth-tone carpet choices, are more likely to twerk, than tweek.
And as far as trimmin the hedges are concerned, she's more likely to float a turd in the punchbowl,
than to give you your inch.
I know you think I'm crazy. But everyone else agrees. We all politely try to the other way...
Your cuck stops here. We'll not near me, go over there...
Nathan Brazil -
my screws are stipped and i am going though the front glass to get to the logic board could some one give me a guide on how to get to the board please... thanks
Caleb Croft - crwdns2934203:0crwdne2934203:0
all you need to do is remove the clip over the wifi antenna and the one that actually attaches the wifi antenna to the iphone two steps to do this job...
Ray Leahy - crwdns2934203:0crwdne2934203:0
The physical battery replacement went off without a hitch, and saw that the phone had no network connection, but also had no way to unlock. The slide lock said "Slide for Emergency Call" over my custom wallpaper and sliding would give the passcode screen, but it would reject the 6 digit passcode (it would buzz and go dark after the 4th digit, re-awakening and putting in the last 2 would indicate bad passcode). Very frustrating! I get it into recovery mode and convinced iTunes to "update" the OS, but it still didn't let me in. I performed a restore to fully factory reset the phone, and it worked! Sort of... the start screen kept being replaced by "Temperature - phone needs to cool down" but it's cold. Temp sensor is on the battery and returning to old battery fixed it. New battery is bad, and phone is wiped. Fun night.
I'm going to guess that disabling the password might save you from a similar fate. So, I'll suggest BEFORE YOU START, backup your phone and disable the passcode. Good luck.
Ian Epperson - crwdns2934203:0crwdne2934203:0
Same here.. Going through that terrible night myself! Guess you had to return your battery right?
Nuno Alves -
Is it possible to replace front glass only? If so, please provide a manuel
Iva - crwdns2934203:0crwdne2934203:0
Yes, it is. But it's very difficult and risky. Forget it... Have a look here: https://youtu.be/L_kCY05jR10
Jiri Altman -
I didn’t find this particularly difficult, even though I’m pretty inexperienced at this sort of work. I watched the video overview to get me going and then followed the steps in the guide. My tips would be to keep the screws and parts organised as you dismantle, and ensure you read all the reassembly tips as you go; it’s easy to skip over them. I also found using the Liberty Kit to replace the pentalobe screws was worthwhile.
Poor old Marv of Feb 2015. Suggest he sticks to chopping logs.
graemebagnall - crwdns2934203:0crwdne2934203:0
caught fire as soon as I replaced the back phone destroyed
Stuart Laurie - crwdns2934203:0crwdne2934203:0
The battery on the phone is swollen so I need to replace it but I can’t turn it on to drain the battery, what do I do?
Beetroot - crwdns2934203:0crwdne2934203:0
sry i'm really late but your best bet is to get isopropyl alcohol (90% or higher!) and apply many drops to the top and wait 1 minute then get a spudger and carefully gently pry it out.
Jake Jackson -
anyone here from 2024? Anyway, I replaced a good phone with a locked logic board with a bad phone with an unlocked logic board and it worked! I'm so happy but sry to the folks who didn't successfully repair it.
Jake Jackson - crwdns2934203:0crwdne2934203:0
