Samsung Galaxy A3 2015 Battery Replacement
  1. Samsung Galaxy A3 2015 Battery Replacement, Display: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A3 2015 Battery Replacement, Display: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A3 2015 Battery Replacement, Display: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Switch off your phone.
    • If your screen is cracked you want to cover the front panel with tape to protect yourself from glass shards and get a better grip to lift it.
    • Use an iOpener to soften the glue on the edge of the display. Concentrate on the sides first and then on the bottom part.
    • With an iSclack or a suction handle you can lift the display a little bit to get in the gap with an opening pick.
    • In the beginning just insert the very tip of the opening pick and slide along the side to loosen the glue. Leave the top and bottom alone for now.
  2. Samsung Galaxy A3 2015 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A3 2015 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A3 2015 Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • When the glue ist loosened enough on the side you can lift the display a little bit more to get underneath the display with an opening pick.
    • Take a second opening pick and work your way just around the bottom edge.
    • Be careful where the two touch buttons at the bottom are (see next step for orientation). Take your time and be patient.
    • Repeat the last step and this one on the other side.
    The connectors for the 2 touch buttons are very close to the bottom edge and easily ripped or cut. I suggest omitting that area or keep your pick very flat (parallel to your table) at the bottom edge.
    Tosnic - crwdns2934203:0crwdne2934203:0
  3. Samsung Galaxy A3 2015 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A3 2015 Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A3 2015 Battery Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Grab the iOpener once again to heat up the bottom and top part to further soften the glue.
    • Now you will be able to move the picks at the bottom closer to the home button and eventually open the display towards the top.
    • Don't open the display all the way. It is still connected to the motherboard. Also the gold foil behind the display might come off and remain glued to the midframe. You can re-attach it later.
    • If your display is still working take care to not rip the front panel off of the display. You also want to leave the top part alone to not risk cutting any flex cables.
  4. Samsung Galaxy A3 2015 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A3 2015 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A3 2015 Battery Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • In the top right corner you can find the connector of the display. Use a spudger to disconnect it.
    • Now you can remove the display.
  5. Samsung Galaxy A3 2015 Battery Replacement, Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A3 2015 Battery Replacement, Battery: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A3 2015 Battery Replacement, Battery: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the ten Phillips #00 screws.
    • Lift up the two touch sensors in the lower area of the frame with a spudger. You can skip this step if you are careful while removing the mid frame from the back cover later.
  6. Samsung Galaxy A3 2015 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A3 2015 Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A3 2015 Battery Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the SD card tray and the SIM card tray.
    • Use a Jimmy to lift up the mid frame on the left side of the phone where the battery is placed.
    • Be careful not to puncture the battery underneath.
    • Remove the mid frame with all its components from the back cover.
  7. Samsung Galaxy A3 2015 Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A3 2015 Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Samsung Galaxy A3 2015 Battery Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug the battery connector with a spudger.
    • Use a spudger or an opening pick to get between the midframe and the battery to separate it from the glue.
    • The frame around the battery is very fragile and easy to break. If the adhesive behind the battery is too strong, you need to use an iOpener to soften it.
    • Remove the battery from the frame.
To reassemble your device, follow these instructions in reverse order. Reapply adhesive where necessary.
crwdns2935229:046crwdne2935229:0
Dominik Schnabelrauch
crwdns2935283:011/23/16crwdne2935283:0
235,481 crwdns2915208:0crwdne2915208:0
crwdns2935297:0682crwdne2935297:0
iFixit EU Team crwdns2935289:0iFixit EU Teamcrwdne2935289:0
Staff
crwdns2931471:038crwdne2931471:0
crwdns2935297:01,164crwdne2935297:0
crwdns2947412:011crwdne2947412:0
Ich habe die Metallfolie abgemacht und jetzt geht das Handy gar nicht mehr an! Ist das normal oder müsste es zumindest einmal vibrieren, selbst wenn kein LCD angeschlossen ist? Habe noch sehr wichtige Daten auf dem Handy ….
Tim GUndert - crwdns2934203:0crwdne2934203:0
Why does it not mention that the screen is glued to the frame (not just around the edges)? I have now found the ifixit guide for replacing the screen that says “NOTE: The LCD is also glued to the frame and will most likely break when removing the display“. Seems a pretty important bit of information to leave out of this article when the screen needs to be removed in one piece, and one that’s just cost me a screen. Not happy.
Alex - crwdns2934203:0crwdne2934203:0
Actually, he does say it. Esta guía incluye cómo quitar la pantalla y el marco intermedio. Necesitarás adhesivo de reemplazo para volver a pegar la pantalla. —>>>> La pantalla LCD también está pegada al marco y podría romperse al abrir el teléfono. <<<<—
Laura Virginia Gómez Ramos -
Do you really have to take the screen off just to replace the back cover
m.brown350 - crwdns2934203:0crwdne2934203:0
There is no real back cover, rather a complete casing. Unfortunately the display is the only way in.
Tobias Isakeit -
Yes, I agree with Alex, I have just cut through the glue that is around the frame and then tried to pry the screen up but was never aware that the screen is glued to the entire phone underneath. Caused the screen to crack and doesn’t work anymore. It should be clear that the screen is completely glued down.
Tom - crwdns2934203:0crwdne2934203:0
Même remarque que Tom et Alex, l’écran est TOTALEMENT collé au chassis ce qui rend l’opération de dépose vraiment délicate car il faut chauffer fortement l’écran pour le retirer, chose que je n’ai pu faire sans le briser.
Donc à vouloir changer la batterie, je dois maintenant changer l’écran.
Il faut bien dire que la dépose de l’écran est une opération très risquée pour l’écran lui-même et délicate car le risque de casse est élevé.
Je ne vous remercie pas car je suis bon pour acheter un nouvel écran…
John Locke - crwdns2934203:0crwdne2934203:0
Nous sommes désolés d’apprendre cela et avons adapté le texte en espérant qu’il reflète mieux le risque maintenant.
Sandra Hiller -
La réparation a bien fonctionné pour moi . Malheureusement la batterie achetée en même temps que le kit n'a tenu que 6 MOIS !!!!!
Je suis contente davoir réussit la manip mais extrêmement déçue de la qualité de la batterie.
le drezen - crwdns2934203:0crwdne2934203:0
Bonjour @kldre !
Désolée d’apprendre que vous rencontrez un problème. Je vous conseille de prendre contact directement avec le fournisseur de la batterie. Si vous l’avez achetée chez iFixit, veuillez écrire au support@ifixit.com (pour la boutique américaine) ou au eustore@ifixit.com (pour la boutique européenne et française).
Ce sera un plaisir de vous aider !
Claire Miesch -
crwdns2936753:07crwdne2936753:0 25
crwdns2936753:030crwdne2936753:0 112
crwdns2942667:0crwdne2942667:0 60,478
