Xiaomi Redmi Note 11 Pro Screen Replacement
crwdns2942287:0crwdne2942287:0Use this guide to replace a cracked or broken screen on your Xiaomi Redmi Note 11 Pro.
If the frame is deformed, it's important to replace it to make sure the new screen will mount correctly and won’t suffer damage from uneven pressure.
If your battery is swollen, take appropriate precautions. Before disassembling your device, discharge the battery below 25%. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
Note: This guide instructs you to replace only the screen while leaving the original frame and motherboard in place. However, some replacement screens come pre-installed in a new frame (a.k.a. chassis), which requires a very different procedure. Make sure you have the correct part before starting this guide.
You’ll need replacement adhesive to reattach the rear glass when reassembling the device. Your device will function normally, but will most likely lose its IP (Ingress Protection) rating.
crwdns2944105:0crwdne2944105:0
Prepare an iOpener and apply it to the rear glass for at least two minutes to loosen the adhesive underneath.
Secure a suction handle to the bottom edge of the rear glass, as close to the edge as possible.
Lift the rear glass with the suction handle to create a small gap between the back cover and the frame.
Insert an opening pick into the gap you created.
Slide the opening pick to the bottom right corner to slice the adhesive.
Leave the opening pick in place to prevent the adhesive from resealing.
Insert a second opening pick at the bottom edge of your phone.
Slide the opening pick to the bottom left corner to slice the adhesive.
Leave the opening picks in place to prevent the adhesive from resealing.
Insert a third opening pick at the bottom left corner of your phone.
Slide the opening pick along the left edge of your phone to slice the adhesive.
Leave the opening pick in the top left corner to prevent the adhesive from resealing.
Insert a fourth opening pick underneath the top left corner of your phone.
Slide the opening pick along the top edge to slice the adhesive.
Leave the opening pick in the top right corner to prevent the adhesive from resealing.
Insert a fifth opening pick underneath the top right corner.
Slide the opening pick along the right edge of the rear glass to slice the remaining adhesive.
Remove the rear glass.
Insert a SIM card eject tool, a SIM eject bit, or a straightened paper clip into the hole on the SIM tray located at the bottom edge of the phone.
Press directly into the hole to eject the SIM card tray.
Remove the SIM card tray.
Use a Phillips screwdriver to remove the seventeen 3.6 mm-long screws securing the midframe.
For the Redmi Note 11, you need to remove the camera cover and get access to 2 extra screws. One of them is already partially visible, the other is under the camera housing.
Once you remove the camera housing, you also get access to the midframe connector, so use a pry tool to disconnect it.
Insert an opening pick between the midframe and front panel assembly on the bottom left edge of the phone where the SIM tray slot is located.
Very hard to do can't get it to work
For the Redmi Note 11, what worked for me was pushing from the inside, in the area next to the buttons.
Slide the opening pick around the bottom left corner of the phone to release the plastic clips.
Slide the opening pick along the left edge of the phone to release the plastic clips.
Slide the opening pick around the top left corner and along the top edge of the phone to release the plastic clips.
Slide the opening pick around the top right corner and along the right edge of the phone to release the remaining plastic clips.
Carefully swing open the midframe to the left like you would open the front cover of a book to get free access to its cable connector.
Place the midframe next to the left edge of the front panel assembly.
Use a spudger to disconnect the midframe cable by prying the connector straight up from its socket.
Remove the midframe.
Use a spudger to disconnect the left and right battery cable by prying the connectors straight up from their socket.
Use a Phillips screwdriver to remove the 3.6 mm-long screw securing the loudspeaker.
Insert an spudger underneath the right edge of the loudspeaker.
Use your spudger to pry up the loudspeaker.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use your fingers or a pair of tweezers to remove the loudspeaker.
Slide a pair of tweezers under the black coaxial cable until they're snug against the metal connector.
Disconnect the black coaxial cable by prying it straight up from the charging board.
Use your tweezers to carefully loosen the cable from its routing on the charging board and bend it to the side.
Use a spudger to disconnect the interconnect cable by prying the connector straight up from its socket.
Insert the pointed end of a spudger underneath the left edge of the charging board.
Use your spudger to pry up the charging board.
Use a pair of tweezers of your fingers to carefully remove the charging board.
Use a spudger to disconnect the display cable by prying the connector straight up from its socket.
Apply a heated iOpener to the screen to loosen the adhesive underneath. Apply the iOpener for at least 5 minutes.
Once the screen is warm to touch, apply a suction handle to the top edge of the screen and as close to the edge as possible.
Lift the screen with the suction handle to create a small gap between the screen and the frame.
Insert an opening pick into the gap between the midframe and the screen, at the left side of the earpiece speaker cut-out.
Slide the opening pick to the top left corner of the screen to slice its adhesive.
Insert a second opening pick into the gap between the midframe and the screen at the left side of the earpiece speaker cut-out.
Slide the opening pick to the top right corner of the screen to slice its adhesive.
Insert a third opening pick at the top right corner of the screen.
Slide the opening pick along the right edge of the phone to slice the adhesive.
Leave the opening pick in the bottom right corner to prevent the adhesive from resealing.
Insert a fourth opening pick underneath the bottom right corner of the screen.
Slide the opening pick along the bottom edge of the screen to slice the adhesive.
Leave the opening pick in the bottom left corner to prevent the adhesive from resealing.
Insert a fifth opening pick at the bottom left corner of the screen.
Slide the opening pick along the left edge to slice the remaining adhesive.
Carefully thread the display cable through the gap in the midframe.
Remove the screen.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
The best way to secure the new screen is to apply a sheet of custom-cut double-sided tape to the back of the screen.
crwdns2935229:021crwdne2935229:0
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0crwdns2947412:08crwdne2947412:0
I used this guide to replace screen on non-Pro version and it worked fine. Thank you!
This really helped me replace a screen for the regular redmi note 11.
Habe mein Note 11s mithilfe dieser Anleitung als Referenz wieder nutzbar gemacht :)
Hat zwar nun nur noch VGA Display anstatt Amoled - aber als Fahrrad-Navigation oder Notfall-Ersatz-Gerät wird es ausreichend sein.
Ich bin zumindest froh dass es wieder nutzbar ist.
Danke für die Anleitung und Übersetzung.
PS: beim 11s ist eine Schraube weniger verbaut und das Layout der Schrauben geringfügig anders.
Zwei. Der Schrauben verstecken sich unter dem Kamerglaskörper der Separat vom Rahmen genommen werden muss (das 11s hat eine Kunststoffrückseite)
For my non-pro Note 11 I bought the replacement screen that comes with a l frame because I thought it must be easier to replace, but apparently there's no guide for that procedure. It says here that it's a very different process, so I'm hesitant to try. Any pointers you can give me to good instructions for that?
Did you find something? I just bought a replacement screen with frame for my non-pro Note 11S. Once it's here I'm just going to try using this guide, unless there's something better available somewhere? I've only skimmed the guide now, will wait for the display to arrive before taking a closer look.
So I successfully replaced the screen of my non-pro Note 11S yesterday with a replacement screen already attached to a frame by more or less following this guide.
In "***Step 9*** Unfasten the midframe screws" I needed to unfasten all visible screws, then pry up the camera protection, because there were two more screws underneath there, which I also took out at this stage.
In "***Step 18*** Disconnect the battery cables" only one battery cable needs to be disconnected, because there exists only one on my model.
In "***Step 23*** Disconnect the interconnect cable" also the screen cable needs to be disconnected to fully free the charging board. After prying it up and removing it I no longer followed this guide, because the rest is about separating screen and frame.
Instead, the battery, mainboard, interconnect flex cable and I think two or three other smaller components now need to be transferred to the new frame attached to the new screen. So I would say definitely a different procedure, but perfectly doable with this guide.
Disadvantages of using screen with attached frame:
The transfer of the interconnect flex cable introduces a certain risk of breaking it - thankfully it worked for me, but this risk is not there when reusing the old screen frame. Also the battery transfer means having to take out the original battery adhesive. I didn't have any replacement, so I just reused it, but this is obviously not ideal. This also applies to some minor components, I just didn't use any adhesive at all for those during reassembly, which should be fine, I think.
Between the mainboard and the screen frame there was some thermal paste. Not sure how important this is, I just reused the old one as best I could.
Advantages:
Steps 27 to 33 are not necessary, which means not having to go through heating the screen and slicing the adhesive and having to reapply this when assembling the phone again. So no risk of breaking anything regarding the front camera.
So probably it's a question of personal preference which approach is considered better.
Tiene la pantalla negra no sé por qué
guys please be carfeul my little friend erik was heating tthe phone but it blew up and he has no facce now. i still have the ptsd
Dawid K - crwdns2934203:0crwdne2934203:0
