iPad Air 2 LTE Display Assembly Replacement
  1. iPad Air 2 LTE Display Assembly Replacement, iOpener Heating: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement, iOpener Heating: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
    I'm sorry, but I started laughing uncontrollably at this point! It's like something out of a Conan or Fallon sketch for the all but non sequitur of microwave use, but it's clearly what needs to be done for the glue. I came from a 2007 MBP, and personally replaced the battery multiple times (one step). I was curious about how it was done with my new 2014 model. 32 steps might as well be a punch line...
    JeffH - crwdns2934203:0crwdne2934203:0
    Hey cut them some slack. There are some really stupid people out there and we don't want some one to end up with their dick caught in the ceiling fan.
    logitechtaco -
    which temperature must be used for heating? Thx
    fbarletta - crwdns2934203:0crwdne2934203:0
    A hairdryer works well - hot to the touch is enough to soften the glue to allow it to come off.
    Gavin -
    They do not use glue to attach the glass. It is very strong double sided 3M tape.
    Odus182 -
    a hair dryer might not be enough. If the temp is too low, the screen will crack on disassembely.
    I use a heat gun now to loosen the adhesive. I wouldnt try to remove a screen unless the section was over 135 F ( I use a laser/non contact thermometer now).
    I've only done one, but that was the lesson I learned the hard way watching the glass break.
    xocornhole69 -
    I use a hot plate to heat up my devices when needed and the recommended temp is 68 degrees C or 150 degrees F. This is hot enough to make the glue soft, but not hot enough to damage anything.
    Trever Nordlund -
    I found you need to be very patient when using the iOpener. It's worth taking your time, giving the heat time to work on the glue. When I finally got the battery out, there were some strips of glue left behind that I just cleaned off with some isopropanol before installing the new battery.
    By the way, I had to run the iOpener for longer in my microwave for it to get hot enough. When it was too hot to touch, I figured it was hot enough for the batteries.
    Fredrik -
    I have used a small IKEA hair dryer. Important is that you start from bottom where suction is easier to attach close to the border. Hot to touch was enough for me.
    haligali -
    If I can't find the new screen how would I fix it. Where can I find the brand new screen.
    Crissel Largo - crwdns2934203:0crwdne2934203:0
    There are screen replacements on eBay but it appears that you can only buy the digitizer glass. Is it difficult to separate the glass from the LCD screen? Some apple products are rather difficult while others already come separate.
    loveofthegame441 - crwdns2934203:0crwdne2934203:0
    for the screen, there's a place in Huntsville Alabama called LCDcycle. they have grade a parts
    livinginthegump - crwdns2934203:0crwdne2934203:0
    Could some one help me please im changing the wifi antenna on my ipad air an don't knoew how to activate the glue on the growding strip. I would think it heat. any ideas thank you.
    danielalanreed - crwdns2934203:0crwdne2934203:0
    I don't own a microwave... Is there an alternative way you can recommend heating up the iOpener?
    margo - crwdns2934203:0crwdne2934203:0
    My rear glass is broken what will be the price of thr rear glass..???can i order it from ifixit suggest me some thing.....!!!!i m from india....help me out plz...!!!
    Abhishek Dutta - crwdns2934203:0crwdne2934203:0
    Always isolate the battery before removing the LCD, and don't reconnect the battery till the LCD is back in place.
    You can screw up a few different things by inadvertently turning on a device while the LCD is disconnected.
    Also, skip the neck warmer/microwave, get a hot plate or hair drier/heat gun and be careful. (I use a duel sensor digital temp hot plate)
    David - crwdns2934203:0crwdne2934203:0
    Seriously 64 fkn Steps!
    Should've just made a %#*@ video
    I can make a flip book out of the pictures there's so many of them.
    rukidnmeh - crwdns2934203:0crwdne2934203:0
    What is the LCD used for? Is that the main screen that has the display?
    virgilio ingram - crwdns2934203:0crwdne2934203:0
    Use a hair dryer! Watch this vid: https://youtu.be/16GkvjVyOJA It is much easier to do if you heat it from the other side.
    Fletcher Carpenter - crwdns2934203:0crwdne2934203:0
    Video seems to have been removed from YouTube.
    Rex Burrus -
    I wonder how many people actually wrapped in their iPhone into iOpener and put this "sandwich" into microwave??
    putinaspiliponis - crwdns2934203:0crwdne2934203:0
    I've been with Samsung for 8 years now!! Never did i have a case on any of my phones My Samsung 8 is 2 months old the case protector around the edge pop off and broke my phone it's like someone put a bullet hole in it
    Sherry Carew - crwdns2934203:0crwdne2934203:0
    Thanks for sharing such beautiful and informative information with us and please keep sharing such beautiful and informative information with us.
    Please also share information about <a href=”https://www.tablethire.ae/ipad-rental”>Hire iPad in Dubai UAE</a> Thanks
    dean lara - crwdns2934203:0crwdne2934203:0
    Not everybody has a microwave. You need to state how long and at what temperature in a conventional oven.
    Esmond Pitt - crwdns2934203:0crwdne2934203:0
    Hi, the microware have multiple power 1 to 9, what must be used ?
    Regards,
    Cedric
    Cedric VINCENT - crwdns2934203:0crwdne2934203:0
    please visit this site for your best understanding https://www.mp3naat.com/
    nailakanwal182 - crwdns2934203:0crwdne2934203:0
    iPad is a good option to hear latest naats. for this purpose you need to browse site and in this process you lost your lot of time. so you can direct enter URL http://enaats.com to access latest naats. It will save your lot of time.
    w­h­At ­m­Ar­cus ­i­m­p­l­i­e­d ­i ­d­i­d­n't ­k­n­ow t­h­At ­A st­Ay ­At ­h­o­m­e ­m­o­m ­A­b­l­e t­o ­g­et ­p­A­i­d $4252 ­i­n 4 w­e­e­ks ­o­n t­h­e ­c­o­m­put­er. ­h­Av­e y­ou r­e­A­d t­h­is w­e­b ­l­i­n­k­,,,,, HERE☛   www.jobsbud.com
    Ashley - crwdns2934203:0crwdne2934203:0
    Ther first time you heat up the iOpener for this repair when its room temperature I had to heat it up for more than 30 seconds. I remember I had to heat it up for around 45 seconds. However, after that when you need to reheat it again during the repair 30 seconds will be enough. www.jobsbud.com
    My microwave just died, can i heat it with boiled water?
    Alex COLOMBANI - crwdns2934203:0crwdne2934203:0
    A hairdryer on low is the best method. Doing it the iFixit way is very time consuming and tedious in comparison. I also cut out a piece of cardboard to protect the display. The heating only has to occur at the edge of the display. With a hairdryer you can have the display off in a few minutes. It doesn’t take much heat. Use your other hand near the area (do a whole side) being heated as a guide. The heat level should be hot but not enough to burn you. Then when you lift up with the suction, use one of the iFixit blue picks like shown in the guide. You can quickly slide your way around as you heat separating the adhesive tape. Stick the other picks in as you go along to prevent it from reattaching.
    Fixrights - crwdns2934203:0crwdne2934203:0
    Taping as shown is impractical when using hair dryer method—tape simply comes off in the heat and gets in way of getting out the shards on the sides. If the thing wasn’t shattered, then taping unnecessary.
    B. A. Computer Services - crwdns2934203:0crwdne2934203:0
    The “Galaxy S8 Replacement Battery” that you are selling with the kit is the wrong battery, the one that you are selling is a 3000mAh (which is the wrong amperage) as the OEM Samsung Galaxy S8 battery is “Model #: EB-BG892ABA / 4000mAh / Normal Voltage: 3.85V / Charge Voltage: 4.4V / A/S: 1588-3366 4000mAh 15.0Wh
    stevengenat - crwdns2934203:0crwdne2934203:0
    I’ve tried for 2 days and cannot get this to work. I should have just taken it to my local iphone fixit shop. This is a frustrating purchase to say the least.
    jeffrey hill - crwdns2934203:0crwdne2934203:0
    Step 1 should be: now that you have looked over the tools of this repair kit, take your ipad to the nearest repair store and let them handle it. Sure you will waste about $65 by purchasing this kit and the cost of the repair but you will not tear your ipad up and you will have at least 2 days of your life that you can spend time with your family.
    Just replaced the battery in my iPad mini LTE. Followed the Ifix step by step instructions and they worked very well. The only thing i would change is step 42. You do not have to lift the LCD connector from the logic board. So don’t. It’s an unnecessary step. Other then that all was good. It took me about 2 1/2 hours from start to finish but I took my time and I recommend you take your time also. Very exciting too finish doing it and see it come to life afterwards. Tested everything and everything still works
    Anybody want to buy my iFix battery replacement tool kit only used once cheap?
    kaplang - crwdns2934203:0crwdne2934203:0
    i opener sucks! it’s incapable of heating factory glue enough to take a sealed phone apart and caused my backglass to shatter. i removed it the rest of the way with a soldering iron!
    Elijah Marvin - crwdns2934203:0crwdne2934203:0
    You should, at least, mention which wattage is used for the 30 seconds heating - 750 isn’t enough, obviously. Display shatterered . Thanks.
    dr_baeschtlr - crwdns2934203:0crwdne2934203:0
    I put it in a heated immersion bath and let it stabilize at 180F, then let it sit on the device until the surface of the opener dropped down to 140F (measured with an IR thermometer). Removing the screen required very little force with this method.
    breadandbits - crwdns2934203:0crwdne2934203:0
    At what power (how many watts) does the 30 seconds apply?
    Jarl Friis - crwdns2934203:0crwdne2934203:0
    I just didn’t have any success using the iOpener heated sausage but did eventually get it to work by using a heat gun. I also found a very useful demonstration video which I would thouroughly recommend to supplement this written guide.
    https://www.youtube.com/watch?v=6u57jbta...
    martin evans - crwdns2934203:0crwdne2934203:0
    I followed the directions and heated my iOpener for 30 seconds in a 1000 watt microwave, and it came out at 160 degrees F, as verified by a infrared thermometer.
    Dennis - crwdns2934203:0crwdne2934203:0
  2. iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat the iOpener for thirty seconds.
    • Depending on the wattage of your microwave, more or less time may be required. The iOpener is sufficiently heated when it's barely too hot to touch.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
    • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst. Do not attempt to heat over 100˚C (212˚F).
    • Never touch the iOpener if it appears swollen.
    • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
    May I know the temperate limit about heating iOpener? (maximum 150 degrees Celsius?) thx so much.
    yamayhuang - crwdns2934203:0crwdne2934203:0
    This repair isn't possible as far as I know. I have done three glass only repairs now with the same results. After professionally separating the glass and LCD, then re-attaching the AMOLED screen to the NEW digitizer/glass assembly with OCA tape the touch would no longer work... strange since I tried a new digitizer on each Apple Watch I was repairing. I started looking a little closer to the broken digitizer and I removed the silver chip cover to reveal the touch/digitizer controller IC. This extremely small BGA chip is epoxied directly to the flex cable, so removing the chip is a one time thing as you can't remove epoxy chemically after it cures. Each touch/digitizer controller IC is INDIVIDUALLY MARKED with a number, for example #1510. I believe each touch IC is LINKED to each Apple Watch, but it is possible that each IC is linked only to the LCD screen. I can not confirm that is the case because I do not have access to a full LCD/digi/glass to try replacing on a broken apple watch.
    Don - crwdns2934203:0crwdne2934203:0
    Can anyone verify that the part sold on ifixits website will work? I bought a digitizer/glass only from eBay and no touch response from it. Other people here are claiming the IC chip is programmed to either the watch CPU or the amoled itself.
    Here is the part on ifixits website:
    crwdns2937315:0IF308-007crwdne2937315:0
    greg - crwdns2934203:0crwdne2934203:0
    So I followed the steps and it all seemed easy. When I tried to turn it on the blue light just pulsed, and the screen stayed black. I did a full charge and tried a power+volume down, which did turn it off, but when I turn it on I still only get blue pulsing light with a black screen. Any ideas? Not sure if its a bad battery, or if I could have messed something else up? Thanks in advance for the help.
    Dawson - crwdns2934203:0crwdne2934203:0
    Its again waterproof when you change iphone 7 battery?
    Jon - crwdns2934203:0crwdne2934203:0
    I don't have a microwave???
    Joe Blow - crwdns2934203:0crwdne2934203:0
    30 sec at which equivalent watts setting and what temperature does iOpener heats up to for 30 secs. Only just bought it so needs info before using it. Thanks
    Sam Stieg - crwdns2934203:0crwdne2934203:0
    can i use just ordinary microwave???
    juneseok kwon - crwdns2934203:0crwdne2934203:0
    If I don't have a microwave then I try to use hot air gun so how many munuts i want to heat ?
    Mohideen Rifay - crwdns2934203:0crwdne2934203:0
    www.jobsbud.com
    30 seconds sure isn’t cutting it… 45 didn’t get the screen of my iPad air 2 to budge either… even after resting on the ipad for 4 minutes.
    60 seconds in the microwave, the iOpener burst.
    I’ll get a new one and try once more with heating it 45 seconds and repeat that for 30 minutes like others have said here. If that doesn’t work it’ll have to be the heat gun,
    The iOpener is, well, sort of silly. I used it for a while by immersing it in a pot of water regulated at 180 F, which worked, but I ultimately found it far faster to use a hair dryer. I do have an inexpensive IR thermometer which seemed to indicate that the adhesive softened sufficiently when the outer surface of the ipad display edge registered about 140 F. That said, the reflectivity of the outer surface is probably not suitable for reliable temperature indications with an IR thermometer. Just be patient. If you don’t have an IR thermometer, just heat the surface until it is almost too hot to the touch.
    Also note the instructions are VERY different for the WI-FI vs. the Cellular version when attempting to release the adhesive along the bottom (home-button) edge. In one case (on left side) you are to cut towards the center, in the other case you are to cut away from the center. I ended up cutting the right-side cellular antenna cable because I didn’t pay close enough attention here.
    Leon - crwdns2934203:0crwdne2934203:0
    Delete the second paragraph above. I had confused the top and bottom of the ipad. Do pay attention to the direction in which you slide the pick. It MUST be toward edge from camera, not home button. Sorry.
    Great. So apparently i !#^&@@ away $20 on the stupid opener. I might just have to make it explode in slow motion to get my money’s worth
    Val - crwdns2934203:0crwdne2934203:0
    Nice blog, If you like to buy safety glasses online but you don't know the best place to buy it then you need to know more about step by step guide on buying rx optical safety glasses.
    Steven Brian - crwdns2934203:0crwdne2934203:0
    As I understand it, iFixit used a 1000W microwave for 30s, so to figure out how long you should heat yours for, confirm the wattage of your specific microwave (usually on a sticker inside the door frame or on the back of the unit). So if you've got, say, a 500w model, you'll need to run it for a minute since it's putting energy into the opener at half the rate of the one used in the instructions. Can also highly recommend using an infrared thermometer as an added bit of precaution to confirm you're up to temp.
    David Rocharz - crwdns2934203:0crwdne2934203:0
  3. iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
    Will a hair dryer work for heating the glass?
    Me berg - crwdns2934203:0crwdne2934203:0
    Can you use an oven instead?
    Rafael -
    microwave on WHAT WATTAGE ??? 100 W OR 1600 W ??? NOT THE SAME
    Ivor Pocrnja - crwdns2934203:0crwdne2934203:0
    This was not easy. I finally got a pick under the glass of my moto x4 phone after my hot plate went up to about 160F—measuring with a candy thermometer. It is easy to be scared of it getting too hot—another video I saw used a 100C heat gun(?) for 2 min when I figured that was 212F I got braver with heating the phone.—My screen and display were already broken.
    Nahariyah Mosenkis - crwdns2934203:0crwdne2934203:0
    This was not easy. I finally got a pick under the glass of my moto x4 phone after placing my phone on my kitchen hot plate and letting the hot plate go up to about 160F—measuring with a candy thermometer. I was scared of it(either the phone or the iopener) getting too hot—I checked in with another online video and saw they used a 100C heat gun for 2 min on the left side: When I figured that was 212F I got braver with heating the phone.—My screen and display were already broken. I can’t say exactly how long the phone was on the hot plate at 150-160 because the hotplate annoyingly goes on and off not sustaining a stable temperatureprobably a few
  4. iPad Air 2 LTE Display Assembly Replacement, Alternate iOpener heating method: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement, Alternate iOpener heating method: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If you don't have a microwave, follow this step to heat your iOpener in boiling water.
    • Fill a pot or pan with enough water to fully submerge an iOpener.
    • Heat the water to a boil. Turn off the heat.
    • Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
    • Use tongs to extract the heated iOpener from the hot water.
    • Thoroughly dry the iOpener with a towel.
    • The iOpener will be very hot, so be careful to hold it only by the end tabs.
    • Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
  5. iPad Air 2 LTE Display Assembly Replacement, iPad Air 2 Wi-Fi  Opening Procedure: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement, iPad Air 2 Wi-Fi  Opening Procedure: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement, iPad Air 2 Wi-Fi  Opening Procedure: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
  6. iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The following steps involve using an iOpener to soften the adhesive holding the front panel assembly in place. When using the iOpener, be sure to heat it in the microwave for no more than 30 seconds.
    • Handling it by the tabs on either end, place a heated iOpener over the top edge of the iPad.
    • Let the iOpener sit on the iPad for two minutes to soften the adhesive securing the front panel to the rest of the iPad.
  7. iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • While the iPad looks uniform from the outside, there are delicate components under certain portions of the front glass. To avoid damage, only heat and pry in the areas described in each step.
    • As you follow the directions, take special care to avoid prying in the following areas:
    • Home Button
    • Front Facing Camera
    • Main Camera
  8. iPad Air 2 LTE Display Assembly Replacement, Anti-Clamp instructions: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement, Anti-Clamp instructions: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement, Anti-Clamp instructions: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Clampy - Anti-Clamp
    $24.95
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down two steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Elevate the iPad enough for the Anti-Clamp's arms to rest above and below the screen.
    • Pull the blue handle towards the hinge to disengage opening mode.
    • Position the suction cups near the top edge of the iPad—one on the front, and one on the back.
    • Push down on the cups to apply suction to the desired area.
    • If you find that the surface of your device is too slippery for the Anti-Clamp to hold onto, you can use packing tape to create a grippier surface.
  9. iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the blue handle away from the hinge to engage opening mode.
    • Turn the handle clockwise until you see the cups start to stretch.
    • Make sure the suction cups remain aligned to each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
  10. iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place a suction cup over the iPad's front-facing camera and press down to create a seal.
    • To get the most leverage, place the suction cup as close to the edge as possible without going past the edge of the display.
  11. iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Firmly pull up on the suction cup to create a small gap between the front panel and the rear case.
    • Do not pull too hard or you may shatter the glass.
    • Once you've opened a sufficient gap, insert an opening pick into the gap to prevent the adhesive from resealing.
    I had a very inconvenient crack above the front camera of my iPad that made this step much harder, but the iHeater worked perfectly well for me. Honestly, once you get one side lifted, the rest goes much easier.
    Ciarán - crwdns2934203:0crwdne2934203:0
  12. iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the pick along the edge of the display, towards the headphone jack.
    • If there is still a considerable amount of resistance when sliding the opening pick, repeat the iOpener heating procedure and apply additional heat.
    • Be careful not to let the opening pick slide between the fused LCD and front panel, as doing so can permanently damage the display.
    • A good rule of thumb is to never insert the opening pick more than a quarter inch (6 mm) into the iPad.
  13. iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a second opening pick by the front-facing camera.
  14. iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the second pick along the top edge of the iPad, towards the Sleep/Wake Button.
  15. iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a third pick by the front-facing camera.
  16. iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Bring the right opening pick down and around the top right corner of the iPad.
  17. iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Bring the left opening pick around the top left corner of the tablet.
  18. iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reheat the iOpener and lay it over the right edge of the display to loosen the adhesive underneath.
  19. iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the right opening pick roughly halfway down the display.
  20. iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reheat the iOpener and apply heat to the left side of the iPad.
  21. iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the left-hand opening pick about halfway down the edge of the display.
  22. iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:022crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:022crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opposite opening pick down to the bottom right corner of the iPad.
    • If necessary, reheat the adhesive on the right edge to loosen the display assembly.
  23. iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the left-hand opening pick down the edge of the display until you reach the corner.
  24. iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the iOpener to apply heat to the bottom edge of the iPad.
  25. iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:025crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:025crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Bring the right-hand opening pick around the bottom corner of the iPad.
  26. iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:026crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:026crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat for the left-hand pick.
    • Reheat and reapply the iOpener as needed. Always wait at least ten minutes before reheating the iOpener.
  27. iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the right-hand opening pick at the bottom of the iPad.
  28. iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:028crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:028crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:028crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the left-hand opening pick along the bottom edge of the display, then remove it from the bottom right corner of the iPad.
    • Be very careful to not insert the pick more than 2 mm below home button to avoid damaging the button.
    • Be very careful to not insert the pick more than a quarter inch (6 mm) into either side of the home button to avoid damaging the display cables underneath.
  29. iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:029crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:029crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Twist the remaining pick by the front-facing camera to separate the top edge of the display assembly from the rear case.
  30. iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:030crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:030crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:030crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Continue lifting the display assembly from the front-facing camera side.
    • Pull the display slightly away from the bottom edge to completely separate it from the rear case.
    • Keep lifting until the display assembly is roughly perpendicular to the body of the iPad.
    • Do not attempt to remove the display yet—it is still attached to the rear case by three delicate ribbon cables.
  31. iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:031crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single 1.8 mm Phillips screw securing the battery terminals to their contacts on the logic board.
  32. iPad Air 2 LTE Display Assembly Replacement, Battery connector information: crwdns2935265:032crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement, Battery connector information: crwdns2935265:032crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement, Battery connector information: crwdns2935265:032crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • These photos show what the battery connector looks like underneath the logic board. Use these photos as a reference while you safely disconnect the battery.
    • Notice that the battery connector has springs on the logic board that press down against the battery contact pads. You'll need to slide something thin and flexible between the contact points to disconnect the battery.
  33. iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:033crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:033crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To reduce the risk of a short, you can use a battery isolation pick to disconnect the battery.
    • Be very careful when you isolate the battery using a battery blocker. The battery contacts are easily damaged, resulting in irreversible damage to the logic board.
    • Slide a battery isolation pick underneath the battery connector area of the logic board, and leave it in place while you work.
    • Alternatively, make a battery blocker using a playing card and slide it underneath the logic board connector to disconnect the battery.
  34. iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:034crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:034crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:034crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the three 1.3mm Phillips screws from the display cable bracket.
    • Remove the bracket.
  35. iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:035crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:035crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the display data connector from its socket on the logic board.
  36. iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:036crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:036crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:036crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the two remaining digitizer cables underneath the display data cable.
  37. iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:037crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the front panel assembly from the rear case.
    • If you plan to reuse your display assembly, you will need to replace the display adhesive. Follow our iPad Adhesive Guide to reapply your display adhesive and reseal your device.
  38. iPad Air 2 LTE Display Assembly Replacement, Home Button Assembly: crwdns2935265:038crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement, Home Button Assembly: crwdns2935265:038crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement, Home Button Assembly: crwdns2935265:038crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lay the display assembly facedown.
    • Use a plastic opening tool to pry the bracket off the back of the Home Button.
  39. iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:039crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:039crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:039crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Tesa 61395 Tape
    $5.99
    • Remove the Home Button bracket and peel up the tape connected to it.
    • During reassembly, after installing the home button, you'll need to glue this bracket into place to secure it
    • Scrape off as much of the old adhesive residue from the bracket as you can, then clean it with acetone or high-concentration (90% or greater) isopropyl alcohol.
    • Secure the bracket with hot-melt glue, superglue, or high-strength double-sided tape. Make sure the bracket is aligned correctly before allowing your adhesive to cure, or the home button will not click when pressed.
  40. iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:040crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:040crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:040crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel up the tape covering the Home Button ZIF connector.
  41. iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:041crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:041crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to flip up the retaining flap on the Home Button cable socket.
  42. iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:042crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:042crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the Home Button ribbon cable.
  43. iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:043crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:043crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:043crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger to peel up the Home Button ribbon cable and Touch ID control chip.
  44. iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:044crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:044crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel up the remaining corner of the Home Button ribbon cable.
  45. iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:045crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reheat your iOpener and lay it over the bottom edge of the display to loosen the adhesive on the Home Button gasket.
    • Wait about two minutes for the adhesive to soften before moving on to the next step.
  46. iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:046crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:046crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:046crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • In the following steps, you will be separating the home button gasket from the iPad's front panel. This gasket is extremely delicate and can tear easily. If the gasket does not separate easily from the front panel, reapply heat using the iOpener before continuing.
    • Use the pointed end of a spudger to gently pry the Home Button assembly up from the display.
  47. iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:047crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:047crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:047crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Continue working the tip of the spudger around the edge of the gasket until the gasket is fully separated from the front panel.
  48. iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:048crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:048crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:048crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the home button assembly.
    • If you are replacing your LCD assembly, some assemblies have a slightly different home button connector placement that will require you to fold over the home button cable in a "S" shape like shown in the picture.
    Salve, dopo aver rimontato il tutto non funziona il tasto, cioè quando lo schiaccio rimane premuto e non mi permette di riprenderlo. Da cosa potrebbe essere dovuto?
    Alessia - crwdns2934203:0crwdne2934203:0
  49. iPad Air 2 LTE Display Assembly Replacement, Display Assembly: crwdns2935265:049crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement, Display Assembly: crwdns2935265:049crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad Air 2 LTE Display Assembly Replacement, Display Assembly: crwdns2935265:049crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Examine your replacement part, and your original display carefully to be sure they match.
    • Your replacement screen may be missing the sleep/wake sensor that is necessary for Smart Cover use. If you want to maintain functionality you will need to transfer the component.
    • Desolder the four solder pads from the lower left of the display to remove the sensor assembly cable.
    • The following step includes instructions for transferring this sensor to the new display assembly.
    • This video details the procedure to desolder the sensor flex cable and reattach it to the new display.
  50. iPad Air 2 LTE Display Assembly Replacement: crwdns2935265:051crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Display assembly remains.
crwdns2935229:058crwdne2935229:0
Scott Havard
crwdns2935283:006/27/16crwdne2935283:0
50 481 crwdns2915208:0crwdne2915208:0
crwdns2935297:031crwdne2935297:0
The displays that iFixit sells, are they actually missing the sleep / wake sensor? Are the display sold OEM?
Roberto Perez - crwdns2934203:0crwdne2934203:0
I’m so glad I decided to try your tips and tricks. I couldn’t find the necessary parts to repair my iPad Air 2 but I got to find the necessary items on this canadian website called https://replacement.parts/collections/ip.... Thanks for incentivizing the users to repair their own devices!
Robert Clark - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 77
crwdns2936753:030crwdne2936753:0 267
crwdns2942667:0crwdne2942667:0 73,257
