iPad 10 Display Replacement
crwdns2869540:0crwdne2869540:0: 1811
38
210
881
1,811
crwdns2955950:0crwdne2955950:0: 1
crwdns2960002:01crwdne2960002:0.
crwdns2959984:0crwdne2959984:0: 0
crwdns2959956:0crwdne2959956:0
crwdns2955944:0crwdne2955944:0: 2 - 3 crwdns2931253:0crwdne2931253:0
crwdns2955970:0crwdne2955970:0: crwdns2937803:0crwdne2937803:0
Follow this guide to replace the display in an iPad 10.
This iPad has a glass digitizer on the front, above the display. If only the glass cover is damaged, follow this guide to replace it instead.
You'll need replacement digitizer adhesive to complete this repair.
This guide was written with iPad model A2696. Different models may look a little different, but the procedure will be correct.
    1. iPad 10 Display Replacement, Prepare the iPad for disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad 10 Display Replacement, Prepare the iPad for disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Disconnect all cables and accessories from the iPad.
      • For your safety, fully discharge the battery before disassembling the device. This reduces the risk of fire if the battery is accidentally damaged during the repair.
      • Note that directions in this guide are given for the iPad in landscape orientation. The USB-C port is on the right edge of the iPad.
    1. iPad 10 Display Replacement, Cracked glass preparation: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • If the iPad has a cracked digitizer, follow this step.
      • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
      • Apply strips of packing tape to the cracked glass until the whole digitizer is covered—this will help keep the glass contained and allow the suction cup to stick to it.
      • Make sure there's a single strip (not overlapping) of tape across the bottom edge, big enough for a suction cup to fit on.
      • Only cover the glass itself—don't stick any tape to the frame.
    2. iPad 10 Display Replacement, Heat the right edge of the digitizer glass: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a hair dryer or heat gun to heat the right edge of the iPad until it’s slightly too hot to touch. This softens the adhesive securing the digitizer glass.
      • Improper use of a heat gun can destroy the display and/or battery—review this guide for instructions. To prevent damage, keep your heat source moving rather than focused on one spot.
      • For tips on using a hair dryer to soften adhesive, check out this guide.
    3. iPad 10 Display Replacement, Insert the opening wheel: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad 10 Display Replacement, Insert the opening wheel: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad 10 Display Replacement, Insert the opening wheel: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Apply a suction handle above the USB‑C port with the open part of the handle facing away from the edge.
      • Pull up on the suction handle with firm, constant pressure to create a slight gap under the glass.
      • Insert an opening wheel into the gap.
      • The adhesive holding the glass in place is very strong. If you're having a hard time, be patient, apply more heat, and try again.
    4. iPad 10 Display Replacement, Slide the opening wheel: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad 10 Display Replacement, Slide the opening wheel: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Slide the opening wheel back‑and‑forth to separate the adhesive directly above the USB‑C port.
      • Try to get underneath the adhesive strip securing the digitizer, rather than slicing through the thickest part. This will make removal easier.
      • Leave the opening wheel in place to prevent the adhesive from resealing.
    5. iPad 10 Display Replacement, Remove the suction cup: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad 10 Display Replacement, Remove the suction cup: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pull up on the suction handle tab and remove it.
    6. iPad 10 Display Replacement, Reheat the right edge: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • This iPad cools very quickly. To get the digitizer off, work in sections of about 3 inches at a time before reheating.
      • Use a hair dryer or heat gun to soften the adhesive securing the right edge of the glass.
    7. iPad 10 Display Replacement, Separate the right edge adhesive: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad 10 Display Replacement, Separate the right edge adhesive: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Be patient while separating the screen adhesive. If you begin to feel more resistance, stop and apply more heat.
      • Apply the suction handle to the right of the USB‑C port and lift the glass to create a gap.
      • Slide the opening wheel beneath the glass you're lifting to separate the adhesive.
    8. iPad 10 Display Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad 10 Display Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad 10 Display Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Repeat this heating and separating process to separate the remaining adhesive along the right edge of the iPad.
    9. iPad 10 Display Replacement, Insert a plastic card: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad 10 Display Replacement, Insert a plastic card: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad 10 Display Replacement, Insert a plastic card: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert a plastic card underneath the right edge of the glass to keep the adhesive separated.
      • Remove the opening wheel.
    10. iPad 10 Display Replacement, Separate the bottom edge adhesive: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad 10 Display Replacement, Separate the bottom edge adhesive: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad 10 Display Replacement, Separate the bottom edge adhesive: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Repeat to separate the adhesive along the bottom edge of the digitizer.
    11. iPad 10 Display Replacement, Separate the left edge adhesive: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad 10 Display Replacement, Separate the left edge adhesive: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad 10 Display Replacement, Separate the left edge adhesive: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Repeat to separate the adhesive along the left edge of the iPad.
    12. iPad 10 Display Replacement, Separate the top edge adhesive: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad 10 Display Replacement, Separate the top edge adhesive: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad 10 Display Replacement, Separate the top edge adhesive: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Be very careful with this step. Don't insert the opening wheel deeper than 2 mm along the top edge to avoid damaging the digitizer cables, but don't use it at an angle.
      • Repeat the heating and adhesive separation process to separate the adhesive along the top edge.
      • Remove the plastic cards.
    13. iPad 10 Display Replacement, Lift the digitizer: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad 10 Display Replacement, Lift the digitizer: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad 10 Display Replacement, Lift the digitizer: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • The digitizer is still connected to the iPad with three ribbon cables. Don't try to fully remove it yet.
      • Try not to touch the back side of the digitizer or the surface of the display with your fingers—any fingerprints can be tough to clean off.
      • Lift the digitizer by its bottom edge and swing it open until it's perpendicular to the iPad.
      • Rest the digitizer on a strong, sturdy object to keep it held up while you remove the display.
    14. iPad 10 Display Replacement, Remove the display screws: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a Torx Plus 2IP screwdriver to remove the ten screws securing the iPad display:
      • Four 3.5 mm‑long screws
      • Six 3.2 mm‑long screws
      • In cellular models, use a JIS 00 screwdriver to remove the additional screws along the right edge.
    15. iPad 10 Display Replacement, Lift the display: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad 10 Display Replacement, Lift the display: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Insert the flat end of a spudger beneath the display in the center of its left edge.
      • Pry up the display until you can get your fingers beneath it.
    16. iPad 10 Display Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad 10 Display Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lift the display by its screw posts until it's perpendicular to the iPad. Rest it on a sturdy object.
    17. iPad 10 Display Replacement, Remove the display connector cover: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a JIS 00 screwdriver to remove the two 1.1 mm‑long screws securing the display connector cover.
    18. iPad 10 Display Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad 10 Display Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use tweezers or your fingers to remove the display connector cover.
    19. iPad 10 Display Replacement, Disconnect the display: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad 10 Display Replacement, Disconnect the display: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the flat end of a spudger to disconnect the display press connector.
    20. iPad 10 Display Replacement, Remove the display: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad 10 Display Replacement, Remove the display: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad 10 Display Replacement, Remove the display: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • The display cable is lightly adhered to the logic board.
      • Peel up the display cable and remove the display.
    1. iPad 10 Display Replacement, Clean the frame adhesive: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad 10 Display Replacement, Clean the frame adhesive: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Don't touch the ambient light sensor or selfie camera along the top edge of the iPad while cleaning the frame.
      • Use a hair dryer or heat gun to heat a roughly 3 inch (~8 cm) section of the frame edge.
    2. iPad 10 Display Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad 10 Display Replacement: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use an opening tool to scrape the old adhesive into a ball on the section of the frame you heated.
      • Use tweezers to remove the balled up adhesive.
      • Repeat this heating and scraping process until most of the old adhesive is removed from the frame.
    3. iPad 10 Display Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad 10 Display Replacement: crwdns2935265:024crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad 10 Display Replacement: crwdns2935265:024crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      Adhesive Cleanup Kit (Set of 12)
      $7.99
      • Apply a bit of isopropyl alcohol to a cotton swab or lint-free cloth and clean the frame until it's free of adhesive residue.
      • Alternatively, use our adhesive cleanup kit.
    4. iPad 10 Display Replacement, Clean the digitizer adhesive: crwdns2935265:025crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad 10 Display Replacement, Clean the digitizer adhesive: crwdns2935265:025crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad 10 Display Replacement, Clean the digitizer adhesive: crwdns2935265:025crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Skip this step if you're installing a new digitizer.
      • Repeat this process to clean the adhesive off the digitizer bezel. Use tweezers to get any large pieces off before using the opening tool.
      • Don't scrape too hard, or you'll scratch the digitizer's black paint.
      • Solvents (like isopropyl alcohol) will dissolve the foam gasket surrounding the clear glass. Only apply solvents to the black bezel.
    5. iPad 10 Display Replacement, Align the adhesive: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad 10 Display Replacement, Align the adhesive: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • If your replacement digitizer comes with adhesive pre‑installed, skip the next four steps.
      • Be careful not to crease or stretch the adhesive during installation. It can't be used if damaged.
      • Before removing any liners, align each adhesive strip over the digitizer to see where it goes. It's easiest to align the strip on the edge with the camera cutout.
    6. iPad 10 Display Replacement, Remove the first adhesive liner: crwdns2935265:027crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad 10 Display Replacement, Remove the first adhesive liner: crwdns2935265:027crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad 10 Display Replacement, Remove the first adhesive liner: crwdns2935265:027crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the large liners from one of the long adhesive strips. The adhesive is now exposed.
    7. iPad 10 Display Replacement, Install the adhesive: crwdns2935265:028crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad 10 Display Replacement, Install the adhesive: crwdns2935265:028crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad 10 Display Replacement, Install the adhesive: crwdns2935265:028crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Work slowly when installing the adhesive—once it sticks, it can't be repositioned.
      • Install one of the large adhesive strips to the back of the digitizer.
      • Check the adhesive to make sure it doesn't overhang the edge of the digitizer glass. If it does, remove it and start over with new adhesive.
    8. iPad 10 Display Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad 10 Display Replacement: crwdns2935265:029crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad 10 Display Replacement: crwdns2935265:029crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Repeat this process to install the remaining two adhesive strips.
    9. iPad 10 Display Replacement, Prop up the digitizer: crwdns2935265:030crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Set the digitizer on the frame of the iPad, so the cables can reach their connectors on the board.
      • Lean the digitizer against a large, sturdy object to keep it upright.
    10. iPad 10 Display Replacement, Connect the digitizer: crwdns2935265:031crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad 10 Display Replacement, Connect the digitizer: crwdns2935265:031crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad 10 Display Replacement, Connect the digitizer: crwdns2935265:031crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use your finger or the flat end of a spudger to connect the three digitizer press connectors to their respective sockets on the board.
    11. iPad 10 Display Replacement, Install the digitizer connector covers: crwdns2935265:032crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad 10 Display Replacement, Install the digitizer connector covers: crwdns2935265:032crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad 10 Display Replacement, Install the digitizer connector covers: crwdns2935265:032crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Set the two digitizer connector covers over their respective connectors on the board.
    12. iPad 10 Display Replacement: crwdns2935265:033crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a JIS 00 screwdriver to install the four 1.1 mm‑long screws securing the digitizer connector covers.
    13. iPad 10 Display Replacement, Set the screen into place: crwdns2935265:034crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Don't touch the front of the screen with your fingers. Any oils will be difficult to remove.
      • Set the screen on the iPad, so the screen cable connector can reach its socket on the board.
    14. iPad 10 Display Replacement, Connect the screen: crwdns2935265:035crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad 10 Display Replacement, Connect the screen: crwdns2935265:035crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad 10 Display Replacement, Connect the screen: crwdns2935265:035crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use your finger to connect the screen connector to its socket on the board.
      • Press the screen cable down so it sits flat onto the board.
    15. iPad 10 Display Replacement, Install the display connector cover: crwdns2935265:036crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad 10 Display Replacement, Install the display connector cover: crwdns2935265:036crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Set the display connector cover into place, aligned with its screw posts.
    16. iPad 10 Display Replacement: crwdns2935265:037crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a JIS 00 screwdriver to install the two 1.1 mm‑long screws securing the display connector cover.
    17. iPad 10 Display Replacement, Lay the screen into place: crwdns2935265:038crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad 10 Display Replacement, Lay the screen into place: crwdns2935265:038crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad 10 Display Replacement, Lay the screen into place: crwdns2935265:038crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Lower the screen into its recess.
    18. iPad 10 Display Replacement, Install the display screws: crwdns2935265:039crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a Torx Plus 2IP screwdriver to install the ten screws securing the iPad display:
    19. iPad 10 Display Replacement, Remove the adhesive liners: crwdns2935265:040crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad 10 Display Replacement, Remove the adhesive liners: crwdns2935265:040crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad 10 Display Replacement, Remove the adhesive liners: crwdns2935265:040crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use tweezers or your fingers to remove the top blue liner off the iPad digitizer adhesive.
    20. iPad 10 Display Replacement: crwdns2935265:041crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad 10 Display Replacement: crwdns2935265:041crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use tweezers or your fingers to remove the blue liner on the left edge of the digitizer adhesive.
    21. iPad 10 Display Replacement: crwdns2935265:042crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad 10 Display Replacement: crwdns2935265:042crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad 10 Display Replacement: crwdns2935265:042crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Lower the digitizer until you can access the final blue liner.
      • Use tweezers or your fingers to peel the final blue liner off the last adhesive strip.
    22. iPad 10 Display Replacement, Install the digitizer: crwdns2935265:043crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 iPad 10 Display Replacement, Install the digitizer: crwdns2935265:043crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 iPad 10 Display Replacement, Install the digitizer: crwdns2935265:043crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Lower the digitizer into place.
      • Press along the edges of the digitizer so it sits flush into the iPad frame.
    23. iPad 10 Display Replacement, Press the screen adhesive: crwdns2935265:044crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad 10 Display Replacement, Press the screen adhesive: crwdns2935265:044crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • In order for the adhesive to bond correctly, you'll need to apply even pressure around the perimeter of the iPad. You can compensate for the camera bump by laying the iPad face-down and placing coins around its perimeter.
      • Alternatively, you can use screen vise clamps around the perimeter of your device to set the new adhesive.
      • Place the iPad screen-side-down on a soft, flat surface.
      • Apply painter's tape to the back to protect its finish.
    24. iPad 10 Display Replacement: crwdns2935265:045crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 iPad 10 Display Replacement: crwdns2935265:045crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Place evenly spaced layers of coins or similarly thick objects on the tape along the edges of the back glass.
      • Stack them to a consistent height taller than the camera bump.
    25. iPad 10 Display Replacement: crwdns2935265:046crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Stack multiple books or other heavy objects on the iPad.
      • The coins may leave an impression on the bottom object, so don't use anything valuable.
      • Leave the objects in place for at least thirty minutes. The lighter the objects, the longer they should be left. Ideally, leave them stacked overnight.
Calibrate the replacement display using Apple's Repair Assistant. Navigate to Settings → General → About → Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad 10 Answers Community for help.
Nick Schultz
crwdns2935283:003/24/24crwdne2935283:0
70,025 crwdns2915208:0crwdne2915208:0
crwdns2935297:0363crwdne2935297:0
crwdns2936751:024crwdne2936751:0 38
crwdns2936753:07crwdne2936753:0 210
crwdns2936753:030crwdne2936753:0 881
crwdns2959996:0crwdne2959996:0 1,811
