Plastic Snap Installation Using a Hand Press
  1. Plastic Snap Installation Using a Hand Press, Snap identification: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Plastic Snap Installation Using a Hand Press, Snap identification: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Plastic Snap Installation Using a Hand Press, Snap identification: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • A full plastic snap set is composed of three types of pieces: caps, a stud, and a socket. When the snap is in use the socket and stud lock together, while a cap holds each of them in place from the other side of the fabric.
    • There are three sizes of Patagonia plastic snaps:
    • Small 14L (0.35 inches, 8.9 mm)
    • Medium 20L (0.5 inches, 12.7 mm)
    • Large 24L (0.6 inches, 15.3 mm)
  2. Plastic Snap Installation Using a Hand Press, Die identification: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • There's a metal die for each snap piece: the cap die, the socket die, and the stud die. Dies are unique to the snap size.
    • Patagonia Repair Tech Tip: The socket and stud dies look like the opposing snap so that the plastic piece will click right in.
  3. Plastic Snap Installation Using a Hand Press, Assess the damage: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Plastic Snap Installation Using a Hand Press, Assess the damage: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the broken or missing snap.
    • Pick out the replacement snap pieces:
    • Socket side is damaged - A socket piece and a cap piece
    • Stud side is damaged - A stud piece and a cap piece
    • Both sides are damaged - A stud piece, a socket piece, and two cap pieces
    • If you're only replacing one side, check that the new piece snaps into the remaining side.
    • If the broken snap needs to be removed, see Step 4. Otherwise, proceed to Step 5.
  4. Plastic Snap Installation Using a Hand Press, Remove the broken snap: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Wear safety glasses to protect your eyes from pieces of the snap.
    • Using end nippers or flush cutters, slide one side of the nippers between the damaged snap and the fabric.
    • Carefully snip the damaged snap until the entire piece is broken off.
    • Be careful to avoid accidentally damaging the fabric.
    • Discard the broken snap responsibly.
  5. Plastic Snap Installation Using a Hand Press, Determine the placement of the new snap: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Plastic Snap Installation Using a Hand Press, Determine the placement of the new snap: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • There should be a small hole where the original snap was placed - use this as a guide for the snap replacement.
    • If the fabric around the old snap is torn or damaged beyond a small hole, apply a patch to reinforce the area before replacing the snap.
  6. Plastic Snap Installation Using a Hand Press, Prepare the snap dies: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Plastic Snap Installation Using a Hand Press, Prepare the snap dies: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Plastic Snap Installation Using a Hand Press, Prepare the snap dies: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the cap die into the lower fitting of the hand press and drop the cap piece into the die, flat side down, so the plastic post is sticking upward.
    • Click the socket or stud piece into the corresponding die.
  7. Plastic Snap Installation Using a Hand Press, Set up the hand press: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Plastic Snap Installation Using a Hand Press, Set up the hand press: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Plastic Snap Installation Using a Hand Press, Set up the hand press: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers, a screwdriver, or a hex key, as needed, to unscrew the tightening mechanism on the side of the press near the top die fitting.
    • Insert the die upward and hold it in place.
    • Tighten the tightening mechanism.
  8. Plastic Snap Installation Using a Hand Press, Install the snap: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Plastic Snap Installation Using a Hand Press, Install the snap: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Plastic Snap Installation Using a Hand Press, Install the snap: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the garment over the bottom snap die so that the hole on the fabric lines up with the plastic post of the new cap.
    • Make sure no extra fabric is caught inside the press and that the orientation of the garment is correct.
    • Hold the fabric in place with one hand, then use your other hand to pull down the handle of the press.
    • This requires a lot of pressure to make sure the snap replacement is successful - so pull hard!
  9. Plastic Snap Installation Using a Hand Press, Quality control: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Plastic Snap Installation Using a Hand Press, Quality control: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Plastic Snap Installation Using a Hand Press, Quality control: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the garment from the press and check that the new snap clicks into the opposing side.
    • A properly secured snap will flatten the cap post into the socket/stud piece. Depending on the type of snap dies used, this will produce one of two outcomes:
    • Three concentric circles visible at the center of the snap (reference image #2)
    • A mushroom dome shape at the center of the snap (reference image #3)
    • If the snap spins in place, the snap isn't secure. Repeat the previous step.
    • If you're replacing both sides of the snap, repeat these steps on the other side, ensuring all the proper dies and pieces are used.
    • Snap the two halves of the snap together to make sure they're properly aligned and functional.
Brittany McCrigler
crwdns2935283:003/05/12crwdne2935283:0
90,046 crwdns2915208:0crwdne2915208:0
crwdns2935297:0142crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,469crwdne2935297:0
crwdns2947412:05crwdne2947412:0
This is not a very helpful post as there are no sources for the tools needed and Patagonia support had no idea what I was talking about. They may not even have the replacement snap. Any further information would be gratefully appreciated.
Lorenzo Savona - crwdns2934203:0crwdne2934203:0
Patagonia sent me some snaps to replace one that popped off a jacket. I do not have access to a hand press. any workarounds or suggestions would be helpful.
Matthew Steliga - crwdns2934203:0crwdne2934203:0
Agree with the previous comments. A workaround for those without the exact sockets and the hand press would be appreciated…
Melissa Bryant - crwdns2934203:0crwdne2934203:0
Joann’s and Michaels sell hand held snap tools and replacement snaps. Any snap can be used for a replacement snap, doesn’t have to be Patagonia specific, hope this helps!
rblgrlmle - crwdns2934203:0crwdne2934203:0
Sort of misleading fix. You can get the replacement snaps from Patagonia and the hand press from Amazon but where do you get those very specific upper and lower sockets for the hand press that are shown? They certainly do not come with the hand press….
Craig Dodson - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 23
crwdns2936753:030crwdne2936753:0 126
crwdns2942667:0crwdne2942667:0 15,122
