Samsung Galaxy S25 Edge Front Camera Replacement
  1. Samsung Galaxy S25 Edge Front Camera Replacement, Prepare your phone for disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S25 Edge Front Camera Replacement, Prepare your phone for disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Let your phone's battery drain below 25% before starting this repair. A charged lithium-ion battery may catch fire if accidentally damaged.
    • Completely power off your phone and unplug all cables.
  2. Samsung Galaxy S25 Edge Front Camera Replacement, Heat the bottom edge: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Mild adhesive secures the back cover. Heating it will soften the adhesive, making it easier to separate.
    • Heat an iOpener and lay it on the bottom edge of the back cover for two minutes to soften the adhesive.
    • Alternatively, you can use a hair dryer, heat gun, or hot plate to heat the cover.
  3. Samsung Galaxy S25 Edge Front Camera Replacement, Apply a suction handle: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S25 Edge Front Camera Replacement, Apply a suction handle: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Apply a suction handle near the center of the back cover's bottom edge, as close to the edge as possible.
  4. Samsung Galaxy S25 Edge Front Camera Replacement, Insert an opening pick: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S25 Edge Front Camera Replacement, Insert an opening pick: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S25 Edge Front Camera Replacement, Insert an opening pick: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull up on the suction handle with strong, steady force until a gap forms between the cover and frame.
    • Insert the tip of an opening pick into the gap.
  5. Samsung Galaxy S25 Edge Front Camera Replacement, Adhesive information: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S25 Edge Front Camera Replacement, Adhesive information: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S25 Edge Front Camera Replacement, Adhesive information: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The back cover is secured with adhesive around the perimeter of the frame. Use this picture as a reference while you separate the adhesive.
    • When separating the left and right edge adhesive, don't insert your pick more than 3 mm to avoid damaging the wireless charging coil and interconnect cable.
  6. Samsung Galaxy S25 Edge Front Camera Replacement, Separate the adhesive: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S25 Edge Front Camera Replacement, Separate the adhesive: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S25 Edge Front Camera Replacement, Separate the adhesive: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • If you have trouble separating the adhesive, apply more heat and try again.
    • Slide your opening pick along the bottom edge to separate the adhesive securing the back cover.
  7. Samsung Galaxy S25 Edge Front Camera Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S25 Edge Front Camera Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S25 Edge Front Camera Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Continue sliding your pick around the entire perimeter of the back cover to separate all the remaining adhesive.
    • Remember not to insert your pick too far under the long left and right edges.
  8. Samsung Galaxy S25 Edge Front Camera Replacement, Remove the back cover: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S25 Edge Front Camera Replacement, Remove the back cover: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the back cover.
    • If you're having trouble, check the perimeter for any remaining adhesive and use your opening pick to separate it.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Check your rear cameras for any smudges and gently wipe them with a clean lint–free cloth if necessary.
    • Your replacement back cover adhesive will be applied to either the frame or the back cover. Use cutouts and contours to see where it lines up best. If it matches the back cover, follow this guide. If it matches the frame, use this guide.
  9. Samsung Galaxy S25 Edge Front Camera Replacement, Disconnect the wireless charging assembly: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S25 Edge Front Camera Replacement, Disconnect the wireless charging assembly: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger to pry up and disconnect the wireless charging assembly press connector from its top edge.
    • Getting the spudger under the connector can be tricky. If you're having trouble, try using the tip of an opening pick instead.
  10. Samsung Galaxy S25 Edge Front Camera Replacement, Remove the wireless charging and loudspeaker assembly screws: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S25 Edge Front Camera Replacement, Remove the wireless charging and loudspeaker assembly screws: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S25 Edge Front Camera Replacement, Remove the wireless charging and loudspeaker assembly screws: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    FixMat
    $31.41
    • Use a Phillips screwdriver to remove the eleven 2.8 mm‑long screws securing the wireless charging and loudspeaker assembly.
  11. Samsung Galaxy S25 Edge Front Camera Replacement, Pry up the loudspeaker: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S25 Edge Front Camera Replacement, Pry up the loudspeaker: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S25 Edge Front Camera Replacement, Pry up the loudspeaker: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The wireless charging coil is connected to the loudspeaker with delicate tape. It's easiest to remove the coil and loudspeaker together as one assembly to avoid damage.
    • Use angled tweezers to pry up and unclip the loudspeaker by the notch on its left edge.
    • During reassembly, press down firmly around the perimeter of the loudspeaker to engage its clips.
  12. Samsung Galaxy S25 Edge Front Camera Replacement, Remove the wireless charging assembly: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S25 Edge Front Camera Replacement, Remove the wireless charging assembly: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use two hands to lift and remove the wireless charging and loudspeaker assembly.
  13. Samsung Galaxy S25 Edge Front Camera Replacement, Disconnect the battery: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S25 Edge Front Camera Replacement, Disconnect the battery: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Every press connector has a corresponding gold arrow on the board that shows the proper location to pry—nifty! Prying at the wrong location risks damaging the fragile surface‑mounted components on the board.
    • Use the point of a spudger to pry up and disconnect the battery press connector.
  14. Samsung Galaxy S25 Edge Front Camera Replacement, Disconnect the earpiece speaker: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S25 Edge Front Camera Replacement, Disconnect the earpiece speaker: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger to pry up and disconnect the earpiece speaker press connector.
  15. Samsung Galaxy S25 Edge Front Camera Replacement, Remove the earpiece speaker screws: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S25 Edge Front Camera Replacement, Remove the earpiece speaker screws: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the five 2.8 mm‑long screws securing the earpiece speaker.
  16. Samsung Galaxy S25 Edge Front Camera Replacement, Pry up the earpiece speaker: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S25 Edge Front Camera Replacement, Pry up the earpiece speaker: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the flat end of a spudger to pry up and unclip the earpiece speaker from the center of its bottom edge.
    • During reassembly, press down firmly around the perimeter of the earpiece speaker to engage its clips.
  17. Samsung Galaxy S25 Edge Front Camera Replacement, Remove the earpiece speaker: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S25 Edge Front Camera Replacement, Remove the earpiece speaker: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift and remove the earpiece speaker.
  18. Samsung Galaxy S25 Edge Front Camera Replacement, Disconnect the front camera: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S25 Edge Front Camera Replacement, Disconnect the front camera: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of a spudger to pry up and disconnect the front camera press connector.
  19. Samsung Galaxy S25 Edge Front Camera Replacement, Heat the front camera: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Epoxy-like adhesive secures the front camera in its recess.
    • Lay a heated iOpener on the front camera for two minutes to soften its adhesive.
    • Alternatively, you can use a hair dryer or heat gun to lightly heat the camera.
  20. Samsung Galaxy S25 Edge Front Camera Replacement, Pry up the front camera: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S25 Edge Front Camera Replacement, Pry up the front camera: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S25 Edge Front Camera Replacement, Pry up the front camera: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the flat end of a spudger to pry up on the left and right sides of the front camera until the adhesive completely separates.
  21. Samsung Galaxy S25 Edge Front Camera Replacement, Remove the front camera: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your fingers or tweezers to remove the front camera.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for troubleshooting help.
Spencer Day
crwdns2935283:009/14/22crwdne2935283:0
145,602 crwdns2915208:0crwdne2915208:0
crwdns2935297:0972crwdne2935297:0
crwdns2936753:030crwdne2936753:0 46
crwdns2942667:0crwdne2942667:0 176
