PDP Victrix Pro BFG Battery and Trigger Replacement
  1. PDP Victrix Pro BFG Battery and Trigger Replacement, Battery and Trigger: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the purple Module Swap Tool that comes with the device to remove the 4 hex screws.
    • Remove the joystick/button modules from the controller.
  2. PDP Victrix Pro BFG Battery and Trigger Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws from each of the module compartments using a PH0 or J1 bit.
  3. PDP Victrix Pro BFG Battery and Trigger Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 PDP Victrix Pro BFG Battery and Trigger Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the iFixit opening tool, gently pry open the two side grips.
    • Using a PH0 or J1 screwdriver bit with a 4mm diameter or less, remove the screws located in the bottom outside corners.
    This is almost impossible to do with the prybar tool. I had to use a size 1 Slot bit from the screwdriver kit instead.
    Vivianelle Mira - crwdns2934203:0crwdne2934203:0
  4. PDP Victrix Pro BFG Battery and Trigger Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the controller to the other side so the label on the bottom is facing upwards.
    • On the label, there is a circular icon; this shows the location of a single screw.
    • Using the same PH0 or J1 screwdriver bit from the previous steps, remove the screw.
  5. PDP Victrix Pro BFG Battery and Trigger Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the controller so the charging port of the controller is facing you.
    • Using a spudger, carefully pry open the front component.
    This step is not necessary, and I can't seem to find a way to complete it without damaging the plate in question. Best to leave it alone unless you need to access the trackpad or Option/Share and Function buttons.
  6. PDP Victrix Pro BFG Battery and Trigger Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the controller so it is upside-down, but the charging port is still facing you.
    • In the center of the now exposed part, there will be a hidden silver screw.
    • Use the flexible piece attached to the screwdriver to remove this screw.
    • Now that everything is loosened, gently pry open the controller along the grooves.
  7. PDP Victrix Pro BFG Battery and Trigger Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the screwdriver tool with a smaller head, remove the three screws from each trigger.
    • Remove the triggers.
  8. PDP Victrix Pro BFG Battery and Trigger Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the screwdriver, remove the two screws in the bottom two corners.
    • Using the halberd spudger, carefully pry the circuit board open.
  9. PDP Victrix Pro BFG Battery and Trigger Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To remove the batteries, use a pair of tweezers to carefully unplug the batteries from the circuit board.
    how to reassemble in step 5pleeasee
    abdulrahman alghamdi - crwdns2934203:0crwdne2934203:0
ryanmorabito
crwdns2935283:003/20/24crwdne2935283:0
239 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 1-1, Santin Spring 2024 crwdns2935289:0UMass Dartmouth, Team 1-1, Santin Spring 2024crwdne2935289:0
UMASSD-SANTIN-S24S1G1
Only guide I could find to get this controller apart for my son. Now have to find someone to resolder the USB c port.
Matthew Lash - crwdns2934203:0crwdne2934203:0
R2 and L2 no response, the board location for button?
Terry - crwdns2934203:0crwdne2934203:0
if my remote doesn’t turn on or charge should I change the battery or just throw it away?
Nerdy mom - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 11
crwdns2936753:07crwdne2936753:0 66
crwdns2936753:030crwdne2936753:0 299
crwdns2942667:0crwdne2942667:0 3,359
