Replace or upgrade the CPU. Don't forget to apply a new layer of thermal compound before reassembling your iMac.
Follow our thermal paste guide for instructions on cleaning and preparing the thermal surfaces and applying a new layer of thermal compound onto the CPU and GPU dies.
Before beginning any work on your iMac: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply. Only handle the board by the edges.
crwdns2935267:0crwdne2935267:0iMac Intel 27" Cardboard Service Wedge$4.99
With the hinge free to move, the iMac will be unbalanced and hard to work on. Repairs can be completed with the iMac laying down, but are faster and easier with an iMac service wedge.
If you are using the iFixit cardboard service wedge, follow these assembly directions to put it together.
Starting on the left of the display, near the power button, insert the iMac Opening Tool into the gap between the glass panel and the rear case.
Would a heat gun make this step easier? Or damage the iMac?
A heat gun wouldn’t help you here as you still need to cut though the adhesive. You also risk damaging the display with the excessive heat.
Dan -
Removing the original adhesive is easier than removing newly applied adhesive (e.g., if you have to reopen iMac). If you should happen to need to reopen the iMac, please use extreme caution and highly consider my suggestions below.
When using the pizza cutter tool, do the first few steps in reverse starting with step 8. Starting on the left side is better since this is where the adhesive is narrowest. The right side has two antennas and the top right has one, see the pictures for step 18-21, they are the brass colored metal rectangles near the edges. The adhesive on these pieces are wider and therefore have more holding power. The thickness of the pizza cutter tool is enough to crack the glass.
Continuing from my previous comment. To remove the adhesive on the right side you’ll need to create a very slight gap to give the pizza cutter some more room. Do this by cutting the adhesive on the left side up and around to the camera. Before attempting to cut the right side. Carefully slide the plastic cards (I purchased two sets) to ensure the adhesive on the left top and side is completely free. Now slowly move towards the right side. After every inch or two of removing new adhesive, slide the card over to create this slight gap. Be careful to not move the card too close to where the adhesive has not been cut. You want to create a very slight gap without creating too much pressure. Use extra caution with approaching the areas where the antenna are since the adhesive is stronger here and will need some additional cutting. Follow this approach all the way around the right side. Be careful to not create too much pressure at any one time. Good Luck!.
I can confirm with Walter - trying to remove freshly applied adhesive is WAAAAY harder! My pizza cutter didn’t work correctly (the circle became a rectangle!) and I ended up with a small crack on the left of my screen. Dang it!
I would highly, highly, highly recommend AGAINST doing this at home. I followed these instructions to a T, and still somehow managed to have the screen not be able to turn on after the hard drive replacement. Then, once you’ve opened your Mac yourself, Apple will refuse to fix anything on the computer, and even other third party, Apple-authorized repair facility will refuse to repair it for you, and you will have to locate a non-authorized Apple repair facility. There, I am having to pay ~$600 to fix things that got screwed up, even though I followed the instructions here to a T, step by step, and did everything slowly and methodically.
Beware, if you’ve never done this before, that be locked out of ever being able to use an Apple repair facility, or Apple-authorized repair facility, if you mess things up here now.
I performed this on a Late 2015 iMac and there weren’t any significant differences to these steps, but I did find the repair to be nerve-wracking. My model cost nearly $3,000 and about 10 steps into this guide (which I did fully read ahead of time) I was thinking, “what have I got myself into?” But I didn’t rush and happily I’m typing this on my repaired iMac! I found a video from OWC that was more useful than the photos in this guide for certain steps: https://vimeo.com/139364064
Don’t know if you are still around, but THANK YOU for posting this video! The video made it seem SO NOT SCARY and, in conjunction with the photos and comments and tips on this guide, was a lifesaver. Big thumbs up.
First impressions so far: yes it can be a bit nerve wrecking if it is your first time doing this sort of thing and even with lots of experience with a 2011 model it’s still a bit unsettling haha (nervous laughter).
What I recommend: use a guitar pick to start cutting the glue. You’ll need a bit of pressure so do just the tip.
Once you’ve done the whole perimeter (minus bottom) do it again but now it should be easier to go deeper so go very slow and careful. Then get the old suction cups used to open older models and start lifting the display very carefully to see where it’s still glued and cut those as well.
Then you should be done and now the real fun begins! :D
It’s ridiculous. Apple should pay for doing this. Like glue parts together to block a repair / make difficult. I smashed my iMac. FU Apple. Seriously, every product I owned had hardware issues. For example, bad solder joints. Never again Apple. I’m happy with Windows and in 2018 / 2019 there are many other manufacturers with high quality stuff. Apple is dying, if they do not change …
NOTE: I followed every step word for word, but the adhesive strips supplied are as bad as double sided tape. Within 48hours the screen had slipped off and cracked. Now I need to fork out for a new screen and try again.
Not sure what to try next time with strips? Perhaps a bit of glue to help hold it??
Where do i get the “iMac Opening Tool?” its neither in the list of tools nor could i find it on the tool page.
Hi @snappadoodle! The opening tool is included in the adhesive kit included in the tool list, but you can purchase it separately here.
After disconnecting the power cord and before cutting the panel adhesive, push and hold the power button for 10 seconds. This will discharge the power supply capacitors. In case you accidentally touch the solder joints on the board, you won't be shocked and drop the panel.
Bottom line: This repair seems to have worked (so far no more intermittent shut-downs). Thanks iFixit!
As a novice who fully expected to destroy the display or worse, I make the following recommendations: (1) Before you start, read the steps several (many) times; visualize doing them and imagine how things could go wrong; (2) Read all the comments—there were some really helpful tips—like simply displacing the left speaker rather than fully removing it; (3) Get the recommended tools*; and (4) take your time—if you start to feel frustrated—seriously, stop and take a calming breath. Time is your friend. Failure is not an option.
*I would add a 3-prong parts puller to the tool list—it’s great for pulling and starting loose screws so you don’t drop them down into the chassis like I did. It’s also great for retrieving the screws you’ve dropped into the chassis.
Hi brad, what exactly did you repair to stop the shutdowns? I’m having the same issue
merinian -
Merinian: I replaced the power supply and it’s still working fine at this late date. No more intermittent shut-downs. Fingers still crossed!
Just completed the Core i5 to i7 CPU upgrade and can strongly recommend getting the “pizza tool” to cut the display adhesive. It worked flawlessly and was done in less than 5 minutes. No inadvertent cables cut. No display problems.
Thank you very much for the instructive tutorial. I just successfully replaced the hard drive on my 2012 iMac 27. I used a disposable surgical scalpel 15 blade, and locked the blade extending 9 mm from the scalpel shaft using office tape. I used regular double sided tape to reattach the screen. I cut the strips using the scalpel. I have no previous computer experience and this is the first time I replaced a computer part. This was easy and fun.
Filip Dolatowski - Friday 11th Dec 2020
You are very lucky! I’ve had three systems come in which someone did the exact same thing! All three cut the display ribbon cables. Please don’t use surgical knifes or any other knife! Use the proper tool the special pizza cutter wheel designed for the task.
You likely spent more on the knifes than what the wheel cost with the correct tapes. You make the next time doubly hard to open not using the correct tapes! Hows the built in microphone? You may have messed it up.
Dan -
Thank you very much for the tutorial. You are the best!
After reading all the post here I almost gave up doing this on my own. But I did it anyway and was succesful. I would recommend everyone to use the rollcutter. There is no risk of harming the screen if you use it. And in my case it was enough to open the imac. If you do not harm the screen connector or the screen the biggest part is done. It gets easier once you`ve stacked your screen somewhere safe. The parts inside are mostely not as delicate as the heavy and expensive screen!
Take your time and work carefully. It is definitely doable!
I found the cutter tool that came with my kit to work just fine. The wheel is extremely thin and I had no problem inserting the wheel to begin cutting. I follow the guide for the most part but took my time and use the cutting wheel slowly and then repeated the process a few times. Once I was able to pry the screen back about an inch I used the other end of the tool to cut additional adhesive that was still clinging to the body of the iMac and the screen. Having just replaced the power supply, and having my iMac running again, I do not think I will use the adhesive strips to reattach the screen. The screen fit back in place no problem which I did to test my Mac. Because the iMac screen sits at an angle I am quite comfortable that the screen is not gonna fall off. Also while having a screen off I was able to clean the inside of the Mac of dust buildup. I think I will only use the adhesive strips down the road if I’m gonna sell the Mac, which means I can give it a good clean before securing the screen.
If the screen falls off (which it will do!) it will damage the parts which would be a lot more expensive! PLEASE get the correct tapes and properly mount the screen back on.
Think of it this way how many people have shot them selves with a gun not realizing it was loaded or set to go off!
Dan -
I think Dan is right as I decided it best to complete the process with the adhesive tapes to secure the screen. I just took some time to do a complete clean of the interior before sealing the display.
Ordered the full kit to replace my busted 3TB disc hard drive. All the tools work and are excellent. These pictorial and instructional install videos are complete, easy to use, and have good imagery. The 2TB SSD installed exactly as depicted. I used some 3M double sided automotive emblem tape to stick adapter to iMac case, no probs there. The adhesive strips also worked fine and stick firmly. Screen is solidly mounted, no falling out here. IFixit is awesome and this kit saved my over $1200 in getting another iMac. Highly recommended.
Use the tool like a pizza cutter—roll it along through the gap, and it will cut the foam adhesive through the center.
Run the tool up along the left side of the display.
I found the 'pizza cutter' surprisingly smooth at cutting through four-year-old adhesive.
In my experience the cutter also worked very well for cutting the original adhesive. Unfortunately when I was reinstalling the display with the new adhesive strips, somehow the display power connector came loose. I had to open the display a second time and the cutter was not as effective against the new adhesive. I managed to break the cutter tool plastic wheel and cause a few small cracks in the edge of the displays glass as I worked! Be careful and go slowly!
The cutting tool worked great until I accidentally twisted it a bit while rounding a corner. A chunk of the wheel snapped off, making the rest of the job quite a bit more challenging. Just make sure you are keeping the tool directly parallel with the screen.
I concur, opening the screen a 2nd time is considerably more difficult because the adhesive strips are thinner than the original, which makes getting the cutting tool inserted much more difficult….as a result unknowingly I elongated a small crack to a much longer crack and somehow, the LCD now has a wide grey strip from top to bottom….The first time opening was easy, second time resulted in a ruined screen.. The cost of. a replacement LCD is the same has replacing the entire computer….I would recommend anyone attempting to remove the screen for any reason, do not use the aftermarket adhesive strips if you ever intend to open it up; again, or cut the strips much shorter, or possibly use a few pieces of scotch tape or similar to hold the screen in place….since the screen tilts back, this should not be a problem…Good luck…
Continue wheeling the tool up around the top left corner.
Cut the adhesive along the top left of the display.
The pizza cutter will sink in all the way to the tool handle when the adhesive is full cut, but don’t feel you have to do this in one motion. Some parts cut easier and some require a lot (like 20x) of gentle back and forth.
Continue along the top of the display.
what about the part where the camera is though? do I just treat it like the rest of the screen?
yes. the tool can’t go too deep
I measured a depth several positions.
- About 6 centimeters near iSight Camera center, you must no use iMac opening tool, because iSight element exists.
- iMac opening tool has a 9mm radius, so it may break iSight camera element.
- Making a plastic card stacking 2 or 3 to 3mm, under the iMac opening tool, that makes inserting a gap 5~6mm like below.
@. iMac opening tool
====== plastic card3 (credit card 1mm)
====== plastic card2 (1mm)
====== platic card1. (1mm)
———————————————— isight camera element (total 5~6cm) ————
In my case, i got a display problem where lcd display yellow connector was torn without care.
Be helpful.
Push the tool around the top right corner of the display.
Wheel the tool down along the right side of the display.
Finish pushing the opening tool to the bottom of the right side of the display.
I didn’t have the fancy cutter or cards. So I used my actual pizza cutter. Followed directions just the same, and it easily cut through the adhesive w/o issues or marring the surfaces. Actually used it to rock back and forth to lift the screen. It’s all about taking your time. I rolled it back and further until cut thru. The 3/8 to 1/4 inch is right, but the screen framing actually prevents further depth unless you force it further. The adhesive actually protected the glass while cutting thru, so no damage. Great instructions, but where to get the replacement adhesive to reinstall?? Should be four independent strips.
You are very lucky you didn't cut to deep! The plastic cutter that's in the kit is the only thing I would use. Spending a few bucks on a tool is a lot cheaper than $500 for a new display!
Please don't use a real pizza cutter!
Dan -
crwdns2935267:0crwdne2935267:0Plastic Cards$2.99
Set the iMac face-up on a table.
Starting from the top right corner of the iMac, insert a plastic card between the display and frame.
I actually DESTROYED my display (black vertical strips) by pushing the card in a bit TOO DEEP. So it is REALLY important to insert the card only a bit (1-2mm) more than the cutter wheel, in particular at the top side, where many flat cables connect the panel with the PCB. These can be damaged very easily!
Same thing with me…. Pushed cards to far…. new panel needed…€600…..
i think ifixit needs to place a bigger caveat, as I have missed it the first time
i successfully upgraded two imacs. one opened with ifixit pizza knife and another with a regular paper knife. however, when i had to open the first one once again i broke its screen glass. it seems ifixit adhesive strips are too strong. next time i’ll try to use heater to weaken glue tension.
I broke one too. And even if you think you did it correctly, you’ll not be able to see where you might have gone too far. You would think it’s very protected behind that metal plate, but no. Take special care with this offence to “right to repair” This should have been designed WAY better. I mean replacing a hardrive that is very likely to fail over the course of time, or even a simple desire to upgrade to an ssd!.
Bummer
HINT: If you turn the card and use the blue part of it, then you can avoid going to deep: no further then the blue part …
On the cards I got with my iFixit kit, the blue part was way bigger than 9.5mm — closer to 20mm!
I made a line 9mm from the edge of each of my cards and used that as a guide.
I’m thinking I might just use vinyl tape to keep the screen in place for at least a little while after an upgrade. The extra strength of the replacement tape sounds scary.
I wrapped two layers of vinyl electrical tape around the short side of an old gift card 3/8” from the edge. This “stop" prevented the card from going in too far. The card really helps to break the panel free.
This is a good tip!
Great idea! Wish I had read this before doing it. My less then optimal solution was to draw lines 3/8” around the cards, not as safe as your fix, but fast.
Umm.. I’m not sure that I’d recommend using a repurposed credit card to open the display - I found that using the “pizza tool” to cut the old adhesive then using a pair of suction cups to gently pull the display up worked perfectly well.
surely the card should have been designed such not to go further than certain distance with a barrier band.
The cards don’t have any means to control the depth, its your skills which control it. Its no different from how you use a knife to cut your chicken up when you serve it for dinner.
Dan -
The pizza roller tool is enough to cut through the adhesive. You dont need to cut in a lot further. So the cards are really not necessary.
might be a stupid question but would credit cards or state ids work too?
You need the pizza cutter! The cards are used to hold the display off of the case frame.
As for as using old credit cards and useless ID cards sure they will work. I wouldn’t use anything important ;-}
Dan -
No problems. I used two old credit cards and marked out a line using permanent marker so it was at the same depth as stipulated on this page. I even pushed it in a little deeper and no issues.
Go very slowly when doing these steps.
Gently twist the plastic card to open the space between the display and frame, and cut any remaining adhesive near the corner.
My children tend to collect cards like this from hotels, Disneyland, old IDs, iTunes cards, gift cards etc. They came in handy for this step. After wedging in the first card into the left corner, I wedged the left corner, then added cards along the bottom edge. Finally I continued to push in additional cards to existing cards and found that this created a smooth even pressure along the display top. At 2-3 card-thickness the last of the adhesive let go, gentle as a baby.
Slide the card toward the center of the display, to cut any remaining adhesive.
was denn jetzt? Vor der Kamera aufhören, oder in Richtung Bildschirmmitte schieben, um DEN REST zu entfernen? Wenn ich vor der Kamera aufhöre, kann ich nicht alles an Kleber entfernen.
Put the card into the corner again and let it stay there to keep the adhesive from resettling.
Insert a second card into the gap between the display and frame in the top left corner.
Gently twist the card, slightly increasing the space between the display and frame.
Slide the plastic card toward the center, again stopping just before the iSight camera.
Insert the card back into the top left corner.
With the cards inserted as shown near the corners, gently twist the cards to increase the gap between display and case.
If there are any sections that seem to stick and won't separate, stop twisting and use one of the cards to cut the adhesive in the problem area.
Begin to lift the top of the display up from the frame.
I would recommend using suction cups at this stage to lift the display.
I would strongly recommend using suction cups
Agreed about the suction cups. An extra pair of hands might be good here as well.
I agree, I’m using iFixit suction cups right now.
Go very slowly when lifting the display – give time for the adhesive at the bottom edge to stretch and flow. If you lift too fast, the glass can crack. That’s what happened for me.
The stickiest location on my iMac was the mid-to-lower section of the right side. There are a couple of thicker areas that needed attention from the plastic cards.
This is the step where I cracked the screen.
Did you use the pizza cutter tool first?
Dan -
WARNING!!! This is where you can crack you screen. TAKE YOUR TIME! Everything work fine for me because I took my time. I was very shocked at how fragile the screen is. It does have a small amount of flex but don’t push your luck. There were two things that made this easy for me #1 Once you have used the cutting wheel to your best judgement to cut the adhesive, start using the iFixIt plastic cards as spacers and space them evenly around the screen. I used 10 individual cards of and gently moved them up and down at each section two at a time. Once I started having less resistance, I combined 2(i.e. 5 sets total) cards evenly space to allow for move rigid and stronger movement to separate the screen. This really helped me to free up more adhesive. #2 before lifting the screen up fully, use tweezers to pull the adhesive like a string from around the entire monitor. This will make lifting the screen much easier since all adhesive will be removed. Finally when lifting the screen use the cards with your hands under them.
Would any of you consider the possibility of heating the glass with a hot-air fan before starting the process? In that way, the adhesive would let the screen go easier, I think.
The type of tape has a lot to do with it. If the original tapes are still present then the pizza tool slices through the thin foam core of the tape so heating is not needed. If on the other hand someone replaced the tapes with just regular double sided tapes then there is no foam core to split and there is a sizable risk the display will get damaged in the process of taking it off. So sure in this case a bit of heat might help, just be aware the LCD panel area is quite close to the edge along the top three sides so you also have the risk of dating it from over heating!
Dan -
If not for iFixit tuts and tools, no way I could do this. iMac 27" takes the prize as the worst design ever for upgrades/maintenance, what were they smoking when they designed it like this?
I have always believed that a properly placed screw can be a beautiful thing. A few decorative, but functional, screws placed in the back of the iMac case to attach the screen would be awesome, but this method is anything but beautiful and borders on insane.
While holding the display up with one hand, use the other to unplug the display power cable.
Mark all cable connectors with a spot of white correction fluid before removal. This will remove the risk, when reinserting them later, of getting them the wrong way round. Yes - I know they will only plug in one way round, but it does make life easier if you are not in perfect lighting!
At this step, if you mess up anything with these 2 cables, especially when plugging them back in, even if you think you’re following the instructions here to a T, then you’re screwed.
Quote - "Beware, if you’ve never done this before, that be locked out of ever being able to use an Apple repair facility, or Apple-authorized repair facility" You cannot be serious can you? So because someone attempted to repair their own Apple device that they OWN, you are saying that they may/will be locked out of using any Apple repair service again? Ridiculous claim sorry.
The display cable, the wider one, has a lock on it , usually a plastic tape lift tab to release it, once thats flipped it should come out fairly easily, if your experiencing resistance and the cable isn’t coming out then check for this lock/latch, the power cable just pulls out, just don’t rush it everything should go fine, fairly easy to do with the end result a working iMac
Is it possible to replace the power cable if its damaged? I can’t seem to find anything about this.
After finishing my hard drive replacement I reconnected these connectors to test my display before using new adhesive. Everything was working beautifully. But then when I applied the new adhesive and went to seal the display on for good - the display power cable somehow became disconnected! I had to reopen the Mac for a second time which was far more difficult with new adhesive. When reinstalling double and triple check that the cables are securely inserted before the final seal. Sounds obvious but it’s quite the annoyance if something goes wrong at this point.
Very difficult to work with these connectors.
Power cable very difficult to unplug - data cable veeeeery difficult to plug in.
I noticed that working with the iMac positioned vertically (and with a proper support for inclination) makes this step slightly easier…
Interesting comments.. personally, I didn’t find the cables particularly difficult to detach and reattach. You do have to be patient and gentle. Personally, I found that a rolled up beach towel gently wedged between the unit and back of the display helped keep the glass up. Also, a small flashlight can be helpful to see the cables and connectors if you’re lighting isn’t perfect.
I’d agree to John - not overly difficult. My workaround was to prep the screen for re-installation and then place it in front of the standing machine. The cables are long and flexible enough to be put in place even in this state. You can easily attach the cables and continue with fixing the screen to the housing.
I would not recommend doing this step as pictured. The cable you are removing has little tabs on the wide side that can be depressed inwards towards the center of the connector, releasing the cable. If you just grab the cable as pictured and yank it out, without depressing the side tabs, you are likely to damage something. Don’t pull on the wires, use your fingernails at the connector to squeeze the very small little tabs inward to release the cable from the connector.
The removal of the LCD power cable does require the left and right sides to be squeezed inwards towards each other first before removing, why this isn’t mentioned in the take apart can lead to damaging the iMac.
I agree with maccentric. DO NOT just pull the power cable. Use your fingernail or spudger and gently press the tiny notch inward and towards you gently and one side will disengage. Do the same for the other side and it will slide right out. The notches just have enough edge to catch your nail or spudger. Using your nail is better as you can better feel when you have caught the edge and can feel the cable move.
I lifted the display a few inches up and propped it open in the middle using my iPhone in portrait mode with its torch on. Did the job nicely:
Flip up the metal retaining bracket on the display data cable.
Disconnect the display data cable.
I replaced HDD to SSD and assembled parts again. When I boot up the iMac, I found black lines on display (looks partly not broken).
I searched Internet, and some says graphic card problem, but I didn't touch anything but cable to lift up.
Could the damaged display data cable cause this situation? I hope I could fix this by just replacing the cables..
Sorry, Black lines is a damaged display assembly ;-{ In the process of removing it you either pushed the tool into deep or you torqued the glass severing the tiny wire traces.
Dan -
Same trouble here, is it cable trouble or connector trouble?
Sorry damaged display
Dan -
I think whenever words like "...is a delicate connection that can be broken. Be sure to pull the [cable in a certain direction] ANYTIME.... It is worth either a closeup or 2, maybe one with annotations or insertion directions and maybe a motion direction arrow with the something like and 'X' char or a circle division slash over the wrong one.
I agree! +1
Yes, John is absolutely correct on this one. I damaged the display cable trying to get it back in. A close up would have helped and now my computer might have actually been fixed.
[|There are 2 cables to disconnect on my Mac (?). Also, I don’t see a metal retaining bracket. I can take a picture, but cannot attach. I got the glass loose with no problem, but am worried about damaging the cables]
Hi Jim! You can go to our Answers Forum to post some better images of your situation!
Can anybody upload an image of how the display can get damaged from removing it? I find it hard to believe (though I’m reading the horror stories here) that a whole display can get damaged. Especially when many of us were following to a T and being VERY CAREFUL.
Thanks.
First: During reassembly, I highly recommend you connect these cables and do a test boot BEFORE you remove the protective tape on the adhesive strips. That way you can fix any issues(like a damaged cable) if something is not right and you have not re-glued the screen back down which will cause a problem. If you have a second person and everything is working after test boot, you can just leave the cables connected, lift the bottom of the screen and have 2nd person pull the protective tape on the adhesive strips and you can set the screen in place. Second I damaged the video data cable during reassembly on my late 2015 iMac- I did not get the connector straight and I damaged the wires on the cable. I recommend you have someone else hold the screen while you attach the cables - they are fragile. Luckily, the data cable was easily replaced for only about $20. If you must do this by yourself, just be careful I highly recommend have 2 people at this step during reassembly.
At least on my “late 2013” model, the smaller display cable connector has tiny, tiny clips on the outside edges. These must be squeezed to unlatch it. Don't pull on the cable itself or the wires can be pulled out. Even with my small fingers, it was hard to grip the clips. When reconnecting, the connector will lightly snap into place.
I managed this step without any problems, but I had my wife hold the screen up while I disconnected/connected the cables. I STRONGLY encourage another pair of hands here so you can focus your full attention on being ultra careful with the cables.
On the 2015 there are 2 cables.
1. Once the display is loose use the Mac foam block sold from Ifixit to keep the display from rocking to hold open the glass
2. Blow out dust with canned air
3. Get a flash light and small flat edged screw driver
4. Use the screw driver to slow pry loose the connector from the socket by gently inserting it in the gap on the left and then on the right slowly easing the connector from the socket towards the top of the glass
5. The more center connector has a pull tape and a wire loop. Lift pull tape and the wire loop will raise up.
6. Pull the wire loop towards the top of the glass to slide out the connector from its socket
Good instructions except for the screwdriver - try and use a plastic spudger instead ! Also, getting a headworn LED light makes life a bit easier.
Have a late 2013 model and went to do the SSD upgrade. When going to remove the display we cracked the bottom left corner of the glass (just the glass frame part - not part of the screen that displays anything). We were also having difficulty putting re-attaching the display flex cable. Whenever we finally went to test it before re-sealing the screen back on with new adhesive it would sound like it is turning on as it makes boot-up noises and the fans start running, but the screen would just remain black. Just wondering if the crack in the bottom left-hand side of the glass/display would have damaged a part of the display assembly or if it would be more likely that we just damaged the display flex cable (which can be replaced for $26)?
Did you get to the bottom.of this?
does anybody know how the Display Cabel pin assignment is? I want to try if I can attach the Panel to another grafic card
I’ve completed the upgrade to SSD, but while restarting my screen remains black. As if no connected.
I assume I broke the sensitive connector.
—> how to order a spare?
Did you get to the bottom of this?.
is the display assembly of 2015’s the same as 2017’s?
No! Apple loves to mess us up!
Dan -
The panels are different since technology progresses at a rapid pace and Apple does like to be on bleeding edge of things. When they do a manufacturing run of screens, there will be a few years that will have the same screen. I believe 2017 is when they introduced the higher resolution panels. Everything from 2012 late to 2015 should be the same though.
That display cable connector is common to many Macs of the 2012 era. I’ve destroyed 2 in 38 years of servicing all types of computer equipment.
As stated, there is a latch on this connector. If you put any incorrect force on the cable or connector during disassembly or reassembly, you will break the cable and possibly the connector. The cables can be purchased online and the video connector on the display is exactly the same.
I repeat, if you pull out on the video cable after it has been unlatched instead of parallel to the logic board, YOU WILL BREAK IT.
The second time I reconnected the display the backlight and the display stayed dark and only 3 out of 4 leds lit up. I chose to bring it to a repair store to investigate whether only a cable needs replacement or just to recycle the whole machine. The boy who took in the iMac Mid2015 told me he didn't risk this internal replacement SSD himself at home, but had plugged in an external thunderbolt SSD instead to run the OS from. If I had thought of that before...
I asked some repair shop to look at the issue of the screen staying dark. With a flashlight they saw the LCD was getting data.
There were two issues, one caused by the other: A gold pin of a cable was bent. Levels on the mainboard were questionable, caused buy the shortcut made by the bent cable.
They bent the tiny gold pin on the cable back. I don't know if the shortcut solved itself that way.
They stated: Apple tells the power cable is never the issue, mostly something on the mainboard.
At the time of putting the datacable in the second time it was a bad lighting situation and someone working on my nerves in the room. It didn't go completely smooth, I had put it a bit towards one side.
So if that happens, draw back, try to look at the tiny pins and retry before continuïng.
This repair has cost me €118,20
Lift the display up to a near-vertical position.
Remove as much of the adhesive as possible by grabbing it at the outer edges, and then pulling or rolling it towards the middle.
Thank you Stef, that's what i will do next time, i cracked the lower part of the screen went opening very slowly, that's probably why those "tabs are for !!
Thanks Stef, this has saved me! Simple yet very effective.
Yep, I cracked the lower corner of the display as well. I failed to work the adhesive enough to loosen it sufficiently. Be careful, I just had to buy my customer another screen!
There seems to be missing a step or two. As I was removing the old display, there are two wires that need to get transferred to the new replacement display. There is not note about these two wires located at the top of the display. The 1.128-inch ribbon cable and then this other 4-inch long, two-wire cable that goes to a very small circuit board that is 1/4 by 3/8 of an inch and seems to be adhered to the panel.I have not been able to get this cable off the old display. There is a port for it on the replacement display.
Note: When ordering this screen, and plastic cards as noted tools, ifixit.com did not list the pizza cutter or the new replacement adhesive strips. So now I’m not sure how to get the new one on and secure.
Are you sure your trying to remove a late 2013 model A1419 display assembly?
robert -
The adhesive strip along the bottom is designed with a pull tab on each outer end. Rather than lever and pull the screen simply carefully pull the tab which removes that half of the lower adhesive strip and frees up the screen.
Niemals den unteren Klebestreifen mit einem scharfen Gegenstand wie Rasierklinge oder so versuchen zu trennen, davon geht die Beschichtung des Displays kaputt und man hat hässliche Streifen unten hinter dem Glas. Stattdessen lieber versuchen, das Display nach oben zu klappen und abzuziehen.
translation from Bas Ti because this is very important:
Never try to separate the bottom adhesive strip with a sharp object such as a razor blade or something, the coating on the display will break and you will have ugly strips at the bottom behind the glass. Instead, try to flip up and pull off the display.
If you are just replacing the hard drive, I have found that it is quite possible to do while leaving the screen connected, making the process much easier. The amount you need to tilt the screen to access the little pull tabs at the bottom to release the screen is also sufficient to access the drive. I remove the drive while the iMac is upright. I also heat up the bottom of the screen to soften the glue and to help with the possibility of the glass cracking while doing this step.
Very dangerous! You’ll stress the cables and the logic board connectors.
Dan -
I meant that you can leave the bottom strip of adhesive attached; you still need to disconnect the 2 cables.
As mentioned before you can pull out the lower adhesive strip. Dont cut it or move the display up and down. This is even more dangerous. On the lower side of mac where the display glass ends is a offset. When moving the display up and down you might crack it over that offset.
When removing the adhesive from the top of the screen, be sure to start at the iSight camera location (= in the middle). If you start at an upper egde of the glass (side doesn’t matter) towards the middle, you risk removing the black background foil from the screen, which will result in ugly stripes behind the glass.
Really risky to crack the glass reading these comments. When I pulled the side tabs. one broke 1/2 way and the other tab just broke. Maybe because I had iMac laying on its back with the weight on it. Next time I'll try with it standing.
I lined a bunch of ultra thin cards to protect the bottom glass against aluminum frame while wiggling slightly. Make sure the cards are all the way to the edge (unlikely my pic) to protect that sharp corner. This help to protect the glass against the aluminum while I tilted slightly back and forth (~30 degrees max)
Then I bent a small corner of the thin card, inserted from the edge and slowly cut across which probably cut about 1/3-1/2 of the tape width. Followed by a larger bend to cut it completely.
ISO to weaken the tape is possible IF you know where the microphone is to not damage that.
Super risky. If just want to replace the drive, much safer boot drive a USB3/USBC SSD
Sounds like you didn’t follow the guide as I’ve done 100’s of systems and haven’t broken a display opening a system. The trick is the special pizza cutter to slice through to tapes. If someone uses the wrong tapes or straight glue then you can encounter issues. I’ve had to use heat to soften the glue on one system sadly the heat killed the display the customer was aware of the risks and won’t fall into that trap again.
Dan -
I have pizza cutter. Cut top and sides no problem. Did 2x 21.5" without problem. 27" bottom long strip is the risky area. I have pro supply distributor tape + adhesive promotor + fully clean the tape surfaces so don't use glue / wrong tape. I put a safety fishing line on the 21.5 although that wasn't necessary judging by the fairly secured assembly. Maybe more necessary on the 21s.
And yes, I didn't dare to do heat with LCD diffuser sheets so nearby.
My note is just the bottom long strip on the 27". Didn't dare to tilt screen vertically after reading these comments and outlined my method to cut the bottom strip.
If necessary, a plastic card can be used to cut any remaining sections of the bottom adhesive strip.
Would have been helpful to box the same red area when using the plastic card to separate the glue. Since the red blocked picture is inverted, if someone doesn't pay close attention it may not be obvious that the area of concern is at the right top of the graphic pictures in which the plastic card use is being demonstrated..
you don't need to cut the bottom part as the bottom tape is stuck on each side and you can easily pull it out
What is the twisted wire taped to the back of the display that can bee seen in the upper right of the first two pictures? I have an 27” iMac without a screen an my replacement does not have this wire. I think it is a temperature sensor but do not know where it connects to.
[|I opened up my iMac and there’s no HDD or SSD in that spot. its just empty.]
You probably had just an SSD installed and no HD, which is on the opposite side of the motherboard (and quite a bit more work to access).
Please update the picture to include the RED BOXED IN AREA that you refer to on all three pictures in this step. I have had a few zaps from these supplies and it is not pleasant.
J’ai réussi à intervenir dans l’iMac sans décoller l’ensemble de l’écran. Je l’ai ouvert en laissant la dernière partie collée (vers le logo Apple) et qui sert comme une charnière. Bien calé et assuré l’écran n’a pas bougé et j’ai pu changer mon disque dur facilement. Le grand avantage et d’avoir l’écran toute suite juste quand on le recolle par la suite.
Well, I of course touched a soldering point in the red area as my hand slipped. I heard and felt a tiny “click” and after replacing the HDD with SSD etc I can not power the iMac up anymore. Not a sign of life :-( I suppose I broke the power supply. Can someone confirm? Or could something else have broken too?
I took my time and pulled both tabs slowly gently. Easily removed and glass came right off.
Before removing any circuit boards or speakers remove the 4mm bar that runs the width of the case, behind the bottom edge of where the screen sits.
It is amazing how much easier you will find it to remove the speakers and circuit boards with this bar removed.
However, before you remove the bar insert a sheet of paper between it and the circuit boards to prevent a short circuit.
The bar is held in by 5 small Phillips head screws (first pictured in step 22).
Once you remove the bar bend the sheet of paper over the front of the case to keep it in place and then remove your circuit board(s).
Lift the display up from the frame and remove it from the iMac. Lay the display face down on a flat, soft surface.
It may be necessary to slowly lift from one side, to peel against the remaining adhesive.
You really should be using film handling or surgical type gloves to handle the screen to minimise finger grease on any of it. Even if it’s possible to clean most of it off, it can be corrosive over time.
Use a large suction cup and latex gloves for this:
I think iFixIt should have mentioned this step might be safer using a suction cup as mentioned by Philip.⏎
I thought following the guide, holding the screen on each side would be fine, but the glass cracked almost immediately.I did not grab it by the corners, just the middle of the glass.
This glass is horrendously fragile. I don't think I can afford to repair the screen :(
Lowering the screen down at the end here does not need a suction cup. It sounds like you left something in the channel so you fractured the screen from the object (a loose screw?). I've done a ton of these systems and have not needed a suction cup at this step. I do agree a suction cup can be helpful in the screen removal process. just to give you a better purchase, not pulling! As you can damage the screen if you pull too hard.
Dan -
Thank you so much ifixit! You're instructions are so very clear! Thank you again!
If there is a wire or cable underneath adhesive tape, always pull the tape off first.
If the cable is glued to the chassis, use a heated iOpener or a hair dryer to soften the adhesive first. You can then slide an opening pick underneath the cable to loosen it. Never pull directly on the delicate connectors.
Slide an opening pick underneath the foam cushion pieces to separate them from the display, and gently pull them off. You may need some double sided tape to re-attach them to the new display.
Be extremely careful removing the LCD Temp Sensor from the rear of the screen. If you pull the wire, you run the risk of severing the metal wire from the connector but not notice it because the surrounding plastic insulation may still be intact. Use a razor blade so “shave off” the sensor under the adhesive. I just had the screen replaced by a local shop and, upon boot, the fan was running full-speed and the Mac’s speed was miserable; Excel took 30 bounces in the Dock to launch rather than the expected 4-5. Novabench showed the Mac running at 4% of its expected speed (overall). The tech examined the sensor carefully, found the broken connection, soldered it back into place, and all was fine. Note that the (partially disconnected) sensor actually showed up when I ran Macs Fan Control in an attempt to work-around this. No problem controlling the fan speed then but the iMac’s running speed was awful until the disconnected sensor wire was fixed.
Hi barryjaylevine,
I’ve had my LCD replaced on my iMac 27 / 2013 and there is no LCD Temp Sensor cable on the replacement screen.
I’m experiencing the same performance issues.
I’ve ordered a new sensor, do you have any pointers as to how to install it?
Thanks,
Simon
UK
hey Simon, I used 2-sided tape….this is assuming the new sensor doesn’t already come with an adhesive surface already applied.
a roll of kapton tape for your own peace of mind will make sure nothing detaches from thermally-induced adhesive crystallization
make sure you position it in such a way that you can easily plug the lead back into the mobo….not a lot of length to that wire
Howdy folks,
Thanks for all the tips, LCD sensor fitted and iMac back in action.
Never again!
Simon
Hello all. So I’m trying to pinpoint my backlight issue on my 2015 retina 5k - I noticed I’m missing my thermal sensor on the LCD. Would this help with the backlight? I’m sure it will keep my fans from going crazy. Any help would be appreciated! Note: I have LEDs except the 4th one. Thanks!
Be careful when removing the adhesive residue!
I didn’t know it, but I ended up leaving slight scratch marks that can be seen from the front side.
Hi all. The 5k screen on the iMac 27" I bought on eBay was totally trashed when it arrived at my home. I was able to find a new 5k replacement screen for it (also on eBay...) which works perfectly. I should note that the new screen did not arrive with a LCD Temp Sensor on it. I was able to Carefully Remove the sensor from the old screen and attach it to the new one successfully. Follow the advice in previous comments regarding removal and re-attaching and you'll have no problems (and save some money). I've had zero problems with it in the last year, so I think this could be a viable solution to a missing LCD Temp Sensor.
Use a Phillips screwdriver to remove the nine 3.2 mm screws securing the support bracket.
You may need to peel up the display adhesive lining the bottom edge of the iMac enclosure to access the screws.
These are new steps from when I did this on my late 2015 retina iMac so I believe step 25 and 26 are optional (you can cope without doing it).
I did not find it necessary to remove these screws and this bar
I lost these 8 during the reassemble. The manual tells I need eight 3.2mm screws.
Can anyone help to clarify what screws I need. I don't really understand this size. Is this M2x3mm?
Remove the lower support bracket (a.k.a. "chin strap") from the iMac enclosure.
No comments on this ?
It's quite possibly the most difficult part to put back in the entire process
The screws are tiny and the there is no easy way to line up the holes on the bracket with the screws
Having got this far - it wasn't even all that necessary to remove this part in the first place
Severe pain in the neck
After an hour of painstaking mess - I managed to get 7 out of the 9 back in
By that time I could care less about the remaining 2
With the right tools and technique, the bracket can easily be replaced in under a couple of minutes.
Use a screwdriver with a magnetized tip which frees up one hand and place a screw on the tip first.
Then line up the screw hole on just one end of the bracket and using a pair of tweezers from the side, hold the bracket in place while you put in the screw.
Next, do the same on the other end of the bracket. After that, all of the screws in the middle are quick to replace. I didn't really have to touch the bracket again after the end screws were in place.
Hope that helps someone else since removing this bracket does make later steps a bit easier.
I used Max Z tweezers technique but screwed one screw in at the end and then worked my way to the other end.
Max & Stephen are correct. Not difficult at all if you start at the right end (either end, probably, but I liked staying away from the power supply), and use a magnetic driver.
Remove two 10 mm T10 screws.
I found i didn’t need to remove the speaker nor the hard drive. In fact I managed to remove the old PSU without even removing the chin strap. However, to install the replacement PSU, I had to remove the chin strap. So I would say, remove the chin strap, but you can optionally leave the speaker and hard drive in.
While you do not need to fully remove the screws as once you loosen them a few turns the speaker becomes free. I found that after the removal of the speaker, I turned it over and popped the screws out as this made it easier to replace it later as I could see the alignment before putting the screws back in. If not you may be off a little and you do not want to force the screw back in.
I used a pill container that I got from Walgreens to hold all of the fasteners I removed during the disassembly process. The container has 14 compartments (individual compartments for each morning and evening of the week). I put a small piece of paper in the compartment with the fasteners to note the name and step of the procedure and the size of the tool I used. Hopefully this will be useful when I go to put it back together again.
Unplug the left speaker cable by pulling it straight up out of its socket on the logic board.
De-route the cable from the gap between the hard drive and logic board.
I didn’t unplug and de-route this cable. Later, Step 29, has you remove the left speaker. This isn’t necessary. If you can just move the speaker over to expose the hard drive mounting screws, so if you’re not going to remove the speaker, you don’t need to unplug it.
on the 2019 iMac, it is horizontal not vertical so pull it horizontally out.
Use a spudger to disconnect the power button connector from its socket on the logic board.
Can someone explain what are the solder joint? Or tell me what it looks it?
The silver spots on the circuit boards. You may not want to tackle this alone. If you touch these areas, you can possible get a shock -- harming you and your computer.
Robert -
there is no need to disconnect the speaker, just unscrew it and move aside slightly to reach the HDD screws (about 5mm) - if you want to replace just the main HDD
Take note of exactly what direction this tiny little wire was.
The connector has a plain black side and the other side you can see the 2 silver connectors.. the side you can see the 2 silver connectors faces the front.. the plain side is to the back/against the logic board.
If I leave my iMac unplugged for an extended period, say 24 or 48 hours, is it still possible to get an electric shock from the PSU? Do the capacitors eventually discharge?
you can do this method, or just wear latex gloves.
make sure you’ve actually unplugged the mac when running this cable, and not had it plugged in to test the diagnostic LEDs, because one of those wee silver spots is carrying 230v, and its 6mm away from the place the cable runs, So if you have fat fingers like mine, that’s a free wake up zap
I don't understand how people can say that you don't need to remove the speaker, unless all they were doing was replacing the SATA drive with a 2.5-inch SSD. If you're using this guide to replace the SSD on the back side of the logic board, you definitely need to remove all the components.
Lift the left speaker straight up, until the power button cable is exposed (about 0.5 inches).
This is MUCH easier to do if the support bracket along the bottom is removed first. See iMac Intel 21.5" Retina 4K Display (2017) Logic Board Replacement step 25.
Use a P00.
To replace it, introduce it like in the photo at the link to be able to hold the right most holes of the chassis and bracket. Replace the first screw, align the bracket to the horizontal and add the screws from right to left. Each one will bring up the next hole in the bracket close enough to screw through. Reverse those directions if you are a leftie.
Gently de-route the power button cable from its groove in the left speaker.
Pay attention: if pulling out the loudspeaker tear off the wire of the power button, Apple have not any service parts except for the whole rear housing!
Use a P00.
Lift the left speaker straight up and remove it from the iMac.
Push from the connector end as you pull from the speaker end to thread the cable under the hard drive's right bracket.
I found it wasn't necessary to remove the speaker from the left side to remove the hard drive. You can remove the screws, and then slide it over to the left — giving more than enough room to access the hard drive.
me too. don't need to remove it if you only want to change the hd
Agreed, wast of time to fully remove the speaker.
It is difficult to remove the bottom of the speaker because it bends into the frame. Be careful to remove the power button cable, which also routes in a channel in the bottom of the speaker.
easier to remove the speakers if you unscrew the front ‘chin strap’ - 6/9 phillips screws that you can see in the picture hold that aluminum piece in place
Agree. This is MUCH easier to do if the support bracket along the bottom is removed first. See iMac Intel 21.5" Retina 4K Display (2017) Logic Board Replacement step 25.
Use a P00.
The trick with removing the left speaker is that you have to slide it up toward the top of the iMac (continuing to de-route the power button cable carefully as you go) to get it out from under the chin before you lift it up to remove it.
Pull straight up on the SATA data/power cable to disconnect it from the drive.
Is the WD hard drive an Apple Special with some internal rom or other thing? Planning to put in a Seagate Firecuda 2TB. Is there some special plug or temperature sensor requirement? Seems like there is only the SATA connector. Will I encounter fast fans? (can load the software to stop that). Think it’s a swap and is “easy”.
Depuis quand un disque dur est soudé sur la carte mère...au dire d'un dépanneur il semblerai depuis 2019...pourriez vous le vérifier???
Remove two 7.3 mm T10 screws securing the left hard drive bracket to the rear case.
If you have the iMac sitting upright, there is a potential risk of dropping the screws into the iMac casing. Be cautious or lay it down flat.
Been there done that. Had to flip it and shake the heck out of it to get that srew to fall out!
Left hard drive bracket screws are T8!! Had to remove HD first before derouting left speaker cable.
Thank you iFixit for sending a T10 with magnetic tip. You saved me!
The bracket screws are T10. The screws on the left side of the SILVER hard drive itself, are T8. If you seem to need a T8, you are actually trying to remove the wrong two screws. Look immediately to the left of the hard drive & you will see the BLACK bracket frame with two screws that use T10.
I can confirm that some models are indeed a T8 on both sides of the bracket (NOT the drive itself). I have two 2015 A1419 and one is T10, the other T8
mine were T8s
Bracket to iMac case screws,T8.
Which is fine.
Just as in the next step, T8 or T10.
Grab the hard drive and left hard drive bracket together.
Tilt the left side up away from the rear case, and slide the assembly to the left.
Remove the hard drive and left hard drive bracket from the iMac.
Two notes here: If you are using OWC’s Thermal Sensor HDD Upgrade Cable, be sure to tuck the cable under the hard drive slightly. You cannot allow the connector to sit near the top edge since this will not allow the monitor to sit flush with the chassis when it is reattached. Additionally, the SATA connector does not seem to fit together as snuggly as when it was connect to the HDD, so tape or a plastic cable tie to keep the connection tight may be good insurance to prevent it from coming loose.
If you are planning on dual booting with Windows 10, the Windows 10 installed failed when the SSD and HDD were both connected at the same time. I had to disconnect the HDD until Windows 10 was installed. Note: I did a fresh install on a new SSD not configured as a fusion drive. If you are planning on doing this as well, use packing tape (or something similar) to hold the monitor in place until after installing the OSs. Then reconnect the HDD and apply the adhesive to the monitor for a permanent seal. Good Luck!
Hi Walter, i’m looking to replace the broken fusion drive with a SSD, do i have to get the OWC’s Thermal Sensor HDD Upgrade Cable?
Full removal of the speaker is unnecessary - just very carefully unplug the two-conductor power button cable, which is routed through the groove along the edge of the speaker enclosure. Next, unfasten the two large torx screws holding the speaker enclosure to the chassis. Now you can easily scoot the speaker away from the drive mount - move it over just enough to reach the drive mount’s 2 torx fasteners beneath the edge of the speaker (a CM or two). There’s now enough room to easily remove and replace the drive assembly .
Just wondering if the HDD 3.5 (3TB) in my 2015 27’ 5K iMac case are the ones with the temp control firmware onboard. Just got quote from Auhorised repair centre for 2x the normal price of a 3TB drive. They say I can drop in one i source myself if I like but I don’t want to get it back and have the fans run all the time. Thanks in advance :)
Remove the left hard drive bracket.
This step is unnecessary. Just leave the bracket in place and set the assembly aside.
On Late 2015 27” iMac I found that after removing this speaker, and the Right side one, I could reach under the motherboard and squeeze and disconnect the SATA data connector with a needle-nose and then remove the SATA power connector and slide the cable out from under the logic board without removing the board. The new cable slid in from the hard drive side with little effort.
If switching to an SSD, the posts on the drive can be removed and used on the 2.5” to 3.5” adapter tray.
Disconnect the power supply control cable from the power supply.
I found this cable very difficult to disconnect, be very careful because the cable is between a black tape and it's stuck very hard to the logic board and the cable is very short and you don't have space to move and separate it from the connection! Be patient and take the time you need
I found than putting the flat end of the spudger at the center of the cable, and tilting it got the cable out without an issue.
I was able to use the flat end of the spudger on the sides. You can see a tiny little clip on each side. Be very gentle!
I simultaneously used the fingernails on my 2 index fingers to dislodge the tabs and continue to pull the cable out. It took a couple seconds.
ultimately the trick for me was to just pull hard enough, but that part is the scariest part. any tips welcome
These connectors seem pretty tough to remove until one understands the latch. Each side of the plug are two little sprung tabs (the tab is part of the spring clip which runs down the side of the plug on each side - makes sense once you see the removed plug!). Squeeze them in towards each other and then gently pull the plug from the socket. No great force, or even the spudger, needed once that is done.
One more tip, has worked on other cables for me. Fish the skinniest spudger tip you have under the cable, and with a finger of your other hand put opposite pressure on the cable against the spudger and gently work it out
If u are right handed, i can recomend to use your index left nail to press de bottom sprung, and a flat spudger on the right hand, came off so easy
Davo Montiel's tip worked for me. Use the fingernail on your left index finger to press in the tab on the bottom side of the connector and with the right hand use a flat spudger to press in the tab on the top side of the connector.
If you have a insulated long nose pliers along with a splugger and can get underneath the cable WITH the long nose pliers on the RIGHT side of the cable, towards the logic board, with the splugger on the LEFT Side of the cable doing the same, you can get the leverage to GENTLY pull this cable out very easily.
Remove the following four screws securing the power supply to the rear case (size T8 or T10 depending on the exact model):
Two 23.7 mm Torx screws
Two 7.3 mm Torx screws
Move the power supply board towards the left edge of the case and up to free it from the notch in the logic board.
Use a P00.
The top right screw on the power supply actually screws into a stand-off screw connected to the back of the iMac case. Once you have removed the 4 x Torx 8 or 10 screws you can move the power supply enough to see the upper face of it.
It has a Torx 25 slot in it and comes out easily. This will give you a lot more room for your fingers in Step 40, depressing the tab on the DC power cable connector to pull it out, and when replacing it on reassembly. You may find it won’t require you removing the support bracket as in the suggestion above.
Depress the tab on the DC power cable connector, then pull it straight out of its socket on the back of the logic board.
Remember to push in the disconnect tab on the large connector. Carefully insert your finger and push on the tab before you pull on the connector.
Thank you Manuel, this was a tricky one.
Yes, I pulled the whole socket out because I didn’t know about the tab. Fortunately I was able to place it back in. Not sure if it was glued or how it was anchored but it seems to have a solid connection and I can’t easily pull it out by hand. Once I plug the power cable back in should be ok.
This connector was very difficult for me to remove (even after pushing the disconnect tab). Eventually I had to use a pair of needle nose pliers to wiggle it back and forth out of the socket. A lot of the cables on the my late 2015 model were very tight and a struggle to get out.
I'm struggling with this step. I presume that the tab to which you are referring is behind the connector. I can see a plastic protrusion there but it does not move when I push it. Just to get my finger behind it requires the power board to be moved quite a bit btw.
Pressing on the release on the back with my finger and at the same time using a needle nose pliers to wiggle the connector with my other hand worked for me.
i could not get it out by the force of my fingers, so what i did was slightly turn the imac 90 degrees so i could reach the area better, push up (so, vertically) the power control board, push in the tab on the bottom of the connector with my right hand, and slightly wiggle the connector out of its socket with a plier
removing the chin strap (the front bit of metal running along the bottom of where the screen was) makes this much easier as you can rotate the board and get to the underside
Left index finger pushing on the tab from behind the connector, using needle pliers in right hand to rock up & down did the trick thanks @starfleet_tone
Just be careful! I’ve seen two systems where the socket was pulled fully off! So the logic board then needs repairs or replacing being just a bit too aggressive!
Dan -
Needle nose and wiggling worked for us too. We were stuggling like heck with it when just using hands!
This is MUCH easier to do if the support bracket along the bottom is removed first - more space to angle the board upwards. See iMac Intel 21.5" Retina 4K Display (2017) Logic Board Replacement step 25.
Use a P00.
I did as Andrew Gough did, per other videos reviewed. Removed it right away. Just makes things easier, more space for just a few screws :)
I used your suggestion to remove the stand-off and then used my left hand index finger to press the tab while rocking the connector side to side with a needle nose pliers. Plug came out easily.
The tab is a pain in the a$$$ to get your finger in there. I was so horrified at the size of the capacitors that I put on gloves to reduce any amount of shock :-) . To get it loose I would pull out carefully the power board as far as I could than I wedge my index finger under and press the tab and slowly pull until I saw a slight gap between the end of the socket and the plug. I than place the flat part of the black spudger or blue one into the gap and use as it as a wedge to help move the plug forward as I kept the tab pressed.
Flip the top of the power supply towards you, like opening a mailbox, to reveal the AC inlet cable connector.
Disconnect the AC inlet cable connector.
To reassemble, do the same in reverse but keep power supply board more upright than slanted down when re-inserting it in to the lower right corner. The lower right screw post has an protrusion under/behind it and the Power Supply's small 2 wire plug must fit between the front of your Mac and the obstruction. Then it just slides right in and then screw it down.
There is a small release tab on the cable.
Wear gloves when doing this to reduce any shock. The size of those capacitors are very unnerving and scary. Also those solder joints.
Remove two 10.0 mm T10 screws.
Gently rock the right speaker slightly to the right, to allow access to its cable's connection on the logic board.
Use a spudger to loosen the right speaker cable's connector from its socket on the logic board.
Pull the connector to the right to remove it from its socket.
Wenn ihr den Lüfter entfernt habt sieht man die interne „ssd“ mit einer Zange kann man dann die Befestigungsschraube lösen und das defekte Speicherelement entfernen.Mein Mac startet und läuft jetzt wieder Tipptopp. 19.7.25 lg Stifi
Lift the speaker straight up and remove it from the iMac.
Did this tonight. I couldn’t get the right speaker out. But I was able to move it far enough to the right to be out of the way of the logic board.
You have to remove the five small screws on the lower edge of the iMac to remove a strange bracket or something, like the 21.5” 2012->… iMacs
Same here. 2013 27”. If you remove two of the tiny screws along the bottom edge then it comes out.
Use a P00.
During reassemble, route the speaker cable behind the two protrusions under the logic board. I am not sure if this makes a huge difference but that’s was the configuration during disassembly.
As with the left speaker, you need to slide the speaker toward the top of the iMac to get it out from under the chin before lifting up.
For reassembly I had to undo the screws again, then plug in the cable with the speaker module slightly out of its final position and after that insert the module and fasten the screws.
Use the tip of a spudger to disconnect the fan cable's connector from its socket on the logic board.
Peel the black tape connecting the fan to the exhaust duct back slightly.
Leave the tape in place on the exhaust duct—you only need to expose the joint to free the fan.
Remove three 12.4 mm T10 screws securing the fan to the rear case.
Remove the fan from the iMac.
Use a piece of tape around the antenna cables to keep them in the same order, makes reassembly a little easier.
On reassembly, start the fan power connector into its socket while you slide the fan in.
I left the antennas attached to the wifi card and removed the wifi card with wires attached. I accidentally broke one of the connectors on the wifi card and had to replace the entire card....
Use the flat end of a spudger to disconnect each of the four antenna connectors from the AirPort/Bluetooth card.
Leftmost
Top
Upper right
Lower right
My iMac has a slightly different assembly. There are 2 - T5 torx screws holding little clamps for each cable (2 clamps per screw). Certainly more secure but another size screw to deal with…
My iMac also same with Greg mentioned. need to T5 torx driver. A1419. Late 2015, Korean Version.
My 2017 has long WI-Fi card, It’s It’s a M.2, cuz no remove antenna. Undo WI-Fi card fix screws and pull out card. Easy one.
Before I disconnect the cables, I use different color sharpies and draw a different color on each one’s head & then I take a picture of the cables connected to the board. Pic is my reference of which cable goes to what connector.
I have a 2017 and I agree with Tanya. There are 2 T4 screws fastening the airport card to the motherboard. It’s easier to remove these and gently pull the airport card straight up out of the motherboard while leaving the 4 antenna wires fastened. You can’t see the connector or the airport card as it’s on the back side of the motherboard but just wiggle it side to side while pulling straight up and you’ll have no problem. I’ve broken off those tiny airport connectors in the past and it’s no fun replacing them.
same as Greg, did with the torx t5
I have a 2019 iMac and we needed to use a T4 screw
My late 2015 has a Airport/Bluetooth card secured with two T5 screws. After removing them you can just wiggle and unplug it from the logic board, without needing to fiddle with the antenna connectors.
Same as the other comments, in my iMac 27” retina 2015, the WiFi/Bluetooth board is a bit longer and the 4 coax cables are fixed by 2 T5 screws…
When reassembling a removed WiFi card keep 4 antenna leads attached as mentioned by poster (tanya et al) when reassembling as you replace logic board keeping it tilted forward helps in aligning the notch on card for easy reassembly and T3 screws replacingonce card is firmly seated.
Can also confirm it for a Late 2015 iMac, there’s just 2 T3 screws to remove, simple move out the WiFi/Bluetooth board and let cable on place.
Flip up the metal retaining bracket on the iSight camera cable.
Pull the camera cable connector straight out of its socket, toward the top of the iMac.
During disassembly, I taped the cable up and out of the way, as it tends to get in front of things.
I recall comments here about this being particularly sensitive. I had an issue with no iSight on rebuild, however taking to bits again and seating and reseating this connector a few times resulted in the iSight camera working again (phew).
Use the flat end of a spudger to disconnect the headphone jack cable connector from its socket on the logic board.
Gently push the cable out of the way.
On my 2017 iMac there is a tiny little cable and connector on the motherboard that is approximately half way along the motherboard and is connected down towards the base of the case. It came free easily when I removed my motherboard but just wanted to remind people to reconnect!
It’s the microphone cable!
This pulls straight up, towards you.
I broke mine…when inserted the speaker… How do I replace the headphone jack and cable?
Lift upwards with the spudger/fingernail, rocking it up back and forth.
(For those who have not seen this style of connector.)
+1 Missing the step on this 2019 iMac 27” guide to remove mic cable. It’s in other guides, just not here.
I cannot determine how to reconnect the headphone jack cable to the logic board. Are there better pictures anywhere that I could access?
Remove the following screws from the front of the logic board:
Two 23.7 mm T10 screws
Four 7.4 mm T10 screws
One 20.8 mm T25 spacer screw
One captive T10 screw
The central screw is very difficult to reach! Use a long and very thin T10 screw driver
On my late 2015 there is another T10 (approx 16 mm long) on the lower edge slightly left of the hole in the logic board giving a total of 4 screws along the bottom edge.
I’ve also found an extra T10 in my late 2015 iMac
My 2017 has small flat cable and connector on logic board. And all screws are changed to T 9
Note: the T25 spacer is behind and to the left of the logic board and below the HDD bracket.
My 2017 had all T8’s, including the captive screw beneath the motherboard
My 2017 had 4 T8 screws along the bottom of the logic board, not 3
Late 2015 iMac - mine had all T8 screws and 4 along the bottom row
Same here, all were T8 including captive screw - 2015 EMC 2834
MotorMac -
On 2019 iMac
Red = T8
Orange = T8
Green = T8
Yellow = T25
In 2017 too.
2017 here.
IMPORTANT - note Tanya’s comment. The narrow flat cable in the middle - it’s the mic cable on a *tiny* ZIF. See iMac Intel 21.5" Retina 4K Display (2017) Logic Board Replacement
Also has the extra bolt middle lower edge.
All T8 except the yellow T25.
In my iMac 27” retina 2015 all screws are T8.
There is also an another T8 screw between the left and central “orange” on bottom of the CPU board
Just completed and removed logic board. All my screws were T6. The screw beneath is a captive screw, stays retained in the fixture after unscrewing.
If I change the logic card on an imac 27’ 2020, will the computer's memory be affected?
There is a 25T stand off that is not listed. It is not on the board but beside or underneath the yellow/red on power supply side.
Pull the cable and connector through the right hard drive bracket. Move the cable to the right side of the iMac, out of the way of the exhaust port.
Anyone know if models that shipped with only a bladed SSD have the SATA cable still inside? I’m guessing probably not, but haven’t been able to confirm anywhere.
The cable was so stiff, I didn’t try to pull it through the bracket. Instead I removed the upper screw holding the right HDD bracket in place. Then I rotated it counter clockwise enough to just move the cable behind it and out of the way. Once I did that, I screwed the bracket back into place. I reversed the process when I put the machine back together. It’s a Torx-10 BTW.
Excellent tip, Kenneth! I did the same, made things easier.
Jesse, no SATA cable inside. My iMac came only with the blade SSD and an empty HDD bay, so I have to buy the SATA cable separately.
the card drive cable is affixed to the heat sink with some sort of adhesive. If it is not placed back similarly, the system cannot sense the heat sink temperature, and the fan will run at full speed continuously. I used double sided tape and pushed it back in adhered position after re-attaching logic board.
the above should read “the hard drive cable” , not card drive (typo)!
Remove two 5.7 mm T10 screws from the top of the heat sink exhaust duct.
My model (2015) had another screw holding the heatsink duct and a stand-off holding the whole thing attached to the back. Even gently moving the logic board almost got the duct damaged till I realised what was going on so I’d suggest to be careful and DO NOT pull the logic board if it looks like it’s still attached - most likely it is!
Carlos,
I am at a bit of a loss. I have a 2015 as well and removed everything else, but the motherboard is still not moving. I found the two, as shown in the picture, but can't find a third one anywhere on or around the heatsink duct. Any help is sincerely appreciated.
Marc
MarcW58 -
Ditto for the 2013 27”. One extra screw
My model 2546 late 2012 has 2 screws on heat sink shroud. First is on left side. The right can only be accessed with board tilted out a bit.
I just finished disassembling a late 2017 27” Retina and for the life of me I couldn’t get the logic board to come out. What. I discovered was that there is a part of the heat sink shroud that is held in place by a stand off boss for the power supply. You will need to remove the stand off boss using a T25. Remove carefully and save for reassembly…
Same here for late 2014.
Yes, there is a screw holding down the fan shroud it is an angled black part where the guy's left hand index finger is located in Step 56
For those like me wondering were is the extra screw: it is not a screw, it is a silver spacer, which must be unscrewed. The spacer is not visible in the picture of Step 55, because it has been removed already. Still, in this picture you can see the hole where the spacer was screwed at the end of the hard drive bracket. This has been said in many ways in the comments, but I wasn't unable to locate it based on descriptions until I've found it myself.
Tilt the logic board slightly forward.
Lift the logic board straight up and out of the iMac. Be careful not to snag on any of the screw posts attached to the inside of the rear case.
You should add a step about removing the sata cable here. When following the directions in reverse I forgot to put in back on and had to remove the motherboard again.
If you are having a hard time removing it, you might have forgot to remove the spacer rod when you removed all the motherboard screws. In my case, it was a T20.
The 2017 iMac has a small cable with a ZIF connector coming from the bottom of the machine that needs to be detached from the logic board before it can be removed.
I can confirm this. As i recognized the cable after i removed the logic board i had some trouble to find the spot where to plug it in.
If you are having a hard time removing it, you might have forgot to remove the spacer rod when you removed all the motherboard screws. In my case, it was a T20. This is in my late 2015 the case. Just like Eric said 11-01-2020.
Same for late 2012. For those curious the spacer is just to the left and appears to attach to the heat sink.
The iMac 27” didn’t come with the PCIe SSD card so of course there wasn’t the necessary screw to mount one.
Here is the screw to order;
https://www.ebay.com/itm/283482947478?ch...
What I did was find a screw that fit. Happened to be the case screw from the iFixit external 2.5” case but since that was a countersunk screw, I fabricated a washer for it.
In my case (Late 2015) I had to remove the HDD bracket (1x Torx, 1x spacer T20) an also two T5 screws from the antenna assembly in order to take the board out.
When reassembling your iMac, be very careful to align the exterior I/O ports correctly. The logic board can sit crooked even when secured with all its screws.
You can use a USB flashdrive or ethernet cable to ensure the logic board is seated correctly while you screw it in.
To help me line up the IO ports, I filled all the USB ports on the back with thumb drives before I screwed the Logic board back down. Worked like a charm!
Ugh! Wish I saw this before. I did this mod and failed to do this step and now only one Thunderbolt 3 port works at a time and the SD card has to get pushed way further to get it to read. I hate taking this thing apart!
Thanks Alex :)
iMac (Retina 5K, 27-inch, 2017) の場合、Thunderbolt 3(USB-C)ポートの位置がシビアです。
Ethernet、USB 3ポート、Thunderbolt 3(USB-C)へ最低でも各1本(合計3本)を差し込んだままの状態でロジックボードのネジを閉めるようにすることを強くおすすめします。
EthernetケーブルとUSBメモリの2本を挿して調整し組み上げましたが、最終的にThunderbolt 3(USB-C)が刺さらないことが後で判明し、結果組み直しをしなくてはいけませんでした。
For iMac (Retina 5K, 27-inch, 2017), the location of the Thunderbolt 3 (USB-C) port is severe.
It is highly recommended to close the logic board screws with at least one cable each (total of three) plugged into the Ethernet, USB 3 port, and Thunderbolt 3 (USB-C).
I plugged in two Ethernet cables and a USB memory stick, adjusted and assembled the board, but in the end I found out later that the Thunderbolt 3 (USB-C) would not stick, so I had to reassemble the board.
Translated with www.DeepL.com/Translator (free version)
貴重な情報ありがとうございました!
I do this job fairly frequently and I have a small box in my iMac tool kit containing a headphone jack, four USB drives, a short two-ended Thunderbolt cable and the end of a red moulded Ethernet cable to keep things aligned from the back when screwing the logic board back into place.
I loosely screw all the screws in, then tighten them gradually, going round the board several times to make sure it lands in exactly the right position.
Remove the four 7.5 mm T8 screws from behind the GPU on the logic board.
Remove the bracket from behind the GPU heat sink.
Remove four black stickers from the back of the CPU heat sink.
Remove four 12.3 mm T10 screws from the back of the CPU heat sink.
Remove the spring plate from behind the CPU heat sink.
Lift and remove the backing plate from behind the CPU heat sink. The backing plate has two posts that fit into alignment holes in the logic board.
Lift the heat sink up from the logic board.
C'est l'étape la plus importante : au moment de retirer le dissipateur, il faut faire très attention de ne surtout pas tordre ou endommager les pins du socket processeur ! Car la cage pour la RAM gêne le mouvement pour enlever le dissipateur et le CPU est probablement toujours collé au dissipateur avec la pâte thermique.
Si les pins du socket CPU sont endommagés le Mac ne redémarrera pas et sera hors service.
Je préconise d'ajouter une étape avant la 59 : démonter la cage pour la RAM, il y a 3 toutes petites vis et un peu d'adhésif. Cela permet d'être plus à l'aise avec le retrait du dissipateur.
Insert the flat end of a spudger between the CPU and heat sink.
Gently pry the CPU up by slightly twisting the spudger.
Remove the CPU from the heat sink. Be careful not to touch the contacts.
Putting the heat sync back on your new CPU is really difficult. I over tightened and borked my new CPU. Also, it's quite possible that you're going to put a great deal of stress on your Logic Board if you are putting an i7 processor in an i5 board. There is extra cooling installed on the i7 boards with bigger graphics cards. I wound up getting new logic board designed for i7 and having a repair shop do the upgrade (Which is a difficult feat in itself as it's difficult to procure Apple parts on your own). I still came out ahead over buying new or buying a used model with the full specs. But only barely. I'd highly recommend working with a friend or someone that has taken an iMac apart before. Look very carefully at how much tension and is applied on the current CPU before disassembly of the heat sync and adding a new one. Once you've done it once it's not to complicated.
I second that note about installing a new CPU. It is VERY hard to put it back undamaged and I too got mine bent.
The way I managed to do it was working sort of upside down: left the board on the desk then sat on the floor to screw the GPU bracket in place first then one side of the CPU bracket one-handed whilst using the other and to make sure the heatsink wouldn’t move and F my CPU again. Only then I flipped the board to attach the other screws which was extra hard as that spring is very strong.
Didnt know about that issue replacing a i5 with a i7 though… saw several guides online where people did exactly that with no problems at all…
Opening my iMac 27 EMC2546 due to a broken display.
It showed me that though iMac are build with will with good parts , Apple surely goes a long way to be extra user unfriendly , like placing the bios battery in such a way, that to replace it is almost as much work as changing a CPU , while it might just as well have been placed somewhere in the memory compartment.
Re the comments about it being hard to put the new i7 in.. I’ve done a few now and actually found it ok. Put one of the four bracket screws in but only by a few threads. Then put the diagonally opposite one in the same amount. Then put the remaining two in - the last one is always the hardest. Just apply a little pressure to the bracket. Then tighten the four screws a little at a time, always moving to an opposite screw, not the one next to it.
OK.. I nearly borked my system upgrade at this step. I have a 3.4 GHz Core i5 system and wanted to upgrade the CPU to a Core i7-4771. I found a new one on Amazon last week. Everything went very smoothly until I got to the final “Then, reinstall the heat sink over the top.” step. As others have pointed out - this is really difficult. I had a heck of a time getting the four screws in the tension plate back in. And, after reinstalling everything and hitting the power button, NOTHING happened. Nada. So, I tore the system back down and removed the heat sink. The CPU was stuck fast to the heat sink and it took a lot of twisting and pulling to dislodge it. The CPU looked OK, but when I checked the Haswell socket, I discovered that several of the delicate pins had been bent and were touching. I used a pair of fine pointed tweezers to VERY gently bend the pins back into place. Then, it was “lather, rinse, repeat”.. This time, when I plugged the iMac back in, I got the 3-chime error signal, so I reset the RAM (cont…)
(cont.) chips and hit the power button again. Nada. I started cursing Steve Jobs in his grave. After a couple minutes, it suddenly chimed and in a few seconds the Apple logo appeared and all was well. I’m writing this on my freshly upgraded iMac. What I learned was that as soon as the heat sink touches the CPU, the thermal paste “glues” it to the heat sink - if you twist or hog on the heat sink, the CPU goes with it. The trick is to make sure that the CPU is firmly seated in the socket and then KEEP it there. It takes a good deal of finesse. As “aboucher” pointed out - it is helpful to insert the first screw *just to the point of catching” - then start adding the others in an “X” pattern. Also, I found that removing the “hood” over the adjacent RAM bay (remove the three T5 screws) gives you just a bit more exposure of the CPU and heat sink. I am still amazed that there isn’t a single decent video tutorial that walks you through this step - this is where you’re at the greatest risk of damaging your system..
(cont.) and it’s where a detailed walk through would be the most helpful. Anyway, if you keep these precautions in mind, you should be able to get through this - but be prepared. And, as a side note, the upgrade from the Core i5 3.4 GHz (4670) to the Core i7 3.5 GHz (4771) didn’t exactly set off fireworks in terms of benchmarks. I saw a 15-20% increase in the Geekbench 5 Multi-Core Score and a nice 30% increase in performance with the Cinebench 20 Score - so, it’s probably going to be worth it in the long run to have upgraded the CPU. If you have a base Core i5 3.2 GHz CPU, you should really see a difference. If you have 3.4 GHz system, you may or may not want to risk going through the upgrade process, as the benefit is much more modest. Your call. I found the biggest bang to be upgrading the 7200 rpm HDD to a PCIe NVMe M.2 SSD drive (I used a Sabrent Rocket Q 1 TB 2280 drive). Personally, I’d do that first and make sure that you have at least 16 GB of memory. You might be happy at this point. Good luck! J
Part 1 of 3
Many thanks to you who’ve shared your experiences, happy to say they really helped make my cpu and ssd upgrade successful, though not without some trepidation. So here are a few things that helped me in case they help someone down the road.
Regarding the cpu grease and “gapping” compounds, I read a lot of discussion about what’s best and how much to use. I ended up using 2 rice grains of grease on the cpu, 1 rice grain on the gpu, and the equivalent of approx 6mm diameter ball of K5-Pro thermal paste on the Vram chips. K5-pro is essentially a “gapping” compound often used to replace thermal pads. After securing the heat sink I peaked underneath it and it appeared that amount was about the same as what was used at the factory.
part 2 of 3
Before re-securing the heat sink, I removed the cage around the ram for easier access. I laid the board off the edge of a table so the gpu was accessible to me working under it, and also far enough to get the awkward heat sink over the cpu off the table to avoid rocking. I laid a heavy book (nearly 5lbs) across the ports on the opposite side for stability. I secured the gpu side of the heat sink under the table looking up, and experienced no shifting of the board at all. After *completely* tightening those screws (i.e. until they stop) I was able to work with it back on the topside of the desk, again without any shifting. Regarding securing the heat sink over the cpu, of course follow good practice of tightening screws opposite one another, and like the gpu, tighten the screws all the way down or until they stop. This point was made clear by an iFixit rep who called attention to an image of the original position of that spring clip, which is *all the way down to the board* essentially (step 58).
Part 3 of 3
And finally the last step, re-securing the glass panel. I decided to not remove the tape backings after putting the adhesive strips in place, to avoid sealing the unit and have something wrong and have to tear it open again. With the iMac on its back on the table, I propped it up in a couple places so that the top edge of the iMac was at least level with the bottom edge, laid the bottom edge of the glass down and inserted the display power/data cables. I then set the glass down gently and made sure the iMac turned on and all was ok.
Attempted to upgrade from i5 to i7, bent pins on socket and bent CPU corner. The CPU became slightly dislodged when I flipped the board over to install the screws. Goodbye previously perfectly working i5 5k iMac.
Really cannot stress enough to take your time when working on Apple products.
The same for me too. Repairing the pins is in my case impossible, so I ordered a new unused logic board. It‘s not here yet but hopefully this time the upgrade works.
I just ordered a new i7 6700K to replace my i5 6600K. With your stories I will be extra careful with the pins…. I will tell you when I finished the job.
Just finished upgrading to an i7 6700K. All went well, but I had to take it apart again because the cooling wasn’t good of the CPU and the GPU. Starting a game and it got overheated and shutdown. I ordered heatpads for the gpu memorychips and thermal compound (1mm) from Arctic (MX-4). Also bought an app iStat Menus ($$) and an app called Intel Power Gadget (free). Real cool monitoring tool. CPU and GPU are cool now, 28-32 degr Celcius. Playing a game temperature climbs to max 90 degr Celcius.
Dont remove the thermal paste with the spudger. You might scratch the heatsink. Its not a great deal as the new paste will fill those scratches. But still better to not scratch it in the first place.
Attaching the CPU and the heatsink is actually not as hard as mentioned before, but you really need to take your time to put it all together.
Four hands are very helpful here. Two hands hold the CPU in place and the other two hands hold the GPU part. Start with screwing in the GPU side and then the CPU.
Replace the backing plate on the motherboard, and hold it in place while you turn the board over so the side with the CPU socket faces up.
Before installing the heat sink, see our thermal paste guide for instructions on cleaning and preparing the thermal surfaces and applying a new layer of thermal compound onto the CPU and GPU dies.
For the VRAM chips surrounding the GPU, install thermal pads or a thick thermal paste such as K5-PRO, rather than regular thermal paste.
The CPU
The GPU
The VRAM chips
The heat sink plates
WARNING! When applying thermal paste on the GPU, spread it with a gloved finger! Apply a little more thermal paste on top of it and then make you push the heat sink down firmly onto the GPU die!
Cleaning with isopropyl alcohol
Clean the surface thoroughly with 90% isopropyl alcohol (or higher) and a lint-free cloth. Always wipe in the same direction, do not go back and forth.
How thick should be the pads on the vrams?
Align the CPU so that the cutouts in the CPU match the tabs in the socket.
Gently place the CPU in the socket. Try to set it straight down and avoid sliding it around once it is in the socket.
Align the holes on the CPU section of the heat sink with the pins on the backing plate.
Set the heat sink straight down on the CPU, GPU, and VRAM chips.
Keeping inward pressure on both the heat sink and the backing plate, flip the logic board over so the heat sink faces down.
I highly recommend removing the RAM cage, it is really challenging to align the heat sink over the CPU with the the cage in the way. The thermal paste wants to stick while aligning to the pins. It was much easier to remove the cage and drop the heat sink into alignment without the cage in the way.
Yes, I agree, removing the cage makes it easier. After reinstalling the heatsink, I was able to reinstall the cage by cutting one side of it, which allowed the cage to be spread wider so that it could be reused. Once in place the screws held it into position. This upgrade was on my 2013 iMac which I upgraded from the base i5 to the i7 (4771) One thing I noticed is that the fan runs more because of the higher temperatures generated by the i7…I would say the gains were modest, but whether it is worth it….I am not sure.
You don’t need to cut the cage , just bend it out slightly and move the RAM arms open to allow it to slot back into place.
Watch when removing the cage, the DIMM proximity sensor NPN's (4 total part no. BC846BLP4-7B) are under the edge of the cage and may dislodge causing issues. Resoldering back with microscope, heat gun, etc. is not easy!
Place the spring plate on the backing plate.
Carefully thread one of the CPU heat sink screws slightly into the heat sink so that just a couple threads are engaged.
Press down on the opposite corner of the spring plate from where you just installed a screw.
While holding the corner down, thread another screw into that corner of the heat sink, again just tightening it until a couple threads are engaged.
Repeat the process of pressing down the spring plate and slightly threading in the screws to install the remaining two heat sink screws.
Tighten the screws down a little at a time in the same order that you installed them—in an "X" pattern starting at one corner and then crossing to the opposite corner.
I upgraded a mid 2015 i5 3.3 CPU to the 4ghz i7 4790k by reversing the spring plate to release tension because the CPU of the i7 is significantly thicker than the stock i5 chip. Tighten in X patten but don’t over torque the screws! Alignment pins won’t be fully seated into heat sink.
Thanks for that tip. I found it impossible on my own to fix the clip in the correct way. The i7 I have is thicker. Mine now idles at 35 deg C. Running some games will take it up to about 45-50. I used endurance for a stress test which maxed out at 92 but quickly went down again. I will be keeping careful watch on the temps for now.
I can absolutely confirm that! Replaced an i5-6600K with an i7-6700K in a late-2015 27” iMac, and on the first try, I really tightened those screws, and that got me a dead iMac. But fortunately, after disassembling everything again, I could straighten out the bent CPU (looked really sad!) and against all odds, got it to work again, this time very carefully tightening the screws (if that is possible at all - you just can’t do it without any force!) and stopping early. I stopped approximately when the thicker part of the screws reached the upper margin of the board. Didn’t try to reverse the spring plate, though. Could also absolutely be worth a try.
Just managed to kill a CPU and main board.
Honestly, this is the worst design possible.
CPU moved during installation (because there was nothing to hold it in place) and ended up bending loads of pins on the board socket.
The CPU also has a nice bend on one corner, and I have a f**€in paperweight.
To reassemble your device, follow these instructions in reverse and use our Adhesive Strips Guide to reattach the display glass.
crwdns2935229:040crwdne2935229:0
crwdns2947412:027crwdne2947412:0
i7 processor that you can put on a Imac 2013?
The thermal compound/paste that is used by Apple on the GPU and memory is less than stellar. I would highly recommend stressing the GPU Memory gap in this guide. As you can see in the images of the cooler, specifically the GPU side, apple uses a white paste compound for thermal transfer. The problem is that the cooler does not contact the memory for the GPU. Once you remove the cooler it breaks the compound in several spots, and it will never be as good as it was unless care is made, and you are aware of this prior to re-installation.
Furthermore, with the GTX775M and GTX780M equipped iMacs, the temperatures are already above normal without removing the cooler. If you try and push these chips with the added memory in the latest generation games you will get artifacts from overheating. Due to the gap between the memory and the cooler you are also unable to use Arctic Silver as a remedy, as the gap is too much, with the logic board being vertical. (Risking seepage down the board, which I have already seen when performing the proper fix on another iMac) The coverage and type of thermal compound Apple is using is not sufficient. In the factory state the thermal compound is centered on the memory, however only 40% of the actual module comes in contact of the memory and the cooler. What I have done on my iMac and a few others so far is use thermal tape.
Hello, i am upgradinf the imac at the moment and want to renew the thermal paste.
For the vram i want to use the thermal tape, could you twll me with thickness you used?
YES, I F*&^* hate thermal tape when compared to quality compound. With this only exception, the tape is more effective than the stock compound, and it is quarantined to make 100% contact, while dissipating heat properly. I have seen a drop of 15% under heavy use on the GPU since using the tape. YOU do not want to use cheap thermal tape! Standard tape only has a 3-5 watt thermal conductivity, which is equal to or less than a standard compound. You can go through frozencpu.com and purchase Fujipoly Extreme Thermal Pads which have a rating of 11. For use on the 27" iMacs, I went with 100 x 15 x 1.5 and (2) are needed to do completely cover both sides of the memory banks on the logic board.
Please, if you remove the cooler to replace the CPU you have to be aware of the GPU and the gap involved on the memory chips, and the potential of further gaps upon re-installation.
Are you suggesting that you used this 11kw tape on both the GPU and the GPU Memory modules?
I brought that tape but 1.5mm is way too tall and chose not to use it after all on my 27' 2013 14,2 model. Instead used 11kw X1 Extreme Fusion paste from Master Cooler. Its non-conductive so don't have to worry about short circuits. Its also very thick so doesn't run. I used the "small pea" technique on the GPU and GPU memory dims. For the actual CPU which I upgraded from the base i5 to a i7 4771 I used the "Thin line" technique.
AW H -
Prior to improving the thermal transfer on the GPU memory I have seen elevated temperatures and graphic artifacts when pushing the graphics to the max, after doing it this way I have experienced no issues and lower temps. As a side note with all thermal tapes they have a tendency to have a shorter effective lifespan than quality compound, but I don't keep computers long enough to be concerned about it. I would suggest a 2yr replacement interval if you choose to keep it for extended timeframes.
Enjoy!
Please also add to guide: DO NOT USE ARTIC SILVER ON THE GPU MEMORY!, yes i know i could just edit it but i'm confident you will read this info^
Thanks Walter!
I'm confused...are you saying Arctic Silver 5 should not be used for replacing the thermal compound on the iMac CPU? Or are you correcting a mistake from a comment from earlier. Why would you use thermal compound on the GPU or memory?
kazoodac -
Thank you tjk4.
I recently upgraded the CPU to my Late 2013 27" imac. When i took the heat sink off, thermal compound from the GPU chips was used between the heat sink and the chips. It was just a bit more of it to cover the gap you specified earlier. I got a thermal pad, the only one I could find in my country was the 6w/mK made by Arctic. It was a square pad, 50mmx50mm and 1.5mm thick. I just placed it over the entire chips and I cut just a little small square in one of the sides where no chip was present.
Problem is now my iMac kicks the fan at 1800rpm whenever I do a bit of intensive work., photoshop etc. It did not do that previously with my i5 processor nor my 21 late 2013 with IRIS gpu, using the CPU close to 100%.
I can only guess that there may be a minor gap between the cooler and the surrounding memory chips. If you go too thick on the thermal pad for the GPU it will create a gap between the cooler and the surrounding memory modules. I had to experiment with several sizes and compounds to find the best fit. It does sound like a memory resistance due to the timing, as it would take a few more cycles for the GPU to activate the fans.
tjk4 -
Did you use the thermal tape on just the GPU memory modules or both memory and GPU itself? I made that mistake and theres no contact from the heatsink to the GPU so it overheats as the thermal pads of 1.5mm are too tall! (at least on 27" 2013 14,2 models) I had to redo mine and just used quality 11kw paste which is non-conductive so no worries of short circuiting from spillage on everything. Temps are all good now.
AW H -
I still couldn't decide which type of thermal interface I should use: thermal compound or thermal pad. However, there are some details I'd like you to tell me.
If thermal pad is chosen (for example - Fujipoly 17.0 W/mK):
- what is actual gap between GPU memory and heat sink in millimeters? Is 1,5mm thick pad ok or not?
- what is actual gap between GPU chip and heat sink in millimeters? Is non-conductive thermal compound most preferred option or thermal pad is the best choice?
If alternative thermal compound is chosen:
- How many grams of it is enough to fill all of the gaps between GPU chip/memory and heat sinks?
Thanks!
3426895 -
PART II:
Do you think the 11w pad makes for such a big difference? These are my current temps, http://autoeducare.ro/foto/screen.png
I think it is better to use a good compound and using the same amount of it, like Apple did, to fit into the sheatsink and chip space. For me it worked better the way they did it, but I did not check the GPU temps before to be able to prove it, the fans were very very silent though.
what app did you use for system info/temps in your screenshot?
Armen M -
What are upgrade options for CPU on this late 2013 iMac 27"?
What is max/best CPU to upgrade to?
Where does one purchase the actual compatible CPU? (standard Intel CPU...boxed vs. OEM...)
"iMac27" 2013" for CPU and GPU I used "Thermal Grizzly Hydronaut" paste and "Fujipoly extreme plus (14W/mK)" 0.5mm thick for GPU Memory.
You need 2 strips 100mm x15mm. You can buy them on ebay.
Don't know if the heatsink height is different for the 2015 model but .5mm was a touch too low for me. If you have a 2015 (same heatsink design as instructions here) and are going the pad route get the 1.0mm. Also you don't need two strips if you just cut the single strip on each - memory chip is 12mm x 15mm so one 100mm strip will do the job. I got K5 pro instead, probably doesnt perform as well as the pad but pads were pricey $ and didnt want to risk another not fitting.
Charles -
I have a late 2013 iMac 27 inch and want to update to a ssd and change the i5 processor to a i7 processor. What is the best ssd for mac and where can I get the newer compatible i7 processor?
Can one use a Xeon CPU instead of i7? I got the iMac27”14,2 and was wondering if one can put a Xeon instead one of the i5 or i7 series.
Is there a list somewhere of current (late 2017) processors that would work in the Late 2013 iMacs?
Hi,
I have made a screw sheet for this guide. It made tracking the screws a lot easier since they are almost all of a different length! Take a look and tell me what you think.
I have a 14-2 Imac, late 2013 with the I7, my understanding is that cpu is a 4th generation. Is it possible to upgrade the motherboard and CPU to something more recent?
Dear Sir, I hope You Help me, I got a problem Now. I just follow your instruction. unfortunately, my iMac 2013/27 inch can't reboot. just I can hear the sound (beeping) I use intel core i7 4771, OWC aura pro x2 480 GB, OWC Memory 32 GB DDR 3L, Each 8 GB, Mastergel pro v2 High Thermal compund, pls give me the solution. I am a great full to you.
I read this about the beeping, read right to the end of the 2 pages. Hope it helps https://forums.tomshardware.com/threads/...
Tengo entendido q se puede actualizar el procesador a un I7 consulta saben que modelo de procesador es compatible
Acho que o suporte do processador foi montado do lado errado nessas fotos. Tenho um IMAC igual que nunca foi aberto, e esse suporte estava montadno do outro lado.
This instruction page is not clear and is ambiguous if you have to do all the steps to just change the power supply please clarify another words do I have to remove the speaker and the hard drive to replace the power supply?
crawfordjohn - crwdns2934203:0crwdne2934203:0
This is a display removal guide not the power supply guide!Here’s the guide you need to follow for that iMac Intel 27" EMC 2546 Power Supply Replacement
Dan -
Didn’t need the cardboard wedge to remove the display. Waste of money. Lay your Mac on its back.
James Clive - crwdns2934203:0crwdne2934203:0
Die verlinkte Karton-Reparaturhilfe ist für den 21"-iMac. Passt sie auch 1:1 für das 27"-Modell?
Stefan - crwdns2934203:0crwdne2934203:0
Before you start this process, please check if your Mac has a Fusion Drive. If so, ensure that you have a full backup onto an external drive (maybe via 'Restore' from the old to new drive with the Disk Utility) so you can later migrate the data into the new computer. Otherwise this process causes the Fusion Drive to be split, and you lose all the data that was on the old drive. Most of my files were on iCloud but I did lose the local data and it apparently cannot be recovered once the Fusion Drive is split.
Upgrader - crwdns2934203:0crwdne2934203:0
