Samsung Watch Active Screen Replacement
crwdns2942287:0crwdne2942287:0Use this guide to replace a cracked or broken screen on your Samsung Galaxy Watch Active.
Note: Some replacement screens come pre-installed in a new frame. That's a different procedure from what's shown in this guide. If you're replacing the screen and frame together, follow this guide instead.
You’ll need replacement adhesive to reassemble your device.
crwdns2944105:0crwdne2944105:0
Turn off the Galaxy Watch Active by pushing and holding the bottom button for approximately 3 seconds. You should feel a short vibration.
When the "Power off" symbol appears tap the center of the screen to make it shut down. You should feel a longer vibration for confirmation.
Use a Tri-point Y00 screwdriver to remove the four 4 mm-long screws on the back of the watch.
I'm having issues with getting the screws out it seems to be stripping them
Use an opening tool and place it between the plastic back cover and the metal housing near the buttons.
Push the tip of the opening tool into the gap to separate the back cover from the housing.
Do i need heat for this? i can't get a pry tool in
EDIT: use a Rasor knife in the corner nest to the screw holes and it's a lot easier and less damaging to take off.
In my case there was quite a bit of glue on the edge of the back cover, and a knife was indeed the only way to pry it open. No way to get the first gap with a plastic tool.
Carefully lift the back cover approximately 2 cm to access the sensor array connector near the two buttons.
Use a spudger to disconnect the sensor array from the motherboard.
Remove the back cover.
Use a spudger to disconnect the display assembly and the microphone and pressure sensor array.
Use an opening pick to peel back the thin tape belonging to the microphone array.
What can I use if the glue no longer holds?
Just make sure it lays flat and the counterpart on the back cover (the white thing at the bottom in the image of step 5) will press it down and hold it in place.
What can I use to make it lay flat?
Every time I press it down it just pops up again.
Insert an opening pick at the bottom right between the motherboard and the frame to lift up the core assembly.
Lift out and remove the core assembly.
Use a spudger to loosen the microphone which is fixed to the frame with mild adhesive.
What can I use to stick this back on during reassembly?
The leftover adhesive is not strong enough to hold it in place.
Use a spudger to lift the pressure sensor up and out of its recess in the frame.
Carefully remove the microphone and barometric sensor array from the frame.
Prepare an iOpener and apply it to the screen for two minutes to loosen the adhesive underneath.
Insert the opening tool under the frame where the sensor array was located.
Pry upwards to separate the screen from the frame.
Will this prying action damage a working screen?
The screen on my watch needs to be glued back down, and this is the closest guide I can find for doing that.
I needed to mark the inside of my watch on either side of the connector to make sure I put the face on with the cable centered properly so that it could reach the connector.
Use your fingers to pull the frame off the remaining screen adhesive.
Any tips for cleaning the adhesive off the screen if the screen is still good?
I accidentally scratched the black paint off the inside of the bezel trying to remove all of the adhesive.
I used this instruction. Few tips:
- You need to attack the backplate from the left or right side. I used a surgical knife to get between the plate and the housing.
- Use some heat to remove the microphone ground tab sticker. It is made of a metal mesh and some kind of glue. In my case it didn't want to stick when putting it back together, so I needed to use some heat again to re-attach it.
- align and mark the alignment with the screen housing and motherboard before glueing it, so the screen connector fits to the motherboard. I test-fitted the screen and the motherboard, then I used some tape across the screen and the housing. Finally cut the tape between the screen and the housing to remove the screen. When glueing it, I could now see the correct alignment with the housing. -
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0crwdns2947412:03crwdne2947412:0
What replacement adhesive is needed? I think my screen is ok, but it is falling out and I need to reattach it.
Try searching on Ali Express or Wish, etc. I just completed a screen replacement, and the screen I got came with 2 adhesives for it.
How do I put the mic array back in?
