Valve Index Controller Left Hand Strap Replacement
  1. Valve Index Controller Left Hand Strap Replacement, Remove the elastic band: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Valve Index Controller Left Hand Strap Replacement, Remove the elastic band: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Valve Index Controller Left Hand Strap Replacement, Remove the elastic band: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press and hold the elastic band adjustment button.
    • Slide the elastic band out of the controller.
    • During reassembly, pinch the elastic band near the tip of the loop and slide it into the controller.
  2. Valve Index Controller Left Hand Strap Replacement, Insert an opening pick: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Valve Index Controller Left Hand Strap Replacement, Insert an opening pick: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Valve Index Controller Left Hand Strap Replacement, Insert an opening pick: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an opening pick under the round plastic cover next to the A and B buttons.
    • Do not insert the opening pick more than 5 mm (0.2 in) into the controller, or you may tear the touchpad ribbon cable.
    • Slide the opening pick around the top of the controller until all three plastic clips are disengaged.
  3. Valve Index Controller Left Hand Strap Replacement, Open the controller: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Valve Index Controller Left Hand Strap Replacement, Open the controller: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully open the top of the controller to access the screws inside.
    • Be careful not to strain or tear the ribbon cable connected to the touchpad.
  4. Valve Index Controller Left Hand Strap Replacement, Unscrew the adjustment strap: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Valve Index Controller Left Hand Strap Replacement, Unscrew the adjustment strap: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T5 Torx screwdriver to remove the two 6.1 mm screws securing the adjustment strap to the controller.
    • Once the adjustment strap is unscrewed, the spring underneath may fall out.
    • Make sure the spring is installed during reassembly, or the ratcheted adjustment mechanism will not work properly.
  5. Valve Index Controller Left Hand Strap Replacement, Remove the adjustment strap: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Valve Index Controller Left Hand Strap Replacement, Remove the adjustment strap: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the adjustment strap out from the controller to remove it.
    • If the spring falls, out, you'll need to reseat it for the adjustment mechanism to work. The spring should be located underneath the lip of the screwed-in part of the strap so that it can push against the mechanism when you push the strap in.
    • First, loosely screw the strap back in. Don't screw it in too tight, or you'll have trouble getting the spring in. Once it's screwed in, adjust the mechanism so that it's lined up with one of the pegs.
    • Place the spring so that the coil is around the nearby spoke, and the lower arm is seated in its little notch behind the strap screws.
    • You may want to use a magnetic screwdriver to seat the spring to prevent it from falling into the controller.
    • Put pressure on the coil of the spring so that it doesn't fly out, and move the arm of the spring over the top of the fastener, and push it in so that it stays underneath the lip.
    • While keeping pressure on the coil, quickly tighten the screws. Tighten the screw closest to the spring first. This will prevent the spring from unseating itself and springing back out.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Valve Index Answers community for help.
Sam Omiotek
crwdns2935283:002/25/19crwdne2935283:0
86,832 crwdns2915208:0crwdne2915208:0
crwdns2935297:0290crwdne2935297:0
crwdns2947412:05crwdne2947412:0
Doesn't explain how to put it back together with the spring which is conveniently missing from the photos.
Draylynn - crwdns2934203:0crwdne2934203:0
I'm several months late, but just in case I figured I'd toss a reply just in case you were interested in the imgur guide I made to help out anyone else struggling with this. It's posted as a separate comment on this post. Hope your repair went well otherwise!
VaporStrike -
I appreciate the guide, but as someone noted above, you are seriously lacking in the spring instructions, which might be the most important part of this assembly. However, I managed to find a way to get the spring seated back in on my own, and so for any other unfortunates stumbling onto this guide, I made my own crappy Imgur gallery guide for re-seating the spring. Each image has a small paragraph beneath it explaining the steps to take. I hope it manages to help anyone else struggling to swap out a strap.
(NOTE: Images were made for Right hand controller, simply mirror for Left hand.)
https://imgur.com/gallery/RQYtS5e
VaporStrike - crwdns2934203:0crwdne2934203:0
I hate this guide for not including the pics for the spring. You don't happen to still have the pics, do you? The imgur link is dead and I've spent the last hour or so trying to fit the spring, but I can't figure out any way how. Would be a lifesaver if you could share these pics again!
DarkKryo -
In fact, using a pry tool alone cannot open the circular plastic cover. You can try using a small flathead screwdriver or tweezers to insert into the joystick hole on the side near the tracking ring, utilizing leverage to create a gap (first push the joystick down before inserting). Then, insert the pry tool and unlock each clip one by one. However, this method requires a certain level of skill and may cause cosmetic damage, so please proceed with caution!
Hrenact - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 35
crwdns2936753:030crwdne2936753:0 228
crwdns2942667:0crwdne2942667:0 14,705
