Use this guide to replace a broken earpiece speaker in an iPhone 14 Plus.
This guide was created using the A2886 (international) model. If you're fixing a different iPhone 14 Plus model, there may be some visual discrepancies, but the procedure should be the same.
You’ll need replacement adhesive to reattach the screen when reassembling the device. Your device will function normally, but will most likely lose its IP (Ingress Protection) rating.
Power off your iPhone before beginning disassembly.
Remove the two 6.8 mm-long pentalobe P2 screws at the bottom edge of the iPhone.
Measure 3 mm from the tip and mark the opening pick with a permanent marker.
Lay overlapping strips of clear packing tape over the iPhone's rear glass until the whole face is covered.
If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the rear glass with that instead.
Use a hair dryer or a heat gun to heat the bottom edge of the iPhone for 90 seconds or until the rear glass is slightly too hot to touch.
Apply a suction handle to the bottom edge of the rear glass, while avoiding the very edge of the glass.
Pull up on the suction cup with firm, constant pressure to create a slight gap between the rear glass and the frame.
Insert an opening pick into the gap.
Use a hair dryer to heat the left edge of the iPhone for 90 seconds or until the rear glass is slightly too hot to touch.
Slide the opening pick around the lower left corner and up the left edge of the iPhone, slicing through the adhesive holding the rear glass in place.
Use a hair dryer to heat the right edge of the iPhone (the edge with the power button) for 90 seconds or until the rear glass is slightly too hot to touch.
Re-insert your pick at the bottom edge of the iPhone, and slide it up the right side to continue separating the adhesive.
Use a hair dryer to heat the top edge of the iPhone for 90 seconds or until the rear glass is slightly too hot to touch.
Insert your pick underneath the top right edge of the phone. Slide it around the top-right corner and halfway across the top edge.
Insert your pick underneath the top-left edge of the phone. Slide it around the top-left corner and halfway across the top edge.
Remove your suction handle from the rear glass.
Slowly open your iPhone by swinging the rear glass up from the left side, like the back cover of a book.
Lean the rear glass against something to keep it propped up while you're working on the phone.
If you don't have anything at hand to lean the rear glass against, your suction handle can do the trick.
crwdns2935267:0crwdne2935267:0Magnetic Project Mat$17.96
Use a Y000 screwdriver to remove the two 1.3 mm-long screws securing the battery connector cover.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use the pointed end of a spudger to disconnect the battery cable by prying the connector straight up from its socket.
Bend the connector slightly away from the logic board to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
Use a Y000 screwdriver to remove the single 1.0 mm-long screw securing the charging coil connector cover.
Use a pair of tweezers to remove the charging coil connector cover.
Use the pointed end of a spudger to disconnect the charging coil cable by prying the connector straight up from its socket.
Remove the rear glass assembly.
Use a Y000 screwdriver to remove the two 1.2 mm-long screws securing the front-facing camera assembly cable bracket.
Use a pair of tweezers or your fingers to remove the front-facing camera assembly cable bracket.
Use a spudger to disconnect the camera and the sensor cables by prying the connectors straight up from their sockets.
Use a pair of tweezers or your fingers to remove the front-facing camera assembly.
Use a spudger to disconnect the antenna cable by prying the connector straight up from its socket.
Insert the tip of a spudger under the top left corner of the antenna.
Pry up to separate the adhesive under the antenna.
Remove the antenna
Use a spudger to disconnect the earpiece cable by prying the connector straight up from its socket.
Use a Phillips screwdriver to remove the eight screws securing the earpiece speaker.
Three 1.6 mm-long screws.
Two 1.7 mm-long screws.
One 1.1 mm-long screw.
One 2.1 mm-long screw.
One 1.5 mm-long screw.
Use a Phillips screwdriver to remove the 1.1 mm screw securing the earpiece speaker to the frame.
Use a pair of tweezers or your fingers to remove the earpiece speaker.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
