Samsung Galaxy S8 Battery Replacement
crwdns2936621:0crwdne2936621:0
  1. Samsung Galaxy S8 Battery Replacement, iOpener Heating: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S8 Battery Replacement, iOpener Heating: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
    I didn't find this to be as hard as I had built it up in my mind to be; HOWEVER, saying that I need to say years ago I was the local Nokia service center in my town. But many years ago right after they got rid of analog times. Yeah. A classic installer/repairer mistake when starting something they haven't fixed or installed before is picking up the instructions, flipping through them; maybe even reading a section that is new-then tossing the instructions over the shoulder. "I got this." This usually comes right before something major gets broke. And I can tell you when you try to do it yourself and then mess it up horribly then take it to the repair shop. Well we called that "I can do it myself" syndrome and charged extra to put back together what they brought in in the box. Now knowing all this - I can't stress this enough because I am stupid, stupid, stupid. COVER YOUR SCREEN IN CLEAR BOXING TAPE AND READ ALL THE INSTRUCTION BELOW THROUGH TO THE END BEFORE EVEN ATTEMPTING THIS FIX. Take my advise.
    windizy - crwdns2934203:0crwdne2934203:0
    I didn't have an iOpener, so I used a wheat type heat bag. If you do this though, make sure you put a layer of plastic between your Mac and the bag, or you'll get condensation in places you don't want it.
    Martin Gray - crwdns2934203:0crwdne2934203:0
    I started out using the iOpener but switched to my wife's hairdryer. A heat gun or hair dryer proved to be much more convenient and is a time saviour. You can heat more and the glue becomes more fluid make the next steps with the opening picks much easier
    Jan Van Puymbroeck - crwdns2934203:0crwdne2934203:0
    I know this is obvious, but backup your iPad with iTunes before you start. I'd also turn off your passcode if you have one.
    Laurie Higgins - crwdns2934203:0crwdne2934203:0
    Ther first time you heat up the iOpener for this repair when its room temperature I had to heat it up for more than 30 seconds. I remember I had to heat it up for around 45 seconds. However, after that when you need to reheat it again during the repair 30 seconds will be enough.
    Yousef Ghalib - crwdns2934203:0crwdne2934203:0
    I used the wheat bag in a sensor microwave heating up to 65-70 deg C (155 def F).
    ian cheong - crwdns2934203:0crwdne2934203:0
    Get yourself a cherry pit bean bag the size of your iPad. Heat it, put the iPad on it for 3 to 5 minutes or so, reheat the cherry pit bean bag, again put your iPad on it. Then heat the iOpener and start working. The cherry pit bean bag will have to be reheated several times, but it will soften the adhesive so you have less problems with the iOpener
    Tim Feyaerts - crwdns2934203:0crwdne2934203:0
    The heating can be done very effectively (and quickly) with 3d printer heated bed. Make sure the bed is clean. Set the temperature to 60c, (130f ) and put the ipad face down for +/- 10 minutes. Repeat as needed throughout the “gentle prying” stages.
    polleyphony - crwdns2934203:0crwdne2934203:0
    The iOpener did not work at all for me.
    I had to use a heat gun and bring the edges of the case up to ~200 degrees (used an infrared thermometer to measure) before the glue would weaken. This obviously superheated the metal frame, so I also had to wear gloves to handle the phone while prying the back off with the included picks.
    Mike Jeanette - crwdns2934203:0crwdne2934203:0
    Repair instructions worked like a charm. Had to be patient with the iOpener and getting the screen off. I tried repeatedly without success until shifting the suction cup a bit to the left side where perhaps the glue had loosened up a bit more.
    Kyle - crwdns2934203:0crwdne2934203:0
    The iOpener, in my opinion, is of no help. Many warnings to say “don’t warm it too much”, but the glue doesn’t melt if not warm enough. As a result, a complete waste of time and energy. In addition, too much liquid in it, so it doesn’t lay on the device on a sufficient surface. I took a hairdryer and it worked much much better.
    laurentvidu - crwdns2934203:0crwdne2934203:0
    I used an immersion bath to heat this to 180F and applied it to the device until the outside temperature of the opener read 150F with an IR thermometer. Removing the screen took very little force with this method.
    breadandbits - crwdns2934203:0crwdne2934203:0
    My experience. I was replacing the screen which had been cracked and a little shattered in some places. The iopener is pretty much useless, so was the suction cup. The suction cup would probably be more useful if I was doing something besides the screen. Also you probably want the clean the screen before using it so it can get good suction. I used a hair dryer on high for a couple of minutes at a time (someone on this tread suggested that). I used my exacto knife and a razor blade to get into the adhesive. First the exacto to get the initial cut, then the razor blade to go a little deeper. Could have probably just used the razor blade, but the exacto has a little more finesse. I got the razor blade in and a little under the glass then I used the picks to wedge in. I didn’t want to risk anything using the razor blade too much. Used tape to keep the shattered glass together.
    trebor65 - crwdns2934203:0crwdne2934203:0
    My experience pt2
    Fortunately the shattering was mostly on the edges and most of it had adhesive on the back so it stuck together. Just take your time and work your way around following the guide to get the screen off. Have some goof off or goo be gone to clean the frame when putting the new glass on or putting the existing one back. (someone suggested that also, very good idea). Be careful of the LCD (you should know that). The cable on my LCD was pretty tight, so I propped it up while taking the cable cover off and when I put it back on I did the same thing. I just put a bottle on the battery and leaned the back of the LCD on that while attaching the cables and putting the screws back on the cover. Also be careful with the home button and the bracket on the back of it. I had enough old adhesive on left on the bracket that it stuck back to the new glass fine. So far only 12 hours in, so we will see how that holds up when the kids get at it.
    Another alternative if you do not have the iopener is to use a bed time hotwater bottle. Do not over fill it though. Just put enough hot water in to support the phone while you work around the adhesive.
    I use both the hot water bottle and iopener together on Samsung's. It makes life easier
    gazza667 - crwdns2934203:0crwdne2934203:0
    I followed the directions and heated my iOpener for 30 seconds in a 1000 watt microwave, and it came out at 160 degrees F, as verified by a infrared thermometer. This allowed me to separate the last bit of the back of my Samsung S8, which was already coming off due to a swollen battery (hence the reason for the repair).
    Dennis - crwdns2934203:0crwdne2934203:0
    Hallo,habe den Akku erfolgreich getauscht.Doch seitdem gibt es bei Telefonaten eine Rückkopplung für den anrufenden.Bei mir ist alles normal.Woran liegt das?Mfg
    Manu R - crwdns2934203:0crwdne2934203:0
    If you follow these instructions, you will crack your screen like I did. Heating the iOpener for 30 seconds, using it to melt glue, then waiting 10 minutes to reheat is useless. The iOpener can be used to maybe warm the glue on whatever side you aren’t working on. You need a hairdryer and/or a heat gun to melt the glue and separate the glass from the iPad.
    Anyone want to buy an old iPad with broken glass and a dead battery?
    mpulliam - crwdns2934203:0crwdne2934203:0
    Not everybody has a microwave. You should provide a target temperature for the iOpener and instructions for a conventional oven, or pot of warm water, or whatever. Although I will probably use a heat gun …
    Esmond Pitt - crwdns2934203:0crwdne2934203:0
    Three times heating opener and no luck. Tried pressing down gently on opener with a towel, and the opener broke. Wondering if I now replace table mats, fancy table cloth, etc. or will this stuff wash out.
    Not impressed so far. Maybe the hair dryer next.
    doug - crwdns2934203:0crwdne2934203:0
    I support the comments about the iOpener. Everyone has a hair drier, FHS, so get a cheap IR thermometer (£18) and blow heat until the area is 60+ deg C. Still takes w while, and getting the screen off is v scary, but just add more heat if you feel resistance.
    The rest of the kit is good, esp the magnetic screwdrivers.
    Richard O'Brien - crwdns2934203:0crwdne2934203:0
    No, everyone does not have a hairdryer. Some of us don’t even have hair. Thank goodness I already had an IR thermometer, though.
    nin10doh -
    #### WARNUNG WENN MINIMALSTER SPRUNG IM DISPLAY IST FUNKTIONERT DAS NICHT!!! ######
    Hatte einen winzigen, minimalen Sprung im Display. Ich dachte es könnte gehen, weil der Sprung “abgeschlossen” war. Er hat in einer Ecke ein winzige Glasteil rausgeschnitten. NEIN! Geht nicht. Habe alles mit viel Geduld dem iOpener und einem Föhn erhitzt. Es ist trotzdem sofort über das komplette Display zersprungen…
    T z - crwdns2934203:0crwdne2934203:0
    I’ve started with iOpener but changed very quickly to a heatgun. That was more efficient.
    Mizzoo, s.r.o. - crwdns2934203:0crwdne2934203:0
    I could not get the iOpener hot enough to melt the glue on my ipad 6. I heated for 45 seconds once and it was boiling and it still never worked. Thank goodness contributors mentioned using a hair dryer. Using an 1700w hair dryer on high did the trick to get the screen off. Still took some time and the case got pretty hot but be patient. It took twice as long and a lot more patience to get the battery out.
    Randal Haufler - crwdns2934203:0crwdne2934203:0
    I have an Ipad with touch screen issue, if i replace this part it should be Ok?
    janderson martin - crwdns2934203:0crwdne2934203:0
    WARNING - DO NOT MICROWAVE ON A METAL MICROWAVE RACK
    The metal microwave rack can heat up and melt through the iOpener cover letting the contents leak out.
    Not a big issue for me as I have a heat gun and used that instead.
    Run Up A Tree - crwdns2934203:0crwdne2934203:0
    I opened my iPad with the iOpener. Be patient! It may take quite a bit longer to it the iOpener in the microwave than it says in the guide. My microwave can only do 800W and I had to put the iOpener in several times (maybe a total of 90-120 seconds). I recommend that you have the transparent side up an watch the bag carefully. As long a the bag doesn't bloat up and the liquid doesn't start bubbling you should be fine. But I recommend to take the iO out from time to time to check it. (More comments in Step 6.)
    marcelflueeler - crwdns2934203:0crwdne2934203:0
    I gave upon the I opener and used a hairdryer. (Fixed an iPad 6)
    Tom Weber - crwdns2934203:0crwdne2934203:0
    iPad mini gen5. I used the iOpener. My microwave is 1200w with carousel. 30 sec got the iOpener to 155ºF. For the 2nd heating, after 10 minutes sitting, the temp was still around 125º so I only cooked it for 15 sec. Not enough increase so +5 sec more which me to 165-170ºF. This should be considered ballpark info because who knows the real output of the various microwaves and the quality of the IR tool used to determine temp.
    To successfully open my iPad mini I applied the iOpener twice to the left edge and twice to bottom. & once to R edge. Using the suction cup was difficult for me (I'm in my 70's so my hands don't work too well anymore). I had trouble holding the guitar pick and slipping them in (at an downward angle). In the end, sliding my thumbnail along the edge opened it very slightly and allowed the pick to get into the gap. I marked the ends of all my picks with a sharpie pen for the recommended 2mm insertion to avoid going in too deep. To get the screen open it took me approx 1 hour.
    jharrison - crwdns2934203:0crwdne2934203:0
    Can’t you just use a hair curler instead?
    Aspect22 - crwdns2934203:0crwdne2934203:0
    A hairdryer or heat gun works, if heating is kept around 100 deg C (212 deg F - boiling point of water). But… heating this way is cumbersome. Using a hotplate, set to 100 deg C, measured carefully with a fairly inexpensive IR gun, is simpler and easier, if you can afford the hotplate (I used an old pancake griddle with a thermostat knob). It works great for phones, setting them face down for 2 minutes, then picking them up with insulated gloves - cheap, wool gloves work fine. This may require repeated reheating to continue the display removal, but its much simpler.
    Because its almost impossible to repeatedly lay an iPad/tablet on the hot plate, I propose an alternative.
    Initially lay the larger iPad/tablet, face down, for 2 min, to heat all of the adhesive surrounding the display. Lift and begin the picking process describe in your removal steps. Then lay an iOpener on the hotplate for 2 min (already set to the exact, desired temp) to bring it to working temp for the remaining operations.
    Dan Smith - crwdns2934203:0crwdne2934203:0
    For iPads in particular, it makes sense to construct a simple, aluminum window frame, laid on a hotplate (see my comment above) that only touches the edges of the display, heating only the adhesive underneath. This prevents general heating of the entire device. Four strips of aluminum, placed together as a frame, would be the simplest and allow variations for all devices - envision it as a pinwheel of strips, radiating outward. Use it for any size device.
    BTW, always read all comments at each step. New, and possibly useful, suggestions appear on occasion that can be crucial.
    My iOpener got damaged at the first heating (30 s @ 800 W). The bag got a little melted hole where the liquid came out and a little melted area. I used a combination oven (normal heat and microwave) in microwave only mode. It has a metal grill where the iOpener was placed on. I suppose the metal grill concentrates the microwaves at some points and there the bag melted?
    K. Fe - crwdns2934203:0crwdne2934203:0
  2. Samsung Galaxy S8 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat the iOpener for thirty seconds.
    • Depending on the wattage of your microwave, more or less time may be required. The iOpener is sufficiently heated when it's barely too hot to touch.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
    • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst. Do not attempt to heat over 100˚C (212˚F).
    • Never touch the iOpener if it appears swollen.
    • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
    I had to heat mine up for more than 30 seconds. After 30 seconds on high it was only warm. It had to keep trying different times and checking it until it got hot. I think the initial time that I put it in for was over a minute.
    whale13 - crwdns2934203:0crwdne2934203:0
    DO NOT USE IN NON ROTATING MICROWAVE! It will pop a hole. I had it in for 45 seconds the first time. It wasn't very hot inside and I saw it started to leak on the paper towel I put under it. Just a fair bit of advice. I think I will just stick with the heat gun. Loud but useful.
    Alex Jackson - crwdns2934203:0crwdne2934203:0
    I heated mine up for 30 seconds, tested, then again for 30 seconds. It felt adequately hot. Leaving it on the left side, per the instruction, for a minute did not loosen the adhesive. I ended up pulling the suction cup hard enough to shadder the old screen. Moral of the story, I don't think it gets hot enough safely to have an affect.
    Travis Dixon - crwdns2934203:0crwdne2934203:0
    There is a clear problem here with the heating part using the iopener things....no details are given. Whoever is testing them needs to make it clear - What temperature does it need to be? And for which phone models, because they differ in what's needed. It's only £10-15 for a laser guided temp sensor unit, and the designers/repairers should have one of those already for doing these kinds of repairs. Explaining half a repair, is worse than not explaining at all :-(
    assortedrubbish - crwdns2934203:0crwdne2934203:0
    All phones/devices differ it’s unrealistic and unsafe to put a exact time/temperature needed to soften the adhesive. It’s really quite simple you warm the device evenly and in a controlled manner just enough to enable pry tools and picks to begin separating. Best tool in my opinion but again this is because I have experience is a hot plate and heat gun both of which are used at nearly the lowest settings and I can handle flat palming the plate for almost 10 seconds I leave the device to conduct heat until approx it’s about 110 at most 120 ish this will be plenty to soften all the adhesive if any problem areas I use heat gun while prying. Again you need go slowly and learn with a throw away phone
    Greg Latta -
    I used a hot water bottle, works well as it covers the whole screen and stays hot for longer.
    dave - crwdns2934203:0crwdne2934203:0
    Now that is a very good idea :) I was going to use a hairdryer
    Maz -
    If I may suggest include your microwave wattage so people can get an idea on time for there own
    Patrick Storey - crwdns2934203:0crwdne2934203:0
    I agree with this.
    Jarl Friis -
    I ended up using a hair dryer. That iOpener thing took forever.
    mark fitzgerald - crwdns2934203:0crwdne2934203:0
    30 seconds sure isn’t cutting it… 45 didn’t get the screen of my iPad air 2 to budge either… even after resting on the ipad for 4 minutes.
    60 seconds in the microwave, the iOpener burst.
    I’ll get a new one and try once more with heating it 45 seconds and repeat that for 30 minutes like others have said here. If that doesn’t work it’ll have to be the heat gun.
    K
    Karl Marble - crwdns2934203:0crwdne2934203:0
    I can’t recommend the microwave. If the the iOpener becomes too hot, it bursts. Better put the opener in cooking water. Dry it and use it. Instead of an iOpener you can use hot/cool packs as well.
    Bernhard Keim - crwdns2934203:0crwdne2934203:0
    Great idea with using the heat packs. I will try that next time. Thank you
    Collins -
    Trust the directions! I forgot and left it in the Microwave too long and after 1 minute I had Mt Vesuvius - the iOpener burst and spewed the goodies out. The problem is, the Digitizer can be damaged by a hot air gun, so I had to tough out and remove the glue the hard way. I made it … with lots of patience! Tough lesson.
    Larry Bennett - crwdns2934203:0crwdne2934203:0
    I also used a hairdryer. I used it on the low setting and I cut a piece of carboard to protect the rest of the screen. The iFixit tool and method is vert tedious and very time consuming in comparison. With the hairdryer method you can literally have the display apart in a few minutes. Using your other hand nearby the area you are heating it should be very hot but not enough to burn your hand. You only have to heat metal part of case near glass edge. If you have a cellular model then you need to be very careful because the black antenna area is plastic. So less heat and work your way up in adding heat just enough to separate around the area but not so much you melt the plastic!
    Fixrights - crwdns2934203:0crwdne2934203:0
    iOpener was the worst part of the kit. Followed directions for :30 in microwave and took 4 trips to the microwave to loosen adhesive on left side of home button. I thought I was figuring it out and it was working well… even set a timer to wait 10 minutes between heating it up. Was on the right side and was on my 12th heat up when it exploded in the microwave. My only tip is that if you set it clear side up, as soon as you see any bubbles or boiling in the liquid, STOP! If you put a pot holder over the iOpener and press slightly to make good surface contact, that seemed to help. I finished heating with a “Corn Sack” that held heat better than the provided iOpener.
    digital_only - crwdns2934203:0crwdne2934203:0
    Mon iopener n'a pas tenu une réparation. Je ne vous conseille pas ce produit
    Berard Romain - crwdns2934203:0crwdne2934203:0
    Bonjour,
    Nous sommes désolés que votre réparation ne se soit pas déroulée comme prévu. Il se peut que le produit était défectueux. Veuillez contacter notre service client support@ifixit.com (boutique américaine) ou eustore@ifixit.com (boutique européenne) en décrivant ce qui s’est passé.
    Claire Miesch -
    Readers looking for temperature advice might check the comments of the previous instruction, as there are more there. I used an immersion bath to heat this to 180F and applied it to the device until the outside temperature of the opener read 150F with an IR thermometer. Removing the screen took very little force with this method.
    Thank you for posting some actual temperatures. I have a heat gun with a very fine self-temperature regulation setting capability.
    I will set it for 150-180 F, and use that to soften the adhesive.
    G Trieste -
    I followed the directions and heated my iOpener for 30 seconds in a 1000 watt microwave, and it came out at 160 degrees F, as verified by a infrared thermometer. A second heating about 15 minutes later in the micro and it came out at 190 degrees F. Plenty hot enough to soften the adhesive for removing the back on my S8. Based on the comments above I think people just need to use more patience.
    I used various time settings. It got very hot. It would soften the glue but not a whole lot. If my screen had been intact and I was replacing something that was not a digitizer, it may have worked. A broken screen makes the process significantly more difficult. I ended up breaking the home button cable. Good bye TouchID…
    cvela90 - crwdns2934203:0crwdne2934203:0
    After reading previous comments I didn't even use the i-opener. Used the heatgun ( hairdryer ) which works great for me. Maybe I was lucky as this is my first attempt at replacing a cellphone battery. Motoz 3
    Collins - crwdns2934203:0crwdne2934203:0
    It appeared 30 seconds were not enough, so I heated it more, by 5 seconds at a time until I got the right temperature about 70 degrees Celsius (measured with infrared pistol) to get the screen heated up to 60 C, the best for softening the glue. But the heat was quickly dissipating by the big aluminum back cover, so the best I got in 2 minutes of applying iOpener was around 45 C, which made the procedure difficult and having risk of breaking the screen. So I eventually abandoned iOpener and user a hot air gun with precise temperature setup. I set it to 90 C, which allowed me to open my iPad quickly and safely.
    Sergey Kofanov - crwdns2934203:0crwdne2934203:0
    I, too, ended up using a hot air gun. I’ve done earlier versions of iPad before but the adhesive used on this IPad 5 A1822 was particularly difficult to remove.
    Also, while the suction cup worked great when the glass is in tact, any cracks in the glass make the suction cup useless.
    manningrl - crwdns2934203:0crwdne2934203:0
    You need to remember here are different sizes of microwaves. I had the same issue.
    Heating on a smaller unit I used 45-60 seconds. That worked but was time comsuming
    William Draheim - crwdns2934203:0crwdne2934203:0
    Yeah, the iOpener didn't work for me either.... ended up using a hair dryer and that worked. The iOpener was too warm to soften the glue in my case.
    Andrés Vettori - crwdns2934203:0crwdne2934203:0
    I had a rotating plate microwave for my repair, and heating the iOpener 30-40 seconds worked plenty well for me.
    Ciarán - crwdns2934203:0crwdne2934203:0
    I tried 600W microwave for 30 sec and it was nicely warm, did nothing on iPad. Added 10 more sec, bit warmer, another 20 sec and it was finally a bit hot to hot in the hand - but still didn't do anything on iPad. I switched to a hair dryer as I used to work with it before, while being a bit sad about not using this brand new iOpener tool. And I found it short on 12.9 iPad anyway, maybe next time.
    Liibo - crwdns2934203:0crwdne2934203:0
  3. Samsung Galaxy S8 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
    I did this repair. I used a hair dryer, I think it works better: gets very hot fast.
    Cobus de Beer - crwdns2934203:0crwdne2934203:0
    I did too, you get far more control and no expense on fancy equipment.
    Billinski -
    Readers looking for temperature advice might check the comments of the previous instruction, as there are more there. I used an immersion bath to heat this to 180F and applied it to the device until the outside temperature of the opener read 150F with an IR thermometer. Removing the screen took very little force with this method. I don’t know how much microwaves vary in heating consistency with these pads, but knowing how inconsistent the temperature of a bowl of plain rice gets in my microwave, I wasn’t interested in even trying to use it for this.
    I used an electric griddle set to the lowest setting. It seemed to work very well.
    John - crwdns2934203:0crwdne2934203:0
    I vote for the hair dryer. The other methods work too but if you aren’t having any luck, switch to the hair dryer. While holding the iPad in my hand, I found that I am aiming the dryer at my finger at the same time and it gauges how hot it is. I stop when my finger can’t take it - maybe five seconds up close. Repeat as needed like I did.
    Robin - crwdns2934203:0crwdne2934203:0
    This thing melts when placed up side down in the microwave…
    Mark - crwdns2934203:0crwdne2934203:0
    If the maximum temperature for this iOpener is lower than the gadget glue minimum temperature, this device does not make sense.
    I think the maximum temperature for this iOpener is below 100⁰C and most gadget glue minimum temperature is higher than 100⁰C. So the iOpener is useless for many opening steps in repair guides. But who knows because temperature range is not specified for this iOpener.
    Jarl Friis - crwdns2934203:0crwdne2934203:0
  4. Samsung Galaxy S8 Battery Replacement, Alternate iOpener heating method: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S8 Battery Replacement, Alternate iOpener heating method: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • If you don't have a microwave, follow this step to heat your iOpener in boiling water.
    • Fill a pot or pan with enough water to fully submerge an iOpener.
    • Heat the water to a boil. Turn off the heat.
    • Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
    • Use tongs to extract the heated iOpener from the hot water.
    • Thoroughly dry the iOpener with a towel.
    • The iOpener will be very hot, so be careful to hold it only by the end tabs.
    • Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
    What do I do if I don’t have a iopener?
    alexdelarge103@gmail.com - crwdns2934203:0crwdne2934203:0
    2 or 3 cups Rice in a sock, heat for about 2 minutes. But, I recommend the iopener.
    Robert Garcia - crwdns2934203:0crwdne2934203:0
    When boiling in water you can put the iopener in a ziplock to keep it dry.
    Even if you don't put in a ziplock bag, I found that the surface is mostly hydrophobic so drying it is very easy. I also didn't have tongs, but the bag is denser than water, so it sank and I attached clothes pins to the ends and was able to remove it with those.
    Jack Adrian Zappa - crwdns2934203:0crwdne2934203:0
    2-3 minutes in near boiling water, then 2-3 minutes on my s10+ and it was super easy to cut the glue off.
    Kipras Bielinskas - crwdns2934203:0crwdne2934203:0
    I have a question, if I have a pan, and I have water, and a mean to boil the water, won't it be easier and cheaper to just use that.
    Ollie Tan - crwdns2934203:0crwdne2934203:0
    Have you tried it? Water limits your temperature to 100℃, whereas 'pan on the stove' can easily get up to twice that. If your pan is even slightly warped, you'll have a few hot spots of direct conduction with convection everywhere else, heating things unevenly. Assuming you get the device up to temperature, how will you get it out without scratching it or burning yourself? After you're finished, do you really want to prepare food in the pan you warmed up adhesives and trace manufacturing substances in?
    Boiling something form fitting to heat your device with is a lot more foolproof, and not being foolish is easier and cheaper. Direct pan heating can work, but you are leaving yourself open to a lot more problems than just taking the safe route.
    James Beegle -
    add a little basil and oregano on the pan peanuts cashews walnuts and bam it pops right off
    david pride - crwdns2934203:0crwdne2934203:0
    It's more 3 minutes than 2 minutes in hot water, in 2 minutes it's not getting hot enough I think. I used the combo iOpener + hair dryer for about 2 minutes and I could then insert a first opening pick easily. The first opening pick is the trickiest step, then if you go slowly and with patience around the screen with other opening picks, it works well.
    vincent becker - crwdns2934203:0crwdne2934203:0
  5. Samsung Galaxy S8 Battery Replacement, Back Glass Assembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Opening your phone will compromise its waterproof seals. Have replacement adhesive ready before you proceed, or take care to avoid liquid exposure if you reassemble your phone without replacing the adhesive.
    • Heat an iOpener and apply it to a long edge of the S8 for about 2 minutes.
    • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the OLED display and internal battery are both susceptible to heat damage.
    • As you're waiting for the adhesive to soften, move on and read the following step to get an idea of where to pry.
    What type of adhesive should be used to seal? Or better said, what would you recommend.
    Ion Ion - crwdns2934203:0crwdne2934203:0
    I’d recommend precut adhesive designed for the rear cover. If that’s not available, thin, hi-bond double sided tape like 1 mm wide Tesa 61395 tape will work well.
    Adam O'Camb -
    Yes, different microwaves have different power levels (e.g., wattage) so one microwave may explode the iOpener after 31 seconds of heating whereas another microwave will barely warm it. It would be helpful to have a more precise target temperature. My microwave is fairly weak so I’m heating it for seven seconds for every two minutes against the phone. In theory, this should slowly add more heat than is dissipated into the phone and surrounding atmosphere.
    Brett Stime - crwdns2934203:0crwdne2934203:0
  6. Samsung Galaxy S8 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S8 Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • In the following steps you will be cutting through the adhesive around the edge of the rear glass panel.
    • The adhesive on the rear case is laid out as seen in the first image.
    • The prying pattern as seen from the outside of the phone is as follows:
    • Thick portions of adhesive
    • Thin areas of adhesive
    • Avoid prying here, to protect the fingerprint sensor.
    Go clockwise (or counter-clockwise) around the border to avoid causing extra stress on the back. The bottom has a lot more adhesive than you think, towards the top-center.
    Michael M - crwdns2934203:0crwdne2934203:0
    Failing completely at this step. I’ve heated the opener like 5 times and the phone is hot to the touch, but I can’t get even the tip of the pick into the opening.
    r torrance andrews - crwdns2934203:0crwdne2934203:0
    Added a hair dryer to the effort and stil making no headway at all.
    Be careful. Insanely careful. If you think you are careful enough, this means you need to be even more careful. If you think it is not possible to be more careful, then be a little more careful and you might be able to remove the back cover without breaking it. Especially the bottom of the phone.
    pio - crwdns2934203:0crwdne2934203:0
  7. Samsung Galaxy S8 Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S8 Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S8 Battery Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once the back panel is warm to the touch, apply a suction cup as close to the heated edge of the phone as you can while avoiding the curved edge.
    • The suction cup will not make a good seal on the curved portion of the glass.
    • If the phone's back cover is cracked, the suction cup may not stick. Try lifting it with strong tape, or superglue the suction cup in place and allow it to cure so you can proceed.
    • Lift on the suction cup, and insert an opening pick under the rear glass.
    • Due to the curved glass, you will be pushing up, rather than inserting parallel to the plane of the phone.
    We can't seem to get anything between the edges even after heating the back panel. Any tips?
    Megan Kennington - crwdns2934203:0crwdne2934203:0
    Hi Megan, unfortunately the adhesive is super tough on this one. I’d recommend carefully continuing to apply heat, very gradually so that you don’t accidentally overheat the battery. Eventually you should be able to get a little gap with the suction handle.
    Adam O'Camb -
    I’ve been attempting to get the adhesive to loosen for four hours now. Exactly how much time is this supposed to take? The pictures makes it look like it should be easy. The adhesive still hasn’t budged and I’m beyond frustrated.
    Lori Lucas - crwdns2934203:0crwdne2934203:0
    Hi Lori, sorry to hear the adhesive is being extra stubborn! If reheating and reapplying the iOpener isn’t working, you can try heating the edge with a hairdryer or heat gun. That way you can get more heat onto the edge faster, but be very careful not to overheat the battery inside.
    Adam O'Camb -
    I used a stanley knife - very carefully, after trying for several hours to get the adhesive to loosen. I bought another back cover with adhesive for the assmbley, which is the best option in my opinion. Just be careful not the scratch the case of the phone, and be prepared for the back glass cover to break when removing it.
    James wright - crwdns2934203:0crwdne2934203:0
    The manufacturers really want to make this impossible, huh… I’ve gone 3 years without ever cracking this phone and end up cracking the corner of the back trying to prise it open. Probably should’ve gotten a heat gun too. This is super tight.
    Benjamin Chaim - crwdns2934203:0crwdne2934203:0
    I am currently working on this. I have heated the phone to just barely to hot to hold. No matter how many times I've done this and pulled up with a suction cup I cannot get an edge to lift.
    Being that this is my second phone repair does anyone have advice on this? I've watched several YouTube videos and it looks so easy.
    DAVID LAWRENCE - crwdns2934203:0crwdne2934203:0
    I suggest you try to lift on the middle of an edge using the thinnest spudger you have. also as the edge is curved remember to insert it so to follow the curve. Hopes it helps
    Cajuteq -
    Our issue was that a small gap would open when using the iOpener, but not large enough to get spudger or opening picks in there (also tried hair dryer but same result). Luckily as a guitar player I had some very thin nylon picks that we were able to get in there, which opened up a large enough gap to get the spudger and opening picks in. From there, we were able to heat the other sides and guide the spudger around the entire edge to get the back glass off.
    First we used a Dunlop nylon .38 mm guitar pick, then a .60 mm pick, and that allowed us to get the spudger in.
    Dan Coleman - crwdns2934203:0crwdne2934203:0
    This is by far the hardest part of any tutorial that requires you to open the Samsung. The iOpener is totally useless on my opinion (it doesn’t get warm enough). What I did instead is use a hairdryer but it took me time before I could get the adhesive soft enough. Especially since I was not able to measure the temperature of the phone will warming it. Also I think that the halberd is not thin enough so I used a radiology sheet (don’t know the right word in English) to get into the phone and it was much more effective and time saving. Thank you for the tutorial and good luck !
    Thomas Alliot - crwdns2934203:0crwdne2934203:0
    Use a utility knife blade to work around the edges. Careful not to pry on the blade since you risk cracking the back
    Derek Gibson - crwdns2934203:0crwdne2934203:0
    I bought a back glass replacement kit with the battery kit since mine was cracked already. I used both iOpeners to uniformly heat the whole back along both long edges. I microwaved each pack twice over 10 mins. 5 mins apply, microwave, 5 minutes apply. That worked!
    William Mellema - crwdns2934203:0crwdne2934203:0
    Similar to other posts, this appeared simpler. I have a couple of tube socks filled with rice that we use a lot for a sore back. Put in microwave for 5 minutes and an amazing heat pack. So I thought I would try this instead of the iOpener as it just was not getting the phone warm enough. Wrapped the phone in the riced-filled-tube sock for a couple of minutes, to the point where I could at least pick it up and hold it. Also, I have the full IFIXIT kit, so I pulled out the jimmy. Viola. Got right in and then allowed me to use the halberd and picks to finish it off.
    kendrickcc - crwdns2934203:0crwdne2934203:0
    I was able to do this with the iOpener warming pad by microwaving for the suggested 30secs then leaving it on for 10 mins. repeated this process 2 more times for a total of 3 times @ 30 mins and used the suction tool and the picks to get it open. There is a considerable amount of adhesive on the tops and bottoms of the phone. So consider warming the whole phone before doing it.
    Note: if you already have a cracked back panel (like me) prior to starting the process, consider getting the replacement as the already cracked panel will crack even more as you are cutting away at the adhesive. Goodluck!
    Harry Williams - crwdns2934203:0crwdne2934203:0
    After over an hour of trying to use heat and the suction tool loosen the adhesive and try to get an opening on one of the edges, I used the blue spudger to see if it would slip thru the edge and it did. I was able to loosen the majority of the back glass but ended up getting excited and rushing and cracked the top corner. I was able to complete the battery replacement and use the cracked back glass. I’m going to order a replacement for that and that should be easier. Lesson to be learned, if any part of the back glass is getting a little tougher to loosen, hit it with heat again just to be safe. The rest of the replacement we pretty straight forward.
    MJH - crwdns2934203:0crwdne2934203:0
    The spudger provided in ifixit repair tool kit is not the same as the one used in this guide and can not be used in the same way as the spudger used in this guide. So I am pretty much winging it on the most critical point of this disassembly. This is extremely frustrating.
    Brent Neilson - crwdns2934203:0crwdne2934203:0
    I’ve repaired many iphones but this was my first attempt on a Samsung. I made no headway at all on opening the case and I’ve decided to just live with the battery being kind of weak. Even with a short life, I would much rather use this phone than an Iphone.
    I've tried 5 times in over the course of 4 hours to loosen the adhesive on this phone, and it won't budge. Unfortunately this kit is useless to me
    Emily Reese - crwdns2934203:0crwdne2934203:0
    Once I opened one edge, I heated up the other edges then just moved the pick around the entire perimeter of the phone to break the adhesive.
    Stephen Legg - crwdns2934203:0crwdne2934203:0
  8. Samsung Galaxy S8 Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once you have the tool firmly inserted into the glass, reheat and reapply the iOpener to soften the adhesive.
  9. Samsung Galaxy S8 Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S8 Battery Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the opening pick down the side of the phone, separating the adhesive.
    • Go slowly so that the tool doesn't slip out of the seam. If cutting becomes difficult, reheat and reapply the iOpener.
    Cracked my glass multiple times, do this very slowly and with more heat to each new area.
    Gary Mirams - crwdns2934203:0crwdne2934203:0
    Second on cracking the back glass. Go slow and apply heat to each side before trying to pry it open.
    Adam Huber - crwdns2934203:0crwdne2934203:0
    Steps 9 to 11 > Be careful.. the NFC and Wireless charging might be stuck to the roof of the back panel. This will look very similar to whats in the video... the difference is that the cable goes away from you, rather than towards the top of the phone. The fingerprint sensor cable is very easy to disassemble, so if you feel resistance, heat up the back cover a little more.
    The Artworker - crwdns2934203:0crwdne2934203:0
  10. Samsung Galaxy S8 Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S8 Battery Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S8 Battery Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
    • Leave an opening pick on each side as you continue to the next to prevent the adhesive from resealing.
    Petite erreur: le guide dit iPhone au lieu de S7 :)
    Nicolas Duthilleul - crwdns2934203:0crwdne2934203:0
    Bonjour Nicolas ! Merci pour la remarque ;-) Nous l’avons prise en compte et corrigé la traduction. La prochaine fois, n’hésitez pas à corriger directement en cliquant sur le bouton Traduire en haut à droite de l’étape.
    Claire Miesch -
    Just in case you didnt see comment in Step 9.
  11. Samsung Galaxy S8 Battery Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S8 Battery Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The fingerprint sensor cable connects the phone to the rear glass near the main camera. The cable is very short and should disconnect as the rear glass is removed.
    • As you lift the glass, peek in to be sure the orange cable with a blue connector has disconnected.
    • Use the opening picks to slice through any remaining adhesive and open the phone slightly.
    • If the fingerprint sensor cable seems snagged or stays taut do not open the phone any further. Disconnect the connector with the point of a spudger before proceeding.
    • During reassembly, in order to reconnect the fingerprint sensor cable, first angle the back cover into position until the cable connector lines up perfectly over its socket. Then, use the flat end of your spudger to gently snap the connector into place by pressing it straight down.
    • Remove the glass from the phone.
    For reassembly, if the fingerprint scanner is removed from the back cover: it’s much easier to place the fingerprint scanner in the small compartment on the back of the phone, connect it and then finally put the replacement back cover on. The adhesive on the inside of the back cover will get connect to the fingerprint scanner and hold it tightly.
    Brian Hoffmann - crwdns2934203:0crwdne2934203:0
    I wish I saw this comment earlier because it's absolutely correct. I hope iFixit remedies this because it is incredibly difficult to connect the sensor when it's already adhered to the glass. It took me a good while and I ended up using some tape to keep the back glass aligned while I used the spudger to push blindly until it snapped into place. The only way I knew it worked was because I tested the sensor before fully sealing the glass.
    Preston Steimel -
    The NFC antenna and coil assembly might get stick to the back cover due to adhesive spreads while trying to pry the back cover to open the phone. Take a look inside to ensure the assebly has not got sticked. If so, try using a credit card like plastic to get it peeled of from back cover without breaking the assembly always paying attention to the fingerprint sensor as well.
    dcode - crwdns2934203:0crwdne2934203:0
    Reconnecting this cable seems like it would be very tricky: how can you get the pieces close enough together to make the connection without having the perimeter adhesive start to connect the front and back? It seems like that adhesive could easily get messed up at this point.
    To remove the akku, high temperature was NOT constructive!! I used ethanol (cc.) instead and it worked in between 2 minutes. I think it´s also better to open the coverage in this way. Instead of heating it.
    Franz Gassner - crwdns2934203:0crwdne2934203:0
  12. Samsung Galaxy S8 Battery Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To install a new back cover:
    • Use tweezers to peel away any remaining adhesive from the phone's chassis. Then clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth to prep the surface for the new adhesive.
    • Peel the adhesive backing off of the new rear glass, carefully line up one edge of the glass against the phone chassis, and firmly press the glass onto the phone.
    • Follow this guide to reinstall the old back cover, or to install a back cover without pre-installed adhesive.
    • Be sure to turn on your phone and test your repair before installing new adhesive and resealing the phone.
    • If desired, you may reinstall the back cover without replacing the adhesive. Remove any large chunks of adhesive that might prevent the back cover from sitting down flush. After installation, heat the back cover and apply pressure to secure it. It won't be waterproof, but the glue is usually more than strong enough to hold.
    • You may also need to transfer the camera bezel to your new part. If that's the case, follow our camera bezel replacement guide.
    Bonjour,
    Vous parlez d’ajouter de l’adhésif, comment et où le trouve-t-on cet adhésif ?
    Difficile à appliquer ?
    Cordialement,
    Stéphane
    Steph D - crwdns2934203:0crwdne2934203:0
    Mille excuses, je viens de voir les “adhesive strips” :)
    I broke the rear glass trying to get all the adhesive off! Be very careful!!
    jimhunz - crwdns2934203:0crwdne2934203:0
    Be careful with the NFC Antenna/Charging Coil Assembly. It’s covered in a black wrapping that can look like adhesive. Don’t scratch too hard with the spudger, the wrapping will come off!
    Hello, I appreciate that tuto, very detailed for a somewhat subtle job . Is it possible to use one of the 7000 or 8000 glues in place of the adhesive Stickers ? Thanks
    Isaac OLEG - crwdns2934203:0crwdne2934203:0
  13. Samsung Galaxy S8 Battery Replacement, NFC Antenna and Charging Coil Assembly: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove eleven 3.7 mm screws using a Phillips #000 screwdriver.
    Are all the screws the same size? I do not have a way to organize every little screw and part of this phone.
    Gavin Clark - crwdns2934203:0crwdne2934203:0
    Hi Gavin, all the screws in this step are 3.7 mm long, so you can safely swap these screws with one another.
    Adam O'Camb -
    The 3 screws on the lower left are not necessary to remove the battery, only the top 8 screws.
    Miles Raymond - crwdns2934203:0crwdne2934203:0
  14. Samsung Galaxy S8 Battery Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S8 Battery Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the NFC antenna and charging coil assembly.
    I had to pry off the NFC antenna and charging coil assembly from the back cover. The adhesive probably spread a little bit while prying around the phone sticking some part of the NCF antenna and coild assembly sticked to the back cover. I had to use a credit card like pice of plastic to get it unsticked from the back cover without bearking it.
    This doesn’t really cover the last step of removing the NFC antenna/charge coil pad from the upper removable frame segment. Those two components separate and the new one adheres back onto that upper frame section. While its fairly self explanatory, it would be nice to have an illustration of that separation.
    JPagel - crwdns2934203:0crwdne2934203:0
    There's also the fingerprint sensor, which I almost accidentally pulled off.
    Kristajn - crwdns2934203:0crwdne2934203:0
    Yes need more details, difficult to remove, not solid, mostly plastic film
    Lyle Walsh - crwdns2934203:0crwdne2934203:0
  15. Samsung Galaxy S8 Battery Replacement, Loudspeaker Assembly: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove three 3.7 mm Phillips #000 screws.
    This is also unnecessary for replacing the battery.
    I found removing the loudspeaker assembly provided better access to the bottom edge of the battery, making it easier to remove.
    Greg Knowles - crwdns2934203:0crwdne2934203:0
  16. Samsung Galaxy S8 Battery Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the loudspeaker assembly.
    Mine stuck, pry from the little L extension
  17. Samsung Galaxy S8 Battery Replacement, Battery: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S8 Battery Replacement, Battery: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to disconnect the battery connector.
    What is the best way to reattach the battery ribbon cable? I am struggling to attach the new one.
    Shawn - crwdns2934203:0crwdne2934203:0
    Hi Shawn,
    Align the battery connector over the motherboard socket and use your finger to gently press the connector down. Sometimes, it's easier to align and connect the battery before you glue it into the phone. Make sure to disconnect the battery before you resume reassembly.
    Arthur Shi -
  18. Samsung Galaxy S8 Battery Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply 1-2 drops of high-concentration (>90%) isopropyl alcohol under each corner of the battery and allow it to penetrate for several minutes to help weaken the adhesive.
    • The battery adhesive is designed to be loosened with isopropyl alcohol.
    • Using too much alcohol can damage the display.
    • Alternatively, prepare an iOpener and apply it directly to the battery for at least two minutes. Reheat and reapply the iOpener as needed.
    Thankyou so much for the Isopropyl Alcohol trick!! This have really helped me :) Learn something new every day.
    ainsnic - crwdns2934203:0crwdne2934203:0
    Great tip - Especially as mid-pandemic, we have 85% Isopropyl in the house!
    sean.donnellan - crwdns2934203:0crwdne2934203:0
    If you use isopropyl alcohol remember it will do water damage and destroy your phone if the liquid gets on components! It does dissolve the adhesive used to stick the battery in place, but it’s not safe to come into contact with other (very nearby) parts of your phone!
    Nate Lately - crwdns2934203:0crwdne2934203:0
    Hi Nate! It is actually pretty safe to use high concentration isopropyl (over 90%) alcohol during repairs—the liquid is not very conductive, evaporates quickly, and does not leave a residue. High concentration IPA is often used for board cleaning during manufacturing/repair processes. IPA is also used to clean and displace water for water-damaged devices.
    Arthur Shi -
    It is super helpful to put a fe drops at the bottom end of the battery. If you use a prying tool it will come loose right away. No force needed - just take out the battery. Was surprised myself how easy the adhesive "breaks" with IPA or Ethanol (both >90% for sure)..
    BenZ78 - crwdns2934203:0crwdne2934203:0
  19. Samsung Galaxy S8 Battery Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S8 Battery Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening pick to pry up the battery from the bottom using firm, constant pressure.
    • You will be prying against the case directly above the daughterboard and antenna cables. Pry carefully to avoid damaging either of these components.
    • You may need to reheat and reapply the iOpener repeatedly to further soften the adhesive. The adhesive is tough and it may take a few tries to get the pick started under the battery.
    • Try your best not to deform the battery during this process. Soft-shell lithium-ion batteries can leak dangerous chemicals, catch fire, or even explode if damaged. Do not use excessive force or pry at the battery with metal tools.
    Very frustrating process. Not a kit problem, but the folks at Samsung must be a sadistic bunch to use so much adhesive to glue in a battery, No success removing yet after numerous reheatings. Cracked back cover, so proceeding with additional caution due to batter location. Cracked board below the battery would be a disaster.
    Bruce Ward - crwdns2934203:0crwdne2934203:0
    Success in removing the battery after about 7 reheatings. To reassemble, I had to remove the fingerprint sensor in order to fasten the circuit back to the board. Wasn’t a big deal. Reused the cracked back cover since I always use a protective cover and waterproofing isn’t an issue for me.
    Overall, I’m satisfied with the kit and the instructions. I just must have been too aggressive when dislodging the adhesive from the back cover.
    If you have removed the front glass already, the process is a lot simpler. You can take a hair dryer and use it close to the back of the battery for just a few seconds, then use a combination of dental floss and the opening pick to pry the battery out.
    Damien - crwdns2934203:0crwdne2934203:0
    I could not get a good angle with the pick to pry out the battery. I used the angled tweezers instead, although you need to be very careful not to puncture the battery. I inserted one tong of the tweezers along the bottom edge. I aligned the tweezer tip so it was flat against the front of the phone, parallel to the battery. Then I twisted the tweezers so the tip of the tong slipped under the battery. And I pulled the tweezers away from the front, continuing to twist the tip to keep it under the battery as I pulled the battery away from the adhesive. That worked quite well.
    Derek Snell - crwdns2934203:0crwdne2934203:0
    The dental floss trick works! So much easier to ‘floss’ out the battery than risking puncturing the battery.
    Wong Kee Wee - crwdns2934203:0crwdne2934203:0
    Another vote for just prying up with tweezers. Be careful not to puncture, but it works fine and is quick.
    This was quite easy for me, compared to the experience of others. I heated the iOpener for 30 seconds in a 1000 watt microwave, which brought it up to about 165 degrees F. I let it sit on the battery just like the directions indicated, for about 15 minutes. I tried to pry the battery up with an opening pick, but no dice. I reheated the iOpener for another 30 seconds, and it came out at about 192 degrees F, due to it being heated only about 15 minutes before. I let it sit for another 10 minutes on the battery or so. Then was able to work an opening pick under the battery from the bottom side of the phone, as indicated in the directions. It did require some force and sort of working the pick back and forth, but it went right under, and then I was able to pull it out the rest of the way with my fingers. Total time to remove the battery was about 30 minutes, including time spent heating the battery with the iOpener.
    I was hesitatant to use my blowdryer to soften the glue behind the battery. So instead, I tried prying it open with the screwdriver (delivered in the tool kit) and punctured it in the proces. STUPID ME. There was smoke and a funny smell. Also the battery heated up. Luckily no flames or bloating up. I freaked out, went outside with the phone and battery still attached. I left it there for the night. The next morning I found this video https://www.youtube.com/watch?v=vkQcmLVu.... It shows you how to remove the daughterboard. This frees up space on the top left corner of the battery. With the spudger you can get under the battery more easily. After this the battery removal was easy. Even without using a blowdryer.
    Bryan Atmopawiro - crwdns2934203:0crwdne2934203:0
    Agree with what Damien said. If you have the screen off, it’s much easier to remove the battery from the other side (screen side). Just use the iOpener directly on the adhesive and slide a pick in very carefully. Seems like the floss tip is pretty useful, wish I had read this beforehand!
    I had a swelled battery, and had a keyboard keycap puller (one of those that look like the H with a longer horizontal, and have 2 sizes of spaces), and wedged it under the bottom of the battery and used a sharpie to keep some pressure on it, and left it for a bit. After 20 mins the battery had partly popped free from the adhesive and was able to separate it the rest of the way. The swelling may have weakened the adhesive already.
    I also agree they are sadistic with the adhesive. if they wanted it to stay in while making it, a simple small strip would have been enough! They likely wanted it not to be removeable, to force a new phone!
    Wolphin - crwdns2934203:0crwdne2934203:0
    Bryan’s video link is the right solution. The daughter board is easily removed and makes removing the battery very easy.
    Sebastian Stabinger - crwdns2934203:0crwdne2934203:0
    A combination of more alcohol (surgical spirit in UK terms) under the battery, plus 15 continuous mins of iOpener on the battery finally did the trick. Agree with the “sadistic" comment above!
    Dale Self - crwdns2934203:0crwdne2934203:0
    Much easier if you remove the daughter board as Bryan suggests. It is a bit tricky to reconnect the board though.
    I read all these comments. Getting more anxious as I read. However, I nuked the iOpener and laid on the battery for about 4 minutes and started prying with one of the blue triangle thingys. The battery basically popped out after about a minute of prying. IMHO I believe I had a helping hand since I am replacing a swollen battery and believe that the swelling is what helped loosen the glue. Since the swelling had also partially opened the case on the battery side with a gap of about 1/4". I am totally satisfied with the iFixit kit. My only complaint would be the delivery time to get the kit. I ordered on 01/02 and didn't receive it until 01/10. In total this saved buying a new phone. Thank you iFixit.
    Wayne Springer - crwdns2934203:0crwdne2934203:0
  20. Samsung Galaxy S8 Battery Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S8 Battery Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S8 Battery Replacement: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the opening pick up the side of the battery to break apart remaining adhesive.
    • Lift the battery out of the case.
    • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
    • If you used isopropyl alcohol, wait ten minutes before installing the new battery to allow the alcohol to completely evaporate.
    • To install a new battery and adhesive, follow this guide.
    There is no need to replace the adhesive for this battery. Please do your future fellow man a favor and do not replace the adhesive.
    I got case adhesive but NO battery adhesive with note 8 kit
    Battery I bought from iFixit worse than battery I took out.
    No customer service on webpage.
    Disappointed...
    sebclae shearn - crwdns2934203:0crwdne2934203:0
    I’m sorry to hear that! We do have customer service—please contact our customer support and we will get the issue resolved!
    Arthur Shi -
    Hi, the screen is not responding after assembling it all back. It comes up when receiving calls or restarting but doesn’t responde to touchscreen or buttons. What can I check? I’ve gone through the process a number of times to ensure everything is properly assembled. Thanks
    Isa - crwdns2934203:0crwdne2934203:0
After reapplying adhesive, follow these instructions in reverse order to reassemble your device.
For optimal performance, calibrate your newly installed battery after completing this guide.
crwdns2935229:0183crwdne2935229:0
Adam O'Camb
crwdns2935283:004/11/15crwdne2935283:0
210.310 crwdns2915208:0crwdne2915208:0
crwdns2935297:0416crwdne2935297:0
crwdns2947412:044crwdne2947412:0
Who are these geniuses that engineer a cell phone that requires complicated surgery in order to replace a faulty or dead battery? Really? And this POS costs the yuppified zombies how much?
Joseph Kennedy - crwdns2934203:0crwdne2934203:0
Mate, check a term “planned obsolescence” on wikipedia. Even if 1/50 of people won't replace a battery but buy a new Samsung, it is a 1 extra cellphone sold. It was designed on purpose hard to remove.
Slavomir -
to make phone sistant and if you take how much thinks are in new phones of course they are complicated its same as new cars sorry but new technology is more sophisticated
denisek2110 -
Mine was stolen, it would be gone forever if they were able to pull out battery right away. But since I was calling and sending “play alert" commands through find my phone server, thieves were tired of it and left it on a sidewalk wrapped in paper and a t-shirt.
sen-q -
waterproofing?
Hugo Botas -
What type of adhesive do you use to stick the phone back
Good Survey - crwdns2934203:0crwdne2934203:0
Hi! In our store you’ll find a rear cover adhesive strip for the S8. In the event that that’s sold out, we recommend using Tesa Tape—the 2 mm width should work well for this repair.
Adam O'Camb -
How complicated compared to my old S4 … what a joke
mofla39 - crwdns2934203:0crwdne2934203:0
This was wild. I hope I don’t have to use this knowledge for awhile. Why doesn’t Samsung just tell you to send it back and they will fix it for the price of a new battery? If I pay $800-$1,000 for a phone that I can’t change the battery on after a year or two, I’m going to be !#^&@@ at Samsung. Should we all complain to them about making this service available or having them advertise the lack of battery changing before a customer buys it?
mtrman94 - crwdns2934203:0crwdne2934203:0
that’s the issue. Like Apple, Samsung want you to buy another new phone every year instead of replace the battery.
ANTHONY CAETON - crwdns2934203:0crwdne2934203:0
This process did NOT work for me. I purchased the kit and spare battery thinking it would be as easy as the video shows. However, after multiple attempts and several different hot pads later, the cover did not budge AT ALL. Now, I’m stuck with a kit that didn’t work and a battery (not even a Samsung replacement battery like the site stated), and nothing to show for it. Not being able to replace any battery in any electrical device on your own is just a poor engineering letdown, especially in such an expensive phone.
Michael Pakosta - crwdns2934203:0crwdne2934203:0
There are versions of phones with waterproof battery compartments and certainly they could maintain their ability to control waterproofing the product of they still redesigned the access to the back cover via a more robust removable rear cover with gasket.
But with rear main cover more secure with screws possibly?
I'm not going to spell out how to tell them to make their phones, but maybe they might consider how users want to have the ability to change the battery themselves, and maintain the control of the device without sending it to a repair site for some time period.
Think of all the professional customers, besides all the soccer moms, students and retirees who they might dismiss right away.
Military & Government Officials, maybe even Senior Company Executives and tech companies that use these for everything from email and texting to secure encrypted NSA stuff.
Make it so they can be field repaired with a fresh battery seems like a no brainer?
That's my 2 cents!
Michael McGarghan - crwdns2934203:0crwdne2934203:0
Hello All,
I went through the comments and two of them caught my attention.
1. Will the phone still be water resistant after this ?
Thanks
aperret - 01/01/2018
I could not see a reply to this question.
2. Just ordered the battery, but curious if anyone has any feedback in terms of reliability and if they get the same battery life out of a single charge versus the original.
Jacob Fulbright - April 9
Is anyone able to provide some feedback?
Thank you
Bogdan
bgdn.soare - crwdns2934203:0crwdne2934203:0
Thanks for the questions!
1. In theory the phone could still be water resistant, but I definitely wouldn’t expect that unless it was repaired by a professional—even then I’d still be pretty careful. In my experience it’s really easy to compromise ingress protections during a repair, so I generally just assume that my repairs are no longer up to the same water resistance standards as they were before.
2. We test our batteries to make sure they’re up to OE standards. If you aren’t getting close to the same life as you were with your original battery, contact our support team.
Good luck with your repair!
Adam O'Camb -
Regarding Question number two: I replaced the original battery of my Galaxy s8 with an Ifixit s8 Battery and after around half a year, the batterylife began to decrease and now my nine months old battery performs quite bad. I only get around two hours of screen on time in energy saving mode.
I hope i could help you with That
Kind regards
The Hightech Channel -
Sorry to hear your battery isn’t working well. Feel free to contact our support team for some help with that.
Adam O'Camb -
Replaced battery and a severely cracked back panel for a total of about $70 (750 NOK).
Less hassle and much cheaper than getting a new phone.
The glue holding down the battery is easily softened with some isopropyl alcohol.
A little warning: The NFC Antenna and Charging Coil Assembly has a rubbery feel to it. This substance does NOT like isopropyl alcohol and will disintegrate if you accidentally get some on there. It shouldn’t really matter much, but better keep the alcohol away from it.
Hans Marius Dalen - crwdns2934203:0crwdne2934203:0
After heating up the adhesive to the battery, it is a lot easier to go from the top where the battery connection is with your halberd spudger and just push it under the battery until it releases. Took me 2 minutes to heat up the adhesive then maybe 10 seconds to remove the battery from the case using the sponger. Also i gave up on the iopener and started using a hair dryer, worked way better.
mike howell - crwdns2934203:0crwdne2934203:0
There is a lot of adhesive on the back cover at the bottom of the S8, it goes about 1.5” up - its a lot of area to get through. Go very easy and make sure the adhesive is well softened with heat. You can go deep under the cover with whatever thin plastic tool you are using to separate the cover since theres nothing to damage in the area - but if you go too fast or pry too hard here the cover will break.
Aftermarket covers are very cheap (likely not gorilla glass), so it may just be better to be prepared to replace it if your original plan was to only replace the battery.
Paul G - crwdns2934203:0crwdne2934203:0
After an hour of iOpener’ing and suction cupping I now have a completely shattered back glass piece.
Picks, halbread, none of the tools included were thin enough, or strong enough to get into the seam opening. Further pulling on the suction cup shattered the entire back glass.
Waste of $80.
Bob Peachey - crwdns2934203:0crwdne2934203:0
Hi Bob,
I’m really sorry to hear about your repair! The back glass for Samsung devices are notoriously difficult to remove due to the adhesive. At this point, you got past the hardest part of the repair! The fix is still salvageable with a replacement back glass, which can be found for a reasonable price.
Arthur Shi -
The iOpener works surprisingly well. It does involve patience, I think I applied it a good 4 or 5 times at least to get the adhesive to give way. It was confusing where to put the new adhesive and I had to remove part of a piece around the camera in order to allow the fingerprint sensor to reattach. It would be nice if it were more clear where the adhesive went, nonetheless, I firmly believe that this is a good kit and I only broke one of the 6 picks. Definitely a moderate fix, but possible with some patience. It took me about 3-4 hours total with breaks. I spent a LOT of time using alcohol, picks and the spudger in order to remove the old adhesive. It did not matter that much in the end though.
MarBor - crwdns2934203:0crwdne2934203:0
I had no issues using the iOpener, though full disclosure the back of my S8 had almost completely separated from the body due to a ballooning battery, hence the reason for this repair.
Replacing the battery on the S8 takes waaaaay longer than the 20 minutes - 1 hour indicated. Start to finish it took me about 6 hours. Scraping off the old adhesive is incredibly tedious and time consuming. Additionally, lining up the new adhesive just right is very tricky, as you only get one shot at it. Once it’s on there’s no adjusting it. That plus the many trips back and forth to the microwave with the iOpener really adds up.
I spent an entire Sunday afternoon replacing my battery, but the result was perfect so I guess I can’t complain.
Dennis - crwdns2934203:0crwdne2934203:0
The battery in my Samsung Galaxy S8 is swollen and the back cover has popped almost all the way off. I used a guitar pick to carefully pry the rest of the back cover off. Now I am just waiting for my ifixit battery replacement kit to arrive. I was computer repair technician for many years earlier in my career, so I understand the delicate nature of these kind of repairs. My question is, while I know I should proceed with extreme caution due to the swollen battery, should I avoid using heat (applying the iOpener) to the battery to soften the glue? Seems like applying heat to a swollen battery is very dangerous. Should I use the alcohol method instead?
Mark Malone - crwdns2934203:0crwdne2934203:0
Yes, for your safety, avoid using heat if the battery is swollen. Use alcohol and plenty of patience/care. Rather than prying, see if you can slip a piece of floss underneath the battery to gently separate it. See ++What to do with a swollen battery++
Jeff Suovanen -
Lösen des hinteren Glases nach dieser Anleitung nicht möglich. Man kommt nicht an die inneren Klebestreifen und das Glas bricht. Jetzt habe ich einen neuen Akkug aber eine komplett gesprungene Rückseite trotz mehrfahchem erwärmen und sehr vorsichtig sein. Sehr enttäuschend, davon habe ich mir mehr erwartet!
Patrick Leitl - crwdns2934203:0crwdne2934203:0
I made this repair around nine months ago and for the first half Year the Ifixit Battery performed well. But after that time the battery drained very fast and i only get around 2 hours screen on time on energy saving mode. Right now the runtime is around the same as with the 3 years old original battery. Thats dissapointing because Ifixit is one of the only places you can buy good repair parts.
The Hightech Channel - crwdns2934203:0crwdne2934203:0
I replied to your comment above, but in case you don’t see that, please contact our support team for help with your battery.
Adam O'Camb -
This guide is great! Thanks!
Lucky Luka - crwdns2934203:0crwdne2934203:0
A hard part that wasn’t described in the guide was how to get the extremely short connector for the thumbprint reader to reconnect. Ended up needing a flashlight and the tweezers to get it reseated with nearly no spare to get it connected! They really should have made it longer so could connect it easier with a greater separation.
Appreciate the “19” steps but timing is waaaaay off! Started at 1:50pm, took till 3:25 just to remove the rear cover (using the iopener)! Took another hour to get the battery out! Battery back in at 4:50pm - after cleaning off the glue. Took till 5:45 to clean the glued areas of the phone, ready for the new back cover. By the way, as I was using a new replacement cover it took 30 minutes to remove finger-print sensor, clean off the glue and re-install it on the new cover. Complete re-assembly was completed at 6:23pm. Tested okay by 6:28pm. of note |I did have all the necessary IFixit gear! So successful install was completed in just over 4 1/2 hours!
Bob Gardiner - crwdns2934203:0crwdne2934203:0
Need to show how to apply the adhesive foil thing that comes with the ifixit battery replacement kit.
Neil - crwdns2934203:0crwdne2934203:0
Hi Neil,
we have a general “How to apply custom-cut adhesive strips” guide which might help you.
Dominik Schnabelrauch -
Why the !&&* don’t you include the %#*@ Tesa tape in the kit????
seannelson4201 - crwdns2934203:0crwdne2934203:0
Or at least tell the customer when they order that they will need Tesa tape as well so be sure to order that?
So removing the battery
I scratched the black pad
That the battery lays on
Exposing a brass sheet
S8 Samsung will this affect
The phone
David Schreder - crwdns2934203:0crwdne2934203:0
Hi David,
That pad is a heat dissipation layer, and the copper sheet is used for shielding and heat dissipation. Scratching the pad won't affect the phone.
Arthur Shi -
Super Anleitung, ich fände sie allerdings noch besser, wenn man auch ein Bild bringen würde, wie die ausgestanzten Klebepads auf den Deckel angebracht werden.
Und als Hinweis für andere, kratzt nicht zu sehr am Deckel um die Klebereste zu entfernen, ich hab jetzt kleine Punkte auf der Rückseite, weil ich die Farbe (?) abgekratzt habe. Und ich habe mit einem Plektrum gekratzt, falls die Frage aufkommt.
Andreas Köhler - crwdns2934203:0crwdne2934203:0
This is a joke. The instructions for opening the back cover don't make a lot of sense. The suction cup just lifts the whole phone off the table, and the iopener dosen't do anything at all. I reckon the phone in the video was already disassembled in a factory before the video was filmed.
Worst of all, the replacement battery is generic, and according to some other comments here, won't last very long at all. I mostly blame Samsung for making it impossible to easily replace the battery yourself, but still this replaement kit seems a really useless product.
Overall, the repair kit is a complete waste of money!
nathan parkin - crwdns2934203:0crwdne2934203:0
Muito obrigado, foi “show”
eco solutions - crwdns2934203:0crwdne2934203:0
The kit doesn't seem to be available anymore since it links to the battery only. Do we know if and when it become available again?
Max - crwdns2934203:0crwdne2934203:0
Well-Working Kit and Tutorial
Hello - like so many others following the tutorial, I shattered my back plate quite a bit. However, I was a bit impatient and omitted using the iOpener almost entirely, so that broken part is on me and I am either way using a protector case, which is why I do not care too much.
I agree with mike howell's comment, that it is way easier, to remove the old battery by using the spudger and removing the battery from the upper side, instead of the lower side and the picks which are quite bendy.
Overall, I am very happy with the repairing process and the time. I think I invested slightly less than an hour - investing slightly more time probably avoids shattering the back plate.
Thank you very much!
Adrian BUW - crwdns2934203:0crwdne2934203:0
Easy enough to do on an old but still virgin phone, the only pain was cleaning it up enough to get a new seal on.
Pulled the back off with nothing but methanol, suction cup and a spring steel spudger.
Honestly buy a spare back with pre applied seal from the usual suspects. If you're doing repairs for money and time is important then don't be scared to shatter the back glass. Let the customer know just in case they don't like the pricing.
TiredSysAdmin - crwdns2934203:0crwdne2934203:0
Found this very difficult. My first repair with the kit. the sides unstuck fairly easily with the iopener, but one end was very tight and I shattered the glass trying to unwedge it. LIve and learn I guess. I think I lacked a bit of patience, a lesson for next time.
John Gorman - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 37
crwdns2936753:07crwdne2936753:0 240
crwdns2936753:030crwdne2936753:0 1,259
crwdns2942667:0crwdne2942667:0 438,414
