Use this guide to remove or replace the screen on your Xiaomi Poco X3 Pro.
If the frame is deformed, it's important to replace it to make sure the new screen will mount correctly and won’t suffer damage from uneven pressure.
Due to the device’s design, you must remove the lithium-ion battery to access the display cables. If the battery was deformed during removal replace it with a new one—reusing a deformed battery is a potential safety hazard.
Before disassembling your device, discharge the battery below 25%. The battery can catch fire and/or explode if accidentally punctured, but the chances of that happening are much lower if discharged.
Note: This guide instructs you to replace only the screen while leaving the original frame and motherboard in place. However, some replacement screens for this phone come pre-installed in a new frame (a.k.a. chassis), which requires a very different procedure. Make sure you have the correct part before starting this guide.
You’ll need replacement adhesive to reattach components when reassembling the device.
Prepare an iOpener and apply it to the back cover for at least two minutes to loosen the adhesive underneath.
Secure a suction handle to the bottom edge of the back cover, as close to the edge as possible.
Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
Insert an opening pick into the gap you created.
Slide the opening pick to the bottom right corner to slice the adhesive.
Leave the opening pick in place to prevent the adhesive from resealing.
Insert a second opening pick at the bottom edge of your phone.
Slide the opening pick to the bottom left corner to slice the adhesive.
Insert a third opening pick at the bottom left corner of your phone.
Slide the opening pick along the left edge of your phone to slice the adhesive.
Leave the opening pick in the top left corner to prevent the adhesive from resealing.
The position of the fingerprint scanner flex cable is slightly underneath the power button, very close to the edge of the phone, be careful not to slice or otherwise damage it while removing the adhesive. The good news is that if you do slice it, your power button will still function, and it is relatively easy to replace.
Insert a fourth opening pick underneath the top left corner of your phone.
Slide the opening pick along the top edge to slice the adhesive.
Leave the opening pick in the top right corner to prevent the adhesive from resealing.
Insert a fifth opening pick underneath the top right corner.
Slide the opening pick along the right edge of the back cover to slice the remaining adhesive.
Remove the back cover.
Use a Phillips screwdriver of the correct size to remove the eleven 3.9 mm-long screws securing the motherboard cover.
Insert the tip of an opening pick underneath the bottom right edge of the motherboard cover.
Slide the opening pick along the right edge of the motherboard cover to unhinge the plastic clips and pry it up.
Insert the opening pick underneath the top edge of the motherboard cover and pry it up.
Remove the motherboard cover.
Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use a spudger to disconnect the power and volume button flex cable by prying the connector straight up from its socket.
Use a pair of tweezers or your fingers to carefully fold the power and volume button flex cable to the side in order to get free access to the battery.
Use a spudger to disconnect the interconnect cable by prying the connector straight up from its socket.
Fold the interconnect flex cable towards the charging port in order to get access to the battery pull tabs.
Use a pair of blunt nose tweezers or a clean fingernail to peel the orange adhesive strip labelled with an A off the battery.
Use a pair of blunt nose tweezers or a clean fingernail to peel the orange adhesive strip labelled with a B off the battery.
Grab both pull–tab ends labelled with an A and pull up on the orange adhesive strip to lift the battery out of its recess and swing it up to an upright position.
Peel the battery off the remaining adhesive.
Remove the battery.
Me deparei que a versão do poço x3 pro indiana ultiliza bateria bn61 de 6000mha e a do poço x3 pro versão global ultiliza bateria bn57 de 5160 mha no caso eu poderia colocar a bateria b 61 com mais mha da versão indiana na do lugar da bn57 de 5160mha para fazer que meu poço versão global dure mais isso seria possível?
Use a pair of tweezers or your fingers to carefully peel the battery's adhesive sticker off the midframe.
Use a spudger to disconnect the display flex cable by prying the connector straight up from its socket.
Use a pair of tweezers or your fingers to carefully peel the display flex cable off the midframe.
Apply a heated iOpener or a heat gun to the screen to loosen the adhesive underneath. Apply the iOpener for at least two minutes.
Once the screen is warm to touch, apply a suction cup to the bottom edge of the screen.
Lift the screen with the suction handle to create a small gap between the screen and the frame.
Insert an iFlex in the gap between the midframe and the screen.
Insert an opening pick above the iFlex.
Remove the iFlex.
Slide the opening pick to the bottom right corner of the screen to slice its adhesive. Leave the opening pick in place to prevent the adhesive from resealing.
Insert a second opening pick and slide it to the bottom left corner of the screen to cut the adhesive.
Insert a third opening pick underneath the bottom left corner of the screen.
Slide the opening pick along the left edge of the screen to slice the adhesive. Leave it in the top left corner to prevent the adhesive from resealing.
Insert a fourth opening pick at the top left corner of the screen.
Slide the opening pick along the top edge of the phone to slice the adhesive.
Leave the opening pick in the top right corner of the screen to prevent the adhesive from resealing.
Insert a fifth opening pick and slide it along the right edge of the phone to slice the remaining adhesive.
Thread the display flex cable through the gap in the midframe and remove the screen.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
The best way to secure the new screen is to apply a sheet of custom-cut double-sided tape to the back of the screen.
crwdns2935229:040crwdne2935229:0
Forgot to mention the camera module and connectors
Wait... Never mind. Weird, the three little cameras were attached to the last housing in mine.
Anyone has any idea what could be the problem?
I have replaced the lcd screen and it works fine until i put motherboard cover back on.
When motherboard cover is on then it freezes or keeps restarting.
I have tried putting it on without any screws but the problem remains.
Qual a temperatura ideal que devo aplicar na tampa traseira para a remoção da cola posso aplicar 70 graus de temperatura?
dicaslegais sobre tec - crwdns2934203:0crwdne2934203:0
