Samsung Galaxy S9 Plus Display Replacement
crwdns2936621:0crwdne2936621:0
    1. Samsung Galaxy S9 Plus Display Replacement, Rear Glass Removal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Switch off your phone.
      • Use an iOpener to loosen the adhesive beneath the rear glass. Apply the iOpener for at least two minutes. You might want to repeat this step several times during the back cover removal.
      • The adhesive of the Samsung Galaxy S9 Plus is very strong. A hair dryer, heat gun, or hot plate may also be used if you aren't able to open the device with the iOpener. Be careful not to overheat the phone—the AMOLED display and internal battery are both susceptible to heat damage.
    2. Samsung Galaxy S9 Plus Display Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • In the following steps, you'll be cutting through the adhesive securing the back cover.
      • The adhesive in the inside of the back cover is laid out as seen in the image.
      • You'll be slicing through the adhesive in the areas shown:
      • Thick portions of adhesive
      • Thin areas of adhesive
      • Avoid prying or slicing in this area, to protect the fingerprint sensor flex cable.
    3. Samsung Galaxy S9 Plus Display Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S9 Plus Display Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • If the phone's rear glass is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
      • Press a suction cup onto the back cover.
      • Lift the back cover's bottom edge with your suction cup, opening a slight gap between the back cover and the frame.
      • This may require a significant amount of force, but you only need to open a very slight gap with the suction cup to insert your tool. If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools very fast, so you may need to heat it repeatedly.
      • Insert an opening pick in the gap and slide it to the bottom right corner.
    4. Samsung Galaxy S9 Plus Display Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S9 Plus Display Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Insert a second opening pick and slide it to the bottom left corner.
      • Insert a third opening pick at the bottom end of the phone. This opening pick stays there during the rear glass removal procedure to prevent the adhesive from resealing.
    5. Samsung Galaxy S9 Plus Display Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S9 Plus Display Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Start to slide the tip of the opening pick from the bottom left corner along the side of the S9 Plus.
      • Leave the opening pick in its place after you cut the adhesive half way up the left side of the phone.
      • Slide the opening pick from the bottom right corner half way up the frame and leave it there.
    6. Samsung Galaxy S9 Plus Display Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S9 Plus Display Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Insert a fourth opening pick at the right side of the frame and slide it to the top right corner.
      • Slide a fifth opening pick along the left side of the phone to the top left corner.
      • Use the opening pick to cut the remaining adhesive under the upper part of the rear glass.
      • Don't open the phone all the way yet. The flex cable for the fingerprint reader is still connected to the motherboard.
    7. Samsung Galaxy S9 Plus Display Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S9 Plus Display Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Carefully lift the side of the rear glass where the volume button is located.
      • Use the edge of a spudger to pry up and disconnect the fingerprint sensor flex cable.
    8. Samsung Galaxy S9 Plus Display Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the rear glass.
      • When reassembling follow this guide to replace the adhesive and reinstall the rear glass.
      • In case you want to replace your rear glass follow this guide to transfer the rear camera bezel including the fingerprint.
    1. Samsung Galaxy S9 Plus Display Replacement, NFC Antenna and Charging Coil: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the nine 4 mm Phillips #00 screws.
    2. Samsung Galaxy S9 Plus Display Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S9 Plus Display Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S9 Plus Display Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert an opening pick under the right side of the plastic cover containing the NFC antenna and charging coil.
      • Flip the opening pick sideways to lift the cover out of its plastic clips.
      • Work your way around the plastic cover, prying up to release the remaining clips.
    3. Samsung Galaxy S9 Plus Display Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the plastic cover containing the NFC antenna and the charging coil.
    1. Samsung Galaxy S9 Plus Display Replacement, Battery Disconnect: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the flat end of a spudger to pry up and disconnect the battery flex cable.
    1. Samsung Galaxy S9 Plus Display Replacement, Unfasten the Motherboard Cover: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the two 4 mm Phillips #00 screws.
    2. Samsung Galaxy S9 Plus Display Replacement, Remove the Motherboard Cover: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the plastic cover from the motherboard.
    1. Samsung Galaxy S9 Plus Display Replacement, Display: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S9 Plus Display Replacement, Display: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the flat end of a spudger to disconnect the display flex cable.
    2. Samsung Galaxy S9 Plus Display Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Prepare an iOpener and apply it to the display for at least two minutes to loosen the adhesive beneath.
      • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
      • If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
      • Lay overlapping strips of clear packing tape over the display until the whole face is covered.
      • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    3. Samsung Galaxy S9 Plus Display Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S9 Plus Display Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Once the screen is warm to the touch, apply a suction cup to the upper edge of the phone.
      • If the phone's screen is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
      • Insert an opening pick in the gap and start to cut the adhesive by sliding it to the top left corner.
    4. Samsung Galaxy S9 Plus Display Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S9 Plus Display Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S9 Plus Display Replacement: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert another opening pick and slide it to the top right corner of the phone.
      • Insert a third opening pick to prevent the adhesive from resealing during the display removal.
    5. Samsung Galaxy S9 Plus Display Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S9 Plus Display Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Start to slide the right opening pick half way down the side of the frame to cut the adhesive.
      • If cutting becomes too difficult, reheat and reapply the iOpener.
      • Slide the left opening pick half way down the frame and leave it in place.
    6. Samsung Galaxy S9 Plus Display Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S9 Plus Display Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Insert a fourth opening pick at the left side of the frame and slide it down to the bottom left corner to cut the adhesive.
      • The screen's flex cable is located just below the midpoint near the power button, and may interfere with your cutting tool.
    7. Samsung Galaxy S9 Plus Display Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S9 Plus Display Replacement: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S9 Plus Display Replacement: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert a fifth opening pick on the right side and slide it down.
      • Slide around the bottom right corner and cut the remaining adhesive on the bottom end of the display.
    8. Samsung Galaxy S9 Plus Display Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S9 Plus Display Replacement: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Once you cut the adhesive on all sides of the phone you can slowly lift the display upwards and remove it.
      • The display cable is threaded through a hole in the midframe; guide it through carefully in order to free the display.
      • Before installing a new display, it's very important to remove all traces of the old adhesive from the frame, and clean the glued areas with isopropyl alcohol (>90%) and a lint-free cloth.
      • If the frame is bent, or if any glue or glass remnants are left behind, the new display will not mount correctly and may be damaged. If necessary, replace the frame.
The best way to secure the new screen is with a sheet of custom-cut double-sided tape. Apply the tape to the back of the screen, then carefully feed the display cable through the frame. Align the screen and press it into place.
After you've completed the repair, follow this guide to test your repair.
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
crwdns2935229:052crwdne2935229:0
Dominik Schnabelrauch
crwdns2935283:011/23/16crwdne2935283:0
263.413 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
Staff
crwdns2931471:0123crwdne2931471:0
crwdns2935297:081.914crwdne2935297:0
crwdns2947412:011crwdne2947412:0
I need only 205 Minutes for changing…. 5 Minutes heat up to 60°C , then…
Kerker S - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
bonsoir
où puis-je trouver la coque arrière du s9 plus? puisque le mien est endomagé.
boubajinior@gmail.com
Boukary OUEDRAOGO - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Bonjour,
voici le lien sur l’article en question : ++Galaxy S9+ Rear Glass Panel/Cover
et voici le lien sur le tutoriel pour l’échange : ++https://www.ifixit.com/Guide/Samsung+Gal...
Sandra Hiller - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
210$ for the screen is more expensive than having it repaired for you in a lab…
Daniel S - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
how to change sansung galaxy S9 plus (screen) LCD flex belt?
Black 1213 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936751:024crwdne2936751:0 12
crwdns2936753:07crwdne2936753:0 98
crwdns2936753:030crwdne2936753:0 417
crwdns2942667:0crwdne2942667:0 125,787
