Razer Kishi Phone Connector Replacement
  1. Razer Kishi Phone Connector Replacement, Remove the screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The opening process is the same on both sides. For simplicity, this guide shows only the right-side opening process. Unscrew whichever side you wish to open and work on.
    • For the right side, remove the five Y0 screws securing the right side of the controller.
    • Four 9.2 mm screws
    • One 7.2 mm screw
    • If you wish to open the left side, remove the five Y0 screws securing the left side of the controller.
    • One 7.2 mm screw
  2. Razer Kishi Phone Connector Replacement, Release the bottom edge clips: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Razer Kishi Phone Connector Replacement, Release the bottom edge clips: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Razer Kishi Phone Connector Replacement, Release the bottom edge clips: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Both cases are held together by plastic clips.
    • Insert an opening pick in the seam between the top and bottom case, at the bottom left corner of the controller.
    • With the pick still in the seam, slide it along the bottom edge to the bottom right corner to loosen the plastic clips.
  3. Razer Kishi Phone Connector Replacement, Release the side edge clips: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Kishi Phone Connector Replacement, Release the side edge clips: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the opening pick along the right edge to loosen the plastic clips.
  4. Razer Kishi Phone Connector Replacement, Release the top edge clips: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Kishi Phone Connector Replacement, Release the top edge clips: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the opening pick along the top edge to loosen the remaining plastic clips.
    • Don't try to remove the top side yet, the case is still connected to the board.
  5. Razer Kishi Phone Connector Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Razer Kishi Phone Connector Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Razer Kishi Phone Connector Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully lift the top side and unfold it to the right, like a book.
  6. Razer Kishi Phone Connector Replacement, Disconnect the interconnect cable: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Razer Kishi Phone Connector Replacement, Disconnect the interconnect cable: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Razer Kishi Phone Connector Replacement, Disconnect the interconnect cable: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the pointed end of a spudger, push the grey tabs on the interconnect socket away from the socket, parallel to the interconnect cable, to release the cable.
    • Pull the cable out of the socket.
  7. Razer Kishi Phone Connector Replacement, Remove the screws: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the two 4.4 mm-long screws securing the trigger board.
    Phillips #00 on mine.
    Model no. RZ06-0290
    also listed: GV190
    Stephen Marshall - crwdns2934203:0crwdne2934203:0
    This step is not essential and risks misaligning the rotary knobs from their tracks as well as losing or contaminating the lubricant. You can leave the breakout board attached to the trigger and remove them together. When the trigger screws are out, lift the whole assembly together, being very careful to lift it straight out to avoid bending the jumper pins.
  8. Razer Kishi Phone Connector Replacement, Remove the breakout board: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Razer Kishi Phone Connector Replacement, Remove the breakout board: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Razer Kishi Phone Connector Replacement, Remove the breakout board: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The breakout board is plugged in. When removing breakout board, it is important to pull it straight out to avoid bending the connectors.
    • Remove the breakout board by lifting it straight up, away from the controller.
    When reassembling this piece, ensure that the breakout board's rotating peg is aligned with the neutral position of the joystick. To do this on the left trigger:
    1. Flip the breakout board over so that the rotating peg is facing you and position it such that the 3 jumper pins are in the top right (and the text is right-side-up.
    2. Carefully rotate the peg until it faces North-East, at just about a 45 degree angle from the horizontal. Move it in whatever direction requires the shortest travel to arrive at this point. Be wary of the lubricant which coats this part and try not to remove much.
    On the right trigger, this process is the same but mirrored. Align with pins in top left and point peg to the North-West at 45 degrees.
    Do you sell R2 button, mine is broken. If so kindly WhatsApp my number 0717709004
    IAN KELLY OTIENO - crwdns2934203:0crwdne2934203:0
  9. Razer Kishi Phone Connector Replacement, Remove the screws: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the two 7.0 mm-long screws securing the trigger.
    These screws have a very shallow angle for the inner Phillips drive, making them feel very easy to strip. For these, a Phillips #1 actually provided the most positive fit. Test a few tips just to be sure.
  10. Razer Kishi Phone Connector Replacement, Remove the trigger: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Kishi Phone Connector Replacement, Remove the trigger: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the shoulder trigger.
  11. Razer Kishi Phone Connector Replacement, Lift the shoulder button board: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Kishi Phone Connector Replacement, Lift the shoulder button board: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of blunt nose tweezers to lift out the shoulder button board.
    This step is difficult as the board is in very tightly, but it can be skipped. The cord allows enough flexibility to just remove the board in the next step to get to the screws for the phone bracket and the USB connector.
    JM Palacios - crwdns2934203:0crwdne2934203:0
  12. Razer Kishi Phone Connector Replacement, Remove the screws: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the two 5.9 mm-long screws.
  13. Razer Kishi Phone Connector Replacement, Remove the board: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Kishi Phone Connector Replacement, Remove the board: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the mainboard straight out of the frame to remove it.
  14. Razer Kishi Phone Connector Replacement, Unfasten screws: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the four 5.7 mm screws securing the phone bracket.
  15. Razer Kishi Phone Connector Replacement, Remove the phone bracket: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Kishi Phone Connector Replacement, Remove the phone bracket: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the phone bracket.
  16. Razer Kishi Phone Connector Replacement, Remove the rubber phone pad: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Razer Kishi Phone Connector Replacement, Remove the rubber phone pad: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to lift the rubber phone pad out sideways.
  17. Razer Kishi Phone Connector Replacement, Unfasten the screws: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the two 4.6 mm screws securing the phone connector.
  18. Razer Kishi Phone Connector Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Razer Kishi Phone Connector Replacement: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Razer Kishi Phone Connector Replacement: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Thread the phone connector through its opening in the side of the controller.
    • Remove the phone connector.
Adriana Zwink
crwdns2935283:012/18/19crwdne2935283:0
58.134 crwdns2915208:0crwdne2915208:0
crwdns2935297:0167crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021.011crwdne2935297:0
Where can I find this c type connector?
eric nelson - crwdns2934203:0crwdne2934203:0
Is it exactly the same on the kishi v2 or is it different? If yes how? And where can i buy that usb c port thats made for the controller to output the inputs?
HypeShadow Duck - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 62
crwdns2942667:0crwdne2942667:0 4,008
