Use this guide to replace the screen in your Samsung Galaxy S24+.
This guide shows how to replace the screen only. If your replacement part is a screen that's pre-installed on a frame, follow this guide instead.
The screen includes the front glass and the display panel. If your glass is cracked, you will need to replace both the glass and the display panel.
This process will destroy your old screen. Don't use this guide if you're trying to harvest a screen.
Unplug any cables from your phone.
Hold the side key and the volume down button, then select "Power off" to turn off your phone.
Heat an iOpener and apply it to the right edge of the back cover for two minutes.
Apply a suction handle to the back cover, as close to the center of the right edge as possible.
Pull up on the suction handle with strong, steady force to create a gap between the cover and the frame.
Insert an opening pick into the gap.
Slide the pick back and forth along the right edge to separate the adhesive.
Leave the pick inserted near the bottom right corner to prevent the adhesive from resealing.
Apply a heated iOpener to the bottom edge of the back cover for two minutes.
Rotate the opening pick around the bottom right corner to separate the adhesive.
Insert a second pick at the bottom right corner.
Slide the opening pick to the bottom left corner to separate the adhesive.
Leave the pick in the bottom left corner to prevent the adhesive from resealing.
Apply a heated iOpener to the left edge of the back cover for two minutes.
Rotate the opening pick around the bottom left corner to separate the adhesive.
Insert a third opening pick at the bottom left corner.
Slide the pick toward the top left corner to separate the adhesive.
Leave the pick near the top left corner to prevent the adhesive from resealing.
Apply a heated iOpener to the top edge of the back cover for two minutes.
Rotate the opening pick around the top left corner to separate the adhesive.
Insert a fourth opening pick at the top left corner.
Slide the pick toward the top right corner to separate the adhesive.
Leave the pick near the top right corner to prevent the adhesive from resealing.
Line up the tip of an opening pick with the flash.
Slide the opening pick under the top of the back cover until you feel it start to snag on the adhesive.
Keep sliding the pick toward the bottom of the phone while gently lifting the cover until the cover is free of the adhesive.
Grab and remove the back cover.
Use tweezers or your fingers to remove all adhesive from the back cover and the phone. Use heat or isopropyl alcohol (90% or greater) and a coffee filter or lint-free cloth if you're having trouble removing the adhesive.
If you're using custom-cut adhesives, follow this guide.
Use a spudger to pry up and disconnect the wireless charging coil press connector from the motherboard.
Use a Phillips screwdriver to remove the thirteen 3.5 mm‑long screws securing the wireless charging coil and the loudspeaker:
Six screws securing the wireless charging coil
Seven screws securing the loudspeaker
Insert the point of a spudger in the notch at the top left corner of the loudspeaker, which is marked by an arrow.
Pry up to unclip the loudspeaker from the frame.
Use your fingers to lift the loudspeaker away from the frame.
Remove the wireless charging coil and loudspeaker from the frame.
Use a spudger to pry up and disconnect the display cable press connector near the bottom edge of the phone.
Use a spudger to pry up and disconnect the display cable press connector from the motherboard.
Remove the display cable.
Put the back cover on the frame to protect the battery and your phone's internals from damage.
Flip your phone over so the screen is facing up.
Use a hair dryer or heat gun to heat the top edge of the screen until it's almost too hot to touch.
If your screen is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
crwdns2935267:0crwdne2935267:0iFlex Opening Tool$11.99
Don't grip the iFlex or similar metal tools by the edges with bare hands—they're very sharp.
The front glass may shatter and spread shards of glass around your workspace. Consider wearing gloves and safety glasses to protect yourself.
Apply a suction handle to the center of the screen's top edge, as close to the edge as possible.
Insert the iFlex or similar tool at a downward angle in the notch between the top edge of the front glass and frame.
Use strong, steady force to pry up the glass with the suction handle while gently pushing the iFlex between the glass and the display panel.
Rotate the iFlex or similar tool around one of the top corners of the front glass until the gap is large enough to insert an opening pick.
Insert an opening pick into the gap and remove the iFlex.
Slide the opening pick around the edges of the front glass to separate the adhesive securing it to the frame.
Lift the front glass off the frame and remove it.
Insert an opening pick under the display panel.
Slide the opening pick around the edges of the display panel to separate the adhesive securing it to the frame.
Grip a corner of the display panel and slowly peel it off the frame to separate the remaining adhesive.
Remove the display panel.
the gide is good but i tride to use the iOpener and i didnt work and you also need a heat gut for removing the screen so just dont buy it in adishen i fix it showed add camera hole in the glow sheet.
