Samsung Watch Active Screen Replacement
  1. Samsung Watch Active Screen Replacement, Turn off the watch: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Watch Active Screen Replacement, Turn off the watch: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn off the Galaxy Watch Active by pushing and holding the bottom button for approximately 3 seconds. You should feel a short vibration.
    • When the "Power off" symbol appears tap the center of the screen to make it shut down. You should feel a longer vibration for confirmation.
  2. Samsung Watch Active Screen Replacement, Remove the rear screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Tri-point Y00 screwdriver to remove the four 4 mm-long screws on the back of the watch.
    I'm having issues with getting the screws out it seems to be stripping them
    Alisha Kennedy - crwdns2934203:0crwdne2934203:0
  3. Samsung Watch Active Screen Replacement, Separate the back cover from the housing: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Watch Active Screen Replacement, Separate the back cover from the housing: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Watch Active Screen Replacement, Separate the back cover from the housing: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use an opening tool and place it between the plastic back cover and the metal housing near the buttons.
    • Push the tip of the opening tool into the gap to separate the back cover from the housing.
    • Don’t remove the back cover all the way yet. There is a cable connecting it to the motherboard.
    Do i need heat for this? i can't get a pry tool in
    23william90 - crwdns2934203:0crwdne2934203:0
    EDIT: use a Rasor knife in the corner nest to the screw holes and it's a lot easier and less damaging to take off.
    23william90 -
    In my case there was quite a bit of glue on the edge of the back cover, and a knife was indeed the only way to pry it open. No way to get the first gap with a plastic tool.
    Marcus Groeber - crwdns2934203:0crwdne2934203:0
  4. Samsung Watch Active Screen Replacement, Disconnect the sensor array: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Watch Active Screen Replacement, Disconnect the sensor array: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully lift the back cover approximately 2 cm to access the sensor array connector near the two buttons.
    • Use a spudger to disconnect the sensor array from the motherboard.
  5. Samsung Watch Active Screen Replacement, Remove the back cover: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back cover.
    Thank you very much. Nice job!
    Alvaro Grites - crwdns2934203:0crwdne2934203:0
  6. Samsung Watch Active Screen Replacement, Disconnect the display and the mic array: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Watch Active Screen Replacement, Disconnect the display and the mic array: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Watch Active Screen Replacement, Disconnect the display and the mic array: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to disconnect the display assembly and the microphone and pressure sensor array.
  7. Samsung Watch Active Screen Replacement, Undo the mic tape: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Watch Active Screen Replacement, Undo the mic tape: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Watch Active Screen Replacement, Undo the mic tape: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use an opening pick to peel back the thin tape belonging to the microphone array.
    • When re-assembling make sure this tape properly sticks to the motherboard by pressing it down with the flat end of a spudger.
    What can I use if the glue no longer holds?
    Dominik Dittrich - crwdns2934203:0crwdne2934203:0
    Just make sure it lays flat and the counterpart on the back cover (the white thing at the bottom in the image of step 5) will press it down and hold it in place.
    Tobias Isakeit -
    What can I use to make it lay flat?
    Every time I press it down it just pops up again.
    Rosalie E. Morgan -
  8. Samsung Watch Active Screen Replacement, Lift the core assembly: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Watch Active Screen Replacement, Lift the core assembly: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening pick at the bottom right between the motherboard and the frame to lift up the core assembly.
  9. Samsung Watch Active Screen Replacement, Remove the core assembly: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Watch Active Screen Replacement, Remove the core assembly: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Watch Active Screen Replacement, Remove the core assembly: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift out and remove the core assembly.
  10. Samsung Watch Active Screen Replacement, Loosen the mic: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Watch Active Screen Replacement, Loosen the mic: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to loosen the microphone which is fixed to the frame with mild adhesive.
    What can I use to stick this back on during reassembly?
    The leftover adhesive is not strong enough to hold it in place.
    Rosalie E. Morgan - crwdns2934203:0crwdne2934203:0
  11. Samsung Watch Active Screen Replacement, Free the barometric sensor: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Watch Active Screen Replacement, Free the barometric sensor: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to lift the pressure sensor up and out of its recess in the frame.
  12. Samsung Watch Active Screen Replacement, Remove the mic array: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the microphone and barometric sensor array from the frame.
  13. Samsung Watch Active Screen Replacement, Loosen the screen adhesive: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  14. Samsung Watch Active Screen Replacement, Separate the screen and frame: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Watch Active Screen Replacement, Separate the screen and frame: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Watch Active Screen Replacement, Separate the screen and frame: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the opening tool under the frame where the sensor array was located.
    • Pry upwards to separate the screen from the frame.
    Will this prying action damage a working screen?
    The screen on my watch needs to be glued back down, and this is the closest guide I can find for doing that.
    I needed to mark the inside of my watch on either side of the connector to make sure I put the face on with the cable centered properly so that it could reach the connector.
  15. Samsung Watch Active Screen Replacement, Remove the screen: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Watch Active Screen Replacement, Remove the screen: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Watch Active Screen Replacement, Remove the screen: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers to pull the frame off the remaining screen adhesive.
    • Clean any remaining adhesive from the frame using isopropyl alcohol (>90%) before installing the new screen.
    Any tips for cleaning the adhesive off the screen if the screen is still good?
    I accidentally scratched the black paint off the inside of the bezel trying to remove all of the adhesive.
    I used this instruction. Few tips:
    - You need to attack the backplate from the left or right side. I used a surgical knife to get between the plate and the housing.
    - Use some heat to remove the microphone ground tab sticker. It is made of a metal mesh and some kind of glue. In my case it didn't want to stick when putting it back together, so I needed to use some heat again to re-attach it.
    - align and mark the alignment with the screen housing and motherboard before glueing it, so the screen connector fits to the motherboard. I test-fitted the screen and the motherboard, then I used some tape across the screen and the housing. Finally cut the tape between the screen and the housing to remove the screen. When glueing it, I could now see the correct alignment with the housing.
    Darash - crwdns2934203:0crwdne2934203:0
Tobias Isakeit
crwdns2935283:003/31/14crwdne2935283:0
125,423 crwdns2915208:0crwdne2915208:0
crwdns2935297:0189crwdne2935297:0
Tobias Isakeit - Repairability Engineer crwdns2935289:0Tobias Isakeit - Repairability Engineercrwdne2935289:0
Business
crwdns2935297:01,132crwdne2935297:0
What replacement adhesive is needed? I think my screen is ok, but it is falling out and I need to reattach it.
Try searching on Ali Express or Wish, etc. I just completed a screen replacement, and the screen I got came with 2 adhesives for it.
Colm O'Sullivan -
How do I put the mic array back in?
Mason Thomas - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 11
crwdns2936753:07crwdne2936753:0 38
crwdns2936753:030crwdne2936753:0 135
crwdns2942667:0crwdne2942667:0 4,872
