Valve Index Headset Eye Tube Replacement
  1. Valve Index Headset Eye Tube Replacement, Adjust the eye tube relief: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Twist the eye tube relief knob clockwise to fully extend it.
  2. Valve Index Headset Eye Tube Replacement, Remove the face gasket: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Valve Index Headset Eye Tube Replacement, Remove the face gasket: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your hand to gently pull the face gasket straight off of the headset.
    • The face gasket is held in place by four magnets that secure to screws in the face bezel.
    • Before installing a face gasket, ensure the four screws securing the face gasket bezel are installed. Otherwise, the face gasket will not stay in place.
  3. Valve Index Headset Eye Tube Replacement, Remove the head strap clip: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Valve Index Headset Eye Tube Replacement, Remove the head strap clip: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Valve Index Headset Eye Tube Replacement, Remove the head strap clip: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the flat end of a spudger in between the bottom of the head strap clip and the head strap padding.
    • Pry up on the head strap clip until it is unclipped from the head strap.
    • To reinstall, first locate the recesses on the head strap for mounting the clip. Next, align the clip with the recesses, verify the tether cable is threaded through the clip, then simply press the clip back into place.
    Do you sell replacement clips?
    TomCatT - crwdns2934203:0crwdne2934203:0
    I didn't really see the need to unclip this or do the next step so I skipped it. It seems easy enough to unplug the cable while it's still attached to these, so unless you're really concerned about the cable bending a little more than it already does it seems unnecessary.
    Stephen Smith - crwdns2934203:0crwdne2934203:0
  4. Valve Index Headset Eye Tube Replacement, Separate the cable from the head strap guide: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Valve Index Headset Eye Tube Replacement, Separate the cable from the head strap guide: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to pull the tether cable straight up off of the head strap cable guide.
  5. Valve Index Headset Eye Tube Replacement, Disconnect the tether cable: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Valve Index Headset Eye Tube Replacement, Disconnect the tether cable: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the tether cable straight back out of the headset.
  6. Valve Index Headset Eye Tube Replacement, Remove the face gasket bezel: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T5 Torx screwdriver to remove the four 6.0 mm screws securing the face gasket bezel to the headset.
  7. Valve Index Headset Eye Tube Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Valve Index Headset Eye Tube Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Do not try and pry the face gasket bezel off, or you will damage the headset.
    • Grab the left edge of the face gasket bezel with your hand and slide it off of the headset.
    • During reassembly, visually verify the clips on the face gasket bezel are aligned with the headset before sliding it into place.
    This was a little tricky. There's a latching mechanism inside the bezel that requires squeezing the sides a bit to unlatch. In exactly the same hand position as the photo, you need to squeeze. Absolutely don't pry it off or it will snap.
    Scyntrian - crwdns2934203:0crwdne2934203:0
  8. Valve Index Headset Eye Tube Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Valve Index Headset Eye Tube Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Valve Index Headset Eye Tube Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the previous step for the right side of the face gasket bezel.
    • Remove the face gasket bezel.
  9. Valve Index Headset Eye Tube Replacement, Remove the eye tube gasket: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Valve Index Headset Eye Tube Replacement, Remove the eye tube gasket: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Valve Index Headset Eye Tube Replacement, Remove the eye tube gasket: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of tweezers to separate the left edge of the eye tube gasket from the headset.
    • Repeat the process for the right edge of the gasket.
    • During reassembly, make sure these holes are secured to the pegs on the headset before continuing.
  10. Valve Index Headset Eye Tube Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Valve Index Headset Eye Tube Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Valve Index Headset Eye Tube Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently peel the eye tube gasket out of the headset.
    • The eye tube gasket is lightly adhered to the perimeter of the lenses. It should pull off easily.
    my headset has an additional piece of plastic that yours doesnt have, and its not letting me remove the lenses in later steps
    Lemon Jumps - crwdns2934203:0crwdne2934203:0
    There is a plastic piece behind the gasket that will prevent the eye tubes from coming out which isn't listed in this guide. It has 3 clasps and pries out horizontally.
    Cer 12 - crwdns2934203:0crwdne2934203:0
    I was pleased to discover that the adhesive on the rubber gasket stays sticky enough to stay in place after reassembly (at least so far) so you may not need to worry about reapplying new glue.
  11. Valve Index Headset Eye Tube Replacement, Remove the front cover: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Valve Index Headset Eye Tube Replacement, Remove the front cover: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your hand to pull the front cover straight off of the front of the headset.
    • The front cover is held in place by four magnets that secure to screws in the motherboard cover.
    • Before installing a front cover, ensure the four screws securing the motherboard cover are installed. Otherwise, the front cover will not stay in place.
    Whoever wrote this is a moron.
    Sam Omiotek - crwdns2934203:0crwdne2934203:0
    My god. Thank you. This was an extremely helpful guide. I just couldn't get it off!
    Theu - crwdns2934203:0crwdne2934203:0
  12. Valve Index Headset Eye Tube Replacement, Remove the motherboard cover: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T5 Torx screwdriver to remove the four 5.4 mm screws securing the motherboard cover to the headset.
  13. Valve Index Headset Eye Tube Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Valve Index Headset Eye Tube Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the motherboard cover from the headset.
  14. Valve Index Headset Eye Tube Replacement, Remove the front fascia: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T5 Torx screwdriver to remove the following eight screws from the front fascia:
    • Four 6.3 mm screws with fine threads
    • Four 6.0 mm screws with coarse threads
    This is your last chance at catching the ipd adjustment groove on the right eye tube and catch the little knob on the back of the motherboard with it. (Just forgot about it myself and thankfully you can do it from this step the latest
    Blecha100 - crwdns2934203:0crwdne2934203:0
  15. Valve Index Headset Eye Tube Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Valve Index Headset Eye Tube Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Valve Index Headset Eye Tube Replacement: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to unlock the ZIF connector at the top-left corner of the motherboard.
    • Disconnect the FPC ribbon cable from the motherboard.
  16. Valve Index Headset Eye Tube Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Valve Index Headset Eye Tube Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Valve Index Headset Eye Tube Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to unlock the ZIF connector at the top-right corner of the motherboard.
    • Disconnect the FPC ribbon cable.
  17. Valve Index Headset Eye Tube Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Valve Index Headset Eye Tube Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to disconnect the press connector from the bottom-left corner of the motherboard.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  18. Valve Index Headset Eye Tube Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Valve Index Headset Eye Tube Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to disconnect the press connector from the bottom-right corner of the motherboard.
  19. Valve Index Headset Eye Tube Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Valve Index Headset Eye Tube Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening pick in between the front fascia and the headset.
    • Slide the opening pick over to separate the front fascia from the headset.
    there are adhesive strips at the 11:30, 01:30, 05:30, and 06:30 positions. Slow, gentle prying removes the front fascia. There are no clips holding it in place.
    JimMcBubbles - crwdns2934203:0crwdne2934203:0
  20. Valve Index Headset Eye Tube Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Valve Index Headset Eye Tube Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Continue sliding the opening pick along the perimeter of the front fascia until all edges are free.
    Frontblende ist sowohl oben als auch unten an zwei Stellen leicht eingeklebt.
    Falls die Frontblende bei Schritt 21 nicht abgeht, könnte der Klebstoff dafür verantwortlich sein.
    In dem Fall kann man ihn mit dem Plektrum von der Blende lösen.
    Grober Feinmotoriker - crwdns2934203:0crwdne2934203:0
  21. Valve Index Headset Eye Tube Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Valve Index Headset Eye Tube Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the front fascia.
  22. Valve Index Headset Eye Tube Replacement, Remove the motherboard: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Note the seven cables that must be disconnected in the following steps before the motherboard can be removed.
    note that the wheel that adjusts the distance between the eyes goes over the boar. So you will tuck the board under it.
    Michael Hehe - crwdns2934203:0crwdne2934203:0
  23. Valve Index Headset Eye Tube Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Valve Index Headset Eye Tube Replacement: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Valve Index Headset Eye Tube Replacement: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger to unlock the wide ZIF connector on the left side of the motherboard.
  24. Valve Index Headset Eye Tube Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Valve Index Headset Eye Tube Replacement: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to disconnect the press connector near the bottom-left edge of the motherboard.
    • During reassembly, be sure this cable is not trapped underneath the motherboard.
  25. Valve Index Headset Eye Tube Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Valve Index Headset Eye Tube Replacement: crwdns2935265:025crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Valve Index Headset Eye Tube Replacement: crwdns2935265:025crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your finger or an opening tool to unlock the display cable connector at the top of the motherboard.
    • Carefully disconnect the display cable connector.
    this one is pretty difficult, and could use some more explanation (esp since the teardown video of the index skips it completely). you need to lift up on the corner of the cover, and then use the pointy end of the spudger to slowly wiggle the cable UP and out of the connector, a little at a time on each side.
    Owen Smith - crwdns2934203:0crwdne2934203:0
    Good tip, this is not a press connector. Once the cover is swung open it slides out upwards not away from the board
  26. Valve Index Headset Eye Tube Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Valve Index Headset Eye Tube Replacement: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of a spudger to gently disconnect the bundled cable connector from the top-right corner of the motherboard.
    don't push up on the indented plastic
    Jose Zamora - crwdns2934203:0crwdne2934203:0
    This pops out towards you, do not try to push up.
    Storm DPD - crwdns2934203:0crwdne2934203:0
    thank you to the comments about not pushing up!
    Aeon Faye - crwdns2934203:0crwdne2934203:0
    Simlarily: when reassembling, line the cable up above the insert, and push slightly toward the MB. You'll hear a tiny click when it slots in.
    Joj - crwdns2934203:0crwdne2934203:0
  27. Valve Index Headset Eye Tube Replacement: crwdns2935265:027crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Valve Index Headset Eye Tube Replacement: crwdns2935265:027crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Valve Index Headset Eye Tube Replacement: crwdns2935265:027crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the pointed end of a spudger to unlock the ZIF connector next to the USB port on the motherboard.
    • Disconnect the FPC cable from the motherboard.
    • During reassembly, make sure this ribbon cable is not trapped under the motherboard.
    Not sure if this is on every headset, but mine had adhesive holding this cable to the motherboard and to the press connector cable. Be very careful peeling these apart, the adhesive is a little strong. Using the guitar-pick looking thing from the fix kit managed to separate them for me, but it might have been sheer luck lol.
  28. Valve Index Headset Eye Tube Replacement: crwdns2935265:028crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Valve Index Headset Eye Tube Replacement: crwdns2935265:028crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to disconnect the press connector below the USB port on the motherboard.
    • During reassembly, make sure this cable is not trapped under the motherboard.
  29. Valve Index Headset Eye Tube Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Valve Index Headset Eye Tube Replacement: crwdns2935265:029crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Valve Index Headset Eye Tube Replacement: crwdns2935265:029crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to unlock the wide ZIF connector near the right edge of the motherboard.
  30. Valve Index Headset Eye Tube Replacement: crwdns2935265:030crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T5 Torx screwdriver to remove the five 6.0 mm screws securing the motherboard to the headset.
    These are a set of 5 coarse threaded screws.
    Patrick Hartge - crwdns2934203:0crwdne2934203:0
  31. Valve Index Headset Eye Tube Replacement: crwdns2935265:031crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Valve Index Headset Eye Tube Replacement: crwdns2935265:031crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grab the motherboard by the USB port and carefully remove it from the headset.
    • During reassembly, be very careful not to trap any of the previously disconnected cables under the motherboard.
    During reassembly be sure to align the ipd slider with the gap on the back of the right eye tube. The ipd adjustment slider is located on the top left of the motherboard and is very easy to miss.
    Failing to align that the motherboard and the eyetube will result in resistance while adjusting the ipd, as well as an incorrect ipd being used in steamVR (which doesn't feel too great).
    Aux - crwdns2934203:0crwdne2934203:0
  32. Valve Index Headset Eye Tube Replacement, Remove the motherboard shield: crwdns2935265:032crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Valve Index Headset Eye Tube Replacement, Remove the motherboard shield: crwdns2935265:032crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the motherboard shield off of the two cross-shaped alignment pegs.
  33. Valve Index Headset Eye Tube Replacement, Remove the IPD screw: crwdns2935265:033crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Valve Index Headset Eye Tube Replacement, Remove the IPD screw: crwdns2935265:033crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your tweezers to remove the rubber boot covering the IPD adjustment screw.
    On reassembly, the best method for getting this back on is to get one end on and pulling until it's about half on. Then begin pulling with tweezers and spinning at the same time.
    if you're struggling to get this back on, I'd recommend prying at the underside (specifically at the part with the little dent on it) with your flathead screwdriver bit until it splits, then pulling it on and over, using your screwdriver to fold the two halves of the rubber over the screw.
    The way I managed to get this back on was to slide the adjuster all the way to one side (eg all the way right) and then put it on starting on the left, then I was able to use the pointy end of a spudger coming in from the front or back of the headset to slide in between the screw head and the rubber piece, into the pocket of the rubber piece (where it folds over) and stretch that part over the sides. The final side I was able to slowly get on just by rubbing the top of the rubber piece in that direction with my fingernail until it went on fully. It definitely took some time.
  34. Valve Index Headset Eye Tube Replacement: crwdns2935265:034crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a 2.5 mm (3/32 in) flathead screwdriver to remove the 6.5 mm IPD screw from the headset.
  35. Valve Index Headset Eye Tube Replacement, Remove the upper eye tube rail: crwdns2935265:035crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T5 Torx screwdriver to remove the five 4.5 mm screws securing the midframe.
    These are fine threaded screws, in case you get your screws mixed up. They are also defined by the only set of 5 with blue locktite on them.
  36. Valve Index Headset Eye Tube Replacement: crwdns2935265:036crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Valve Index Headset Eye Tube Replacement: crwdns2935265:036crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the midframe loose, slide the case towards the back of the headset to expose the eye tube rails.
  37. Valve Index Headset Eye Tube Replacement: crwdns2935265:037crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T5 Torx screwdriver to remove the 4.4 mm screw securing the left end gear to the eye tube rail.
    • If the screw is not accessible, turn the eye relief knob to rotate the gear until it faces outward.
  38. Valve Index Headset Eye Tube Replacement: crwdns2935265:038crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the left end gear from the eye tube rail.
    Be careful, there are retainers and plastic bushings on the outer sides of the rail, just inside of the midframe. I removed these with tweezers as I slid out the rail. To reinstall, I had to feed the retainer through the little hole in the front of the midframe and work it into place with the tweezers. I got the final positioning with the pointy end of a spudger. You can see one of the retainers in this picture, just to the right of the inside of the midframe where the rail is sticking through. The hole to feed it through is just below it, where the last bend of the retainer is sticking out.
    Ulric Dettweiler - crwdns2934203:0crwdne2934203:0
    This guide says "Remove the left end" but I suggest deciding based on the side you want to actually change.
    I left the both top and bottom bars in place and just pulled them out as much as needed to free the eyetube on the side I wanted to change. it makes your life way easier!
    Pouya - crwdns2934203:0crwdne2934203:0
  39. Valve Index Headset Eye Tube Replacement: crwdns2935265:039crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Valve Index Headset Eye Tube Replacement: crwdns2935265:039crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Valve Index Headset Eye Tube Replacement: crwdns2935265:039crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab the gear on the opposite side and slide the eye tube rail out of the headset.
    • When removing the upper eye tube rail, two plastic bushing will fall out and two metal springs may fall out. Keep track of these parts.
    • During reassembly, slide the bushings back on to the eye tube rail and use a pair of tweezers to align the springs to their original positions.
    I had two small black pieces that look like they belong on the eye rail pop off on this step. https://imgur.com/a/tZ1mxPf Anyone have any idea where they go back on during re-assembly?
    Tyler MacInnis - crwdns2934203:0crwdne2934203:0
    I had this problem too. If you look at the below disassembly picture you can see that these are bushings on the inner side of the gear axel. This is extremely easy to miss. They face opposite sides and are on either side of the axel, there is also a spring on the inside of these that is completely neglected in this guide.
    These bushings are used to ensure that the FOV adjustment axel gears remain flush.
    https://imgur.com/a/uP7mVGt
    Xayrga -
    Wish i had read the comments here. Both the little metal bar and plastic piece went flying on both sides when I removed the rod. Took me a good hour to find one that fell. Honestly the hardest part of reassembling this for me was getting that little piece back how it's supposed to be on both sides.
    Gray Corgi - crwdns2934203:0crwdne2934203:0
    Did you have just one metal bar or two? Could have sworn two popped out but now I can only find one. Did you happen to snag a picture?
    Astrid Wood -
    Reassembling in this step is one of the most difficult things I've ever had to do. I've been at it for days and haven't been able to fit in back in place.
    I lost one of the two springs/wires when removing the rod - I'm warning anyone to BE READY with the magnet screwdriver or when you start pulling it out- the springs are very thin and will slip in to the tiniest gaps in the headset. When trying to reassemble, I keep dropping it into little gaps and struggle to get itback.
    I think the first one I lost might be within the old eye tube - going to try cracking it open to get it back.
    There really needs to be some more direction in this guide here other than 'align the springs.' this has been an ordeal, kudos to anyone with the dexterity to pull this off.
    Joj -
    I'm convinced everything in this guide is ambigious and the person who wrote it never even touched a headset.
    maxima_crashed -
    To answer my own question. Yes there is a set of bushing and spring on each side. The spring here is a bent piece of metal, with some bends in it. The side with the larger bend goes into a small hole at the bottom and is used for retention. If you thread the top through the hole and kinda get it in there straight you will see how it lines up. This is a pretty big step for iFixit to miss. It is a pain to get in so if you are reading this beforehand use some tape or tac to stick the side coming through the hole in the plastic frame down. Much easier to get it all in that way.
    Astrid Wood - crwdns2934203:0crwdne2934203:0
    Any easy way of getting those springs back in cuz &&^& me I can't get em
    Death Venom - crwdns2934203:0crwdne2934203:0
    Ok, I figured out a workaround if you're having trouble getting those stupid little wires clipped through the hole and onto the bushing.
    I figured this was like trying to shove a ship into a bottle rather than building a ship in a bottle. So I ditched the wires, got a spool of wire of similar width, then just fed it through the hole and bent it around the axle, bent it into place back in the hole, and clipped it for length. Still very difficult, but doable.
    Got the headset together, and haven't had a problem adjusting the knob, so I think I did well here.
    Found a way to do it, step by step:
    0. Make sure the plastic bushing is oriented the right way, as in the picture.⏎⏎
    1. Fit the rod into the headset from the right side.⏎⏎
    2. Use the tweezers to put the bushing on. Push the rod only as to fit and mount the bushing.⏎⏎
    3. Fit the spring the bent side-first into the hole. Beware, it might fall into the inside of the headset. Orienting the headset diagonally helps. ⏎
    4. Guide the spring with tweezers to mount it on the rod.
    5. !!! Guide the rod through the holes in the eye tubes. !!!
    6. Stretch the spring and the bushing diagonally. Push the bushing slightly to the center of the headset while you lift the spring slightly with the tweezers. The spring has to fit inside the bushing.
    7. Align the parts as in the picture/
    DO NOT PUSH the parts completely to the side, the spring WILL fall out and you will contemplate your life choices.
    For the left side, reverse steps 2 and 3: The spring needs to come in first.
    I'll try to add this to the repair guide.
    maxima_crashed - crwdns2934203:0crwdne2934203:0
    Make sure the FOV distance is same on both sides of the headset when reassembly the cogwheel. I missed this and needed to backtrack to this step and resync the sides. You just need to remove the cogwheel on one side so the sides can move independly of eachother, now make sure the sides sync and reistall the cogwheel.
    Karin Westerlund - crwdns2934203:0crwdne2934203:0
    So the way I approached the rails and the bushing with the spring was to use the thinnest spudger I had (basically just a metal rod) to follow the rail as I pull it out so that the bushing and spring slide onto the new rod. I was able to avoid having to re-insert either spring since that sounds very difficult. I also ended up doing 1 side at a time, pulling the rods halfway out to one side so that I only have to worry about keeping 1 spudger in place at a time. I figured if I tried to do both with 2 metal rods holding both springs in place I would surely knock one out and lose the spring. I also followed the first spudger with a second spudger going back the other direction (from center through the hole towards the outside) so that I could only capture the spring and not the bushing. It seemed more stable that way and less likely the spring will slip. You could also temporarily tape the spudger to the frame to keep it secure holding back the spring while you work.
  40. Valve Index Headset Eye Tube Replacement, Remove the lower eye tube: crwdns2935265:040crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Valve Index Headset Eye Tube Replacement, Remove the lower eye tube: crwdns2935265:040crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Valve Index Headset Eye Tube Replacement, Remove the lower eye tube: crwdns2935265:040crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger or your fingers to remove three of the four clips from the lower eye tube rail.
    • Hold the clips steady with one finger to prevent them from ejecting.
    • To reinstall these clips, place the open end on the groove in the rail and press them into place.
    • Two of the clips require holding the spring back to install them.
  41. Valve Index Headset Eye Tube Replacement: crwdns2935265:041crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Valve Index Headset Eye Tube Replacement: crwdns2935265:041crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Hold each spring with one hand to prevent them from ejecting as you slide the lower eye tube rail out.
    • During reassembly, slide the springs on to the rail and carefully "walk" them back with your fingers until they are entirely on the rail.
    I ran into a problem with reassembly somewhere at this point--two very small black parts seem to have fallen out and now the headset's eyepieces won't return to the middle, only stay where they are if moved with the IPD slider.
    Foxhound - crwdns2934203:0crwdne2934203:0
  42. Valve Index Headset Eye Tube Replacement: crwdns2935265:042crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Valve Index Headset Eye Tube Replacement: crwdns2935265:042crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Valve Index Headset Eye Tube Replacement: crwdns2935265:042crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the lower eye tube rail.
    • The eye tubes are now loose and can fall out.
    If you're like me and had the swirly gear piece thing in the middle fall out, make sure you put it back in correctly or your IPD adjustment will be wrong. You can use the picture in the guide as reference for the position of that piece vs the position of the IPD slider. Move the slider at the bottom left screw with white washer thing to the same position as in the guide, and drop the swirly gear in the exact position as shown in this guide.
    Alternatively, you can push the IPD mechanism into the lowest IPD (closest together) setting and set the swirly gear thing in the position where both of the little half circle "notches" in it are perfectly horizontal / at the same level on each side.
    Mine popped off. How do you know it's in the correct position? My adjuster can reach both ends and steamvr reports 58 and 70mm is that good enough verification?
    Anders Malmgren -
  43. Valve Index Headset Eye Tube Replacement, Remove the eye tube(s): crwdns2935265:043crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Valve Index Headset Eye Tube Replacement, Remove the eye tube(s): crwdns2935265:043crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the eye tube(s).
    • The eye tubes are a tight fit and can be tricky to remove and install. Try different orientations as you work them in or out; do not force them.
    The reconstruction steps should be included as well...
    Phillip Hochman - crwdns2934203:0crwdne2934203:0
    Installation is opposite of removal
    Jayce Feldmann -
    Wasn't exactly opposite, those springs did not want to go back in!
    Fizz -
    I can't seem to lift the eye tube out, there is this plastic part in the front that blocks it (they are loose but there is no position in which they can be removed):
    https://files.catbox.moe/it930u.jpg
    https://files.catbox.moe/lqq7lk.jpg
    I also have that plastic part. it is glued to the inner plastic frame. So I left it alone just folded it out of the way so that eyetube could be pulled out ( bottom side first)
    Pouya -
    I have that part too. I was able to get the eyepieces out by tilting them back, and then flexing the top of the index to let them slide underneath it. Make sure that your eye relief adjustment is as far out and thus as loose as you can make it.
    Aric TenEyck -
    Can't remove the lenses either, the plastic frame is not giving enough space to pull them out. There is no way you can remove or bend the plastic frame holding the eyetubes together without breaking it, either.
    There should have been extra steps provided to remove that thing.
    Apparently you're supposed to bend the upper frame slightly so as to give the screw holes on the eye tubes some space to exit.
    Contrary to what the author says, no, it won't break. It's a firm plastic.
    There has been a snap sound but this is the step that does require some force to complete.
    maxima_crashed -
    Yep, also had this nosepiece-shaped piece of plastic making removing it impossible. The thing isn't present in the teardown video, so might be a different version?
    I ended up slightly flexing the piece to free the eye tube, but I heard something snap, and then I was able to wiggle it around a little more, making installing new tube easy. . Haven't completed the operation, hopefully I didn't screw myself here.
    The hard plastic nose piece in between the lenses can be removed with light to light medium pressure there are three clips similar to the clips holding the inner facia piece on.
    once removed, the tubes come out with ease.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Valve Index Answers community for help.
crwdns2935229:021crwdne2935229:0
Sam Omiotek
crwdns2935283:002/25/19crwdne2935283:0
85.465 crwdns2915208:0crwdne2915208:0
crwdns2935297:0290crwdne2935297:0
crwdns2947412:020crwdne2947412:0
I gained two extra small pieces not mentioned, I think when removing the top rail, they just dropped out into the housing. Looks like they go next to the eye tubes and are not included with the replacement so make sure you don't lose them!
https://imgur.com/a/AW4dHOW
Fizz - crwdns2934203:0crwdne2934203:0
I believe those are suppose to add tension to the top rail. I lost mine but it should be for a small metal spring tensioner (I think).
Gabe -
Great guide. Thanks so much!
David S - crwdns2934203:0crwdne2934203:0
Hey, you guys forgot to mention anything about 2small pieces of bent metal no thicker then a staple that looks pretty important. Might want to include every piece that may be affected when assembling/disassembling the headset, Especially in the later stages.
Jesse the Dragon (Dragon) - crwdns2934203:0crwdne2934203:0
wtf are these??? I also had them fall out and don't know what they are!
Patrick Hartge -
I know this is a little bit late, but I'm just going to post this here for anyone doing this in the future: They mention this in step 39. They are EXTREMELY hard to get back in. I recommend putting the headset on it's head and then using your fingers, not tweezers, dropping them in the small upper hole (lower from the index's view). I took a photo of it here.
The metal clip holds the plastic tube in place that the upper rail goes through.
Schweinsfuss Nasenbeutler -
If for some reason you broke the audio connector on step 26, the part number you are looking for is Molex 781710005 and the plug is 781720005.
[deleted] - crwdns2934203:0crwdne2934203:0
My IPD adjustment is way out of whack now after a left lens replacement. It's reading much higher numbers than actual and the lowest possible setting reads at 63 or so. Anyone else have their IPD adjustment go off? Any ideas on how to fix it?
Jeremy P - crwdns2934203:0crwdne2934203:0
For reference I figured this out with help from a comment at the motherboard stage. There is a tiny slider at the top left of the motherboard that fits into a slot on the rear of the RIGHT eye tube (the left eye tube when looking from the motherboard side). When that slide is properly in its slot the digital IPD lines up with the physical IPD correctly. I had missed it when doing a left eye tube replacement because I hadn't focused on the other side.
Jeremy P -
I added a comment on step 21 that shows a picture of this, in case anyone is having the same problem.
For anyone looking, the picture schweinsfuss posted is on slide 21. it's hard to see but the non-rubber component needs to be between the two rubber pieces for it to be correct.
Alexander Sparks -
After replacement my windows cannot recognize the headset. In device manager it says "unknown usb device (device descriptor request failed)"
Anyone know how to fix this? I have tried a lot of methods found online, tried replugging, reinstalling...
lance2499 - crwdns2934203:0crwdne2934203:0
Is there a way to test which of the eye tubes is faulty?
Mike - crwdns2934203:0crwdne2934203:0
wear it. see what eye tube is faulty. play a game.
Paul Treagan -
Did it and thanks to this guide the Index is working again.
For everyone searching the web: My symptoms were vertical white lines in my left eye. Got the new eye tube from iFixit and everything is working now!
The Guide needs two updates though.
Step 39 needs to show the black pieces and springs for reassembly as this was very hard. (I think one of the parts is missing in thge pictures of the guide ;-) )
And There seems do be a newer version of the headset that has a plastic plate over the bottom parts of the tubes that prevent them from being extracted. This part is missing in this guide.
BIG THX @samomio for the guide and iFixit for having the part!
Robert - crwdns2934203:0crwdne2934203:0
I had the same experience with the plastic part. Just bend it down. It just seems to be some kind of dirt-guard. It is quite bendy and doesn't snap or anything. I went pretty rough on it to get the tubes out.
I sold my Index on eBay and somehow during shipment black bits of old foam or something fell out and were visible in the screen so I had to give him a refund. I took the lenses out from the front. I heated them up carefully with a heat gun and used a suction puller and a steel spudger but I slipped and scratched one lens They came out (just one side) seperated. I cleaned all the gunk out and reassembled it. Two years ago - still using it every day. the scratch which is quite clearly visible is not really visible close up strangely enough so it doesnt interrupt my gaming. Now that I have removed a lens I am comfortable that I could easily remove an Index lens. (ratcat17@hotmail.com)
Ratcat Nugile - crwdns2934203:0crwdne2934203:0
Extremly good guide, took me 2 hours in total. My tip is to print out all the pages, lay them out as you go and put cups or something as containers for the parts on the specific step. There are a huge number of tiny parts in this thing. Makes it way easier to reassemble. Also read step 39 carefully! During reassembly make sure that the upper rail actually goes through the small plastic tube on the eye-tubes, otherwise you won't be able to adjust IPD.
Schweinsfuss Nasenbeutler - crwdns2934203:0crwdne2934203:0
Awesome guide.
Should be mentioned that when turning the headset upside down to remove the eye tubes themself that the gear thing in the middle will fall out, and is a little tedious to get into the right orientation when reassembling.
Also the paperclip-type "springs" are extremely difficult to get back in, would be nice to have more thorough installation instructions on that.
I ended up threading it back through the hole at the bottom, and using tweezers to pull it back up and over the plastic bushings.
Dalrae - crwdns2934203:0crwdne2934203:0
Reinstalling the tiny little springs was a nightmare, but I got it done. I found it easiest to turn the headset upside down so that gravity would hold the spring in the right orientation. The rest was patience, dexterity, and a lot of luck...
Torrent Amador - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 15
crwdns2936753:07crwdne2936753:0 79
crwdns2936753:030crwdne2936753:0 312
crwdns2942667:0crwdne2942667:0 23,532
