Samsung Galaxy S24 Front Camera Replacement
  1. Samsung Galaxy S24 Front Camera Replacement, Prepare your phone for disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S24 Front Camera Replacement, Prepare your phone for disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Let your phone's battery drain below 25% before starting this repair. A charged lithium-ion battery may catch fire if damaged.
    • Completely power off your phone and unplug all cables.
  2. Samsung Galaxy S24 Front Camera Replacement, Heat the right edge: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat an iOpener and apply it to the right edge of the back cover for two minutes.
    • You can use also use a hair dryer or heat gun to heat the right edge of the back glass until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
  3. Samsung Galaxy S24 Front Camera Replacement, Insert an opening pick: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S24 Front Camera Replacement, Insert an opening pick: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S24 Front Camera Replacement, Insert an opening pick: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply a suction handle to the back cover, as close to the center of the right edge as possible.
    • Pull up on the suction handle with strong, steady force to create a gap between the cover and the frame.
    • If you have trouble, apply more heat to further soften the adhesive.
    • Insert an opening pick into the gap.
  4. Samsung Galaxy S24 Front Camera Replacement, Separate the right adhesive: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S24 Front Camera Replacement, Separate the right adhesive: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S24 Front Camera Replacement, Separate the right adhesive: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide your opening pick along the right edge between the back cover and the frame to slice through the adhesive.
    • Leave your opening pick in the bottom right corner to keep the adhesive from resealing.
  5. Samsung Galaxy S24 Front Camera Replacement, Heat the bottom edge: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reheat your iOpener and apply it to the bottom of the back cover for two minutes.
  6. Samsung Galaxy S24 Front Camera Replacement, Separate the corner adhesive: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S24 Front Camera Replacement, Separate the corner adhesive: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the opening pick around the bottom right corner to separate the adhesive.
  7. Samsung Galaxy S24 Front Camera Replacement, Separate the bottom adhesive: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S24 Front Camera Replacement, Separate the bottom adhesive: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a second opening pick to the left of the first one and slide it along the bottom edge to slice through the adhesive.
    • Leave your opening pick in the bottom left edge to prevent the adhesive from resealing.
  8. Samsung Galaxy S24 Front Camera Replacement, Heat the left edge: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reheat your iOpener and apply it to the left side of the back cover for two minutes.
  9. Samsung Galaxy S24 Front Camera Replacement, Separate the corner adhesive: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S24 Front Camera Replacement, Separate the corner adhesive: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the opening pick around the bottom left corner to separate the adhesive.
  10. Samsung Galaxy S24 Front Camera Replacement, Separate the left adhesive: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S24 Front Camera Replacement, Separate the left adhesive: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a third opening pick above the last one and slide it along the left edge to slice through the adhesive.
    • Only insert your pick up to 4 mm deep to avoid damaging the rear cameras or flash.
    • Leave your opening pick in the top left corner to prevent the adhesive from resealing.
  11. Samsung Galaxy S24 Front Camera Replacement, Heat the top edge: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reheat your iOpener and apply it to the top of the back cover for two minutes.
  12. Samsung Galaxy S24 Front Camera Replacement, Separate the corner adhesive: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S24 Front Camera Replacement, Separate the corner adhesive: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the opening pick around the top left corner to separate the adhesive.
  13. Samsung Galaxy S24 Front Camera Replacement, Separate the top adhesive: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S24 Front Camera Replacement, Separate the top adhesive: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S24 Front Camera Replacement, Separate the top adhesive: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a fourth opening pick in the top left corner at the same depth and slide it along the top edge and around the top right corner to slice through the adhesive.
  14. Samsung Galaxy S24 Front Camera Replacement, Separate the flash adhesive: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S24 Front Camera Replacement, Separate the flash adhesive: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert a fifth opening pick directly above the camera flash cutout.
    • Insert the opening pick under the top of the back cover until you feel it start to snag on the flash adhesive.
    • Insert the pick deeper into the phone until you feel the adhesive completely separate from the back cover.
    • Don't insert the pick any deeper than its center point to avoid damaging the rear cameras.
  15. Samsung Galaxy S24 Front Camera Replacement, Remove the back cover: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S24 Front Camera Replacement, Remove the back cover: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pick up the back cover by its edges and remove it from the phone.
    • If your cover is still sticking to the frame, slide the tip of an opening pick around the perimeter until the cover completely separates.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat and isopropyl alcohol (90% or greater) if you're having trouble removing the adhesive.
    • If you're using custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
  16. Samsung Galaxy S24 Front Camera Replacement, Disconnect the wireless charging coil: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S24 Front Camera Replacement, Disconnect the wireless charging coil: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the point of your spudger to pry up and disconnect the wireless charging coil press connector from the motherboard.
    • To re-attach press connectors, align the connector carefully over its socket and press down with your fingertip—first on one side, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
  17. Samsung Galaxy S24 Front Camera Replacement, Remove the wireless charging coil and loudspeaker screws: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S24 Front Camera Replacement, Remove the wireless charging coil and loudspeaker screws: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S24 Front Camera Replacement, Remove the wireless charging coil and loudspeaker screws: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips screwdriver to remove the thirteen 3.5 mm‑long screws securing the wireless charging coil and the loudspeaker:
    • Six screws securing the wireless charging coil
    • Seven screws securing the loudspeaker
  18. Samsung Galaxy S24 Front Camera Replacement, Remove the wireless charging coil and loudspeaker: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S24 Front Camera Replacement, Remove the wireless charging coil and loudspeaker: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the point of a spudger in the notch located on the left edge of the loudspeaker assembly.
    • Pry up the loudspeaker to release its clips.
  19. Samsung Galaxy S24 Front Camera Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S24 Front Camera Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S24 Front Camera Replacement: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingernail or the flat end of a spudger to pry up the wireless charging coil and loudspeaker assembly away from the frame.
    • Remove the wireless charging coil and loudspeaker from your phone.
    • During reassembly, press around the edges of the loudspeaker to clip it to the frame before reinserting the screws.
  20. Samsung Galaxy S24 Front Camera Replacement, Disconnect the battery: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S24 Front Camera Replacement, Disconnect the battery: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the flat end of a spudger under the battery cable press connector (located on the motherboard) and pry up to disconnect it.
  21. Samsung Galaxy S24 Front Camera Replacement, Disconnect the earpiece speaker: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S24 Front Camera Replacement, Disconnect the earpiece speaker: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the tip of a spudger underneath the left side of the earpiece speaker connector and pry up to disconnect it.
  22. Samsung Galaxy S24 Front Camera Replacement, Remove the earpiece speaker screws: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S24 Front Camera Replacement, Remove the earpiece speaker screws: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the five 3.5 mm‑long screws securing the earpiece speaker.
  23. Samsung Galaxy S24 Front Camera Replacement, Remove the earpiece speaker: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S24 Front Camera Replacement, Remove the earpiece speaker: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S24 Front Camera Replacement, Remove the earpiece speaker: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the flat end of a spudger underneath the bottom of the earpiece speaker assembly and pry up to free it from the chassis.
    • Remove the earpiece speaker.
  24. Samsung Galaxy S24 Front Camera Replacement, Disconnect the front camera: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S24 Front Camera Replacement, Disconnect the front camera: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up and disconnect the front camera press connector.
  25. Samsung Galaxy S24 Front Camera Replacement, Heat the front camera: crwdns2935265:025crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The adhesive securing the camera is very strong. Work slowly and apply more heat if the camera feels stuck. Avoid separating the circuit board from camera housing, such as this.
    • Use a hair dryer or a heat gun to heat the front camera for 90 seconds.
  26. Samsung Galaxy S24 Front Camera Replacement, Remove the front camera: crwdns2935265:026crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S24 Front Camera Replacement, Remove the front camera: crwdns2935265:026crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S24 Front Camera Replacement, Remove the front camera: crwdns2935265:026crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Tesa 61395 Tape
    $2.99
    • Use the flat end of a spudger to pry the front camera from its recess in the frame.
    • The adhesive separates easiest with consistent force applied.
    • If the camera doesn't loosen, use the point of your spudger to scrape away the epoxy surrounding the camera.
    • During reassembly, you will need replacement adhesive to secure the replacement part to the frame. If your part does not include new adhesive, use thin, double-sided tape instead.
Compare your new replacement part to the original part—be sure to transfer remaining components and remove adhesive backings from the new part before installing.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Samsung Galaxy S24 Answers Community for troubleshooting help.
Nick Schultz
crwdns2935283:003/24/24crwdne2935283:0
20,279 crwdns2915208:0crwdne2915208:0
crwdns2935297:0115crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,567crwdne2935297:0
crwdns2936753:030crwdne2936753:0 55
crwdns2942667:0crwdne2942667:0 372
