Follow this guide to replace the power supply on your Sony Playstation 4.
Unplug your PS4 before beginning any repairs.
Flip the PS4 upside-down with the back side facing towards you.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use tweezers to remove the two stickers in the center of the back of the PS4 exposing two case screws.
Use tweezers to carefully remove the plastic screw covers in each corner, exposing two more case screws.
Remove the four 7.2 mm T8 Torx security screws on the back of the PS4.
Use your thumbs to lift the lower case up and off the PS4.
Use a pair of tweezers to pull the power supply cable straight out and disconnect the power supply unit from the motherboard.
Remove three 9.7 mm-long TR8 Torx security screws.
Remove two 41 mm-long Phillips screws and brackets.
Lift the power supply straight up and out of the PS4.
crwdns2935229:0223crwdne2935229:0
crwdns2947412:077crwdne2947412:0
Gonna do this tomorrow, I'm just hoping this is what's wrong with it.
A few months ago something popped in the system and I smelt a burning scent.
Diamond - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Bro,did it work for you?
I have same problem
EL cablemo - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I have same thing.
Erik Ferguson - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Just be careful when pulling up power supply on the left side facing you when Ps4 is upside-down.
jerrylaird3000 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Oui c’est exactement ça j’ai arraché un câble.
Est-ce que quand je vais commander le bloc d’alimentation j’aurais j’aurai un autre ?
Fazel Slh - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
