Samsung Galaxy S22 USB-C Port and Charging Board Replacement
  1. Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Remove the SIM card tray: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Remove the SIM card tray: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Remove the SIM card tray: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a SIM eject tool, bit, or straightened paper clip into the SIM card tray hole on the bottom edge of the phone.
    • Press the SIM eject tool into the SIM card tray hole to eject the SIM card tray.
    • Remove the SIM card tray.
    • If you accidentally inserted the SIM eject tool into a microphone hole, don't worry! You most likely didn't damage the microphone.
  2. Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Heat the bottom edge: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Let your phone's battery to drain below 25% before starting this repair. A charged lithium-ion battery may catch fire if damaged.
    • Heat an iOpener and apply it to the bottom edge of the back cover for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are susceptible to heat damage.
  3. Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Adhesive information: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Adhesive information: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • While you wait for the adhesive to soften, note the following:
    • There's adhesive securing the back cover around the perimeter of the frame.
    • The adhesive is strongest in the bottom right and top left corners.
  4. Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Insert an opening pick: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Insert an opening pick: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Insert an opening pick: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply a suction handle to the back cover, as close to the bottom edge as possible.
    • Pull up on the suction handle with strong, steady force to create a gap between the cover and the frame.
    • If you have trouble creating a gap, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Insert an opening pick into the gap.
  5. Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Slice the bottom adhesive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Slice the bottom adhesive: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Slice the bottom adhesive: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the pick back and forth along the bottom edge to slice through the adhesive.
    • Leave the pick inserted in the bottom left corner to prevent the adhesive from resealing.
  6. Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Heat the left edge: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the left edge of the back cover for two minutes.
  7. Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Slice the left adhesive: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Slice the left adhesive: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Slice the left adhesive: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a second opening pick at the bottom left corner.
    • Slide the pick to the bottom of the camera bezel to slice the left adhesive.
    • Only insert the pick up to 5 mm, as you may damage the antenna flex cable or the power button cable.
    • Leave the pick in to prevent the adhesive from resealing.
  8. Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Heat the right edge: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat an iOpener and apply it to the right edge of the back cover for two minutes.
  9. Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Slice the right adhesive: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Slice the right adhesive: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Slice the right adhesive: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a third opening pick at the bottom right corner.
    • If the adhesive has resealed, insert the pick closer to the bottom edge.
    • Slide the pick to the top right corner to slice the adhesive.
    • Leave the pick in the top right corner to prevent the adhesive from resealing.
  10. Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Heat the top edge: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat an iOpener and apply it to the top edge of the back cover for two minutes.
  11. Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Slice the remaining adhesive: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Slice the remaining adhesive: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Slice the remaining adhesive: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an opening pick in the gap at the top right edge.
    • Slide the pick across the top edge and around the top left corner to slice the remaining adhesive.
    • Only insert the pick up to 4 mm, as you may damage the rear cameras or flash.
  12. Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Remove the back cover: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Remove the back cover: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Remove the back cover: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab and remove the back cover.
    • If your cover is still sticking to the frame, slide an opening pick around the perimeter until the cover completely separates.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
    • To apply new adhesive, follow this guide.
  13. Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Disconnect the wireless charging coil: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Disconnect the wireless charging coil: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of a spudger to pry and disconnect the wireless charging coil from the motherboard.
    • To re-attach press connectors, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend and cause permanent damage.
  14. Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Unfasten the wireless charging coil: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Phillips screwdriver to remove the six 3.5 mm-long screws securing the wireless charging coil.
  15. Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Unfasten the loudspeaker: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Phillips screwdriver to remove the seven 3.5 mm screws securing the loudspeaker.
  16. Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Unclip the loudspeaker: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Unclip the loudspeaker: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Unclip the loudspeaker: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the pointed end of your spudger between the upper left corner of the loudspeaker and the frame.
    • Pry up to unclip the loudspeaker from the frame.
    • During reassembly, press around the perimeter of the loudspeaker to engage the clips.
  17. Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Remove the charging coil and loudspeaker assembly: crwdns2935265:017crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Remove the charging coil and loudspeaker assembly: crwdns2935265:017crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Remove the charging coil and loudspeaker assembly: crwdns2935265:017crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab and remove the wireless charging coil and loudspeaker from the frame.
    • Do not separate the charging coil from the loudspeaker.
  18. Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Disconnect the battery: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Disconnect the battery: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of your spudger to pry up and disconnect the battery press connector.
  19. Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Disconnect the interconnect cables: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Disconnect the interconnect cables: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Disconnect the interconnect cables: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the pointed end of your spudger to pry up and disconnect both interconnect cables from the motherboard.
  20. Samsung Galaxy S22 USB-C Port and Charging Board Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 USB-C Port and Charging Board Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 USB-C Port and Charging Board Replacement: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the pointed end of your spudger to pry up and disconnect both interconnect cables from the charging board.
  21. Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Remove the interconnect cables: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Remove the interconnect cables: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Remove the interconnect cables: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab and remove the two interconnect cables from the frame.
    • During reassembly, orient the cables so the "main" ends are toward the top of the phone and the "sub" ends are toward the bottom.
  22. Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Unfasten the charging board: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your Phillips screwdriver to remove the three 3.5 mm-long screws securing the charging board.
  23. Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Pry up the charging board: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Pry up the charging board: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the pointed end of your spudger between the top right of the charging board and the frame.
    • Pry the charging board up from its recess until you can grab it with your fingers.
  24. Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Remove the charging board: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S22 USB-C Port and Charging Board Replacement, Remove the charging board: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grip the charging board by its corners and slide it out of its recess in the frame.
    • Remove the charging board.
    • During reassembly, reinsert the charging board at a downward angle to guide the USB-C port into its recess.
To reassemble your device, follow the instructions in reverse order and perform the opposite actions, e.g., "reattach" instead of "removing."
crwdns2935229:09crwdne2935229:0
Clay Eickemeyer
crwdns2935283:009/19/22crwdne2935283:0
93.379 crwdns2915208:0crwdne2915208:0
crwdns2935297:0460crwdne2935297:0
Guide Team crwdns2935289:0Guide Teamcrwdne2935289:0
Staff
crwdns2931471:010crwdne2931471:0
crwdns2935297:015.534crwdne2935297:0
crwdns2947412:05crwdne2947412:0
Just finished this repair and it was fairly simple when you follow the instructions! A replacement adhesive is included with the kit, so no need to buy that separately.
NickMuir - crwdns2934203:0crwdne2934203:0
Does the wireless charger use the charging board for charging? Or is battery charging managed in the main board?
Wade Smith - crwdns2934203:0crwdne2934203:0
I’m based in the uk so unfortunately you cannot supply the charging board. Can anyone recommend somewhere to purchase. There are plenty on eBay but unsure of quality. Thanks
JohnyB - crwdns2934203:0crwdne2934203:0
Same Problem i am in Austria. Someone Narbe help us¿ ty
philipp juen -
Did you manage to find one you can recommend? I'm uk based too and looking
Heather Tinkler -
crwdns2936751:024crwdne2936751:0 40
crwdns2936753:07crwdne2936753:0 194
crwdns2936753:030crwdne2936753:0 836
crwdns2942667:0crwdne2942667:0 34,216
