PS4 Optical Drive Removal
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. PS4 Optical Drive Removal, Flip over the PS4: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the PS4 upside-down with the back side facing towards you.
  2. PS4 Optical Drive Removal, Remove the warranty stickers: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PS4 Optical Drive Removal, Remove the warranty stickers: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PS4 Optical Drive Removal, Remove the warranty stickers: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use tweezers to remove the two stickers in the center of the back of the PS4 exposing two case screws.
  3. PS4 Optical Drive Removal, Remove the plastic screw covers: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PS4 Optical Drive Removal, Remove the plastic screw covers: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to carefully remove the plastic screw covers in each corner, exposing two more case screws.
  4. PS4 Optical Drive Removal, Remove the rear case screws: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PS4 Optical Drive Removal, Remove the rear case screws: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 7.2 mm Torx security screws on the back of the PS4.
  5. PS4 Optical Drive Removal, Remove the lower case: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PS4 Optical Drive Removal, Remove the lower case: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your thumbs to lift the lower case up and off the PS4.
    • The lower case is held into place by plastic clips. You may need to use significant force to release the lower case.
  6. PS4 Optical Drive Removal: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PS4 Optical Drive Removal: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to pull the power supply cable straight out and disconnect the power supply unit from the motherboard.
    • If your connector feels stuck, use a spudger to gently pry the connector out.
  7. PS4 Optical Drive Removal, Remove the Wi-Fi antenna: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PS4 Optical Drive Removal, Remove the Wi-Fi antenna: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tip of a spudger to disconnect the antenna cable from the motherboard.
  8. PS4 Optical Drive Removal: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PS4 Optical Drive Removal: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PS4 Optical Drive Removal: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of tweezers or your fingers to grab the antenna cable and move it out from the cable guides.
  9. PS4 Optical Drive Removal: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PS4 Optical Drive Removal: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PS4 Optical Drive Removal: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pair of tweezers or your fingers to thread the antenna cable out from underneath the optical drive cable.
  10. PS4 Optical Drive Removal: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PS4 Optical Drive Removal: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the 9.7 mm Torx security screw securing the antenna.
  11. PS4 Optical Drive Removal: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PS4 Optical Drive Removal: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the Wi-Fi antenna.
  12. PS4 Optical Drive Removal, Disconnect the optical drive: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PS4 Optical Drive Removal, Disconnect the optical drive: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PS4 Optical Drive Removal, Disconnect the optical drive: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingernail to press down on the metal release lever of the ribbon cable on top of the optical drive.
    • Use your fingers or a pair of tweezers to disconnect the ribbon cable by pulling on the black tab.
    • You do not need to press the metal lever when inserting the ribbon cable back in. You will hear a click once it is fully inserted.
  13. PS4 Optical Drive Removal: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PS4 Optical Drive Removal: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PS4 Optical Drive Removal: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingernail to press down the metal release lever for the ribbon cable connected to the motherboard.
    • Set the ribbon cable aside for reassembly.
  14. PS4 Optical Drive Removal: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PS4 Optical Drive Removal: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers or a pair of tweezers to disconnect the optical drive cable from the motherboard.
  15. PS4 Optical Drive Removal: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 PS4 Optical Drive Removal: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 PS4 Optical Drive Removal: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your fingers or a pair of tweezers to remove the optical drive cable from the cable guides that hold it in place.
  16. PS4 Optical Drive Removal, Remove the optical drive: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PS4 Optical Drive Removal, Remove the optical drive: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four screws securing the optical drive.
    • Three 9.7 mm Torx screws
    • One 6.2 mm Phillips screw
  17. PS4 Optical Drive Removal: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PS4 Optical Drive Removal: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the optical drive straight up and out of the PS4.
Sam Omiotek
crwdns2935283:002/25/19crwdne2935283:0
88.016 crwdns2915208:0crwdne2915208:0
crwdns2935297:0290crwdne2935297:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 202
