Teenage Engineering OP-Z Battery Replacement
  1. Teenage Engineering OP-Z Battery Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Teenage Engineering OP-Z Battery Replacement, Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Teenage Engineering OP-Z Battery Replacement, Back Cover: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unlock the four rubber feet by turning them 90° counterclockwise using your thumb or finger tip.
    • There is a tiny mark on every foot facing the bottom edge of the OP-Z. After turning them they should face towards the short edge where the on/off switch is.
  2. Teenage Engineering OP-Z Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Teenage Engineering OP-Z Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • When turning the OP-Z over again the bottom plate should come off by itself (thanks gravity).
    • If the bottom plate won’t come off you might want to make sure every foot is rotated correctly and gently tug on one of them.
  3. Teenage Engineering OP-Z Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the bottom plate including the rubber feet.
  4. Teenage Engineering OP-Z Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Teenage Engineering OP-Z Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingernail or a spudger to lift the battery on the right side where the notch is.
  5. Teenage Engineering OP-Z Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Teenage Engineering OP-Z Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery.
    • When installing the new battery make sure you put it in contact side first.
For optimal performance, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
Repair didn’t go as planned? Ask our Answers community for help.
Tobias Isakeit
crwdns2935283:003/31/14crwdne2935283:0
125,348 crwdns2915208:0crwdne2915208:0
crwdns2935297:0189crwdne2935297:0
Tobias Isakeit - Repairability Engineer crwdns2935289:0Tobias Isakeit - Repairability Engineercrwdne2935289:0
Business
crwdns2935297:01,132crwdne2935297:0
Does anyone know if there a way to purchase this battery in Australia? the link for the battery above says not available in Australia.. Does anyone know of another source? thanks
richard - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 29
crwdns2936753:030crwdne2936753:0 141
crwdns2942667:0crwdne2942667:0 8,910
