Samsung Galaxy S20 Battery Replacement
  1. Samsung Galaxy S20 Battery Replacement, Heat the bottom edge: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug and power off your phone before you begin.
    • Heat an iOpener and apply it to the back cover's bottom edge for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    Found that using the iOpener did not provide enough heat to weaken the adhesive, went with a hairdryer instead. Make sure to never keep the hairdryer still, and apply heat on high for 30 seconds to 1 minute per side did the job for me. iOpener just did not get hot enough
    Phil R - crwdns2934203:0crwdne2934203:0
  2. Samsung Galaxy S20 Battery Replacement, Separate the bottom edge adhesive: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S20 Battery Replacement, Separate the bottom edge adhesive: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S20 Battery Replacement, Separate the bottom edge adhesive: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply a suction cup to the back of the phone, as close to the center of the bottom edge as possible.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Pull on the suction cup with strong, steady force to create a gap between the back cover and the frame.
    • Insert the point of an opening pick into the gap.
    • Due to tight tolerances, this may take multiple attempts of reheating with the iOpener and separating with the suction cup before you get it right.
    • If you are having trouble creating a gap, apply more heat to the edge and try again.
    • Do not apply excessive force with the pick, or you risk cracking the back cover glass.
    I have found it easier to use an iFlex on the camera side to get in enough to get an opening pick in. Then work the pick towards either end slowly and down the ends, making sure it’s warm to the point of being almost to hot to hold. Slow, gentle pressure t open it like a clam ;)
    Stow - crwdns2934203:0crwdne2934203:0
    While pulling on the back glass with the suction cup, I found it helpful to use something like the opener tool to press down on the frame. Made it easy to pull open even with the iOpener.
    Ryan Sammons - crwdns2934203:0crwdne2934203:0
  3. Samsung Galaxy S20 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S20 Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S20 Battery Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the pick back and forth along the bottom edge to slice through the adhesive.
    • Do not attempt to cut the adhesive near the corners of the phone where the glass is curved or you risk cracking the glass panel.
    • Leave your opening pick in the seam to prevent the adhesive from resealing.
  4. Samsung Galaxy S20 Battery Replacement, Heat the left edge: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the left edge of the back cover for two minutes.
  5. Samsung Galaxy S20 Battery Replacement, Separate the left edge adhesive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S20 Battery Replacement, Separate the left edge adhesive: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S20 Battery Replacement, Separate the left edge adhesive: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply a suction cup to the back of the phone, as close to the center of the left edge as possible.
    • As the glass on this edge is curved, you won't be able to insert this pick very far. As long as the very tip of the pick is underneath the glass's edge, you will be able to proceed.
    • Due to tight tolerances, this may take multiple attempts.
    • You can try also applying a few drops of high concentration (over 90%) isopropyl alcohol into the seam to help loosen the adhesive.
  6. Samsung Galaxy S20 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S20 Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the pick is underneath the glass's edge, tilt it downward and insert it further to fully separate the back cover's adhesive.
  7. Samsung Galaxy S20 Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S20 Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S20 Battery Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the pick all along the left edge of the phone to separate the back cover's adhesive.
    • Take care when sliding across the ridge in the frame surrounding the volume and power buttons—the cutout in the glass may make it more prone to cracking.
    • Leave your pick under the left edge of the glass near the top left corner to prevent the adhesive from resealing.
  8. Samsung Galaxy S20 Battery Replacement, Heat the right edge: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the right edge of the back cover for two minutes.
  9. Samsung Galaxy S20 Battery Replacement, Separate the right edge adhesive: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S20 Battery Replacement, Separate the right edge adhesive: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S20 Battery Replacement, Separate the right edge adhesive: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply a suction cup to the back of the phone, as close to the center of the right edge as possible.
    • Like with the previous edge, you will need to tilt the opening pick downward to fully insert it underneath the back cover.
  10. Samsung Galaxy S20 Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S20 Battery Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S20 Battery Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the pick all along the right edge of the phone to separate the back cover's adhesive.
    • Leave your pick under the right edge of the glass near the top of the device to prevent the adhesive from resealing.
    • As you do this, the back cover may release one or both of the other picks and allow them to fall free. If this occurs, set the pick(s) aside as the bottom edge shouldn't reseal from this point onward.
  11. Samsung Galaxy S20 Battery Replacement, Heat the top edge: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a heated iOpener to the top edge of the back cover for two minutes.
  12. Samsung Galaxy S20 Battery Replacement, Separate the top edge adhesive: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S20 Battery Replacement, Separate the top edge adhesive: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S20 Battery Replacement, Separate the top edge adhesive: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The glass near the corners of the back cover is curved and very susceptible to cracking. Be gentle during this step to prevent damaging your back cover.
    • Gradually slide the pick from the right edge of the device around the top right corner.
    • Continue slicing along the top edge all the way to the top left corner to fully separate the back cover adhesive.
    • If the slicing becomes difficult at any point, stop and reapply heat before continuing.
  13. Samsung Galaxy S20 Battery Replacement, Remove the back cover: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S20 Battery Replacement, Remove the back cover: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the back cover slowly. Use opening picks to slice any remaining adhesive.
    • Remove the back cover.
    • During reassembly:
    • This is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Remove any adhesive chunks with a pair of tweezers or your fingers. Apply heat if you're having trouble separating the adhesive.
    • If you're using custom-cut adhesives, follow this guide.
    • If you're using double-sided tape, follow this guide.
  14. Samsung Galaxy S20 Battery Replacement, Unfasten the motherboard bracket: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Magnetic Project Mat
    $19.95
    • Use a Phillips #00 screwdriver to remove the five 4 mm-long screws securing the motherboard bracket.
  15. Samsung Galaxy S20 Battery Replacement, Unclip the motherboard bracket: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S20 Battery Replacement, Unclip the motherboard bracket: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to gently pull up and unclip the motherboard bracket from the plastic midframe.
    • Do not completely remove the bracket yet, as its still attached to the wireless charging coil.
  16. Samsung Galaxy S20 Battery Replacement, Remove the wireless charging coil: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S20 Battery Replacement, Remove the wireless charging coil: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S20 Battery Replacement, Remove the wireless charging coil: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently peel the wireless charging coil away from the device.
    • Remove the wireless charging coil.
    • The coil is connected to the rest of the device via spring contacts, so there is no need to disconnect any connectors.
    • During reassembly, refasten the motherboard bracket screws first to properly align the charging coil into place, then firmly press the rest of the coil down to adhere it.
  17. Samsung Galaxy S20 Battery Replacement, Disconnect the battery: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S20 Battery Replacement, Disconnect the battery: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up and disconnect the battery connector.
    • When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
  18. Samsung Galaxy S20 Battery Replacement, Unfasten the lower midframe: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the five 4 mm-long screws securing the loudspeaker and lower midframe.
  19. Samsung Galaxy S20 Battery Replacement, Remove the loudspeaker: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S20 Battery Replacement, Remove the loudspeaker: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S20 Battery Replacement, Remove the loudspeaker: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the point of a spudger or a pair of tweezers into the notch in the top left corner of the midframe and pry up to release the clips holding it in place.
    • Remove the loudspeaker and lower midframe.
  20. Samsung Galaxy S20 Battery Replacement, Disconnect the daughterboard: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S20 Battery Replacement, Disconnect the daughterboard: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S20 Battery Replacement, Disconnect the daughterboard: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry up and disconnect the main and auxiliary flex cables from the daughterboard near the bottom of the device.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  21. Samsung Galaxy S20 Battery Replacement, Disconnect the main flex cables: crwdns2935265:021crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S20 Battery Replacement, Disconnect the main flex cables: crwdns2935265:021crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S20 Battery Replacement, Disconnect the main flex cables: crwdns2935265:021crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry up and disconnect the main and auxiliary flex cables from the motherboard.
  22. Samsung Galaxy S20 Battery Replacement, Remove the main flex cables: crwdns2935265:022crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S20 Battery Replacement, Remove the main flex cables: crwdns2935265:022crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy S20 Battery Replacement, Remove the main flex cables: crwdns2935265:022crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently peel up and remove the main and auxiliary flex cables.
  23. Samsung Galaxy S20 Battery Replacement, Disconnect the main display cable: crwdns2935265:023crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S20 Battery Replacement, Disconnect the main display cable: crwdns2935265:023crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry up and disconnect the main display flex cable from the motherboard.
  24. Samsung Galaxy S20 Battery Replacement, Reposition the display cable: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S20 Battery Replacement, Reposition the display cable: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently peel up and bend the display flex cable out of the way of the motherboard and battery.
  25. Samsung Galaxy S20 Battery Replacement, Apply isopropyl alcohol: crwdns2935265:025crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply 1-2 drops of high concentration (over 90%) isopropyl alcohol to the top edge of the battery.
    • Using too much alcohol can damage the display.
    • Wait one minute to allow the isopropyl alcohol to soften the adhesive.
  26. Samsung Galaxy S20 Battery Replacement, Lift the battery from its adhesive: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S20 Battery Replacement, Lift the battery from its adhesive: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Apply a suction handle to the center of the battery.
    • Brace the top and bottom of the device against your work surface with one hand and firmly pull up on the suction handle with the other.
    • The adhesive takes time and repeated pulls rather than strong force to loosen. Pull on the suction cup with steady force for 15 seconds at a time.
    • If the battery doesn't loosen, apply 1-2 drops of isopropyl alcohol along the top, left, and right edges, wait a minute, and pull again.
    • When the battery begins to lift from the device, proceed to the next step.
  27. Samsung Galaxy S20 Battery Replacement, Pry up the battery: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Samsung Galaxy S20 Battery Replacement, Pry up the battery: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Do not proceed with this step until the battery is lifted enough to easily insert an opening pick underneath the battery. If the battery is still firmly glued into place, you risk piercing the battery with your pick and causing a dangerous thermal event.
    • Once the battery lifts, don't apply isopropyl alcohol, or it may seep into the fingerprint sensor and damage your screen.
    • Insert an opening pick underneath the bottom edge of the battery and twist to loosen the battery adhesive.
  28. Samsung Galaxy S20 Battery Replacement, Remove the battery: crwdns2935265:028crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery.
    • Peel up and/or scrape away any remaining battery adhesive before cleaning the battery well surface with isopropyl alcohol and a lint free cloth.
    • If you used isopropyl alcohol, wait ten minutes before installing the new battery to allow the alcohol to completely evaporate.
    • During reassembly, if your new battery doesn't come with pre-applied adhesive, apply some to the well. Then, firmly press the new battery into place.
    • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard. Replace it with a new battery.
    What is the piece behind the battery that looks like its circled called? Is it normal to see this piece when shining a flashlight onto the screen when the phone is off?
    Jessica Nash - crwdns2934203:0crwdne2934203:0
    That’s the fingerprint sensor! Because it’s embedded in the screen, if you shine a light behind it, you can see it through the front glass.
    Carsten Frauenheim -
Follow this guide to perform a battery cycle reset, and calibrate your newly-installed battery.
Repair didn’t go as planned? Check out our Answers community or S20 battery troubleshooting wiki for help.
crwdns2935229:032crwdne2935229:0
Tarun Thiruma
crwdns2935283:011/20/19crwdne2935283:0
38,356 crwdns2915208:0crwdne2915208:0
crwdns2935297:0134crwdne2935297:0
crwdns2947412:027crwdne2947412:0
The guide is good, but I really don't like the "do the steps backward to reassamble" approach, that's annoying especially for people wanting to do their first repair.
allanxp4 - crwdns2934203:0crwdne2934203:0
I cannot agree more!
Karim -
I had a huge amount of difficulty removing the battery during this repair. The adhesive is really strong, the suction cup doesn't stick to the battery very well and if you lever it out you run the risk of puncturing the battery. It's also really difficult to pull up on the battery while holding the phone down, especially because you want to avoid touching the circuits.
Eventually I succeeded and everything seemed to work but the next day the phone wouldn't switch on. I think maybe the adhesive remover got somewhere it shouldn't have. If I could add something to this guide, it would be "once battery is removed, allow phone to sit for 30 mins to ensure all adhesive remover has evaporated". If I was allowed a do-over I would try to heat the adhesive instead. Or use the string trick. I'm switching to an iphone now because apparently they don't glue their batteries.
HarleyD - crwdns2934203:0crwdne2934203:0
Good point! I would suggest to use pure isopropyl alcohol and not something below 99%. The residual water might be not much but still there is a slight chance of it getting somewhere inside. Also the 99% pure alcohol evaporates much faster and leaves no traces. Apple batteries are also glued in with adhesive. What apple does right are the pull-strings to remove the sticky tape between chassis and battery.
Harry Gee -
Followed every step and managed to complete it but after a couple of minutes the phone screen stopped working and turned black.
I'm pretty sure that happened because the isopropyl alcohol went through the phone into the screen through the gap right under where the battery seats.
If you attempt this at home be aware this might happen, so disconnect the display too or look into using a different method for removing the battery.
Matteo Xhixha - crwdns2934203:0crwdne2934203:0
I don't think this repair is worth attempting. I also killed my screen with this one, similar to the two commenters above. Whether it was isopropyl alcohol getting into the LCD or whether it was some issue with flimsy connectors I don't know. I was super careful and I've still bricked it, so I'd rate this repair as 'too risky'.
Paddy Owens - crwdns2934203:0crwdne2934203:0
i typically use an iPlastix opening tool, a heating pad and lots of alcohol, get the very tip of the opening tool to sort of bend or roll into a curve, then slip the bent tip into the gap between frame and battery dripping some alcohol onto the tool, eventually you can get the rolled end to slip underneath the battery. then just slide the tool around the perimeter of the battery, cutting the adhesive, eventually, once all the adhesive is cut the battery will easily pry out of the phone. continually apply alcohol to the surface of the tool once you get the curved end under the battery, the alcohol will drip down the tool and find its way under the battery more easily weaking the adhesive.
since the tool is made of plastic, its almost impossible to scratch, bend or puncture the battery during the removal process by using this method, this is also my preferred method for removing bulged batteries that a suction cup wont stick to, or batteries where putting any unnecessary pressure could cause them to burst.
Alex Frideres - crwdns2934203:0crwdne2934203:0
As with other comments, battery swap went fine, but after a bit of use I connected the phone to a charger and screen went black. Strange experience, feels like it's booby trapped.
Cameron Elvey - crwdns2934203:0crwdne2934203:0
I used this repair guide to change my battery in my S20. All went well and successfully especially after using this guide. IPA helped massively to remove the battery but I DO NOT RECOMMEND USING IT. i read the comments about the screen going blank etc. i used a heat gun to evaporate the IPA before reassembling the device thinking this would eliminate any issues. I WAS WRONG. DO NOT USE IPA to remove the battery. I turned my phone back on ant it was okay for a few minutes. Then the screen started flickering and turned completely green then went black. The phone still works as i can hear the notification sounds etc but no screen. Again DO NOT USE IPA TO REMOVE BATTERY
shaun young - crwdns2934203:0crwdne2934203:0
When the alcohol gets into the screen, the screen becomes black, it dies. Do not try this guide.
Ábrahám Szilárd - crwdns2934203:0crwdne2934203:0
Did this repair to a T, it killed my display about 30 mins later. DONT USE IPA
I even used my heat gun to evaporate all of it off, let the phone sit for an hour too. still killed it!
Bradley - crwdns2934203:0crwdne2934203:0
Hi Bradley,
I'm really sorry to hear of your repair experience. I think the IPA may have seeped through the fingerprint sensor cutout and into the OLED panel.
When the battery adhesive is still intact, it should seal against moderate use of IPA along the top and side edges. I looked over the guide and changed the wording to give clearer guidance and warnings on how much to apply, where to apply it, and when not to use IPA.
Arthur Shi -
Is there any procedure needed to reset the battery stats or charging levels? I replaced without problem but my battery life is not as good as my old battery! Wondering if there is a step on the software side?
Chuck Tatham - crwdns2934203:0crwdne2934203:0
Did you figure it out? I have the same issue. Looks like an original battery, but batt life is weak and Samsung Members diagnostics shows battery needs replacement...
Slawek -
The screws are more likely to be #0 JIS rather than #00 Phillips. Certainly my JIS screwdriver fits much better than my Phillips one.
I haven't had a problem with IPA use yet, but the battery adhesive is stupidly strong. Just use a mechanical clip, Samsung. My Blackberry is: slide back off, lift up battery, insert new battery, slide on back cover. Probably five seconds. Things weren't so bad in the 2010s.
The Samsung battery reset app doesn't recognise the QR code on the packaging so far.
Rafaela Lugubrio - crwdns2934203:0crwdne2934203:0
Did you do anything to software after battery swap?
I am having weak battery life after replacement and I wonder if I should change something in software to let Samsung know there is a new battery inside...
AccuBattery shows ~3300 capacity only ;/
Slawek - crwdns2934203:0crwdne2934203:0
As well i killed my screen, i turned up and and worked a few minutes, later I left it charging, and when I came back the screen was completely black, I plug it to my monitor, and the phone is still working but no the screen. Anyway his method did not help me to remove the battery
Luis Enrique Martinez Rojas - crwdns2934203:0crwdne2934203:0
After all these comments concerning a screen-blackout after using alcohol I didn't dare to use that. Just pulled with the suction handle and pried with different tools from the bottom. That took a lot of time, sweat, fear to break the battery and quite some force. Why do manufacturers glue in the batteries?!
Worked out fine and I'm happy with the new battery.
Rolloblonsko - crwdns2934203:0crwdne2934203:0
why does it needs to be below 25%? I understand it being at maximum 60%, but for what I learned Li-ion batteries are unstable at 0% too. Maybe it needs to be better specified?
Guilherme Diogo da Rosa - crwdns2934203:0crwdne2934203:0
Toller Guide!
War mein erster Akkutausch.
Statt dem Alkohol hab ich aber den Akku bzw Kleber mit einem Föhn über die Displayseite erwärmt. Hat wunderbar funktioniert.
Klebereste hab ich dann mit 2 Tropfen Desinfektionsgel und nem Wattestäbchen gelöst. Rückbau hat auch ohne Probleme funktioniert.
Isabell Querfeld - crwdns2934203:0crwdne2934203:0
I completed the swap without affecting the screen. To avoid killing the screen as others have done, I used 2 tiny drops of acetone from a needle behind the battery then applied constant even pressure to the battery over a long period of time. If you do not have a way of getting the solvent accurately only onto the glue, use the constant pull method alone. Be careful about putting tools behind the battery as there is an area behind the battery with a soft membrane.
Brandon Blizard - crwdns2934203:0crwdne2934203:0
I completed the swap without obvious issue. However if I unplug the phone from a charger it immediately turns off as if there is no battery at all. I re-opened the phone and disconnected and reconnected all the upper and lower flex cable connectors carefully. This did not resolve the issue. The battery shows 4000 mAh at 100% or 99% charge when connected to USB and powered on. I don't know if there is something I am missing of if I possibly revived a bad replacement battery.
Thanks for this informative instruction manual. What I would like to ask is, where can I find a genuine S20 battery?
Conrad Chikwanda - crwdns2934203:0crwdne2934203:0
It is advised to run down the battery before starting to prevent damage, but this makes it impossible to test the phone before replacing the back cover.
Joan - crwdns2934203:0crwdne2934203:0
Some kids come with glue strips to secure the battery AND a tube of glue. Is the tube meant to run a seal around the outside of the case before replacing the back cover?
Does this tutorial works for Samsung Galaxy S20 FE ?
Thank you for the guide, it's very clear !
Camille Bousquié - crwdns2934203:0crwdne2934203:0
Yes, most steps are similar. I first followed the S20FE Charging Board Replacement Guide, because I also had to renew that.
You could follow that up to step 18, then resume this guide from step 20. There are fewer flex cables, but otherwise the process is the same.
Markus29 -
crwdns2936751:024crwdne2936751:0 114
crwdns2936753:07crwdne2936753:0 727
crwdns2936753:030crwdne2936753:0 3,404
crwdns2942667:0crwdne2942667:0 189,531
