Samsung Galaxy Note10 Battery Replacement
crwdns2942287:0crwdne2942287:0Use this guide to remove or replace the battery on your Samsung Galaxy Note10. If your battery is swollen, take appropriate precautions.
For your safety, discharge your battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
crwdns2942269:0crwdne2942269:0
crwdns2942337:0crwdne2942337:0
crwdns2944105:0crwdne2944105:0
Prepare an iOpener and apply it to the left edge of the back panel for one minute.
Apply a suction cup to the heated edge of the back panel, as close to the edge as possible.
Pull up on the suction cup with strong, steady force to create a gap between the back panel and the frame.
Insert the point of an opening pick into the gap.
Slide the opening pick along the left edge towards the bottom left corner to slice the adhesive.
Leave the pick inserted in the bottom left corner to prevent the adhesive from re-sealing.
Insert a second opening pick and slide it across the left side towards the top left corner to slice the adhesive.
Leave the pick inserted in the top left corner to prevent the adhesive from re-sealing.
Prepare an iOpener and apply it to the top edge of the phone for one minute.
Insert a third opening pick into the gap on the top edge of the phone.
Slide the opening pick to the top right corner, slicing the adhesive.
Leave the pick inserted in the top right corner to prevent the adhesive from re-sealing.
I cracked this top right corner because the camera cutout causes it to be more prone to cracking. Make sure to use heat in that corner, and spray some >90% isopropyl alcohol in there to loosen up the adhesive. I would do this corner last.
Prepare an iOpener and apply it to the right edge of the phone for one minute.
Insert a fourth and final opening pick into the gap on the right side of the phone, sliding it down towards the bottom right corner of the phone to slice the adhesive.
Slide an opening pick back and forth around the entire perimeter of the phone to release any missed adhesive, reheating if you find any extra-stubborn adhesive.
Lift up and remove the back panel.
Use a Phillips screwdriver to remove the five 4 mm screws securing the wireless charging coil.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use a pair of tweezers to lift up and flip back the metal shield covering the battery connector.
While holding the metal shield up and out of the way, use the pointed end of a spudger to pry up the battery connector to disconnect it.
Use the pointed end of a spudger to disconnect the wireless charging coil connector from the motherboard.
Tilt the metal shielding up so you can grip it with your fingers.
Peel the wireless charging coil up and away from the device.
Remove the wireless charging coil.
is it possible to replace with brand new wireless charging coil
How do you remove the metal plate to attach it to the new flex coil
Why do you want to do so?
Use a Phillips screwdriver to remove the five 4 mm screws securing the loudspeaker.
Actually, you don’t need to remove the loud speaker as long as you can do with 3 daughter board cables hanging off and distract a little bit, there is no effect with it bcoz the cable is flexible
Use a pair of tweezers to remove the loudspeaker.
Use the pointed end of a spudger to disconnect the main interconnect cable from the motherboard.
Disconnect the secondary interconnect cable from the motherboard.
Use the pointed end of a spudger to disconnect the main interconnect cable from the daughterboard.
Disconnect the secondary interconnect cable from the daughterboard.
Use the pointed end of a spudger to disconnect the display cable connector from the motherboard.
Apply 1-2 drops of high concentration (90% or greater) isopropyl alcohol underneath the battery at the tear-shaped indents near the corners of the battery well.
Wait about two minutes for the isopropyl alcohol to penetrate and weaken the battery adhesive before you proceed to the next step.
Apply a suction cup to the back of the battery.
Pull up on the suction cup with strong, steady force to begin to separate the battery from the frame.
Insert the point of an opening pick into the gap created between the battery and frame.
Pull up on the suction cup to remove the battery.
If you used isopropyl alcohol, wait ten minutes before installing the new battery to allow the alcohol to completely evaporate.
Hallo zusammen,
ich habe mein Handy nach dieser Anleitung auseinander genommen, jedoch ist der Alkohol wohl in dieses Dreieck unter den Akku und bei dem Fingerabdrucksensor rein geflossen. Ich habe mich gefragt, wofür dieses Dreieck gut ist. Könnt ihr es mir sagen? Und habt ihr eine Vorschlag, wie ich es besten wieder trocken bekomme?
Vielen Dank
Hello,
I took my phone apart following these instructions, however, I guess the alcohol got into this triangle under the battery and by the fingerprint sensor. I was wondering what this triangle is for. Can you tell me? And do you have any suggestion on how best to get it dry again?
Thanks a lot
For optimal performance, calibrate your newly installed battery after completing this guide.
crwdns2935229:018crwdne2935229:0
crwdns2947412:07crwdne2947412:0
Is N10+ (4g) identical in battery and steps to change?
Here is the Galaxy Note 10+ battery replacement guide!
I just wanted to add that after swapping in the new battery, apparently the only way to reset the battery cycle count is by rooting the phone. There doesn't seem to be any way to get the phone to recognize the new battery as new, otherwise.
Are you sure about that? I mean, can't just we use the classic calibration with Samsung ?
Federico -
Good instructions. Per iFixit, I am supposed to do "Battery Calibration" which consists of charging and keeping on charger for +2 hours, then using it until it dies, then recharging to 100%. Simple.
Apparently, I messed up the fingerprint sensor because it wouldn't work, but the phone was working great. Chaulk that up to learning experience. Was looking for a reason to upgrade anyway.
I set it up to play YouTube shorts, which loop until the phone dies. The phone dies while I'm asleep. I wake up. I plug it in. NOTHING. I flip the charger. NOTHING. I try a different charger. NOTHING. GREAT.
I swap back to my old battery in hopes I got a bad NEW battery. Get that all swapped and still nothing, but SOMETHING. It vibes when I plug it in but the screen is totally black. Try soft reset. Try reversing through all the steps to see if I forgot a cable or had one unseated. No problems at all.
Something happened to the SCREEN when the BATTERY DIED during recalibration. PROCEED WITH CAUTION
I had the same exact issue as well, phone vibrates so I know its alive but screen just does not work anymore at all, the screen worked at first when i first put the battery in but after it died after the first 100% charge that was it.
HELP. I replaced the battery and charging connector and immediately ran a charging test to see if the connector was working and also the battery. The phone was charging, I then proceed to unplug it and close it completely.
The next day I turn it on, put it on charge but this does not charge. As soon as I put the cable in, the brightness of the screen increased, it recognized that it was connected but the battery icon just blinked. Same thing with wireless charging. Once discharged, I tried charging it again, the phone responds but then the yellow triangle with the thermometer appears on the black screen.
Thinking it was the new battery, I reopen it and put the old one in, same
result.
I proceed to disassemble everything again and then carefully assemble it, do a test without putting the shell back in and it works normally.
Not even time to reattach the shell with double-sided tape and slight heat on the heat pad, I plug it in and the yellow triangle with the thermometer reappears.
What could be the problem?
