Use this guide to replace a cracked or broken back glass (aka back cover or rear glass) in your iPhone 16 Pro Max.
You'll need replacement back glass adhesive to complete this repair.
After your repair, calibrate authentic Apple replacement components using Repair Assistant.
Unplug any cables from your iPhone.
Hold the power and either volume buttons, and slide to power off your iPhone.
If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
Use a P2 pentalobe driver to remove the two 7.4 mm-long screws on either side of the charge port.
Measure 3 mm from the tip and mark the opening pick with a permanent marker.
Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
what fix kit?
My fix kit didn't include an opening pick either
Make sure you check inside the black boxes after emptying them. My pick was stuck inside one of the boxes.
My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
It's not an Ifixit KIT if it doesn't include everything. You'll need to order the opening pic separately. Or head to Walmart like myself and look for guitar pics. Hopefully, this will work just as well.
No pick in mine as well. It’s really not clear that you have to order this separately when ordering an IPhone SE 202/2022 screen repair kit. Is this the case?
Frustrated, I ordered a compact package where everything was encapsulated. Useless suction tools could not separate the screen. If it is unable to decouple the screen, then why sucking suction tools you have provided.
For my kit the triangle pick was stuck inside the box with the screen not with the other tools maybe it's also there for you
Y’all are getting far, FAR too detailed with some of this stuff…. Measuring and marking the pick that you won’t actually use to open the device?!? lol that’s kinda funny. Just heat it up, grab a spudger, and the back just pops right off! The iFixit tech need to stick to the KISS method more often, you know KEEP IT SIMPLE STUPID!!! Like l, for reals, I’ve been doing this stuff for YEARS and using iFixit guides regularly and this is just ridiculous at this point!
Will the phone still work if the sensor assembly on the back of the screen is damaged?
crwdns2935267:0crwdne2935267:0iOpener$12.99
Use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
Apply a suction handle to the bottom edge of the back glass.
Pull up on the handle with strong, steady force to create a gap between the back glass and the frame.
Insert the tip of an opening pick into the gap.
A delicate cable connecting the back glass to the iPhone, right next to the volume up button. Don't insert your pick here to avoid slicing the cable.
Multiple spring contacts around the perimeter of the iPhone.
Slide the opening pick along the bottom edge to slice the adhesive.
Leave the opening pick in the bottom-left corner to prevent the adhesive from resealing.
Use a hair dryer or heat gun to heat the left edge of the back glass until it's hot to the touch.
Insert a second opening pick into the bottom-left corner, close to the existing pick.
Slide your pick along the left edge to separate the adhesive and release the metal clips.
Leave this pick inserted in the top-left corner to prevent the adhesive from resealing.
Use a hair dryer or heat gun to heat the top edge and top-right corner of the back glass until it's hot to the touch.
Insert a third opening pick into the top-left corner.
Slide the opening pick along the top edge and around the top-right corner, stopping above the volume up button.
Leave this pick inserted to prevent the adhesive from resealing.
Use a hair dryer or heat gun to heat the right edge of the back glass until it's hot to the touch.
Insert a fourth opening pick into the bottom-right corner.
Slide the opening pick around the corner and up the right edge, stopping below the volume down button.
Swing open the back glass to the right of the iPhone to separate the remaining adhesive.
Support the back glass with a clean, sturdy object.
Use a tri-point Y000 driver to remove the three screws securing the battery connector cover:
Two 1.3 mm‑long screws
One 1.0 mm‑long screw
Lift and remove the battery connector cover.
Use the point of a spudger to pry up and disconnect the battery press connector.
Use a tri-point Y000 driver to remove the four screws securing the back glass connector cover:
Two 1.0 mm‑long screws
Lift the back glass connector cover straight up and remove it.
Use the point of a spudger to pry up and disconnect the back glass connector.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use blunt nose tweezers or your fingers to remove large pieces of adhesive from the frame perimeter.
Use a spudger to scrape the adhesive residue off of the frame.
If the adhesive feels stubborn, apply some heat using a hair dryer or heat gun and try again.
crwdns2935267:0crwdne2935267:0Microfiber Cleaning Cloths$3.99
If you're reusing your back glass, apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to a microfiber or lint-free cloth and wipe around the perimeter to prepare the surface for new adhesive.
Wrap a lint-free cloth or a coffee filter over the point of a spudger and apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to it.
Wipe in one direction along the perimeter of the frame to clean the adhesive residue.
Lay the adhesive sheet over the frame to determine its proper orientation.
Grab the tab in the corner of the adhesive sheet and peel the liner to expose a third of the adhesive.
Carefully align the exposed edge of the adhesive strip with the corresponding edge of the iPhone's frame.
When it's correctly aligned, gently press the exposed adhesive strip onto the frame.
Continue peeling away the liner from the adhesive, gently pressing the adhesive into place.
Use a spudger to press the adhesive around the entire perimeter of your iPhone.
Use a spudger or your fingers to lift the pull tab connected to the large front liner. The pull tab is often in a corner of the liner.
Use the pull tab to peel off the large front liner from the adhesive.
Prop up the back glass along the right edge of your iPhone.
Use your finger or the flat end of a spudger to press and connect the back glass connector onto the logic board.
Use your finger or a spudger to press and connect the battery press connector onto the logic board.
Align the back glass connector cover by its screw holes and lay it in place.
Use a tri-point Y000 driver to install the four screws securing the back glass connector cover:
Align the battery connector cover by its screw holes and lay it in place.
Use a tri-point Y000 driver to install the three screws securing the battery connector cover:
Use your fingers or a spudger to peel away all perimeter liners, exposing the adhesive.
Check the frame and back glass for any stray liners and remove them. There should be no liners remaining.
Lower the back glass onto the frame, beginning with the top edge.
Press along the edges of the iPhone until the back glass sits flush against the frame.
Use a hair dryer, heat gun, or an iOpener to heat the back glass perimeter until it's slightly too hot to touch.
Use your fingers to firmly squeeze around the perimeter of the iPhone.
Place your iPhone screen-side down on a clean, flat work surface.
Lay a strip of tape around the perimeter of the back glass to protect the finish.
Stack coins around the perimeter of the back glass until you create a wall that's as tall as the rear camera protrusions.
Place 3-4 heavy books squarely on top of your iPhone.
Leave the books in place for about 30 minutes.
Use a P2 pentalobe driver to install the two 7.4 mm-long screws on either side of the charge port.
After your repair, calibrate a genuine replacement part using Apple's Repair Assistant. Navigate to Settings → General → About → Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
crwdns2935229:05crwdne2935229:0
Gracias por todo lo que hacen por los demás. Dios me los bendiga
coooool but l need help because its broken like broken
