Nintendo Wii Remote Main Buttons Replacement
crwdns2942287:0crwdne2942287:0Removing the main buttons requires opening the device. The main buttons include all buttons except the trigger style B button.
crwdns2944105:0crwdne2944105:0
Flip the Wii Remote over so the battery cover faces you.
Push up on the bottom tab.
Remove the battery cover.
Remove the first battery by pressing down on the positive end and pulling the battery out.
Remove the second battery by pushing up on the positive end and pulling the battery out.
Using a tri-point Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
Repeat with the two bottom screws.
With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
Open the front plate like a book.
Mine is not opening like a book? What do I do?
It stops short of explaining replacing rechargeable battery. Unless you’re referring to the AA’s which don’t involve removing cover
Working on the inside of the front cover, peel off the three rubber pads covering the buttons.
Flip over the cover, allowing the buttons to fall into your hand.
crwdns2935229:026crwdne2935229:0
crwdns2947412:05crwdne2947412:0
Where did you get your replacement buttons? I can't find them online anywhere...
Me too, can’t find them.
2024 and can't find them online ANYWHERE! I'm hoping a WiiUDpad fits on the wiimote. You'd think there'd be a bunch of wiimote shells of different colours available everywhere online, but they're nowhere to be found
how frustrating!
Vinted is full of them. Although some people ask wayyy too much for them!
Yo tampoco los encuentro por ninguna parte
my battery cover is different. The batteries are attached to the actual cover and come out when the back is removed.
Kim Pearson - crwdns2934203:0crwdne2934203:0
