Why You Should Clean and Maintain Your Automatic Coffeemaker
    • Remove all loose attachments such as the water tank, drip tray, and coffee beans. Open the machine using this guide.
    • Inspect the water hoses and internal components for any signs of contamination.
    • The hoses don’t always need to be replaced. Often, cleaning with a thin brush, detergent, and hot water is sufficient.
    • Remove the screw on the cover. Remove the cover.
    • Unscrew the brewing unit.
    • Carefully remove the brewing unit for inspection and cleaning.
    • Detach the drainage valve to check for internal contamination.
    • This guide shows, how to overhaul the drainage valve.
    • Pre-clean parts before placing them in an ultrasonic bath for deep cleaning.
    • If you don’t have access to an ultrasonic bath, clean all parts thoroughly with hot water and detergent. Avoid using a dishwasher.
    • Install new or cleaned hoses and replace any worn-out seals.
    • Thorough cleaning of the interior and exterior is necessary.
    • The coffee spout tends to become contaminated with coffee grease. If you want to remove it, you have to remove the spout, which can be quite time-consuming.
    • After cleaning and replacing necessary parts, reassemble the machine.
    • Run a cleaning and descaling cycle before brewing coffee again.
Repair didn't go as planned? Try some basic troubleshooting, or ask our Answers community for help.
eCuration
crwdns2935283:005/19/17crwdne2935283:0
449,301 crwdns2915208:0crwdne2915208:0
crwdns2935297:0252crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,006crwdne2935297:0
crwdns2936753:030crwdne2936753:0 41
crwdns2942667:0crwdne2942667:0 319
